- TPE's New Twin Screw Kit makes almost 700rwhp!!
- Fuel System Problems
- 91 octane how much boost is safe?
- Need help with BOV / BPV on procharger setup
- *** Edelbrock E-Force LS3 Install Special [PICS] - Pre-Order your LS2 Now! ***
- A&A Vortech Meth Nozzle Location
- What do you FI guys think my TT car is worth?
- racetronix kit and maggie
- LS1 LS6 Crank Pin Kit
- Anyone cracked a flexplate?
- how much restriction is the procharger intercooler and associated ducting?
- what kind of spark advance are you guys running on stock bot end, w/ meth, 8psi
- Can you guys point me in the right direction on my fuel system.(Twin Pumps?)
- Vortec V-2 making bad noise!!
- c5 z06 aps blowing smoke
- Sad day today
- Need some turbo info from turbo experts!!!!!
- Electric ratchet
- How to wire RSI dual fuel pumps separately?
- ECS Novi 2000 Supercharger Install SALE!!! $62.99 INSTALLED
- TC Question/Problem
- More noise with smaller pulley ?
- High-Altitude Supercharging
- Traction woes...need advice
- Procharger D1SC Head Unit, A&A 8-Rib Bracket, Pulleys FS!
- help with NOS
- maxed at 650rwhp fuel system? what can i do?
- Thanks A&A for the great BOV
- Bubbas' 402 up and running !!!
- Protect your pump-----
- nos with supercharger
- Fuel not siphoning from second tank
- Question: Oil cap breather filter
- where do i mount my moroso breather can??
- Battery.
- Which heads??
- C5 High-Rise Cowl Hood
- Need 8 rib alternator pulley
- Question for anyone with an electric boost gauge
- Cammed maggie / REDLINE???
- FI on daily drivers
- HELP my supercharger just stopped !
- Who's car is this?
- Help me figure a rear mount turbo system out!
- F/S Blower Cam
- Judging interest on nx nitrous kit!
- How exactly do superchargers/turbos work?
- Removing TNT Nitro unit
- Part number for ARP head studs
- •► ► C6 A6 w/ 3.42s gets EDELBROCK E-FORCE @ CORVETTES of WESTCHESTER ◄ ◄•
- 346 and a YSI vs 402 and D1sc..who has more torque?
- how long is alky/ meth good for?
- ACI Cowl Induction Hood
- I want to buy some Nitto's but cant!!!!
- A/C evaporator inside an Intercooler?
- Is it necessary to o-ring the heads at 1k rwhp?
- Vengeance Racing | A&A Supercharging Sale!
- nitrous with 4 degrees in timing
- looking to forge stock 5.7 ... suggestions for parts?
- What Exhaust are you guys running...
- Apsis' Another PIECE OF ART WORK...Main Dash in Alcantara w/Red Stitching...must see
- E-Force for the LS1?
- Bad o2s?? Scan Pics attached
- *** St Jude Auction #40 Custom Dyno Tune C5 and C6 ***
- Torco
- It's going to be a GIRL!!
- STS twin turbo install
- EnglandGreen Twin Turbo C5 Z06 Install
- WTB F1A or F1c procharger, or YSI
- 6 rib and flipdrive...how small a pulley can i go
- boost gauge question
- Come ON!!! ECS HD bracket
- supercharger and nitrous
- My new Nitrous Outlet Direct Port
- help with alternator pulley
- F/S SuperCharger V1t trim
- What are the big cubes with high boost seeing for IAT using meth?
- Better fans for the c5???
- Has anyone upgraded to A & A new style procharger P1 bracket?
- New to the FI game
- Direct port ?
- A4 trans cooler
- still at it
- How hot is too hot for engine oil and coolant?
- Nitrous-Wet or Dry?
- I'm going to have an almost complete PTK kit for sale soon
- Overheating Problem
- Its been awhile...FI Porn....
- My ECS procharger kit, meth kit, gauges for sale.
- Anyone have a 3.125 8 rib Vortech Pulley for sale?
- Rod bolts?
- Laptop Stand
- FS - 3.75" 10 rib Reichard ProCharger Pulley
- finally some results! 10.5@141
- Anyone gear down their rear end?
- My 427 and YSi is at Virginia Speed for the final tune
- June 2010 C5 Specials - www.PartsTaxi.com
- How long will it last?
- ~~~ St Jude Auction # 39 "Get your motor runnin' ! " Cam Auction ~~
- Stock bottom procharger guys
- Car dealer lending me a 800 hp turbo car to test drive?
- APS burning Oil smell, no leaks, no smoke
- Xtreme News. Must Read!
- Hinson Carbon Fiber driveshaft install problems
- Forged 346 or 383???
- SC Install question
- Cruise Control and SC question
- STS Still Blowing oil???????
- Will having my vararam installed with my vrotech ruin the system
- Error codes after supercharger install
- • • > C5 VARARAMs INSTALLED at CORVETTES OF WESTCHESTER < • •
- Dirty Blow Off Valve Filter symptoms?
- Anyone need an LSX block?
- show pics of pillar guages
- blow off valves
- fuel system/pumps/busta pumps
- Some FS Threads of interest for the C5 FI Section
- L92 Heads and Intake question
- Max hp on 97-98 rails and lines
- Considering joining the FI club
- Will Mcleod street twin fit inside Quicktime bellhousing
- Anybody ever drill out the end of your meth nozzle
- Wiring Schematic for C5 Nitrous?
- Where did you guys mount your boost controllers??
- For Sale: Turbonetics 4" Silicone Hump Coupler
- Finally getting ready to go cruising!!!!!!
- If your just cruising, which burns more gas
- 4 inch dongle
- will an 8 inch overdrive pulley work well with a flip drive?
- Where is everyone mounting there FPR ( anywhere but off the rails)
- WTB:Aggressive Sounding Blower Cam
- * * TPE CAM SPECIAL * * Amazing Deals!!
- Fogger Plumbing
- Where to sell my old housings?
- Waiting for coatings...finished new traction mods.
- what are better for FI out of these two?
- 408 iron block plus procharger= to heavy for good handling?
- Crank case venting options
- Those with a NGK wide band
- Louder head unit after new A&A bracket?
- New Numbers
- Lingenfelter cams
- Fuel Problem
- YSI, FIC, F1A how loud at idle?
- Noise from SC?
- slight knock at idle should I worry?
- decoupling pulleys
- Do I need meth for this setup?
- Opinions on Toyo R888’s
- "Quick Spool" valve testing for STS kits?
- About to be boosted!!
- Wtb 01-04 zo6 exhaust manifolds
- Oil Weight Question
- forged 346
- Personal Best ( Thank To Dr Phil )
- A&A Set up.. How much power.
- L/f c5 turbo/supercharger.
- 408 , how much power?
- Belt tensioner bending/ breaking problem with newer A&A kit with an YSi
- Who has upgraded from Procharger bracket to A&A bracket w original dual IC system?
- cam 232/240 .595/.609 115 for turbo or supercharger?
- Low Vacuum?
- Quality Motorsports 25% off Labor Special!!!
- what fuel pump to use
- Anybody got a cam similiar to this?
- 08 Z06 TR6060, Diff conversion for the big F/I and Nitrous powered bunch
- My tips suck.
- Wanted: Stock C5 fan assembly
- dipstick on A&A v3-si
- This is why NOT to use 2 ply hosing on inlet..
- 83lb injectors @ 92% DC...what to look at next?
- Can a TTiX make 700+rwhp with a forged 346cid?
- Formula 1 does Austin
- Supercharge AND Turbo?
- Another how much power will I make thread :)
- Radical turbo cams. Who's gottem?
- I GOT BOOST! Had to cut hole in my trunk. Haha.
- SC/Turbo Turn Key price.
- CenterForce DF Power Range???
- How much does larger injectors change fuel consumption on the DIC?
- cam 226/228 58x/58x 114+4 in a 5.3 motor? good for turbo?
- FI power gain with LS2 intake & TB???
- CF safe Sunday Cruise!! {HD Vid}
- Meth and targeting A/F ratio's cont...
- Harmonic Balancer Ring Walked Forward - Seperated (Pics Inside)
- Nitrous help
- spec super twin SC66SST II
- Fuel Pressure problems
- FI pcv check valve
- Quick belt question
- ***A&A Supercharger kits INSTALLED AND TUNED FOR $6300.00/OTHER SALES ALSO!!!!***
- Lots of Blower related Parts for Sale
- Flip Drive + iron block. How many have done this?
- Torque convertor
- Direct Port nitrous solenoids & relay question
- WTB 8 rib KB supercharger pulley
- Low RWHP Numbers
- Motor and YSI Install
- LS2 Throttle body for Kenne Bell
- EFI Live ?S
- Something so simple....
- Initial Tune for an A&A install?
- 2004+ Fuel Pump Question for FI
- Need a Vortech V-1 Rebuild
- Hood alternatives (with pictures) for top mounted blowers?
- Heads up on a great sc and supporting mods for sale
- Chrome Alternator w/SC
- WTB:The "NEW" Style A&A Bracket for Procharger
- I'm so bored........
- Best way to get SC belt on?
- 2.5" smooth idler
- Big power difference going from 9.5 AFR to 10.5??
- Big Thanks to Scott, aka a/c man
- Thinking of taking advantage of my forged motor
- How well would a Maggie or Twin Screw work with this cam?
- Turbo Car Price? Let me know!
- A&A Vortech install question
- Another TTI X in the 9's on PUMP GAS (+ Meth)!
- Under versus Over drive balancers
- Turn Battery gauge into boost gauge?
- patriot vs world products
- 160 MPH Speedo shot on Runway... {Video}
- Finally getting Blown
- MSD Timing twister install, need help on wiring?
- STS question
- 98 single turbo c5
- * S A L E * 60lb & 80lb Injectors In Stock & Ready to Ship Immediately *
- **etmc a&a kit installed sale!$$6300****
- Loud Exhaust and your phone...
- ***EnglandGreen Entry Level Mod Specials Through June 30, 2010***
- what same cam works great for turbo and supercharger?
- Gear choice for auto w/a&a kit
- my Tigershark custom front air dam
- Ruh Roh....Wife says she did something to my car.
- Procharger terrible service?
- newbie question
- Problem with boost and power on ECS D1SC kit
- My Ysi horror stories
- FS-Brand New--Latest generation Flip Drive
- How many of you are running a Meziere?
- clutch problem
- class timel, bar is the question???
- Pulley swap on an A and A new bracket
- Need help with tire calculation for MPH
- Mike04's old kit back to life!
- C5 HSW WET KIT Install pic's
- Meth: IDC referenced? Eaton Blower Problems?
- Tvs 2300
- Need a reliable vendor!!!!!!
- External fuel pump ?
