- NOS Pro Shot Fogger
- Advice on supercharger relative to stock drivetrain
- Strait M1 Methanol vs. Methanol Water Mix
- Having problem with BAP
- Which nitrous kit is right for me?
- **Vette Doctors-ARH complete Exhaust System $1,995 Installed and Dyno Tuned!!**
- Vette Doctors End of Summer Special-Vortech Supercharger $6,599 Installed and Tuned!
- >>>> St Jude Auction #53 MSD 8.5mm Superconductor wires w/ WeaponX Iridium Plugs <<<
- building a lsx block with lsx heads 427
- My sqirming belt.
- best drag radial for a 800hp plus
- Rear mount turbo with roots type charger? Possible???
- fighting fuel pump prob
- Special big thanks to Rob and the boys at Champion Motors!
- New fuel option?
- Finally hit the dyno not to happy!
- vortech v1 t-trim
- vortech rebuild needed
- Triple disk lockup converter - Twin turbo A4
- Edelbrock E-Force Supercharger
- putin nos on what kind of gear to run?
- Blown C5 Repeatedly Throwing Codes
- Slave cylinder?
- High HP Guys Looking for Auto Swap Look Here!!!
- BIG fuel system guys (and i mean HUGE)
- PTK guys quick question
- BLOWNBLUEZ06 - Big thanks!
- WTB: anyone have a 4.10 Procharger P1SC pulley for sale?
- ATI damper?
- MSD vs. Ken Belle
- ECS Fuel System w/ MSD BAP
- Electric Supercharger
- Finally Got Dyno Sheet from A&A V3 install
- Plate Kit Solenoid Locations
- Oil spout breather.
- ***FS RSD Snap Shifter***
- selling my hsw nitrous system
- More power wanted: Better flowing heads OR larger blower??
- FREE INSTALL & DYNOTUNE in NC on ANY ProCharger Kit for C5 Vette by Tick Performance
- trans cooler fan
- Finally going to pulley down, questions :)
- KB Blower with EG Insanity Cam
- Want to forge the bottom end.
- Gorillavette pics in here!!!
- Dry shot on bolt on Z06
- How safe is nitrous?
- Kenne Bell install pics
- ARP Head studs too long
- 402ci & V7 JT (almost done)
- I just ordered my A&A S/C any tips
- Exhaust fumes in cabin.
- AEM wideband installers ?
- It Lives
- stock c5 dry kit install help
- Need A&A Installation Instructions
- •► ► CHUCK CoW gives you CASH @ CARLISLE!!! ◄ ◄•
- nitrous... where are your switches?
- WTB: 3.4 or similar size pulley for vortech v-2 A&A kit
- Another what will it make thread
- What plug wires?
- Short HD Video: 853 RWHP Dyno Pull!
- •► ► THE OFFICIAL TUNER OF 2010 CORVETTES @ CARLISLE is CORVETTES OF WESTCHESTER ◄ ◄•
- New GMPP valve covers
- Capability of A&A V2 S-trim kit
- kenne bell hood
- P1sc, which pulley for 6 psi on a stock LS6??
- Fuel System for 600-650rwhp on Nitrous
- My 427-F2 Build Underway...
- building a motor iron block lsx or aluminum ls motors
- What is a "blower cam"
- Meling high volume pump
- Got a Stock Block? Got a Procharger? Well then step inside!
- Quick Fuel Pump Relay Question
- Participants????Guess the power thread
- RSI fuel system pictures needed...
- aluminum tube fabrication
- Funny Vid for my FI boys :)
- Need help diagnosing fuel pressure drop
- FS: ECS external fuel pump adapter ring
- Halltech Ram Air Tunnel Ports (Fiberglass) On Sale!
- hinson single turbo
- Speed Inc./ Nitrous Outlet 10% off sale!!
- FS- A&A Turbosmart Blow Off Valve
- Going to a smaller pulley, any concerns?
- what air filter upgrade
- I have an extra ABS pump bracket for sale for a PTK kit/e-bay kit
- Upgrading my fuel lines
- Where to buy ATI pulleys?
- Dyno guru's...I have a question
- Looking for a high capacity Meth. filter
- BIG RED Pics & Article
- 60-130 mph list: please post your results here
- need motor asap
- another how much boost will it make
- For those of you with water/meth....
- Changed the oil in my V3 today. There wasen't much oil in it. WTF
- A&A BOV sound changed all of the sudden. Is something wrong?
- Head gasket choices??
- What fuel pump do I have?
- F/s light oak lloyd mats/stock t/b
- Procharger kit with extras $3,500
- Hot running 99 twin turbo (high coolant temps)
- Can I still use my 97-98 PCM for 402YSI ?????
- New Turbos On The Way........
- I want to upgrade my 03+ A&A fuel system...
- It's Hotter Than July A&A Corvette Superchargers Installation Sale
- 160 MPH Runawy sighting pass! {boost/fuel gage & speedo/rpm}
- Cartek 347 forged motor and F1A Procharger
- Question about blower cams..
- RSI Twin Fuel Pump-Whine
- Anouncement
- throws off belt with supercharger and smokes clutch, what to do?
- Wooo Hooo check it out!!!!!!!
- Back to stock
- Motron Injectors
- Nitrous and stock fuel pump
- Methonal color
- Wideband O2 death
- maggie + nos
- Emissions for a turbo car
- A&A Upgraded Fuel System for Sale with pics
- LG's Pro headers life span?
- Pinning an Innovators West OD balancer
- EASTCOAST PERFORMANCE has Snow Performance Water/Methanol Injection Kits on SPECIAL!
- Where to tap in for oil supply on my single turbo kit?
- Some great fi deals fs
- It Probably Won't Happen, But...
- ***Congratulations Mike (STEALTH 99 C5) for getting his 1,000-horse Cartek FRC in Vet
- FS/T: RPM 4L65 Conversion - Procharger F1C Kit - A&A Fuel System
- ***ACT Clutch Sale - 10% Off and Free Shipping!***
- Oveheating after F/I - again thread
- Clutch?
- FI Engine Sale Gone Bad - Bad Transaction with Jeffrey Burke AKA LB or xLBx
- Upgraded A&A Fuel System for Sale
- Whose water/meth kit should I purchase?
- RSI Fuel System _ Install Instructions/Diagram
- Wondering who people are taking there higher hp cars to for tuning
- Vids twin turbo lsx
- NEW 1/4 Mile Record - Corvette With IRS - Keith Berry
- New A&A install
- ECS P1SC + Alky + EnglandGreen Results
- New Meats
- Too much meth - what did I break?
- HELP, threw a connecting rod through oil pan
- ttix passenger side manifold question
- 9.75 comp. good gas, still get knock randomly
- 1st Start Up of my new 383 D1
- C5 LSX Twin Turbo photo shoot
- PLX boost/vacuum and AFR sensors
- True CAIs w/ FI setups.
- Peter pan
- What setup will best suit my driving style?
- Oil leak after supercharger install
- Looking for info on this flooded 03 Z06 w/ Kenne Bell in TX
- Vortec v9 from fbody
- Short Idle w/ No belts - issues?
- Going From N/A to F/I
- whats the best 402 ls2 boost piston?
- Kenne Bell blower systems??
- Good Tune
- Best heads for boost on a budget??
- WTB-Tial Q
- U/D puelly
- centrifugal vs. Roots type Supercharger?
- Does anyone build and sell just the hotside for our C5's????
- Oil Cooler???
- New Digital Fuel pressure and Boost gauge with memory for sell
- is a P1sc standard rotation?
- I need Magnavolt schematic.
- Would this work for a rear mount?
- Hot Day + Maggie Temps and pressures?
- New Toys A Comming
- WTB:P1SC,D1SC or F1A Head Unit Only
- Running hot with SC
- stock c5 on a 100 shot.
- Need turbo/wastegate work done in South Carolina
- Fuel system
- Anyone sell a kit for mounting the IAT in a rubber coupler??
- Which Cam ?
- Dyno numbers 798WHP/805WTQ
- Need Innovative West Balancer
- Twin turbo
- misfire on 150 shot
- coil relocation and valve covers
- Meth needed for this boost/compression combo?
- FI Gurus Step Inside
- WTB: Billet Oil Cap w/10an bung
- Thinking about selling my YSI kit....
- Weekend Carnage
- Non Corvette, but GM turbo results
- Another Great Job From Mike and Charles
- Big HP Needs Balancer Which One???
- New Intake Charge Pipe and Recent Engine Bay Upgrades
- Maggie IC reverse flow?
- Were To Put Fuel Cooler
- NX Dual Nozzle, want to go to a Plate, Help! Pics inside
- Fiber-Tuned Intake
- Grond Resurrection???
- What next? I need help with next mods.
- Nitrous??? need details please
- ECS Novi2000 on a LME 440?'s
- ECS Maggie tensioner vs 8 rib
- Looking for options, Tail BOV makes too much noise at lower rpms around town
- supercharged e85 vette: lean spikes on throttle change, weird MAP, PICS
- 800rwhp C5 ZO6 , 640rwhp C6 ZO6 , 640rwhp ZX300 dyno
- racetronics fuel pump good enough?
- TPE in now on Facebook
- ECS A/C Tensioner Issue (w/ Resolution)
- How hard is it to install meth injec on a c5??
- E85 fuel system for 1000+ at the crank?
- Nitrous w/ Automatic 02 Vette
- problem with 90mm tb/92mm fast and a&a kit
- Damaged Idler pulley
- Need 3Bar Offset Values
- MSD BAP, LPE Fuel pump, Racetronix harness for sale
- Oil Temps With Turbos
- Nicely edited HD Track vid: Car sounds & 2 views...
- Methanol MPG
- Flow Matched High Flow LSx Injectors Available
- MAF or SD? PTK twin turbo 346
- What belt size for Procharger w 3.85 and A&A's latest bracket?
- Whats the belt number for the org vortech system for the c5.. the surp. belt.
- Fuel pressure at boost
- Question about Procharger Kit, PICs inside!
- Turbos and Exhaust
- Need Help With Boost PID
- Car stalls/dies after shift with P1SC - Need Help!
- BOV with Turbos
- NX maf kit
- Rps clutch
- Question for BIG HP guys with A4s
- Help with picking a good cooling system
- Whats better for a boosted 347 ? L92/LS3 or 317 heads??
- Gauge Pillar Pod for Sale!!!
- Guys with YSI step in
- FS- 3.250 A&A pulley
- Dyno results going from a LS1 to LS6 intake?
- STS Mufflers - Pics available
- WTB Procharger 6-rib 3.0
- proper turbo size question
- FS: Gates belt laser alignment tool
- FS- PS and Alt Idler 8 rib
- Contacting Vortech
- C5 Maggie issue
- Nitrous question...
- Need HPT PID For MEth
- HI Def Supercharged Roadcourse Video!
- Boosted head choice ??
- delete
- TPE's NEW Remote Clutch Bleeder kit (The best on the market!!)
