- Lowest Pricing Ever onTextralia @ KY SPEED
- What is the pipe diameter of the STS charge pipes?
- Black Friday Sale
- Buying a blower cam
- BPP Black Friday Sale
- Ragin Racin / Nitrous sale 25% off plus free shipping
- high hp boosted cars plz step in
- King of the Maggies Trophy Pic
- Portraits of a serious disease...
- does the position of the TB matter?? Right of Left?
- vented oil fill cap,,, why,,, alternatives?
- Pod and Guages
- Pod and Guages
- NA car breaks 6 speed record?
- 97-98 fuel rails w/adjustable fuel pressure regulator?
- Fuel pressure still dropping at higher rpm's (wot)
- Champions is Champ!!
- HSW nitrous on a forged 427ci?
- boost controller? Will it help?
- Tick Master Cylinders & Bleeders on sale @ KY SPEED
- Under boost, FAST intake Vs. LS2 intake?
- TTiX 60-130 results on my car (video of the run)
- F/S SLP 51011 cam, great mild blower cam
- Car won't move: SD tune problem??? Experts needed!!
- does your maggie make noise?
- Do I need to Pin the crank??
- TTiX Turbo Rebuild time
- Do I need to run a thicker gauge line to my pump?
- Champions 402@ 894 rwhp!!!
- AnyBody running an ecs kit on there ironblock Ls motor ?
- Need help picking out heads/cam combo
- Need a Tuner open on Sunday????
- It's Alive
- Question about belt slip...
- 12-rib 3.4" ProCharger pulley
- ATI supercharger install question/HELP
- Maggie Magna Spark
- APS issues
- Say Happy Birthday To Jesse!
- 8 Rib Blower Pulley's Procharger & Vortech for sale
- Proggresive/non proggresive Alky Injection
- Fuel Pump Issue Fixed
- Attn: Mods - this website is still infected!
- 2 day 60lb Siemens injector sale
- Just started my car after installing my supercharger....Help
- TPE's T2 Widebody FRONT FENDERS are done!! [Pics inside]
- Has anyone seen the newly released Procharger with "Helical gears"?
- Anyone looking to buy a 2bar map sensor?
- Bought a new Vette (new to me)
- Admins/Mods Attention please
- New forged motor, more boost=drivabilty issues. What now?
- AMS 1000 Boost controlers
- does any one have the instructions for the A&A procharger kit with the origenal inter
- new C5 maggie owner have questions
- Zeroing in on 1000 Supercharger kits sold!
- how much power?
- FS 4500 Nano System With 15 lb Bottle
- Apsis' C5 D-type SW w/yellow leather on top....beautiful....pic
- Converting to SD from maf
- Got the LS1 engine apart
- where do i hook up the vaccum line that comes off of the top of the throttle body??
- good nitrous cam?
- what kind of power should i be able to make with my setup??est
- HRTBRCR turns up the wick and crack's 850 rwhp!!!!
- Remapping required with Air Intake change?
- build costs ?
- Cam Suggestions
- 01c5 fuel drain?
- what hood to use and how much more clearance over stock
- WTB 9# Tial 50mm BOV
- Basic question about differences between superchargers.
- vortech aftercooler water pump??
- Another "What do think about my set-up? How much power will it make? "
- Big Thanks To RPM TRANSMISSIONS!!!!!
- Injector size question with dropping fuel pressure
- Has anyone made their own meth kit?
- Yet another EAST TEXAS MUSCLE CARS A&A kit out the door!
- What do think about my set-up? How much boost will it make?
- I finally got blown and its awesome
- Edelbrock or FAST intakemanifold for vortech?????
- Arun Lifting Off.
- A&A Kit 3.8 RPM vs Boost Breakdown
- Fuel pressure DROP directly correspond to amount of boost?
- Forced Induction crew-Selling 710rwhp ECS Z06 with Erik Koenig/HKE forged LS6 engine!
- Bosch fuel pump 044 rubber disc removal?
- FS: Labonte Meth/Alcohol Injection *BRAND NEW*
- F/S 2 Turbonetics S-Vtrim,.48 AR stage 2 turbos
- Purge Stuck Open..
- *** EnglandGreen Customer Appreciation Party! - December 5, 2009 ***
- idle rough after BOV install
- Video of '98 C5 with ATI ProCharger D-1SC
- ECS' car carrier coming east/north from Vegas/TX RT40 to 81 with one open spot
- Twin 76mm S/W Coupe
- Driving to Vegas next week from sunnny North Ontario
- Which Flywheel for a A4 with a new balanced engine?
- LS2 Manifold w/90mm TB vs LS6/78mm
- Pilot Bearing Removal......Tricks?
- What gears are you FI Street car guys running?
- I got the car back!!!
- having problem with meth pumps
- MTI Houston builds; how much boost??
- what do you use to polish head unit and brackets
- My newest racecar build...check her out.
- Hood options for Kenne Belle?
- Supercharged C5 Vs Enzo: Complete Race!! *Promo Vid*
- hp factory
- *NEW* Apsis' C5 Carbon Side Mirror....awesome....pix
- Need WP For Build W/LS2 Timing cover
- ECS or A&A?
- EASTCOAST PERFORMANCE & CORVETTE Holiday Specials <> Giving away over $1000 in Prizes
- what is meth injection?
- Champions TT TR Z06
- Bolt pattern on fuel sender.
- 2Bar MAP Part Number
- B.O.V. Placement ? For ECS kit
- Paul Major hurt his car.
- Pros and cons of dual side intercoolers Vs. front mount?
- my dyno numbers are in got it tuned today
- Anyone have pics of a procharger being installed?
- What are your thoughts on the Stock Procharger BOV?
- blown head gasket?
- Procharger hose help
- 8/9 sec Vettes inside
- Do your 3.90's whine?????
- Nitrous Plate Opinions
- NEW BEZELS!!! 1 C5 and 2 C6 ready to go for the F/I crowd
- Expert's Step In Please
- Buy Methanol
- Pic request Tigershark front end in black
- FI and High Flow Cats
- 2nd stock longblock into the 9s
- Some real cool pics from the MIR rental!!
- Nitrous vs. Boost
- Which Aeromotive boost referenced fuel pressure regulator?
- Methanol Winter Storage
- Dart head install
- 4DRUSH and ARUN's PASSES FROM MIR
- Newest style A&A kit and tial BOV fitment?
- Forced Induction on the track
- front airdam can i cut it
- tuner questioned my 3.6 pulley??
- AA Kit + 3.8 pulley
- Arun's runs from Maryland Raceway
- ECS Novi 346 - 4DRush goes 8.95 @ 151!!!!
- EPP LS2 402ci Aluminum Short block - Camshaft included!
- so lets get this correct... to go with a 2 bar map sensor i replace my old one with..
- Fuel pressure woes
- Differnce between a sd tune and one with out it??
- *** Low Boost Shakedown run yields new best MPH( 8.98 at 158.63 )
- Need help with upgrading my fuel rails and regulator (1998)
- Looking to go twin turbo next year. Recommendations?
- FI Oil Fill Breather question
- Maggies with Meth Warning!
- what are my other options so i dont run out of fueling maps during my tune on my 98??
- Best FI piston rings
- *** My Cartek beast is alive again ***
- Think you having a BAD day?
- *** NEW PRODUCT ALERT w/pics: Carbon Fiber Oil Catch Can *** HOT NEW LOOK
- New PMC for a 1998
- Thinking about purchasing a LS2 manifold for TT 402. Ported or non ported?
- LPE Fuel Pump - How much power?
- I am looking at buying this car. Is it worth the money?
- where to put a wideband 02 sensor
- where to buy meth northern CA
- 98 vette, switching to a 2 bar map sensor??
- Where do i get a 2 bar map sensor for my ls6 intake manifold??Good idea for a tune?
- And So It Begins
- How often are you in boost?
- Need Help going from N/A to FI
- Final dyno numbers for g5x3 Procharger combo
- *** EnglandGreen's CRAZY November Drivetrain SPECIALS!!! ***
- My experience with CMS (Cunningham Motor Sports)
- Anyone Broken a C6Z06 Output Shaft?
- Estimated gains going from a 1 3/4 header to a 1 7/8 header on a blown 427
- How does the sound of a Tial BOV with an A4 compare to a M6
- Grit in fuel tank
- Re pinning crack help
- 2300 tvs and 15lbs
- 02 zo6 procharged?
- A&A Corvette Decals
- Can I Retrofit Newer Electronics on a '98 C5?
- *** ALL SPA Technique Dual Digital Gauges ON SALE at FI Performance
- 32 mpg city from rear mounted twin turbos?
- Belt or Bearing Squeal?
- TVS c5 goes 10's
- Remote Bottle Opener concerns..
- Help needed for boost loss & other issues
- At what hp level do 75lb injectors max?
- Stock 97 LS1 Nitrous question
- afr heads 205 vs 225
- Congrats 4DRUSH, pushing his 346 Novi 2000 to 9.10 @ 151 !!
- Tial orig or new "Q" ?
- Will a 4.8 manifold supercharger fit a 5.7 or 6.0
- What balancers are you guys running with Centrifugals?
- finally some numbers for my a&a supercharged frc 546hp/618torque
- A&A Procharger Bracket For Sale
- LS2 portworks.Has anyone used this company.
- What do you think ?
- Need advice on what to do...
- ***east texas muscle cars stage1 blower cam results***
- powerglide shifter
- Looking for an idle clip
- Looking for idle clip
- The little maggie is out
- Max "safe" bore for FI LS6 block
- Old style (2004) ATI LS6 set up
- Carroll Supercharging Co...any info???
- cog drive system?
- 1300rwhp Vette
- 42lb to 60lb
- mounting the water cooler for my vortech system behinf the open front plate
- data logging question
- Anyone used these
- Ive got a vortch supercharger kit, where do you hook up the boost gauge?
- FLIP Drive = Happy Tracker
- Clutch bleeder line from Charlie at RPM Motors is a great design..
- Keying crank
- *****guys go check out our new web site!!!*****
- Cooling issues with an intercooler
- ls2 intake upgrade gains and parts?
- best head/ cam question (help - vendors welcome)
- My bbk throttle body spacer is coming in the way of my vortech pulley??
- Champion Motors track day review
- Funny "Blooper" Story..
- AIT sensors for 99 maggie
- Arun Fastest Street Car (Champion)
- Cam recomendations for my Ls3 build
- WTB - ProCharger 10 rib pulleys
- Cam rec. from the specialists
- A&A Superchargers- over 1/2 off installation.
- can someone local tune my car
- Cam Swap Help ( Need to move cam sensor )
- question about data logging
- c6z diff and tranny swap
- How much
- Who to use for nitrous install and tuner in Houston?
- 110% F1R blower speed with Cartek Flip Drive 2
- New bolts with new clutch?
- ECS vids of the LSX shootout
- Tuners: Who has a really good IFR table for the 80's?
- I Got To Speak My Mind About TPE!!!
- some TTiX maint work
- broken MAF housing what are my options?
- Great customer service from TTi.
- Clutch
- Moving Gauges
- Champion track date change to oct.26
- Dyno results for P1SC AFR 205 G5x3
- Clutch recommendations for FI power
- TTiX Max front wheel/tire size?
