- 90 vert
- how do i extend my spark table to 6400rpm $6E
- ***** For sale is HP Tuners VCM Suite version 2.1.18
- New guy inhireted my Dads 1987 L98
- Jet DST
- Just joined today
- Fast ez efi
- Straight Up Question re: tuning a LT 1 6 speed
- Tuner expert wanted $$ dyno tune even better
- Shift Indicator & 1-4 skip shift
- Code 43 on my 85 Corvette
- Vette Doctors Performance New Years message
- IAT/CTS table in Tunerpro
- Basic questions re: datalog cables - OBD1
- Tuning question
- Error: FLASH Memory Checksum Error
- 90 ZR-1 dead cylinder Injector not spraying
- Rev Limiter Question
- ALDL not reading on 90 coupe
- Cheapest LT1 Tuning Software?
- Advice for Burning 85 Chip
- Tuner RT learn control disabled?
- I-pad for tuning
- Tuning Advice
- 355 ci Rich Getting Richer
- 95 LT1 vette DataMaster File help
- Engine choice
- Accel DFI user/ tuners take a look...
- Car runs rough 2000+ rpm
- LT1 PCM Tuning?
- ECM $8D and UpShift dash light
- Android?
- Best tuning computer with parallel and serial?
- dyno shaft
- 84 ECU...What can be done?
- BLM Datalog Readings
- Chip for L98 1991
- 1986 Tune or New Chip
- TunerPro RT Suddenly Not Working?
- Hypertech Power Tuning Module
- AIC replacement
- got my tuner cat today...
- 383 throttle follower issue
- anybody use a OTC4000e scanner?
- Datamaster EGR values
- 95 OBD reader
- Ed Fast Chips
- Do I Need a New Prom?
- Tuning a 1985 ECM
- Advice on EGR valve disconnected and dreaded check engine light
- new motor not starting
- Request: BUB Stock Bin (86 4+3)
- 383 Stroker Logfile!
- Corvette 383 Stroker misfiring like crazy!
- tuner pro, Spark Adv. Rel. to TDC
- 1994 LT-1 surging and sputtering at cruising speeds
- Need a tuner & or chip burner Central FL.
- Di-Electric Grease on Fuel Injectors?
- Car is now bucking
- Whats the biggest bang for my buck on 84 crossfire?
- LT1 Painless Wiring fuse block power
- worn distributor gear
- DFI with Calmap 6.32 vs TunerPro RT 5
- maf
- 87 tpi flooding on right bank
- TPI with HSR...PROM Programming?
- Does anyone have a stock BIN file for a 90 Auto ECM?
- knuckle buster "92"
- Need help with a possible failing ECM or PROM
- HELP Prom for 1990 Corvette
- 89 tune port. idles high then low?
- Pulled 1st Datamaster File 1995 Code H44
- Tps low volts
- Bosch 3 Injectors longer crank times
- 1995 Code H44
- Does any website sell a good PROM chip?
- Please help check my conversion harness pins (1985 to MAP)
- sys,alert
- reduced fuel pressure but a/f ratio gets richer
- What it looks like when the opti dies?!?!?!
- accel delta tps, for a 58mm Tb how to tune?
- $1F parameters-what do they mean?
- Lower pressure injectors or tune with stock???
- Slightly High Idle and Strong Gas Smell from Exhaust
- '86/'89 Memcal Help Needed
- Mods on 86 need new chip Help
- ODB11 scan software
- software
- Bosch III'S Reprogramed/wrong tune advise
- PDX tuners
- Won't stay running on a cold start
- Stalling w/new rebuilt engine
- Need help blown water pump
- Hiiiizzzaaahhhh i finally figured out how to do it!!!!
- why wont tunerpro read this memcal? (pics inside..)
- 87 ecm questions.....
- ALDL connectvity problem
- How Does the ECM Shut Itself Off?
- so how exactly do i read what is on my computer's pcm now?
- Tuners in Eastern PA
- Would someone analize this bin for me please?
- questions on tuning - what's up with my datamaster! ? and tunerpro... too
- tuner pro rt... can i use this def file for my car?
- Engine dies while coasting
- xdf
- Do these numbers look OK?
- 1991 high idle
- HELP. DELTEQ with LM1 rpm converter cable and inductive clamp
- 93 vette into Jeep
- @@@ St Jude Auction #76 Case of Royal Purple and a K&N Filter @@@
- New Differential Gears, need new Set-Up
- does this tool burn proms? I am at the point now roughly I have to tune it....
- Hard Start
- Can I change my Oxygen Sensor B Voltage readings?
- anyone heard of extreme motorsports in tempe, az?
- LED Gauges not working
- holley fi
- New or reprogrammed 94 PROM needed.....
- Wanted anyone in CInci will help me tune
- Accel DFI Calmap for Windows 7
- Tech 1 data advice needed on these settings
- LT1 cold start idle tuning
- Diacom with Win XP?
- Who's running a Accel DFI Gen 7?
- 89 L98 Idle issues
- No "Fuel Enable" signal from CCM
- Lean O2 code with BLM 122 at idle
- ??Pulled engine codes tonight
- idle and timing
- painless wire harness to remove vats system completely
- Wideband AFR in Datamaster(or anything for that matter)
- Corupt or hosed shift tables / 1994+ L460E
- about to work on a 1984
- heated o2 sensor help
- anybody know how if there is a table for spark retard vs. IAT - 93 lt1?
- Dyno Tune needed 87 388 Stroker
- BPW and SA Calculations ($32B)
- the wife ride just got home
- LT1 tuning question
- Is this an OBDI or OBDII port?
- New prom, no code 12.
- Question on HP increase with a dyno tune
- Need advice on a new chip..
- Tuning L98 to get the BLM's in the safe range
- this just dawned on me I have a laptop now, how do I tune my chips myself?
- 1992 383 built Tuner Cat or Stand Alone
- bad off-idle stumble, almost dies -96 LT4
- Need Chip And Scan Device
- Newb F.A.S.T questions
- What do you do when you get codes 41 and 72?
- 1967 c4
- 1990 Fuel Gauge LEDs Stick
- Datamaster TTS - and spark retard. shows a weird number? see pic
- shift points on a 96 lt1
- OBD II datalogging options?
- Diacom Software Download
- Stalling out / smell of fuel
- New to scanning -- Link to first scans
- Idle Problem
- 95 LT1 Piggyback Engine Management Options
- Need Help with Tuner Kit Selection
- BAD Ecm?
- Code 24 - Hypertech Related?
- Dump Contents of MCU in P4 ECM?
- 1994-c4 autumatic need help throttle cable
- Could this be a Fuel injector problem?
- Tunercat issue
- Still getting idle smoke until engine is fully warmed up.
- please help with your knowledge
- Ecm problems 93 lt1
- 94 Scan Equipment
- 32B Extended TunerPro definition file.
- Intermittent changes to AE at WOT
- tune on 87 to reduce no cat smell
- I'm having trouble understanding desired AFR's especially with E10
- which chip?
- Help please non starter please
- 88 year: thoughts on a stroked 427 small block?
- % Change to AFR vs. RPM in Power Enrich
- Fiddle with the MAF tables, or injector constant more?
- $32B BLM Cell Boundary addresses?
- 1994 (vin p) Need help and can give help
- DFW tuner?
- Anyone up for some 870 questions?
- 96 CE LT1...Please Help !!
- Tech 1 advice needed
- What is everyone using
- dyno runs and AFR
- radio change
- BLM Cell question...
- Pick your Wdeband O2 sensor. Thanks
- Failed Emmissions Test?
- Can timing be changed on LT4?
- 84-89 Digi Dash solutions.
- simple tune up question
- Cold engine dies when backing up.
- Rich at idle, but BLMs are >128.
- Tuning my 396 Super Ram
- stalls on right turns
- Theft Deterrent Mode on C4
- Where is the EST wire?
- Tuning a NA 383 with aftermarket ECU
- what does this do?
- Spark Plug suitability
- custom 1989 stalls when P/N to D
- BLM reset? After changing Tune?
- Has anyone here ever
- 1988 c4 first scan
- What to use
- Convert from $32B to $6E, or attempt to backport $6E to $32B?
- Good OBD2 Code Reader
- How accurate is this reading?
- Need stock ABTD Bin file
- CCM Code issues
- What am I over looking?
- Datamaster no-pcm sync 1993 LT1
- Where to start out on diag/tuning,95 vette
- First chip burn - some success / some questions
- What fuel injectors should I get?
- ECM tuning equipment
- OBD1 equivalent product like DashDaq
- tuners near chicago,IL
- 96 lt1
- Does the TunerProRT 6E mask has an error for Open Loop Fueling?
- Evaporator Purge Canister
- Any real difference in ARAP vs AYPY bin?
- Datamaster time out or mpg switch interaction?
- Tuning out EGR on L98
- WinALDL & TunerPro ????
- Question on timing and Datamaster..WW
- 96 LT-4 Dyno Results
- 305 vs 350 TPI: Whats the difference?
- What's under the carpet ?
- Ease Diagnostics PC Scan Tool
- TTS Datamaster question
- trouble codes
- Scanning software for 90 1227730
- Running Rich / Clogged Cat's
- Any Tunerpro Rt Gurus out there?
- 1996 PCM - Help - (Please read)
- Too Much Cleaner ?? Erratic IgnitionTiming Please Help
- Suggestions for Irratic idle below 50 deg?
- Datamaster disconects every 6 seconds
- Fuel pump run without memcal?
- How to read datamaster data?
- In search of
- In search of
- WTB ADL cable for 92 Vette LT-1
- Timing jumps, normal?
- does anyone know of any tune software, for 92-93 lt1, which allows ind cylinder fuel
