- Spark plug and wire life?
- What do you get when you add an LME C5R 427 + 2 @ GT35R's (15 PSI) + Pump Gas...
- A few boost related parts for sale in the parts section
- need help guys!!!!! what your oil and coolant temps?
- Sudbury C5's 402-F1C is ready to launch!
- 346/D-1SC at 16 psi/740 rwhp now getting LS2/402 and F-1C
- how bad is this cam for fi?
- Strange deposits on only one plug?
- kenny bell times
- Thanks Canadian Performance TTIX 9.9's 151
- how to install a bottle pressure gauge?
- Forced Induction Maggie vs. Paxton
- Fuel gauge install, NEED HELP !!!! ASAP
- Hobbs switches
- ECS Methanol kit will provide fuel for how much horsepower
- Opinions also Vendors LOOOK!
- Turbo oil drain in pan location?
- Kenne Bell owners inside
- Man....I don't know how you guys do it!
- STS down in power
- 03 procharged zo6
- Novi 2000 Methanol Setup - ECS
- TT FRC almost ready for dyno time. PICS
- Turbos and Engine Oil
- FI experts. Please help with heat issues!
- Kene Bell 2.8 Dyno numbers and race videos
- Worlds Fastest C5 Corvette???
- My official intro...
- Pfadt Tranny Brace
- new guy here and need help with procharger pcv setup!
- new member of the club!
- Rebuilt the fuel system, is MPG display accurate?
- KB Install....
- Need help installing NX direct port
- some food for though on turbo oiling
- So I finally got my car back from being forged and i'm stoked!
- Vortech Install
- my c5 project
- I do not like my B&B Bullets with the supercharger
- MTI Racing's(Marietta,Ga.) Annual Dyno Day and Open House on Saturday, August 16th
- A&A supercharger package installed and tuned
- What size belt?
- [PICS]Check out the New A&A Intercooler, and Install![PICS]
- faster reacting iat sensor
- How to measure boost
- IAT's ?
- Loud rattle from my Maggie please advise
- Need help with procharger
- How much boost on pump gas plus meth?
- Anyone Using "P" Gauge
- IAT Sensor Part Number
- Corvette ONLY autox @ Raceway Park Road Course!
- Any issues with the Vortech?
- Some new stuff and mystery shop
- HP tuners question
- boWhere can you put bottle and keep top storage?
- Would you think STS and TTi stage 1 got close base tune?
- Highest pump gas TT numbers?
- ECS NOVI 2000 Belt Slip
- advice on which to choose... kb or v3
- what vendor can make me this part?
- torque converter
- Need a crank pinning kit
- Exhaust Question
- A4 & 150 shot nitrous
- ECS Paxton 8-rib pulley alignment
- Which S/C kit for a daily driver?
- Blower cam tuned and new dyno numbers....
- Race gas Vs Pump Gas
- Best spark plugs ? for NOS?(ACD...- NGK)
- Please take a look at my tune for TTi stage 1
- Finally, on the Dyno!
- SC and Aluminum Flywheel
- Bill Mitchel engines anyone?
- My alcohol injection system leave me stranded
- Road Racing
- having noise issues with textrailia oz 700
- TTi stage 1 issue question
- The FI dilemma
- fuel for 1000rwhp?
- CDNPERF 402 MAKES 894 RWHP WITH A YSi ON 91 OCTANE!!!!!
- Racetronic pump went out- Time for a new fuel system
- how bad will my cam hurt me
- First run after ProCharger install!!
- Patrick G custom blower cam
- Methanol Kit
- I just joined the FI family, Check out my new toy!
- Fast 90 is it for me?
- New Modular Photo Shoot, with a new Wheel Combo!
- AFR 205's or 225's???
- Anyone use the Nitrous Outlet Dual stage window switch?
- Blow thru vs. draw thru
- Boost-a-pumps Where do you have them mounted?
- blower vs 6rib question
- 700whp + Road Racing = VERY FUN!
- Lets talk Balancers
- want a LM2
- Sts twin turbo z06 at the dyno
- Put Loctite on crank bolt threads?
- Autometer Wideband Setup
- This should do the trick
- car
- Quick sale, today only, only 2 in stock, billet left side shaft
- Innovate XD-16 and LC-1 owners, how are your gauge reading behaving?
- The Weakest Link?
- Kenne Bell PCV
- Throttle body motor hitting supercharger bracket
- Let's here your pulley combo !!!!
- A&A supercharger kit ???
- Please help Diamond pistons
- Fuel pump Woes continue
- Some fun from a roll
- Some pics of the project
- Whatever happened to FunCool?
- Kenne Belle 2.6 78MM or 90 MM TB
- top tt c5 in canada 7.2 @ 205 mph
- Magnusion SC vs Procharger / Votech
- LS1 vs LS6 throttle body for Magnusson Supercharger
- transporting methanol
- Supercharge C5Z or C6 coupe?
- **Help** Guys who put a LS2 Oil Pan on a LS1
- [VIDEO]Blower cam in and first startup
- ECS meth question
- Can I replace the burst disk on a full NOS bottle
- A&A Fuel System Install
- AEM, AIS, Alkycontrol, CoolingMist, Devil's Own, SMC, Snow: meth plethora!
- Kenny Bell 2.8 install
- Bolting up random turbos
- Squires STS TT hot coolant - any tips?
- How little fuel is not enough?
- Procharger PCV - properly setup??
- My ECS Tune Thread
- Return line for late 03 fuel system.
- P0343 Code and Cam Bolts NOT loose
- Anyone here "tight" with anyone over at Mcleod Industries?
- APS TT Oil ?
- when to upgrade valve springs?
- Air/Fuel Ratio
- a bit of smoke from breather
- Power increase for custom turbo cam over Z06 cam?
- Overboosted Z06: Part II "Black Box of Death"
- Procharger Manual Idler
- How much faster will I be?
- How much boost question? And what bracket is this?
- Questions about IATs and timing retard
- who uses a launch controller?
- Dual Pirahna Wet nozzle in Blackwing idea?
- sts interferes with rear sway upgrade
- Magna Charged Z06 - Keeps going through Aft Knock Sensors...Why?
- FI Vs LSX 1/4 Mile Performance
- Help Help Help
- twin turbos
- Finally got the new 3.6 pulley on
- Question about kenne bell
- Nitrous Backfire
- Are the Callaway tb's worth it on a stock LS6 man.??
- Kenne Bell Folks - Intercooler?
- Nitrous system Help!
- whats next???
- Where do you guys mount your alkly pumps?
- Some bad Z's with Modular Concept Wheels [PICS]
- Procharger pulley size help
- Just ordered the new A&A Intercooler! Question?
- sts tuning question
- Nitrous Express Wet kit - Timing retard?
- any one have a 402 dyno graph for an STS
- Dart with LS1
- Which supercharger?
- ~~~ St Jude Auction #48 Pfadt Coilovers C5/C6~~~~
- Which cam is right for me?
- Horsepower ideas?
- FS: A&A D1sc Procharger Kit/ extra big intercooler
- How much exhaust back pressure do you have?
- NOS Related: Where are you guys mounting holes for your blow down tube
- 740whp + autox = FUN!
- 06 Z06 Fuel Pump On Late 03 Coupe
- AFR 225 HEAD port / no port
- Turbosmart E-boost 2 experts come in
- Help me complete my TNT F2 kit!
- DIY Heat Extractor Hood!! {Pics & Video}
- Will Dewitt or LG rad fit layed down?
- Input on nitrous for new engine
- can a procharger on a c5 also work on a c6
- Quick newbee question regarding Torco
- Gearing question
- Thanks Vette Doctors! 1st time out, 173MPH and a trip to Finals!!! [VIDEO]
- Procharger question
- Help withp1sc pulley selection
- How many 9 sec passes can be done on a built 4l60e ?
- belt keeps slipping off
- Better tensioner?
- Driveline reliability at high power levels
- Kenny Bell 2.8
- Where to route a Wideband sensor cable?
- DOUG@ECS sent you a PM
- What kind of power #'s are you guys making on a stock motor with aps twin turbo kit?
- hey guys need advice
- Where to mount SBC i-Color Boost Controller
- Why does the C6 tenisoner not line up on my C5Z?
- Who's running the A&A YSi??
- 3 pillar gauge pod for 2003 Z06
- Transporting methanol
- LS9 Build Video
- Can I/C piping leak raise IATs?
- Pulley question (Key way)
- LS12NV's preliminary dyno results 690+@5400-we need more fuel!!!!!
- Ontariovette's 427 F1R build up: VIDEO!!!!!!!
- WTB: APS twin turbo kit complete
- Ported LS1 or 317 heads.Anyone have any flow #ers?
- Boosted Stroker Motor
- Got Lips. Try 5.5 inch lips
- procharger noise
- Bought Maggie!! Pulley Suggestions?
- TT and supercharger installations
- Hard to change roll bars with a Procharger on?
- boost controller
- How difficult is a Dry Nitrous setup (to install/use)
- Innovate LC-1 and XD-16 owners, need wiring suggestions
- where to get the oil from for the turbo
- Where should I mount my window switch.
- RPM Trans. Swap: Manual to Auto Conversion
- dont feel no boost on with twins
- Funny smell on Startup
- A&A Tensioner question
- Can my cam work with a Pro Charger? 233/239
- Need Help With Fuel
- Upgraded APS kit?
- New Hardcore Parts are Ready!!!!!!!
- Upgrades 98 C5 coupe
- Any Kenne Bell guys running a SD tune?
- KB BAP and 60# Squirters....How Far
- Synergy motorsports Supercharger Sale...
- where can i buy differential springs
- Is 61.4 psi fuel pressure at idle normal?
- Left speechless by my wife
- Does 61.4 psi sound normal for fuel pressure?
- Too much fuel pressure
- T-Trim how many running a 6 rib 10-12 lbs
- replacing inner fender liners
- Twin Turbo LSX 427ci
- How much is max boost on a Novi 2000
- TTi stage X: any picture of AC lines routing?
- Wet Vs. Dry Nitrous?
- T trim stock bottom 1/4 times on street tires
- ECs paxton?
- ZO-6 "Supercharged" emblems
- What converter for mid 9 guys?
- Help did I just put my Procharger filter in backwards?
- Which Air Intake for Vortech SC?
- Cam ideas...
