View Full Version : C5 Forced Induction/Nitrous
  1. ecs alky install how-to? anyone
  2. My Car is Featured on Planet LSX !
  3. Procharger stage 1/HO kit upgrade questions?
  4. Power Tour, Who is participating?
  5. TT Hoods...again!
  6. Champion motors summer sale
  7. Corvette Forum FI Members Sema Get Together?
  8. A&A's SI Trim first startup! (vid)
  9. Anyone need a Goodyear Gatorback 6 rib, 90" belt??
  10. Where have all of the Kenne Bell boys gone?
  11. 75 shot?
  12. drag radials anyone running 10s or better
  13. Help nailing down CR
  14. Anyone Running a Howe,Dewitt Radiator w/ Novi setup
  15. Amazing C5 Red Carbon Dashes.... how do you like it?
  16. ECS Z06 Pics thread
  17. anyone make a MAF eliminator pipe?
  18. WTT F1r series Procharger for an F2r
  19. ***JBSBLOWNC5 Reincarnated***
  20. Anyone have a 8psi pulley for P1 procharger?
  21. 576 HP / 526 TQ - Just another EB Z
  22. New 2010 Camaro.5 miles & a 427!
  23. FS 427 C5R based TT with 4L80E conversion
  24. Is it possible to convert my Garrett turbo to be a supercharger?
  25. Approx. EGTs on a LSX? Figured you guys might know.
  26. dte brace question
  27. Cam Only?
  28. How big of a difference is 93 vs 91 octane?
  29. A&A procharger 1st generation instructions needed
  30. Help with CAM Selection
  31. Just curious
  32. Tired of blowing your hose?
  33. P1SC-1 re-clock thread with new A&A bracket. Many pics and part #'s
  34. And I Thought it was FAST before!!!! Speedyd's APS TT
  35. A&A SI Trim + Auto Tans cooler?
  36. forged low cr Mahle pistons & Rods
  37. Thanks Champions and Aroooooon
  38. Re use main cap side bolts?
  39. A Few New Pics of My Turbo Z06
  40. fast 90/90 or vic jr intake? how much increase will i see?
  41. Glow Shift gauges
  42. Silicone vs steel braided
  43. Write-up: My Cool Air, Air Scoop for the Radiator Laydown Project
  44. Mototron 60's.. 359.00??????
  45. RPM'S faced gears, info?
  46. Getting Closer 9.25@150!!!!!
  47. How much to rebuild a procharger?
  48. Stand alone fuel system or major overhaul
  49. Arun from Champion Motors 2nd time at the track . . . 9.25 @ 149!
  50. air/fuel ratio
  51. 402 Stabbed in: Pic's
  52. TTi turbonetics t3/t4 turbos with wastegates
  53. Procharger 8 rib belt
  54. What heads to buy with a procharger????
  55. TPE's **JUNE SPECIALS**
  56. Anyone running 21 deg of total timing?
  57. Major valvetrain issue...need help.
  58. What wideband are you running?
  59. Big thnx to epp!
  60. single or twin intercoolers?
  61. [PICS] A&A's new Dongle
  62. WOT Spark Retard??? Yes or No?
  63. water pump
  64. I want a complete used LS1/LS6 engin!
  65. TT Hoods
  66. FS: 402 LS2 short block
  67. TTiX turbo - man it's tight!
  68. how can I tell what model procharger I have
  69. Patriot Gold Duals -Part # ?
  70. Help Pleeeeze!!!
  71. Dual nozzle meth placement into APS TT pipes?
  72. What will a LS6 longblock handle power wise?
  73. FS: Setrab 19 Row Oil Coolers!! BNIB!! *CHEAP*
  74. **Supercharger Install Special**
  75. Changing Oil with an Accusump
  76. High Idle after WOT pull
  77. AIR Pump delete in DFW?
  78. LS2 Manifold...Whats needed?
  79. 8 Rib Tensioner Pulley, Need One, Who Has Them
  80. C5 Nitrous Bottle Install??
  81. Performance questions on a LS1
  82. My APS TT build
  83. catch can hook up?
  84. Arun's day at the track
  85. GP Special: C5 D-Type SW .... *PIC*
  86. SC Viper Dyno sheet over a SC Vette Dyno Sheet
  87. Major Tranny Probs ...
  88. Best way to delete the PCV system????
  89. Limits of stock fuel lines/rails (return system)
  90. Found a great location for the Meth controller (Pics)
  91. What Clutch
  92. new ls2 numbers tuned by east Texas muscle cars
  93. TPE Begins the **NEW** Quad Pump fuel system
  94. Nitrous install, where to route the line?
  95. turbo oil drain??
  96. will underdrive pulley work with a S/C
  97. A&A Kit '04 Z06 Numbers
  98. fuel pump / boost a pump question
  99. ***RSD Announces an All Aluminum 2 Row Radiator***
  100. Pictures of bottle mount location
  101. I had the dreaded P0343 today
  102. Anyone else using a Labonte Meth Kit?
  103. GM fuel rail to AN, what's the standard???
  104. wheel hop/vibration during aceleration FI 800+
  105. Turbo Technologies: New Turbos?
  106. Which engine mod would you do first on stock S/C LS6?
  107. True duals with Z06 titanium mufflers.
  108. *procharger belt squeal solved
  109. Anyone Using a 2Step
  110. Injector size for ~750whp and 60psi fuel pressure?
  111. i think i got it?
  112. Reducing exhaust dB (without getting a new exhuast)
  113. opinions please
  114. FS: Gates belt laser alignment tool
  115. CTS-V with LS2/402 and ProCharger F-1A - 864 rwhp at 12.4 psi of boost!
  116. Twin channel exhaust housing valve.
  117. Video Preview of Pfadt Carbon Driveshaft
  118. CAMS No Clue?
  119. 19 lbs of Boost on SpeedyD's APS TT!!
  120. Question for Those Who Removed Factory Air Shroud
  121. TTiX No Boost
  122. maggie with headers
  123. Any help would be great. Boost question
  124. Can you run coolant through an oil cooler?
  125. progess numbers on TT vette
  126. Toys For The Toy
  127. A/F ratio?
  128. A/F ratio?
  129. Belt question
  130. GM High-Tech article on my 4L80E Conversion
  131. TTi Twin Turbo System Stage X NEW IN BOX
  132. Car is running VERY rich all of a sudden
  133. Stock C5 auto tranny, how much horsepower will they handle.
  134. Kenne Bell questions
  135. FINALLY - Boost By Gear for CENTRI Supercharged Cars by Dallas Performance
  136. Is a twin disc better for high hp than a single?
  137. ax boost on a TTIX kit????
  138. *** Unlimited HPTuners Pro Box *** See Inside!
  139. Desired IAT Value??
  140. P1 and D1 clocking, ECS, Procharger Stg II brackets
  141. Vote here!!!
  142. please help with plate kit
  143. For Sale! STS kit, complete! Pictures.
  144. polished my procharger!
  145. STS and Smoke when shifting and braking???
  146. Procharger/breather?
  147. one tune....
  148. do i sts with my 408?
  149. TTiX + stock LS6 pulls 717hp/677tq
  150. Our 8 Second Twin Turbo LS1 RX7
  151. Help, Car loads up and dies
  152. ECS SC600 + Toyo R888
  153. Anything wrong with this Belt Configuration?
  154. 3.4 and 3.6 SC pulley 6 rib for sale
  155. coolant heat issues with a TTiX kit, need some options
  156. Quick question regarding pipe routing and power steering cooler
  157. Beautiful C5 Blackwood Interior *PIC*
  158. Introducing!! **Plug-N-Play Oil Pressure Relocation Kit**
  159. Belt slip
  160. 922rwhp in the wrong hands..
  161. Two thumbs up to Jeff @ TPE
  162. Fitment Issues with Procharger install
  163. Who's running an LS2 intake manifold with FI ???
  164. serious help needed with heat problem asap
  165. anyone running FI on a stock c5 z06 LS6?
  166. I have a new Maggie Tank for sale
  167. FS: Found some old inventory - Beer Panels
  168. car rocks side to side after s/c install??
  169. NitrousDirect.com????
  170. How much does weather affect N20 cars?
  171. Boost Reference source
  172. Ls-6 or fast intake
  173. Predictions on power.
  174. Grit in intake manifold, Supercharger filter the cause?
  175. First Experience "as a customer" with TPE.
  176. TCI T-Com Transmission Controller (HaHaHa)
  177. TPE's New **Widebody** Quarter Panels {PICS}
  178. whipple / KB question
  179. Any in depth instructions for Paxton Novi install?
  180. Fuel PSI Question For Those Using BAP
  181. APS guys
  182. another procharger question
  183. How much do headers help a supercharger?
  184. Custom 2" ARH Headers and 3" Exhaust
  185. Anyone has a Procharger Stage 1 kit???
  186. Reduced Engine Power
  187. which pulley for my procharger setup?
  188. 2.08" Valve on a 3.905" Bore....
  189. 4.00" 6 rib pulley
  190. Looking for a maggie schrader valve
  191. It Lives!!!!!! MuHaHaHahahahaha
  192. boost or nitrous?
  193. Finally joined the FI club-KB inside
  194. RSI fuel hats; great product...but..
  195. installed patriot valve springs today and have questions?
  196. TTiX & LS1 Track Results
  197. Need help with oil issue from engine builders
  198. additional maintenance?
  199. What FI for forged 403ci?
  200. Turbo Rebuild
  201. Ms3 with p1sc????
  202. Provharger stage 1 kit questions?
  203. Changing DRL's with APS kit.
  204. Boost guage and Alky controller mounting options?
  205. Fuel range readings?
  206. what TT kit is this??
  207. Please help!!!!!!
  208. Maggie sticking through Hood....
  209. Worth it to build a 383 stroker?
  210. TTiX + stock LS6 goes 9's
  211. XMS Spring Into It Forced Induction Sale
  212. Who makes the HIGHEST rise hood avaiable...
  213. Check out my Fuel Cell...pics inside
  214. N/A or F/I for 600rwhp street/road race?
  215. How much did your S/C & LS2/LS3 setup cost?
  216. Thanks ECS!!
  217. A4 To M6 Conversion
  218. 500hp goal!!
  219. great stress reliever A & A
  220. Kenne Bell 2.6 versus 2.8
  221. aftermarket rocker arms
  222. Crazy Loud noise coming from Drivetrain
  223. Great customer service A&A
  224. want to spray my c5
  225. Edelbrock pro flo xt intake fitment on c5
  226. Top Mounts
  227. Ram air sheet metal mod to intercooler?
  228. Opinions on running stock rockers on FI
  229. doug rippie motorsports
  230. belt squeal
  231. •TECH TIP• How To Make The Stock Master Cylinder Adjustable
  232. For Sale: 70264 B&M Trans Cooler (Brand New "Never" Installed W/Pics)
  233. Warhawk 440ci N20 Motor Build Pics
  234. Results EPP 383 with a D1SC at 10psi.
  235. Question
  236. I think its Vortech rebuild time...
  237. Horsepower sales of florida magnacharger sale
  238. Kenne Bell Build Thread by TPE {With lots-O-pics}
  239. Now Avail!!! HUGE TPE Coolant Pumps for the Kenne Bell
  240. A and A Vortech by Vettedoctors
  241. Top Speed Numbers
  242. Anyone Have Pics of Nitro Daves Fuel Cell Installed ?
  243. Post up stock cube numbers!
  244. Custom Hidden Dry Kit for sale...(DFW,TX)
  245. Now Shipping!! **NEW** Mototron 80LB Injectors
  246. *** My Cartek beast gets some press on Lsxtv.com ***
  247. Results: A&A T-Trim Stock Bottom End
  248. Biggest Turbos for STS Setup
  249. Paxton novi 2000 z06. Expected hp/tq gains from dif. bolts-ons?
  250. Fuel system return advice
