View Full Version : C5 Forced Induction/Nitrous
  1. Vendor fogred shortblocks for sale built for customers specs
  2. Wide Band vs. Narrow Band and Gauge Opinions
  3. STS Install..How did you mod your antennae?
  4. another question from the new guy...
  5. WTB: 72-75 lb Fuel Injectors from my FI Fella's
  6. MADMATT's Dyno Day Limited to 692 RWHP and 573 RWTQ (Dyno Sheet Inside w/B@@ST #)
  7. Procharger Race Valve Mounting
  8. Too much crank case pressure! AAWWW
  9. 4.10" pulley to 3.90" RR for P1SC
  10. WTB: F1C Procharger
  11. Question ?? Lingenfelter supercharger FRC's?
  12. Looking to buy a APS or TTI C5 Z06
  13. How long does it take to install a TTI X kit?
  14. D-1 Procharger catch can relocation
  15. valve train noise / pics
  16. Selling my ECS Paxton Novi 2000 Kit
  17. 408 with ECS Novi 2000 build
  18. 900rwhp = what fuel system???
  19. Great guy after the sell jeff @ TPE
  20. EFILive V1 vs V2?
  21. New oil cooler install
  22. Methonal and the windshield fluid sensor
  23. 100mm MAF..anyone using one and how is it?
  24. So here is the story.... Idle issue
  25. FLIP-DRIVE Belt Wrap Vs. Long SuperCharger W/Accessory Belt Wrap Around Crank
  26. New Textralia Triple disc clutch is in.
  27. Why don't we put the MAF infront of the blower on a FI car?
  28. 8-Rib "Generator" Pulley
  29. Belt for A&A P1SC-1 kit on 2003 Z06
  30. coil question
  31. tr6 plug question
  32. leakdown question
  33. Big Thanks to Nick Yoskin and Chris Forest
  34. Self contained for me?
  35. nitrous guys would this b sum kind of mph record?
  36. Its clutch time....advice, comments, pro's and con's of all options out there
  37. A&A Blower Cams?
  38. gauge install help
  39. Halltech Ram Air Tunnel Ports Now in Fiberglass Gel Coat
  40. 04 fuel system questions...
  41. Compatibility of my H/C setup with FI?
  42. STS TT 01 ZO6 Shooting Oil from the Exhaust!!! Need HELP fast
  43. Did your head unit make a differnt sound after a while?
  44. What kind Of Methanol Are You Using????
  45. NA Stroker or Forged 346 for blower?
  46. Cammed LS6 w/ Maggie & 2.6 pulley
  47. Scared the BAGEEEEBAH's Out of Myself this Morning!Will need TOYO R888's(A good read)
  48. nitrous jet size questions
  49. Nitrous - Most Critical Gauge Readings and why?
  50. Radiator "SHROUD" Done from Laydown Project - Write-up W/Pics (Madmatt's)
  51. Boost Caculator
  52. Tuner
  53. MTI Racing's LS1/LS6 TVS system now available!
  54. Who's boosted but doesn't use gauges...?
  55. F1C stock shortblock results
  56. Made VERY difficult decision, decided to sell my Blown Z06 & keep 71 Prostreet Camaro
  57. Recipe for 9's in the 1/4?
  58. zex direct port sys. more shot
  59. Re tune
  60. APRIL FOOLS SALE! A&A Systems for $4500!!
  61. Bellhousings
  62. clamps
  63. Maggie Question
  64. What's included in the A&A Supercharger kit and how is it different?
  65. How much does the 8rib conversion run?$?$?
  66. IAT Temps With Meth?
  67. Novi 2000 under 400hp and ecs sc600 mail order tune
  68. Radiator layback/relocation for SC
  69. Fuel pump & regulater advice
  70. For sale Universal ATI Race Blow Off Valve cheap
  71. Turbo Leaking Oil Question
  72. TOTAL DESTRUCTION... Lots o Pics
  73. A&A VS ECS Procharger bracket
  74. Nitrous Spark plug ???
  75. how much power does it take to run 10's and 9's with and A4
  76. pcv valve for fi ls1
  77. Which p/s pulley tool works best???
  78. Anybody familiar with this car?
  79. ECS SC600 Hood Clearance
  80. When do you need to upgrade stock fuel rails?
  81. Late build 03 with FFS fuel system. Possible to drop tank without driveline removal??
  82. any vendors sell ashtray gauge pod
  83. How to stop a leak
  84. what do I need to get 650 to 700 rwhp
  85. Kenne bell ((big bore))
  86. (Finally Madmatt's)Radiator Lay-Down & Over the Top w/4"=2+ More PSI B@@ST(W/Pics)
  87. Installing comp 921 springs
  88. How to increase horsepower...
  89. ECS brother's please getting asap
  90. New Pics for my FI Boys :)
  91. Check my new intake...Edelbrock L92 and Elbow
  92. need help!! Putting the belt
  93. I am bummed, new build, dyno + blow-by
  94. whats the biggest cam for 370cid ?
  95. Halltech Ram Air Tunnel Port now available in Fiberglass and CF
  96. Group buy interest in Crane valve spring compressor tool?
  97. STS haters heres your chance to let loose
  98. mini-tubs vs fender-flares
  99. BAP mounted in the rear near the pump
  100. •• Purchase HP Tuners Pro and get an Innovate LC1 for $139 or NGK AFX for $239!!! ••
  101. The Grond Chronicles : The Final Chapter
  102. need a tuner in north west indiana
  103. )) NEW C5 Clutch Bleeder Kits $59.95 ((
  104. Best plug wires
  105. TTIX kit in forsale section
  106. trade 8 rib 3:70 for 4:00
  107. Fuel feed size
  108. Methanol Tanks
  109. looking for fitting
  110. Kooks 2" Primary headers...they acutally fit
  111. Vette FI related, but funny video!!
  112. STS Turbo exhaust
  113. FIRST D-Type Steering Wheel installed *PIC*
  114. who is the most recomended tuner on the east coast for FI application.
  115. Upgraded fuel system and meth necessary??
  116. How does this sound....
  117. Finally dyno'ed my new ECS S/C
  118. Oooh so close - just one more tenth!!!
  119. Propane
  120. Car made 562 wrhp and 480 tq
  121. Introducing our Carbon Fiber Driveshafts
  122. Flip Drive Dyno results
  123. ProCharger
  124. Quick vid of the 408 maggie
  125. Any Turbo Vendors Here?
  126. Write Up Alert: FLIP-DRIVE Install Complete W/Pictures
  127. Blower cam selection
  128. FYI 45 Day Guideline
  129. how much power should i be looking with my novi2000?
  130. The Assembly Is Complete....
  131. max hp limit on stock block
  132. digital boost gauge sensor location question??
  133. THANKS Cartek..New PB 6 Speed Rear Mount Turbo
  134. New Vendor Location
  135. my new epp blower cam and kooks installed
  136. anyone with AIS injection
  137. broken valve spring (CARTEK w/ DUAL SPRINGS)
  138. Novi 2000
  139. how much power should i be looking fwd to
  140. WTB:Installing FlipDrive & Need to Get C5 Alternator W/Short Snout (Pic inside)
  141. HP Estimate Based Off Logging
  142. PCV Routing Help
  143. Need APS Inlet.
  144. reason # 986754 why ECS and Crew
  145. Single Turbo possible?
  146. My methanol in windshield fluid reservoir is leaking what's common cause?
  147. Any Interest in an Alky Panel Group Buy?
  148. I'm looking forward to joining the SC gang
  149. reports on ecs 600
  150. Boost a pump query for Kenne Bell
  151. Big Cubes & Spray VS. Stock Cubes & Blower
  152. getting procharged
  153. Big cube LSx based stroker motor
  154. MAF blew apart..
  155. I need Fuel System help for the average vette Guy..
  156. Stoker Engine and Forced Induction Issue
  157. where can i find the custom screened front licence plate cover.
  158. replaced cam and need some help keeping the car running.
  159. MSD Pump Booster work on a 04 ?
  160. New here...97-98 supercharged??? Advice????
  161. scavage pump
  162. Write-Up ALERT: RACETRONIX Fuel Pump Harness Install W/Pics
  163. Questions about a Wet Nitrous System
  164. converted from 6spd to stalled A4
  165. Trading TTi stage 1 for Maggie?
  166. HyperBoost Diverter Valve
  167. Whats the best oil and wt to run??
  168. kenne bell guys
  169. Electric fan(s) on the back of intercooler?
  170. lq9 heads / ls6 block - what headgasket?
  171. Boost gauge
  172. Fuel Pump Operation
  173. Initial impressions on Toyo R888s for my 700rwhp Procharged Z!
  174. JP double roller install
  175. New Comp LSR grind..check my specs
  176. Those Over 700 RWHP How Often Do You Change Your Blower Belt
  177. BOSCH044 in-tank 03-up pics inside...any suggestions?
  178. $$ NEW FAST 92mm Intake Manifold $799 $$
  179. Anyone drilled and tapped intake right behind TB for IAT sensor?
  180. cost of changing valve springs?
  181. what tune do i need?
  182. What size primaries?
  183. STS Questions..
  184. quality shop
  185. FS Fuel pumps
  186. Procharger Throttle response vs turbo throttle response???
  187. erratic boost
  188. Msd pump problem
  189. problem maggie help
  190. Direct Port time!!
  191. COMPLETE Nitrous systems on sale for 599.00!!!
  192. ECS Novi 346 goes 9.19@148
  193. ECS Novi 2000?
  194. Vengeance Racing TTi 383 auto Z06 !!!
  195. Pics of my new blower for my stock cubes!!
  196. Stock LS1 boost levels
  197. SC with cam
  198. I need boost!
  199. Just Posted My C5 Vert TT PTK 402 Stroker ;-(
  200. Shell's "nitrogen enhanced" gasoline...whats everyones take on this?
  201. A&A sc system on 346 with E85, fuel requirements
  202. Any of you Kenne Bell guys...
  203. Supercharging vs Heads/Cam on a lightly modded street car...need advise
  204. Purge line mounting?
  205. Good Read On Boost....LONG!!!
  206. My modifications to the ECS fuel system
  207. what are your thoughts on this cam
  208. WTB: Twin Turbo 2001-2004 Z06
  209. APS T.T. installed ***SALE*****
  210. Question about tuning after procharger install
  211. Question about Nitrous Setup/Safety
  212. Methanol and a maggie?
  213. SC & Drag Race Requirements
  214. Spring Break Special -- Corvettes of Dallas
  215. Nitrous Outlet Plate kit and BBK 80mm
  216. Free Supercharger Install When Forging!!!
  217. Altenator Relocation
  218. Question about 418cu motor and 317 heads
  219. Question about 418cu motor and 317 heads
  220. Mounting oil catch can
  221. Longer IAT sensor for the KB set up?
  222. AN Threaded PCV Valve?
  223. spring failure
  224. Vortech superchargers question...reverse rotational?
  225. Tires??
  226. **TPE KENNE BELL BLOWN 434 lSX AND HANNIBAL LECTOR CAM**
  227. Vette Doctors STS Twin Turbo 383
  228. ECS fuel system help?
  229. What do I really need to spray?
  230. Vortech A&A Supercharger installed at Mike Norris Motorsports
  231. Procharger Install
  232. Boost Gauge: How do i...
  233. Advice keep D1 or buy APS TT
  234. Looking for a bottle, maybe
  235. Pics of dual bottle setups.. Thanks
  236. New Mill Went Together Today!!! (56K NO GO!!!!)
  237. P1153, Factory Set A/F
  238. Norris Motorsports / A&A Stock 2003 A4 Numbers
  239. Clutch shim info!!!!
  240. Do you have C5 core Steering Wheel for sale? We are still buying.
  241. C5 D-Type SW Limited Spring Special $588 *PIC*
  242. What is the best lookin Magna Charger hood?
  243. Vendor for a great price on a boost a pump I lost your name
  244. Working on my rebuild
  245. Belt alignment
  246. what nitrous should I use
  247. Aps guys check your oil lines.
  248. Will the hood from the Tiger Shark fit over the Maguson SC?
  249. Smaller balancer on a Maggie, where will boost be?
  250. Falling in Love All Over Again!
