- Which timming chain for 900+rwhp?
- My P1SC just came in!
- Advice on Meth Nozzle Location
- question on fuel
- Laser etched Intercooler plate!!!!
- Throttle body pros ??
- When is 860 rwhp TOO much? (ugly)
- Got Bored so I bought an A&A April Fools 2009 kit and had Dallas Performance install
- RPM Stage 2 or 3 differential?
- FAST 102mm with boost?
- * S A L E / INSTALL SPECIAL * TPE is now a DISTRIBUTOR for LG *
- Alky pump problem
- What are you guys using for a 3bar MAP?
- HP with 100 shot...
- check this out!!
- LS1 LS6 Crank Pin Kit
- ****A/C mans YSI build at ETMC***
- double pump set up
- Can I fit a bigger radiator with my PTK kit?
- Need advice on good FI tuner in FL
- A&A SC install
- FINALLY built my CAI
- My A&A install and dyno (pics)
- Ashtray Switchpanel/Nitrous Questions
- Installing A@A kit with big radiator??
- Should my Switch Panel Bottle Heater BUTTON get HOT?
- Going from NA to FI
- Big HP guys with A4
- Header Install
- effects of ECS blower cam ?
- Heat issues??
- Can't WIN, bottle heater works, but not heating past 800 psi?
- Anyone running A@A YSI how do you like it!!
- What Power Adder for this setup???
- Will a stock C5/ZO6 rearend handle 750 rwhp ?
- Do I need a new fuel pump
- STS Oil Supply????
- D1SC from F-body kit direct swap onto my c5?
- Anyone relocated the radiator?
- Injection and code 1221
- F/S procharger 3.4 pulley 8 rib! $65 shipped!!!
- alcohol injection
- Racetronix Harness And BAP
- Need Some Info Thinking of Going FI
- Ordered my A&A kit today, do I need headers?
- 2200CC HI Z injectors
- Props to Andy at A&A
- Thinking about going to a 17" wheel
- Attn: Spec 5 Clutch Owners ; need your opinions
- Radiator Upgrade
- Help me with a tranny and diff set up for my C5Z.
- changing A/C compressor on a blower car.
- F/S D1SC PROCHARGER KIT A@A stage 3 bracket
- New fuel pump and no go.
- 100 octane
- overdue props for the ECS boys 864rwhp
- Should i spray more?
- Do it yourselfers
- Torn Between A&A and Procharger
- Favorite BoV video? (boost newbie here)
- ECS Half Shaft Safety Loops, Doing the Job they were designed to do!!!
- WTB 3.6 Vortech supercharger pulley
- Anyway to "Valet" a FI Z06
- Another idle problem
- N20 problems @ strip on my C5 still?
- Whats a good wideband monitoring system??
- Where to place the BOV??
- A&A Supercharged C5 Corvette A4 Results
- Would you let your wife drive your FI car?
- Dr Phil & RPM Trans
- WTB 6 rib crankshaft pulley
- Idle problems
- Another YSi hitting the streets soon.
- Reputable Shop in/near El Paso
- D1SC pulley swap: 4" to 3.55" results in here! Belt slip or resrictions??
- You may like reading this.
- Question on reaching HP goal with an A&A kit
- getting rid of maf, so i have a couple questions.
- F/S procharger 3.5 pulley 6 rib! $65 shipped!!!
- Anyone have Procharger cold-side or A&A?
- Experience Running Breathers - No PCV
- 700 club!!! 402, D1
- External Fuel Pump Question
- Freddy's Supercharged 2002 Z06 600RWHP
- Gates green stripe ID
- 317 heads?
- Spec 3+ slipping...what does everyone recommend
- Concern on diff and tranny
- My new fuel system
- oil return pumps...and check valves...
- Need help with A&A pulley
- DIY Dual Walbro question(s)
- procharger pulleys 3.40 / 3.50 / 3.85 $65
- Will it make differnce if i was to switch to turbo smart bov from my stock bosch?
- A&A kit DR question
- Will this mcleod clutch work for 700rwhp?
- Pro-Charger 3.85 6-rib $65 SHIPPED
- Would I be insane to boost my 11.5:1 CR with stock internals?
- Antone ever sent a head unit to SC rebuilders?
- Considering A&A SC. Question of age..
- Anyone kill their fuel pumps with BAPs?
- WTB// 8 rib 3.50 procharger pulley
- Street cars, how is traction? what is your gearing?
- i have a vortch supercharger but its 2 quite.
- What power level do you ditch the mass airflow sensor?
- First soundclips of new Magnaflow custom 3" exhaust! short HD vid...
- Exhaust swap, safe to run on current tune?
- One UP!!!
- New Motor
- Smoothest clutch with A&A
- Broken Belt = Broken Block??
- AFR 225s for sale
- Max boost on a Maggie, stock internals.
- WTB: ProCharger 3.6" or 3.4" Pulley
- Just another blown LS2 - I like it a lot!
- Procharger supercharger air filter
- Vortech S-Trim Owners...Question
- Anyone need a 2-Bar MAP sensor.
- lingenfelter high volume fuel pump
- Kenne bell boost-a-pump
- 4.10 Pulley, D1SC Avg boost level
- magnacharger mp90
- Is it OK to use a .020 NOS Jet instead of a .020 NX Jet?
- P1sc1 capable of 700 wheel horsepower?
- NOS Octane Booster W/Nitro Methane, OK to use???
- 150 WET SHOT Dyno Results Inside with YankSS3600 Stall. QUESTIONS
- Ls2 kncok sensor connecter question
- Do I need to tune when installing nitrous?
- Does anybody have this piece laying around that i could buy?
- Looking for launch techniques from you 800+ whp 6psd guys!
- Melling 295
- Do I need a FPSS?
- APS TT, My turn
- Innovative WB Question??
- Procharger F1R for sale!
- Built 347+boost= What compresion to run on Pump 93?
- injectors
- 575-600 RWHP on a Nitrous filled Z is fuel an issue
- Maggie Bypass problem
- Anyone got a BOV sound video!
- Running kinda warm??
- Procharger special at SP Motorsports
- A&A "idiot" kit installed
- need help deciding on which setup
- Are these HP #'s right for my car?????
- Got bored popped in a New t6060, F3R, and two tone paint Job last night!
- Fuel pressure drops when Electric Cut-outs are open???
- launch controller location
- *** VETTE Magazine Shoot ***
- Most HP out of a Blown 346
- Need Help w/ "Quality" Nitrous Setup
- Whats everyone using for Base Fuel Pressure
- New C5 IRS 1/4 Mile Record Set !
- *A few upgrades to my Car*
- Hp?
- Dr. Phil...
- what blower cam to use with procharger p1?
- Which injectors for my blown 427
- Got bored popped in a new ysi from A@A last night
- Anyone here with a cerra single turbo setup??
- fuel pressure not rising with boost
- Nitrous Plate 78mm
- How Low Can You GO ? N20 LSX Eye Candy
- New Pics of the vette
- 500+ HP is just not enough anymore NOI??
- Took The Dive
- 98 wire harness same as 99-03?
- What are the advantages of having a meth kit installed with a supercharger setup??
- Calling all ppl with 600+rwhp on internally stock blocks
- How do I align a Novi 2000
- I'm putting this hear for my blown brothers!
- More or Less exhaust back pressure with forced induction?
- The limits of the old A&A stage II kit??
- Do I need an upgraded Fuel Pump to run a WET 100 Shot?
- Ran out of fuel pump on dyno spraying, help!
- D1 results with belt slip!!
- Procharged Z06 oveheating, not building enought boost
- APS TT not reaching set boost.....?? HELP!!!
- Max HP out of a Maggie?
- Anybody looking to upgrade to the TR6060 aka T6060?
- Question for those who use a YSi
- FS: A&A fuel system late 03 and up
- What fuel rails can I run with my PTK setup?
- Fuel Question
- need injectors
- 1 lb of boost enters the throttle body at what speed (mph)?
- 02 Z06, Maggie, Building a new engine need advice on size
- What Plus with 100 Wet Shot Nitorus?
- 427 ysi cam advise
- Guys running meth, please post up pics of nozzle/ IAT sensor location
- Procharger F2 Reversed rotation
- Need help with running bigger fuel lines (97/98 return style fuel system)
- a little advice please(head gaskets
- New mods what do you guys think, need advice
- Help no fuel pressure
- more nitrous shot
- DFCO on blown engine
- 1000HP 99' for sale
- Look what i got today
- ECS Blower Cam Installed!!!!
- Any FI guys have a spare Autometer 3220 light socket I can buy?
- What timing chain? I'm trying to decide between 3 chains.
- supercharged c5 transmission problem
- How to remove Novi head unit?
- WTB/old procharger parts!!
- Bottle mounting question
- GM parts
- No BS top end horsepower on stock LS-6--cent/roots/twin screw
- help with 8'' balancer
- Procharger Questions
- TTIX Forsale
- Hidden dry shot in stock air box (pics)
- where to buy silicone/rubber hose locally?
- Turbo c5
- Procharger ??
- Champion Intercooler Upgrade (TTiX ECS A&A)
- What compression will I be at?
- Callaway 606 Grandsport
- Big HP Centrifugal Guys: I Need Your Input
- •• American Racing Headers on Sale! ••
- Can I put a TT goat in here? PICS!!!
- Finally installed the nitrous through the 102MM throttle body!~ Pic inside!
- Flip Drive vs New A&A procharger bracket?
- WTB: 60lb injectors for my 02 Z06
- Looking for a used set of low mile 60 lb Mototrons
- FS: 91mm Garrett GT5533R
- 3" exhaust...do I need to make some changes to my tune?
- .::NEW House of Boost/Aeromotive Fuel System::.
- Something Evil is coming...
- Guys that are using an A&A external fuel system, please give me a hand!
- PTK help!!
- Methanol In New York Area?
- aps tt blowing oil? Black specks on rear bumper?
- Does forged internals help on stock compression engine?
- need help
- A&A Corvette Brings You: A Discussion About Belt Wear
- Anyone have an extra dongle lying around??
- Getting my Final Tune on April 17 with Arun !!!
- Anyone tried reverse truck manifolds for a twin turbo corvette?
- Flow Matched High Flow LSx Injectors
- Is a blower Cam really worth it!!!
- burning oil...question
- Fuel pressure to high
- Manley pistons for FI build?
- Tire Pressure ??? MT/ET 345/35/18
- Spec Twin Group Purchase mix up
- how much rwhp is a stock 07 c6 zo6 pump good for!!
