- Why is torque so low in some cars?
- ***God Bless GM!***
- ProCharger is giving away $5,000 CASH
- New Dyno numbers
- I need to understand METH injection
- Pulley alignment tutorial
- what size shot?
- Kenne Bell and Vararam?
- *** Attention Moderators ***
- 99 Magna Charger S/C vette
- American_HP
- Need an 8 rib balancer, options?
- thanks to Steve A&A
- Another how much boost question
- Is this belt slip? Dyno graph inside
- Tim Buse
- Tuning question for wet plate kit...
- Superchargering my 99 vette, Should I replace my rod bolts???
- Need advise
- Add heads and cam or not?
- STS Twin Turbo
- My future setup. You might like it
- Mileage and FI
- Headers ??? Coated or Uncoated that is the ??
- V-1 A&A S/C - Adding Cam, have questions.
- FYI, I changing setups.......Check it out!
- Which Cats can handle 720RWHP??
- Need help with K/B measurements
- ECS Blower Cam in 98 NA Setup Results!
- Any Damaged Halltech Stinger Hoods???
- How much loading on the ECS tensioner?
- Nitrous Outler Plate
- Gauge Pod For steering colum
- wow!!! ECS Hands Down (NOVI 2000)
- Sold my PTK twin turbo vette today.
- PC Entry lvl Turbo Kit
- supercharger guys need help please
- K&N Filter with no oil on it?
- Wideband/Boost combo gauge?
- Sneak Peak at TPE's Project Car Twin Screw Blower!!
- Timing controller question??
- Vortech impeller play how much?
- how to identify my procharger headunit, p1 or d1?
- 1st run blown, 2nd time at track, results:
- HELP! Need alternator pulley retaining nut size
- Anyone running a single muffler with 1 turbo?
- Anybody Done a DIY Dual Walbro Setup?
- K/B S/C and bigger MAF???
- (NEW Product) TPE's 6 & 8 Rib Pulley system!!
- TPE's NEW!! Extreme Duty Kenne Bell S/C Bracket {PICS}
- How much boost?
- Procharger P1-SC Stage II
- TTI turbo - Which Cam/heads?
- All C5 FI Owners...don't worry too much about ZR1
- Catch Can is catching a lot of oil.....?
- 1 Set of our 6 rib Procharger bracket left-$450
- APS System OIL LEAK in Exhaust. HELP!
- Any tips for installing shorter belt?
- Stock bottom end, PTK, AFR 205's...results.
- What kind of increase from P1 to D1?
- I just want to say thanks to >>>>
- ECS Novi, what size is the oil return line?
- Forged D1 with meth. should i add some torco and tune it?
- Gates 91006 Laser alignment tool information
- C5 Z06 stock bottom ends?? with SC's...
- ECS Meth Kit
- What needs to get 600-650 rwhp ?
- tuner
- Wide fuel pressure range
- quick video of the 761 pull
- Extended coolant lines?
- Best forged 402 for boost and for the money
- Anyone here with 550+Rwhp with 20" wheels?
- Where is Brian at ICS?
- G5XB, anyone running it or know specs?
- FI and long road trip reliability
- Procharger oil
- Supercharger & heads ??
- Need advice on my build
- need help with direction of rotation
- Limitations of 8 rib belts. Shredded mine.
- Experience of Direct Port nitrous system from NITROUS DIRECT?
- How come we don't have C5 FI "gathering"?
- Purge Video
- Limit of Darton sleeved LS2 427?
- 402 LS2(GT5533R)honestly,how much power can it make?
- What is the max you can boost on a stock motor
- Ok, I almost have this sts kit down, need help on one more problem!
- Last Kenne Bell Sale of the Year **Limited Quantities**
- Aps tt 403 dyno results
- ECS meth controller mounting options?
- dyno results
- Newest Hot Rod Problem tensioner moving belt getting loose???
- PTK Twin Turbo Kit - 75% complete - BRAND NEW!
- ***ECS 427 TTiX Dyno's 800 RWHP at 12 Lbs.. ***
- Will a C6 rad fit into a C5?
- Pump gas tune Vs. Race gas tune
- Not C5, But LS1 and 8,53 and 160 mph turbo!!
- C5 APS Twin Turbo installated package
- 60 Lb. Injectors Motron
- Where to find meth?
- gt2876
- complete nitrous kit
- which forum sponser wants to sell me a blower?
- 42lb injectors out of a ford
- Moving radiator for Procharger?
- ECS restrictor plate
- bad octane gas and how often you have got some out of the pump
- about to buy a procharged vette, what to look for? Please Help!!!
- Stock C5 with A&A supercharger what do you think
- Just ordered my first Mod A&A supercharge
- Researching going FI
- FMIC size on C5?
- Thinking about putting the outside air sensor in the air tube to the TB
- Need belt part number
- Anyone with a fluidamper pinning kit?
- How much was your custome roll cage?
- How much boost can my motor take?
- Stock bottom end guys
- #2 RPM Transmissions Track Rental / Dyno Day - Oct. 3
- Guess how much HP
- Procharger questions
- Meth line routing from trunk?
- Who has the Best Price on ProCharger Kits?
- Supercharger = louder exhaust?
- NEW RAM AIR INTERCOOLERS will be IN ALL OUR KITS!
- When does an L76 intake run out of breath on a 408ci w/L92 heads???
- fmic
- Procharger Bracket
- TPE's NEW 6 & 8 Rib Heavy Duty Tensioner Assembly!!
- Why supercharger noise comes and goes..
- Not Bad, 300 RWHP From a Tune............
- Took restrictor plate out to see what the difference would be in boost/power
- Those that have done their own laser pulley alignment, how difficult was it?
- Meth Wiring Diagram
- Already have a K.B. 2.6L and I need more!
- UD pulley on a KB Supercharger
- I have hose from oil cap to air filter and am worried bout oil mist into blower
- Here's a special for you guys with Alky Control kits
- Are these numbers right?
- **AFR 205 and 225 cylinder heads in stock!**
- 85mm vs. larger MAF for LS6 maggie with LS2 snout
- **LG Motorsports BIG 3 Specials**
- Good source for turbo/sc hose couplers?
- "Visual" comparison of 6 rib verus 8,10 and 12
- Possible meth issues in the future?
- HP Gains With 90mmTB on Maggie
- Good info for diagnosing belt problems
- stock or modded ti's
- 6 spd to auto
- Auto meter Cobalt wideband??? Any good or pos
- duel intank walbro install?
- fuel pressure question
- Vaccum???????
- problem
- Need advice on a part
- 0-5V throttle positon source?
- PLZ HELP ASAP. 2002 w/vortech, alternator not clearing head
- LS3 Engine MODS......Advice
- What should i dyno? P1sc, headers, bullets
- Project advice please
- Advice needed for next step on my TT C5
- EPP blower cam video, or something similar
- Fuel system question
- ECS Superchargers @ Straightline
- New Motor Advice for my APS TT Setup
- best way to check belt tension?
- It's alive!!!!!!
- P1sc or D1Sc newbie question....
- RWHP with boost a pump/racetronix/60lb injectors?
- Thinking about buying a C5 with a Procharger Supercharger
- Lingenfelter TT650 Owners Come in Please
- Calling all St. Louis vette owners
- My P1SC kit is for sale (Ouch!)
- non-intercooled turbo kit
- Is two in tank Walbro 340's enough for 1000fwhp?
- • • • Announcement RPM Motors Expansion • • •
- 408 iron block afr 225, ls7 mls gaskets and 15psi?
- lingenfelter gt7 and 1.8 rockers?
- WOT miss carnage pics
- ECS Alky control Instructions
- My new numbers
- NEW Abear 2 piece "Superchargerd" valve covers
- Hypothetical turbo engine questions.........
- P-1SC question/Help
- ProCharger D-1SC used head unit for sale at EPP
- nitrous help
- Wideband woes...
- Affect of cold ambient temps on dyno tuning?
- looking for cajundude alkypump link
- NA cam w/ blower
- Lean codes with PCV and breather oil cap?
- Maggie... on stock manifolds?
- This looks like a lot of lag- am I reading this right?
- belts for A&A
- Big stick goes boom!!!!!
- Fuel pressure drops even with upgrades
- Fidanza or Spec Twin???
- I have 2004 Z06, what size injectors?
- O2 sensor question
- Just bought a NOS dry kit
- **** CARTEK 346 Procharged goes 9.49 ****
- New PCV/vent layout, opinions please!
- Ecs sc600 setup
- Standing Mile Race
- Who has best prices on PRC vale springs?
- FYI My Car Is Up For Sale
- busted belts
- engine build questions
- Thanks RPM.. You did it again!!
- Need a little more octane...need users input on Torco vs racing gas mix
- Potential MAF problems from venting crankcase gases to SC filter?
- Ordered a new part tonight
- Twin Water Cooled Turbos and Electric water pump
- Forged 347 + supercharger owners.
- Looking to rebuild my engine. Couple ?'s for you guys
- FS: Lingenfelter LNC-001 Launch Controller
- R.I.P. My Motor
- some cool pics
- 1005hp on Corn
- ECS fuel system help
- What water pump to buy?
- Is 62cc comb chamber too high for 150shot
- Ram air license plate
- AEM UEGO Wideband
- Old style procharger
- power loss swapping catbacks?
- Sneak Pic of What Makes My Car Tick
- Procharger part # dipstick stg2
- Wow what a vendor
- ECS Fuel System and Fuel is BOILING !?!?!?
- question about ccw drag pack?
- LSX Shootout, Memphis, Oct 9-12, 2008
- Broken alternator / power steering bracket
- 232/240 on 115 with blower?
- upgrade intercooler? a&a old style vs new style!
- need help with A&A Kit
- what will i run? 603hp/564tq, 4lbs of Boost
- 28" slick reducing my gear ratio???
- pillar pod for 3 gauges
- Summits 8 rib Balancer (Pics)
- Finally got a chance to work on my car! Pics inside!
- Rpm rocks! Thank you
- a few questions about a maggie s/c car
- Removing restrictor from ECS kit
- MAF Elimination, need piping please
- MTI now doing TVS for Corvettes.
- Blown Ls7
- Procharger Stage II owners, where did you put your catch can?
- Meth heads, chemical experts, step in...
