- how much rwhp is a stock 07 c6 zo6 pump good for!!
- Boost Advice
- Need Help With which Balancer for an A&A Kit
- Super charging an LS6 the right thing to do??
- WTB/ overdrive 8'' balancer
- Aftermarket heads? who needs them! 9.38 @ 145 with stock cubes bone stock LS1 heads!!
- piston and crank for a 383
- Need s/c header education
- Where is all my boost??
- What A4 with ECS SC600
- *FS* NIB ECS Dual nozzle alky kit
- A&A Kit - Supporting Mods?
- Do I need BAP with Walbro 420?
- another A&A C5 finished up 200+ HP
- Twin Turbo Follow-up - 640 / 630 @ 8.8 PSI
- My blower build with lots of pics
- Exotics Rally Miami Runway Event April 25th....anyone going?
- Mercedes Benz 6.3 Bi Turbo?
- W/T/B 80+ Injectors
- Nitrous in stages by gear in an A4?
- Any Problem Leaving Airpump/Hoses In Place and Hooked up With No Cats?
- New nitrous dyno is in!
- procharger questions
- Got to the dyno today
- Dry nitrous install on 98 coupe.
- Heat protection for my engine wires?
- Cam selection with a maggie
- Hpm 1999 ls7 tt frc
- need a new fuel pump on my 98.. can i just drop in a 255?
- Single BOV for TT's ??
- V2-SI Vortech Supercharger....
- TTi's New "Upgraded" X-Kit intercooler pics.. SEXY
- Aem fic 30-1930
- want a blow off valve
- *** EnglandGreen April Specials! We're Giving The Stuff Away! [Practically] ***
- Need Advice
- APS exhaust gaskets?
- Header Size on SC build a true restriction ?
- UltraGrip Blower Pulleys
- Nitrous Tuning Help
- What size valves for 317 heads on 402 with twin turbo's
- A&A T trim dyno numbers plus issue
- Which air filter for PTK kit?
- SCOTTS low 10 sec 04 corvette
- Anyone here use Aquamist?
- EPP Blower cam installed
- Can't decide on which clutch to go with
- Looking for some good quaility silicone couplers
- Which x-pipe can be used with PTK kit?
- Should I got to aftermarket motor mounts?
- when to build motor
- turbo guys plse help
- Boost gauge really necessary when SC?
- Dyno'd low, and have knock issues :(
- Some new Video and Pics
- We need a tire shootout.
- Upsizing Nitrous lines....
- How to remove tension on tensioner to remove ideler pulley?
- what do you think.....
- HP numbers aren't adding up!
- C5 z06 + n2o??
- FS: Cartek Flip Drive
- How much boost with forged 346 and 10:1 comp ratio
- Dyno results
- 4.10" Pulley, old A&A bracket, need belt...
- RSI Fuel Pump
- 4.00 & 4.10 6-rib procharger pulley
- Which Check Valve for PCV!?
- Kenny Bell BAP
- A&A T-trim?
- Anyone want to take advatage of a typo?
- Blower Cam Help
- Need cam advice
- ProCharger Dealers
- Overtightening causing belt to jump?
- Ecs 346 blower cam!
- Looking for a Used Supercharger in working order
- Eastcoast Performance Has You Covered>>>Supercharger Kits/Axles/Clutches/Couplers!!!
- 6 rib or 8 rib?
- Need to rebuild diff
- NOS kit for stock c5?
- Anyone switch to ZO6 Catback and Regretted it?
- OUR NEW C5 Build!
- NGK AFX Wideband Kit - Now comes with upgraded NTK sensor at no additional cost!
- Looking for a BOV.
- Why does my belt want to come off on my vortech supercharger??
- Anyone with procharger and new helical gear?
- Hey APS guys......
- 3rd round of upgrades
- just got done my car
- F1 or D1
- Anyone running an Electric Water Pump?
- Kenne Bell BAP
- Need help with Fuel Injectors! {asap}
- Its on and doing good!
- aps twin turbo terrible throttle response???
- F1c vs vortech Xi
- Crazy idea for an Air to Water setup, what do you think?
- Just blew my motor
- Plans for upgrading P1SC-1, what else do I need or should I do?
- Tune advice needed.
- Engine Knocking Noise
- Flexible blow down tube?
- Which Automatic Transmission?
- ** HUGE ** Dewitts Sale
- Thinking about FI... tuner questions
- 2 port regulator question
- blower cam ??
- Forging the LS6
- High Flow LSx Injectors All Flow Matched
- Help on nitrous install
- Need some help... going nuts.. with my org. vortech kit
- Need parts from blower guys
- Removing Pulley D1
- ** GROUP BUY on T2 WIDE BODY PANELS **
- Fuel Pressure Issue
- JL Turbo STS C5Z breaks 200mph in TopGunRun
- C5 hot section
- Hinson, RSI, Victor JR, Aarons. Turbo build
- ** TPE's Oil Pressure Sensor Relocation Kit **
- Im so let Down ;( F/I brothers
- Whats the best belt to use with a vortech supercharger??
- My BAP nightmare
- upgrading my turbos.. how much gain
- SoCal TT install and tune shops
- Pulley messed up... Pictures inside.
- Is this normal for a SC stock bottom Z?
- Anyon stick a LS7 clutch in a C5Z to hold 600 RWHP
- Slight re-tune on my Z06
- Difference between Maggie MP112 and Eaton M90?
- New Number Stock Bottom End
- what to get to run more boost?
- supercharger!
- Recommendations on turbo for PTK/Ebay setup
- 02 Z06 A&A kit
- Juice going in the Z...
- TVS/Eaton blowers with Methenol, can it damage the blades?
- Black Hills Corvette Classic 2010 - July 13-18! Registration now OPEN!
- First test drive with S. C. And clutch pedal stuck why?
- Torn over modding my C5Z or stepping up to a C6Z
- T Trim to YSI question
- Anyone running kooks full 2" headers?
- timing chains?
- TVS 2300 and C5 hood options
- Simple Crank Case Vent?
- Rear ZR1 rearend for c5
- Think I need a fix..F/I Related
- LS6 Timing
- LS7 Clutch Kits In Stock! - www.PartsTaxi.com
- ***East Texas Muscle Cars C5 stage 1 kit on sale ***
- My single turbo Build. My Design. (w/pics)
- Twin Turbo Kit on Ebay???
- Nitrous guys!!!
- Procharger F1 or F1A Daily Driver??
- Anyone have a NW 90MM TB for sale?
- Who sells the dyno jet wide bands
- LS6 600 RWHP Question
- A&A Kit Dyno Results 3.8
- ***ETMC stage 1.5 750 HP kit out the door***
- OK Vendors, In Need Of A Radiator....
- My 347 build complete (56k=death)
- ECS ever get instructions and new prices on their fuel systems?
- Questions on ecs blower kit and turning the boost up
- FS: Siemens 60lb Injectors
- A&A S trim kit vs Procharger?
- Engine swap thoughts
- Swap to LS6 intake with P1-SC or not?
- building the Ls6 !! need advice
- Pin or not to Pin Crank
- Some results!
- Blower cam
- anyone live in ft myers/ cape coral?
- Car has AUX 116 octane + Meth, Avoid Intercooler?
- Springs or Heads? What do you think?
- LS1 LS6 Crank Pin Kit
- toyo ra1 or nitto nto5
- Exhaust Super Sale @ KY Speed: Kooks, ARH, SLP, Magnaflow
- Procharger issue- help needed.
- Need opinions please on this FI buildup list . Thinking of buying the car.
- Anyone in the DFW area need a nice blower hood?
- Quick General Supercharger question
- Got bored and popped a new cam in the Blown Blue machine
- watch out for luv2spd (jay)
- Tires for 500rwhp
- 3.7 10 rib Pulley wanted
- ***new trunk mount meth kits ready to go***
- Looking for a P1SC Pulley
- Spark Plugs Black and Fouled, Does my Engine Look Like this Inside?
- VetteDoctors Istall American Racing Headers & Dyno tune for 1899.99
- Take a Deep Breath
- how many people have had issues with the spec 3?
- I started the S.C. Install today yea!!!!
- 0il misting
- 0il misting
- Fuel System Trouble
- FI 600rwhp with Stock Pistons 2000 C5 vert?
- What to do with my fuel system.. installed a vortech..
- Lets talk ignition coils? LS1/LS2/Truck coils?
- It's The Master Tuner's Birthday
- APS oil return
- What Plug Wires are Ya'll Using for Long Tubes?
- FS - Gates Green Stripe 8-rib 93.35"
- Frozen D1 Pulley Bolt *** Need suggestions...
- Oil Leak...AGAIN
- red crackled texture on procharger
- changing rockers and spring
- what intake manifold are you guys running?
- What RWHP level to run 10.00 in 1/4 mile
- Front Spring Replacement
- Is there any reason
- 3.85 Pulley, need a belt #
- Clutch for 800-900rwhp?
- WTB: Supercharger kit for 99 C5
- New Dyno numbers
- Write-Up Alert: 17lb Light Weight BRAILLE Battery Install-Works for FI Apps (W/Pics)
- Whats efficient as far as RWHP per lb of boost?
- When's it time for a Speed Density Tune
- Think I blew the seals on the turbos tonight...
- Cause of fuel leak on a wet plate kit?
- Z06WANTED get's his 8's second slip today!!!!!
- Question on FI and Head /Cam set up?
- FS: A&A fuel system
- Performance Inductions 275cc catherdral port heads(real world results)
- ***parting stonabones69 engine please take a look***
- ATTN: All SPA TECHNIQUE Gauge Owners **** Step Inside, need help from my customers...
- Larger Fuel pump needed for 600-620ish rwhp on 99 FRC...All Motor 442ci LS7
- AN Fitting / Fuel return?
- Street/Strip Tire
- Any A4 FI folks out there???
- Need some more customer pictures.
- Clutch replacement
- boost increase
- Lookin to buy a Magna Chager set up.
- Go With Some Show
- Boost Compression Ratio
- What can i do to my vortech kit to prevent the belt from coming off..
- Anyone with an A&A charger on a stock C5 auto?
- Used STS System - Complete - $3500
- Fuel Pressure Reg. Adjustment
- Need advise.... should I put things back to stock?
- BRAND NEWSED A & A Blower kit for sale
- Want to buy Pro-Charger BOV
- LS1 bottom end
- Increase boost at low RPM by adjusting BOV?
- Vacuum Leak?
- BAP Install question?
- Curious Anybody using Vararam With Supercharger or Turbo?
- Blower cam group purchase?????
- late 03, 04 fuel pump question
- What is the way to Reach Absoluty Highest Boost # on the Vortech Kit?
