- custom plates for FI/nitrous guys?
- ***NItrous kit installed and tuned sale!!!!!*****
- Blower RPM Calculator
- D-1SC. Need to calculate how much more boost I can run...
- Help me choose a size of Drag Radials.
- Roll racing
- F/S Nick Williams 102mm Throttle Body
- how much boost with 6 bolt heads/block and TTix???
- Self contained or not?
- 8 rib pulleys
- FS: Beer Panels **CHEAP**
- Product Update for Kenne Bell (BIG BIG blower coming)
- The Breathless Big Mouth Air Intake
- SC theory ?
- tensioner rubbing
- Fastbird's APS Vette Version 2.0 is Done
- 3.8 or 3.6 pulley help me decide
- Need Pics of Aluminum Radiator Hold Down
- LSx hanging tough with the fastest guys in the country
- Radiator Hold Down w/ ecs kit???
- 60lb motron injectors
- ECS Powerglide Conversion
- Just need to confirm...
- Used TTi Stage X Kit Anyone interested?
- Fuel pressure woes!
- Most Maggie boost on stock LS1
- Cerra Single Turbo Kit, any interest?
- Maggie 112 oil leak
- Metal supercharger hoses
- too big of a cam for supercharger?
- Suggestions on break in, no tuner in town..
- Your feedback about those tires please...
- Selling the LG Motorsport BIG 3 3" on my FI Set-Up!
- what are the steps to taping into your oil pan for the vortech system??
- About to give up.
- Methanol "Alky" Injection
- Where do you guys buy your methanol in CA?
- More questions
- NemesisC5 come in please.........
- Flywheel for Spec Stage 3+ Clutch?
- Blitz SBC ID II boost controller over boosting
- NGK R5724-8 for TT Vette?
- Wish I had a Camera !!!!
- Small seepage from top of Procharger fill screw
- How much more boost going from T trim to YSI?
- Lg Motorsports Hood Louvers
- Too much cam?
- What should my IAT sensor readings be at cruise and WOT?
- Anyone know what size belt to use for Procharger 3.7 pulley, with ECS bracket/tension
- Finally got my car back
- EnglandGreen's new eddy current dyno - shakedown run
- TIAL 50mm is noisy as he.. lower rpms out of boost..
- A&A Corvette 3.6" 6-Rib Supercharger Pulley for sale
- Edelbrock Supercharger for LS-1 ?
- Chattering noise from procharger (videos)
- How many FI guys upgraded their brakes?
- how much power through stock exh?
- A&A supercharger kit installer....
- FI Hoods
- HPM C5 LS7 Dry Sump
- Can a clogged cat cause lower engine idle vacuum + higher A/F at idle + run terrible?
- Want to add a maggie to highly modified C5, q's
- pics of no2 cars
- Need new Cats - what are my choices?
- Typical symptoms when a fuel pump starts to fail?
- '02 C5 ZO6 A&A/T-Trim results inside!
- To LSX or LS2
- High hp/boost cars...what fuel system you running?
- RPM's Tuning Special
- Tial BOV spring question and idle surge
- Highest Mileage: Orignal FI Block: Stock or Otherwise
- 97-98 Rails - Which Line is Which?
- looking for a way to track a/f ratio
- 3.60 pulley belt size?
- something broke
- Can i have my vararam hooked up to my vortech supercharger??
- HPM LPE Minitub Installation - Part 2
- TT or blower for c5r 427?
- Fuel pump die instantly?
- More advice please
- Install pics on ECS fuelsystem?
- Procharged C5Z vs C6Z?
- Car still running warm
- Weird Sound when letting out Clutch
- Help me decide? SC???
- TQ Tube Bushing Options
- What else do i need to install with my vortech supercharger kit??
- Big thanks to the folks @ rpm transmissions!!!!!!!!!
- question about tune and boost.
- Kenne Bell IAT again, again, again
- Are supercharger's Nirvana?
- I need to find a replacement alternator for my PTK kit. Please help!!
- si trim
- Meth nozzle mounting in rubber coupler work ok under boost?
- New Motor new Numbers
- ECS's 402/Novi/Glide Drops ET again - 8.70/1.28 60ft/157 mph
- Building a single rear mount - turbo size advice please
- Those with Maggies step inside please!
- Just bit the bullet
- alternator on my PTNeed help!! My kit is bad
- Fuel line routing causing pressure drop?
- >>>MICHELIN PILOT SPORT 335/30/18's less than 500 miles!!
- Huge Procharger Sale @ KY SPEED
- Thanks Rick @Synergy
- Maxing out the novi Project
- rear tire size
- Question? STS or A&A = Stock C5 (Real Gains-No B.S.)
- 408 start up/idle video
- a&a corvette pulleys
- NEW Vengeance Racing Ported..FAST 92mm Intake Manifold..Only $999!!
- FS: Brand New Custom 102mm Polished CNC Billet TB
- Yella terra great company
- Procharger help!
- Woooo Hoooo!!! It's ALIVE
- high hp guys how much boost you running with builds
- meth / water / ww fluid
- ls2 intake manifold price and improvement
- Wheel hop...kind of a funny story
- Turbo Specific Cam Info Needed***Vendors Step In***
- (PICS) APS car all cleaned up
- whos running an 8 rib set up on there charger
- *** FI Performance Introduces Our Military Layaway Program *** Details Inside ***
- C5 Vette Cog Drive
- Check this thread for great deal on Nitrous Outlet Kit and Accessories.
- FS: Custom Maggie FRCs
- maggie questions
- T-Minus 1 Week From Today.....
- Did a dyno session change the appearance of the jet hot coating on your headers?
- NEW! The MicroEDGE gets a buddy!
- C5 Dry Sump Conversion Complete
- How to make AN lines, great link inside
- If you have Dewitts Fans please chime in.
- what is the popular supercharger
- When Machinists get bored!!!! Billet KB L92/LS9 Manifold
- Iron block effects?
- Raptor shift light install help.
- Boost a pump. KB or MSD???
- Race Proven Motorsports Stock C5Z W/ A&A Kit
- Question about belt noise....
- Need help hooking up ZEX NOS Box?
- Eco-Skel Slipping Is This Rebuildable Clutch
- Brocken rocker
- Comp Cams LS Belt Tensioner
- X-Post Group Purchase for the C5 FI Crew
- Dimmer wire for autometer gueages installation help.
- Need methanol ASAP
- Any issues with a 2.75" pulley on a paxton?
- Just blew a head gasket
- Tuning question
- Blow off valve - 2 completely different sounds?
- can a bad tank of gas cuase the car to run poor?? HELP!!
- Any STS guys in FL run big rwhp?
- D1SC Cubic Inch limits.
- sway bar fit
- CMS dyno video and graphs
- Some help with gauge selection
- Snow meth question: Can I run 100% meth??
- Walbro 255 / Racetronix?
- Big Lopey cam in FI question... Who's done it???
- HPE - Flip Drive - Version 2
- Wrapped Exhaust /Manifold ?'s
- Boost a Pump Question
- What hose is needed for a LS7 Throttle body
- Blown 427 Losing Boost
- New a stock part from a blower install
- loss of power I think !
- ALky pump issue?
- Do drag radials require stronger rear end
- Thank you CMS (Cunningham Motorsports)
- August temps are rising, while the ET's keep dropping-ECS Paxton 402 - 8.73 @ 158!
- Oil on Cylinder 3
- improvements with meth
- Budget Build****A&A Vortech
- Procharger D-1SC to F1R
- Fuel safety question(s)
- Tick Master "Spring" ?
- G-Force Gears...Noise?
- I think I'm running our of fuel/injectors still....
- Will i need to upgrade my fuel pump system...bought a vortech kit
- Need advice for 70+ high impedance injectors
- 0068 code
- *******a&a kits instaslled on your c5 for $5499.99!!!!!!******
- meth kit
- County Corvette's A&A Supercharger Special @ Corvettes at Carlisle
- Thanks ECS and Champions
- Finished SC install with ported TB & new intake, car idles at 4,500 RPM with basetune
- Maggie on Meth:
- does ATI make a new quite F1r, A or C..like a YSI
- LSX / 6.0L options
- Apsis' C5 Waterfall + Armrest in all Nappa Black Leather..... new pic
- Well it hooked=broken parts
- Alky meth kit
- Help! Throwing Codes after procharger install and tune
- HELP strange power cut please HELP
- Bought a vortech kit do i need a new fuel pump for my 98 vette.
- 1st and last "Andy's an idiot" sale!! A&A systems never cheaper!
- Happy with my twin turbo C5 numbers!!
- WANTED: S/C comments & opinions for 2004 Coupe w/A4 & 3.15 gears
- help with s/c decision
- Runway Titans: Wide Open Throttle! Release Trailer...
- sneak peak at the new double din for the F/I crowd
- ECS tensioner trouble
- Make no mistake Virginia Speeds 438" LSx runs with the big boys
- Advice on running N0S at track
- Traction Control; Need Some Ideas
- Ignition problem
- FS/WTB Procharger D-1SC/F1 or F1R
- APS Guys, tuning question
- Valve cover breather question for boosted car.
- Stolen COPO Camaro,trailer and rig.
- Kenney Bell Pulley?
- Need Some Help Swapping Radiator
- Cartek @ Carlisle Corvette Show
- Thinking of APS TT?....think again....
- WTF? Why is it overheating this time?
- **ECS@Carlisle** Bigger Booth - 2 locations – Dynoing - & the return of the $99 tune!
- Apsis' C5 Waterfall + Armrest in Premium Italian Nappa Leather..... pic
- Apsis' C5 Door Panel in Premium Italian Nappa Leather....beautiful....pix
- 160 T stat and AA supercharger bracket questions
- Idea...may be dumb
- Boost at altitude
- Standing mile miami 10.11.09
- What size pulley for P1SC on my H/C/I zo6
- New pics of the LPE car with black rims!
- ** A&A Kit...NEW Member **
- *** NEW HKS BOV (SQV3) Now Available ***
- FI and cam bolts
- ATI bypass/BOV alternatives; what are my options?
- MAF Question
- traction issues ???
- Anyone running Turbonetics GT-K series turbos?
- F/S M & H Racemaster Drag Radials
- WTB: procharger race bypass
- harris speed works c5 plate system
- Rear Diff for 574Rwhp Z06 and DR's
- LS6 Block Strength
- Is it normal to have oil mist on and around BOV?
- lg cat back
- Gunk clutch fluid, thoughts?
- Just got my Dewitts radiator and fans today
- Ambient Temperature
- Stock Fuel Rails...New Regulator!!!!
- *** AEM Uego WIDE BAND Air Fuel Gauge SALE Thru 8.31 ***
- 345 DR's are on the ZO6. w/pics
- Gearing w/ FI
- Free Shipping on ProCharger Systems at EPP
- ECS alky kit
- Pics of t6060 and zr1 differential
- need some local help - after SC, clutch, trans and springs install, problems found
- want to add TT`s on my 99 C5 what should i do?
