- ls9 engine block
- Private messages not private but visible...
- Dynojet vs Mustang Dyno
- What do you have to install to reinforce a stock engine?
- looking to buy a forced induction system
- Blower input shaft seal, P1SC-1. Help please!
- How many cubes out of a LS-6 block?
- Turbo Question
- sheetmetal intakes
- *** Shop Specials at LG Motorsports ***
- Max boost with stock compression on built motor?
- P1 vs D1 for my goals
- *** Incredible Deal on ProCharger Installations at LG Motorsports! ***
- Different blower types for daily driver--good gas and massive hp
- Building a Fuel Cell...need advice
- Kenne Bell Z06 dyno
- Part of Factoryracecar arrives north of the border!
- >> NEW MONSTER CLUTCHES Available NOW !!
- Project TTiX FRC
- Oil return on A&A kit
- My Kenne Bell Stroker results
- just introducing myself to the fi section (with pics)
- Roots/twin-screw blower options
- Methonal question just switched from M3 to M1
- A&A stage 2 Procharger bracket belt size?
- Is it safe to run a 75 wet shot on my vette??
- YANK Torque Converters Customer Service Unbelievably Excellent!
- Kenne Bell results thread
- Length of return line
- stock zo6 cat back on a procharged c5?
- Some advice on a output shafts
- ouch! engine went boom!
- fast fuel rails
- Procharger stock engine??
- Fastest Time with 6-speed and supercharger
- Help me, future FI setup
- **Vette Doctors-ARH complete Exhaust System $1,895 Installed and Dyno Tuned!!**
- **Vette Doctors A&A Vortech Supercharger with Ram Air Intercooler $6,599 Installed!**
- Simply turn volute, or not???
- Alkycontrol/ECS Meth Kit Users In
- Re-Clocking P1SC-1. DIY job or not?
- Pre turbo/SC water injection.
- Forged crank, who sells it?
- Vortech Maxflow racing bypass valve for sale - used -
- high compression and boost.. who is doing it?
- GTP ported 6.0 heads.
- Hinson kit w/ custom intercooler setup
- NOS Intercooler spray bar kit. What kind of gains?
- •• Annoucing Klotz Synthetics ••
- Tensioner pulley for Maggie
- How often should I change plugs on a nitrous car??
- Powershifters... what knob?
- 2001 ZO6 346 forged motor P1sc1-stage II
- ECS Paxton novi2000 sc problems again..
- ecs paxton novi 2000 dyno sheet video time slip
- nitrous activation switch question
- Twin Rearmount Turbo Sizing Question
- Power Gain From A&A Kit?
- TTi X kit with an SD tune
- Meth kit question
- Another great job done by Nick Yoskin!
- Ram air intake, headers, exhaust, What's next?
- blow off valve without supercharger
- intercooled maggie Q
- spal fans
- 6 or 8 rib with stock motor C5 Z?
- My plan for controlling engine temps
- Meth users where do put you IAT sensor
- Procharger install instructions
- Dressed the blower up a bit.
- FLIP DRIVE - More power at same boost level and tune
- Procharger Air Filter
- A&A Procharger stage 2 backet upgrade??
- ECS Paxton novi2000 sc / tune help!!
- Red Hot Cats
- WTB: F1R Head Unit
- Short little video Rob took of my 924 rwhp dyno
- restrictor plate question
- boost pump wire help
- what degree thermostat are you running??
- Here's a brain twister for Meth addicts-How come I'm leaking alky and not water?
- Exhaust Back Pressure Lift Head?? Water In Oil. Have Questions ( PICS )
- c5 maggie question
- My new baby Boy
- A&A P1SC-1 with stage 2 upgade. Question on running piping.
- Another satisfied customer, A&A kit w/ Charlie @RPM tune
- How hard is a 75 wet shot on my transmisson??
- New to Nitrous
- Do i need different injectors for my z?
- Anyone want a transmission that will hold your F/I, nitrous power???
- Intake Air Temps
- A Huge Thanks to ARUN @ Champion! from MadMatt!
- Almost did it today 924rwhp@6300 pump gas !!!!!
- blow off valve
- New Over Drive Balancer Question for ProCharger
- Hmmm word on the street is Arun has done it again!
- need some Pics, advice and info on Nitrous
- ecs twin turbo
- Supercharging ? ?
- procharger pulley
- Opinions on Z06 Project
- ACT Twin Disk Clutch Review first impressions
- How much should this cost ?
- Ok, I'll ask over here. Did Spec change their PP?
- Easy A&A Vortech belt change???
- Pavlock Performance C5Z06 LS2 402 TT Build pics
- Just squeezed 150shot on my C5 Coupe!!!!!
- Mechanical or Electrical gauges?
- FS: 3.85" Pulley from ProCharger (MadMatt's)
- Tranmission Tune
- A&A Fuel System - FP Gauge
- With a new SC what else do I need to replace?
- Who has re-clocked an F1?
- WTB: 3.6 10 rib pulley for F1C Procharger
- WTB: 4.0" 8-rib Pulley for Procharger
- Ok Guys, Need Help....MASSIVE oil leak
- Custom TT Kit *UPDATE W/PICS*
- Barabus' Old Car?
- Exhaust question...
- We are ready to stab in the 4L80E!!
- Marshall guages
- meth kits with SC's - Need 'em?
- SC's and A4's?? Any issues?
- Does the dash have to come out to install Tick Master?
- IAT sensor info needed
- Need Help With Part ( Check Valve )
- help with KB boost pump install and racetronix harness please
- c6 wheels
- 7k RPM & 125 shot?
- C6 rear diff?
- meth question
- MadMatt Lost 3-4 Gear in Tranny Today! Ahhhhh!
- Do I need a progressive Meth control?
- how fast are 100 shot Z06s??
- Need help guys.
- Forged Short block questions
- Who makes the best oil cooler for a C5?
- Well I guess I can join the club now
- help with code
- Pyramid Rings Questions
- tell me what happened on my nitrous passes...
- Group Buy - Greddy Profec Boost Controllers
- Andy @ A&A - Continued Support !!!
- ATI ProCharger/EPP Complete D-1SC Kit with tune
- Install my new ACT Twin - Can't get car into gear
- The Punisher (Fogger Pics)
- Someone give me a link explaining this? Someone is trying to tell me a p1sc > d1sc
- E85
- EAST TEXAS MUSCLE CARS SALE on ALL FI products
- ecs "catch can thingy/pcv" diagram
- Those with Daily driver SD tune chime in
- Quick Question - Crank Pulley
- ** New Dyno Numbers are in.....**
- 97-98 Return Fuel System
- fuel pump ?
- Question about dyno numbers - 100 shot on Z06
- Cutting the tunnel for my 4L80E. {Questions}
- MadMatt's Dyno Day #2 with 80lb SIEMEN Injectors (Boost & Dyno Sheet #'s Inside)
- air / fuel guage
- Speed Density and Inspection
- Belt preference
- Wire digrams and instructions for n20 set up
- Most of you been there done that - soot?
- 3.5" 8-Rib Reichard Racing Pulley FS
- Progressive Meth
- Competition Mode
- what do you guys think of this vented grill.
- Any of my F/I nitrous brothers need a stage III diff ?
- Dyno results!!!!!!!!!!!!!!!!!
- maggie coil covers
- What BOV are you running?
- Got my Monster level 3 clutch today...
- Dr. Phil Strikes Again
- Nitrous advice needed
- Help installing a&a supercharger kit
- What turbos are on base aps kit?
- Anyone know this car? Looks like a good FI deal
- 220 lb/hr Injectors *NEW*
- Where to buy methanol?
- Help! Need idler pulleys!
- *** Cam Install Special from LG Motorsports ***
- FPR at the rails, which do you recommend?
- Corvette Insurance
- Turbo????????
- ZED upgraded
- FOR SALE: 42 lb LUCAS Injectors (Proven! I made 692 RWHP w/Them)
- NOS on a daily driver?
- Finally Finished The Z06----Dyno results inside
- too much noise
- Little Maggie blower question
- GM 2.5 MAP sensor
- what plugs to run
- ECS kit on completely stock 01 Z?
- supercharger & catch can?
- What cam you guys using for your blown 402?
- A&A Kit Should I Attempt This Myself?
- Boost referencing an 03/04 fuel system?
- Paging MadMatt9471!!!!
- brake booster vacuum hose lets see your set up
- FI owners....Torco 5 gallon for sale for local sale only N. California
- Getting Ready To Install the Nitrous, What Else Do I Need?
- Just took the Z out..Good Lord!
- Happy Easter C5 Boosted Members
- Very Big thanks To Nick yoskin and Chris Forest. Ptk/ebay kit done.
- Procharger Crank Pinning
- Fuel Pump issues?
- Where To Go For Rotating Assy?
- Resurecting the 97-with 800RWHP!!!!!!!
- Champion402+Novi+FlipDrive=NEED MORE FUEL!!!!!
- whats everybodies FI race weight??
- 2004 Z06 with APS kit from LGMotorsports
- Futral 383 692 rwhp!!
- E3 Spark Plugs, And ZEX Ls1 Full Nitrous Setup
- Price check please 98 lingenfelter supercharged
- Exhaust system for Fi
- Got it together, but smoke?
- question about LS motors
- Kenne Bell Grinding Noise- - Anyone?
- Adjusting rockers question
- compression and leakdown results
- Progess pictures C5 TTiX kit
- Beautiful C5 D-Type Carbon Steering Wheel......... *PIC*
- Help with ecs paxton novi2000 install.
- 2 step lounch controler
- Supercharger kit?
- spark plug wires
- PCV Questions for the expert
- FI TSP 402 with prochager p1sc-1
- Pics of The new 6 piece Valve Spring
- Kenne Bell?
- Stock catback?????
- Can someone kindly give me the contact info for Julio who sells Alky/met kits?
- Rocker arm question
- Tell me about Jet Hot Coated headers and FI
- A&A Vortech Z06, Low RWHP Help!!
- I have a Newb question about amount of boost?
- Is 1-2 PSI positive crankcase pressure a problem?
- Problem with STS Oil Pump
- "Budget" FI motor Costs NOT including peripherals
- stock tensioner
- Do containers of octane boost work?
- Gauging Interest: Selling 42 lb LUCAS Injectors (Proven! I made 692 RWHP w/Them)
- APS TT: Cats or no Cats?
- Nitrous and Alcohol Question
- Was the Stock LSx Motor built for F/I?
- making my own vacuum log??
- what should i do???
- I can't decide which turbo kit/supercharger kit to go with?
- LSXR™ Composite 102mm Intake Manifold-LS7/LS3/L92
- Twins to FMIC
