- ATI Cog setup
- FS: Vortech Cog pulleys
- Question for my PTK brothers
- The new inlet showed up today.
- Tick Performance Corvette ProCharger BLOWOUT: Installed AND Tuned @ $500 Off Retail!
- New ECS Novi on the way!......Have some questions??????
- Injector Dynamics GM LS3-LS7-L76-L92-L99 Engines
- Wastegate question
- Mcleod RXT Twin Disk
- ? About AFR 205's & Boost
- Plug wires touching headers
- Cheapest 17" rim for drag radials?
- need suggestion or .02
- PVC solution for Boosted Motors
- F/S Procharger P1SC-1
- Adding nitrous to a 98 A4 w/ 72000 miles
- WTB items for ECS Novi kit
- LS2 Intake 4Sale Houston
- Blower cam recommendations.
- LSXTV.COM build
- Concern about my motor build 317 heads on a ls6 with 5.7 gaskets
- Any after-market fuel rail setups still accept stock fuel rail covers???
- Areomotive, single pump drop-in fuel system w/ Eliminator pump; Whose using it?!?!?
- Pictures of joe's f3r procharger
- Texas Mile March 2011, who's going ???
- Check this gauge setup out!
- LS3/A6 with A&A Si-Trim goes 9.75 at 139mph
- So what is the current known 1/8 and 1/4 mile record for Si trim S/C on a vette?
- FI with big cube 440ci
- Why so little news on the Hinson turbo kit?
- Erl engines, anyone use them
- Wet or Dry?
- how many are using a trans brace?
- Drive line upgrades?
- Post build thread
- F/S 317 ls heads good for boost!!! 400.00 obo!!
- Anybody need some headers 1 7/8 arh
- Dss stub shafts get stronger!!!
- Blower cam
- stock LS1 w/spray
- Intercooler Dimensions
- Centri Blower Step Up Ratio's
- A&A KIT install advice
- Has anyone read Hot Rod lately.
- New to FI, need help
- Any STS kits for sale?
- sneak peak at what i have been building over the past 10 months
- Supercharger help
- ACT Single Disc Street Clutch Anyone?
- Research before going FI
- ***A&A supercahrger kits TAX TIME SALE at ETMC***
- "shady's" East Texas Muscle Cars STG 6 BUILD
- 4.5 pulley...hiw much boost??
- ****UPP's AFFORDABLE Twin Turbo Kit!!!***
- Kenne Bell Boost a pump question
- Vortech V3 A&A setup questions??
- Turbo AR?
- Another Gauge Question?
- What changes to the Maggie since 2005?
- What SC do I go with???
- Then what kind of boost without meth??....
- Edelbrock Superchargers
- Which size headers for AA SC kit
- Oil Breather
- gauges
- Alright guys I'm all in...Here's what I got...What can I make and any recommendations
- Got boost!!!
- rebuilding Vortech V-2 SQ Si-Trim torque for the impeller
- HELP with Blower
- Champion Motors TTIX 3" Downpipe Upgrade
- nitrous progressive controller
- testing of blow off valve?
- cam and header options
- ashtray pannel
- Procharger Head Unit removal: Whats needed
- get this guys
- Could i reach my goal at only 8psi ...
- Ecs stock c5 460 whp on mustang dyno 8psi
- FS: ECS Breather Oil Cap
- ***RSD Line Loc***
- Racetronix kit + pump booster how far can i go?
- PCV Idea w/o breather
- Higher boost without liquid cooling injection?
- 600 RWHP or bust
- ECS/Julio ALKY CONTROL non windshield reservoir tank options?
- Tx2k11
- H/C be converted to S/C?
- Any clearance issue with(A&A v3-si) and TCI damper
- T-trim upgrade worth it ?
- STS intercooler inlet size?
- For FI guys with true CAI systems: Keep those air filters clean
- Help guys. please educate me on some things. about supercharger.
- Halltech saves another 1.36 lbs on the wheels (unsprung weight)
- Anyone know where I can buy a V band T4 exhaust housing?
- Any Blackberry users here?
- Need advice guys on your hood
- Got car back from dyno
- Motor Build Advise Needed?
- Seafoam in intake?
- Crankcase Ventilation
- best place to buy meth kit?
- racetronix fuel pump hotwire harness need
- Need Wiring Diagram ( EXA Pump )
- Question for the STS TT guys...
- nitrous
- Impeller Speed V3-Si
- Fuel Pump Question
- Anyone upgraded to an 8 rib setup...
- Does flip drive replce idler ?
- TT people, who runs the Borla straight pipes
- Anyone done a cam AFTER going FI?
- best pump ??
- vortech or procharger, which one is more reliable?
- Best nitrous setup 03 ZO6?
- Finally pictures of Mo's 2004 Z06 APS TT
- Edelbrock charger in C5..??
- Fouled plugs
- Discontinued Item-Last change to buy!!!
- Going to Get a SuperCharger And...
- *** HPE Flip-Drive Now $789 + FREE SHIPPING!!! For 2011***
- Please Post a Pic of Your Blower!
- Off To The Dyno Monday!!!
- GTO procharger on a C5?
- Which Fuel pump?
- Help with procharger project!
- ECS Idler pulleys needed..Anyone got some??
- Novi 2500-more info
- Big Dawgs Locater
- Finally making the upgrade. D1SC ----> F1A! Which pulley combo??
- Procharger setup...what am I missing?
- When do I need polyurethane couplings?
- Nitrous Experts: Wiring diagram needed.
- Kenne Bell on '97 - fuel rail issues w/ return?
- Help with twin turbo question....
- FI on Stock-Block club.
- HELP! I need fuel!
- Old STS oil pump VS Turbo Werx pump
- Cracks in torque tube housing welds WT....
- ETMC AUTO CAR over 900 HP through an AUTO, on 16 psi WITH A&A KIT
- Ordered Turbo kit
- New Year Special A&A Supercharger kits $6250 installed and tuned!!!!!
- Help! slp 55002 timing set and oil pump fit
- Boost A Pump ?
- ECS Radiator Cradle
- New forged Wiseco pistons, Garrett turbos & other Turbo Parts FS
- Hennessy Venom GT
- dyno tune tommorow new #s soon
- What the heck?
- 2.6 Kenne Bell Up For Sale
- What are A/F and Boost gauge "normal" levels?
- Which cam should I go with?
- Anyone Need Fuel? RSI Hangar up for sale...
- KB Blower and IAT Solution???
- I was bored so I decided to change a little bit
- New Years Resolution
- Last chance to get in on the sale.
- Forged 402 and an SI
- I finally got to see & drive my APS TT car !!
- How much boost can a stock motor handle?
- fuel upgrade quick questions
- Any reason NOT to have an SD tune compared to a MAF tune??????
- forged 383, A&A system question
- F1R guys please step in...
- Alkycontrol adjustment knob, where are people mounting?
- Gonna be joining the FI crowd soon~
- Texas Mile C5 what Hp to run 200+??
- Potential Belt Problems
- E85
- PCM calibration
- 3.4 or 3.6 Pulley for V-3 Si-Trim & stock LS1
- Desinstall a C5 a&a kit to fix on C6
- Using supercharged C5 on track
- Using supercharged C5 on drag strip
- V-3 Si-Trim for LS1 ?
- What weight flywheel are you guys using? (for street cars)
- WTB: Factory Zr1 cam and or LPE GT9 Cam
- comp cam questions
- Best supercharger for a C5?
- Who makes upgraded turbos for a C5 aps kit
- Anybody seen these kits?
- Boost drop when switching to headers?
- where to mount the mondo bov & flange on the ecs kit?
- new clutch, lots of chatter,shudder.
- FS: Comp Cams Fi Cam
- Pisc procharger upgrade?
- Ever see a Corvette Burn?
- 3.85" 8-rib Reichard Racing ultra grip pulley FS
- Heading Out For The Final Puzzle Piece
- A&A on the way! I can't wait, but what should I do for a ..............
- Question about Maggie and nitrous
- New 2-70mm/68ar turbos 4-sale
- Quick clip under boost - twin rear mount
- Procharger D1SC Headunit FS
- RPM trans
- High Fuel Pressure?
- Kenne Bell LS6 Tuner Kit - Need Info
- eBoost 2.Two solenoids or one?
- AEM wideband
- Wolfe Racecraft roll-bar owners, step inside
- Any A&A install deals in Florida?
- Best way to increase boost on APS TT ???
- RPM Transmission
- power trip again
- Boost and Fuel Gauge! Do I NEED this on my Car?
- Merry Christmas
- Merry Christmas
- To my F/I bretheren and forum Moderators
- finally made the 900rwhp club!!!!!!!!!
- Re-build motor or new motor?
- Merry Christmas from RSD
- Who running a Hp Performance TT kit???
- •► ► MERRY CHRISTMAS & HAPPY HOLIDAYS from CHUCK CoW & CORVETTES of WESTCHESTER ◄ ◄•
- Boost vs. IAT
- Is this the correct Alchy conrol system everyone seems to be using?
- Anyone Know This Guy
- Kb bap install
- Merry Christmas From HPS!!
- nano nitrous guys chime in
- OH KNOW, just ordered my A&A 3.4
- A&A Install special!!!
- •► ► CHUCK CoW TUNING in CORAL SPRINGS, FLORIDA - JANUARY 13th - 15th ◄ ◄•
- Boost By Gear for Centri Supercharged cars - you wanted it, here it is!
- Turbo Choice
- Has anyone here sucessfully run their fuel crossover in the rear?
- Borg Warner VTG turbos
- best meth kit!
- How much rwhp can my fuel support?
- Who Uses Breathers?
- Curious mind
- Valve Cover options
- TTIX Improve Heat mgmt
- A lil bit different type of build
- X-mas presents for your car ??
- Excited to go on SPRAY!!!
- backpressure - Would big wastegates help?
- Selling the Novi kit
- When is it enough?
- Kooks Custom Headers | Stainless Works SALE
- Looking for an APS High Output Exhaust 04Z
- next mod
- Looking to get more mid-range boost without more top end boost?
- LMR Reality Show #10
- FS: Procharger D1SC Head Unit
- cleckchaum's new toy and winter project
- best fuel pump?? Walbro 255? or??
- edcmat-l1 from VA speed.....
- fuel system question
- WELL... not my clutch...
- Numbers
- LG Big 3 exhaust for TT people. MOPOWER ?
