View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. PROM Failure 9-09-07
  2. Hardware location for emmulating - What's best?
  3. Tuner Pro showing different values than Tuner Cat?
  4. Hypertech III and LT-4
  5. Problems Flashing OBD-I
  6. Need 94 Codes Decrypted
  7. lil help please
  8. Estimate my new horsepower and torque
  9. 5Y5 code???
  10. Picture of ALDL connector 1994
  11. Anyone have a picture of a stock 7727 ECM?
  12. Traction Control Again? ASR tables TunerCat
  13. TunerCat ASR/Traction control tables?
  14. emissions help
  15. help w/ tunercat and cable
  16. Help me understand this Datamaster Scan
  17. O2 Closed Loop - Unsolved Problem
  18. DataMaster 3.5.1 Compatible with 86 Vette?
  19. I Need Help w/TSS Datamaster
  20. Chip, ECM, both or neither? Weird problems this morning
  21. That pesky ECM issue ASR Check Engine
  22. Anyone know if 'Instrument Panel VSS Pulse Divisor' will correct speedo on a chip car
  23. HELP!!! Car hasn't started in almost two months!
  24. Firmer Shifts?
  25. LT1 Problem
  26. Is There a Way to Adjust Display MPG Using Using Lt1-Edit on a 95 Coupe?
  27. % A/F change at WOT
  28. Looking for stock 1991, M6 BIN file
  29. "Power enrich. Spark Advance" Basic question
  30. Screen shot of changes that added 31 RWHP and 50 RWTQ
  31. USB to Serial Adapter and Datamaster
  32. 95 LT1 running rich
  33. Bosch 30# in a LT1?
  34. How can i remove engine harness?
  35. newbie Hypertech question
  36. Quick injector setup question
  37. Need ScanMaster help
  38. CODE 36 review
  39. Multec Injectors for my 91 vette (GM product ?)
  40. find code with a paperclip
  41. 1992 code 36(faulty high res signal)msd opti; help
  42. Exhaust pops - will timing tune that out?
  43. 1991 outside window seal
  44. Need an .xdf file for a 92 Vette
  45. newbie asking about hypertech
  46. to chip or not to chip
  47. FI engine management
  48. Hypertech on Another Car?
  49. Check engine light
  50. your thoughts ... idle / IAC / TPS
  51. LT4 with Hotcam tune
  52. Rich Idle and VE Tables
  53. 95 3rd O2 sensor - Passenger side
  54. New chip reprogram required?
  55. re: datamaster question ?
  56. LT1 Datamaster Question
  57. 85 Check Engine Light HELP
  58. Is there a way to upload a flash tune for a 94 using tunerpro?
  59. High idle '96 LT1 104k miles
  60. Accel Wideband Datalogger
  61. C4 Tuner in S.E. Michigan
  62. VEmaster, how much of a file needed?
  63. Looking for a code scanner for '94 LT1
  64. rear of car steering?
  65. Good thing I'm Patient
  66. Can't enjoy '93 yet
  67. headers and cat
  68. Ignition wire change
  69. opinions on chip programming businesses
  70. Direction and help needed with tuning
  71. Bad fuel odor
  72. 94/95 .bin Disassembly
  73. 86 Radiator fan problem (help please)
  74. throttle stuck
  75. Dealing With Cam Overlap
  76. fans not working
  77. Finished LT1 intake conversion need advise
  78. Codes: C or H
  79. total timing
  80. FORD SVO 30# Injector Constants number in LT1
  81. VE & Timing table past 5600
  82. Tips for programming a rich idle
  83. help with 1227727 ECM
  84. Going to use LM1 wideband with no rpm converter.
  85. DataMaster?
  86. Let the Fun begin! 92 383 LT4, Vortech Ysi trim
  87. What years interchange?
  88. Scannerpro finally something that’s work on 90 Corvette!
  89. Check Engine Light while Highway Cruising?
  90. 16 mpg on the highway?!?!?
  91. pcm question for alvin
  92. Memory loss
  93. "91 Rough idle, surging PROBLEM SOLVED
  94. CCM codes help?!
  95. Who sells chips for socketed PCMs now?
  96. Need Help With Com Port For Tunerpro
  97. WinBin
  98. Datamaster Question
  99. LT-1 Edit doesn't adjust duty cycle of TCCPCS in Tranny, What Tuner Software Does?
  100. 1985 Corvette TPI Throttle Problem. HELP!!
  101. 1227165 ECM Data stream
  102. Fuel Injectors - Rebuild
  103. First Datamaster Scan
  104. ASR/Service engine Light
  105. Removing Cold Start Valve
  106. Anyone Running 87,88 or 89 bin In An 86 4+3
  107. 1986 MAF realy wiring harness
  108. Baseline Suggestions
  109. "Service ASR" light when scanning
  110. Tuning Setup
  111. Looking For Corvette Mechanics In Miami Area .
  112. Tuning Websites ??
  113. EGR light????
  114. Question regarding tuning, 94 lt1/383
  115. ECM needed
  116. code 26 on a 93
  117. Computer and A/C
  118. Can someone make me a custom bin.
  119. "tuning" prom for 24lbs injectors?
  120. Anybody using a Macintosh to scan / tune the vette??
  121. ALDL Connection on a 90
  122. Please Help!! Need 90 bin
  123. Hypertech Streetrunner
  124. Help!!!
  125. 1992 zr-1 datamaster scan help.
  126. 91 L98 Procharger Tune - Lean under Boost
  127. Chicago-land Tuners meeting
  128. 8,000 rpm tach in a 96 lt1
  129. Lost in translation.....
  130. spark plugs
  131. Best scanner tool for a 91 C4?
  132. looking into reprogramming my ECM..need help!!!!
  133. 89 L98 ECM Problem?
  134. Service Ride Control Light Is On
  135. custom chipped tpi ecu to run big block?
  136. What inputs does the Iac use to determine how far to open or close.
  137. Keeping PCM "Alive" w/ Battery Disconnected
  138. Now its a DTC 41
  139. 1988 Codes 33 and 36 Help!
  140. Any ideas on scanner software to buy?
  141. $EEB and BLMs
  142. Ostrich and '727 underhood ECM
  143. Hypertech and Reflash
  144. Datamaster/Tunerpro RT
  145. throwing codes?
  146. disassembling a `727 ECM- anybody done already?
  147. Sabre 86
  148. Radio Static
  149. Snap-on or the Vette, which computer lying
  150. schematic of ALDL interace cable
  151. surging idle on 90 ZR1
  152. 1993 Idle speeds
  153. Scanned my engine, could someone tell me what's going on?
  154. Delay when shifting manually... '95 4L60e
  155. Can TunerPro or other data loging SW read SES codes?
  156. Running Rich
  157. Convert 96 LT4 ODB2, to 95 ODB1
  158. WinALDL / EGR question / L98 - 1227165
  159. Code P1441?
  160. neeed help on 2zr1s block learn?s
  161. car only idleas
  162. Datamaster connection issues?
  163. Ignition Control Module Issue
  164. 95 LT-1 passes smog exhaust stinks!
  165. 1990 Rough, unstable idle, running rich
  166. Datamaster - Vista/USB?
  167. 1986 Climate Control Panel Problem
  168. 2K RPM Knocking
  169. Datamaster file. What's your opinion?
  170. obdII question
  171. Looking For Modified Bin And Def For Late 86
  172. Ecm Bad???
  173. 89 runs OK cold, nasty when hot
  174. 1984 need advice- should I try logging data
  175. Main Line Press 0-64 ??? Looks odd!
  176. 95 LT-1 OBD1/OBD2 Scan Tool Please Advise THX!!
  177. Need assistance Lt4 1996 scan tool connections
  178. Ist Scan w/TTS Datamaster - Need Guidance
  179. What kind of scan tool?? (87)
  180. injector advice: Datamaster inj DC over 80%
  181. BLM Tuning - Deceleration on a manual car
  182. need tuning advise
  183. Code 32
  184. newbee vette owner that makes tons of mistakes
  185. 52 or 58mm TB/ tune changes
  186. 94 LT1 Auto Hypertech question
  187. 89 L98 Tuner options
  188. Ground Problem?
  189. 1994 LPE 383 help
  190. Emission problems? need help!!! 94 LT1
  191. C4 1984, with carburetor
  192. Looking for tuner in Cleveland, Ohio
  193. pulled some codes
  194. Tuners or Racers?
  195. Can Different brands of fuel really change my A/F this muCH ?!!! wtf
  196. 93 LT1 tuning
  197. What causes upload "Crashes"???
  198. First Post ... Need Help ... 94 Won't Fire Up
  199. I have a code H42 NEED HELP!!!!
  200. Low idle / stall once warm and slowing to a stop
  201. TunerPro shows TPS 1.82 v at idle?
  202. What's the best scan program for 94 LT1?
  203. Can you change the choke/enrichment temp on 1991?
  204. Code 12??
  205. understanding engine scan analysis?
  206. Code 26
  207. Advise on best USB interface cable on 91
  208. Can't Run Diagnostics
  209. Would Like My Fan Temps Programmed
  210. 1988 with lt1 conversion
  211. Time for more stuff
  212. DFCO mode: Should I disable it or leave it be? Advantages/Disadvantages
  213. Need help with TunerPro RT
  214. "90" Instrument/LCD problem
  215. can lt1edit turn off ses light for rear 02's
  216. 90 Vette popup lights problem
  217. " tuner pro or tuner pro RT ?"
  218. " tuner pro or tuner pro RT ?"
  219. 94 corvette starting problem
  220. 1990 definition files
  221. "Weird" Code 15 issue on my 85
  222. Tps/iac 86 L98
  223. LT4 exhaust system on an L98
  224. Help with Hypertech Power Programmer
  225. 96 LT4 Code P0300 help
  226. Outside Air Temp. reads 50*
  227. AFR 20 at Idle
  228. $DA2.xdf for Tunerpro RT
  229. ALDL Cable
  230. Moates Burn1
  231. Datamaster and 1990 ccm problems
  232. Idle AFR/Timing
  233. LT-1 Dyno-Tune
  234. Bruce Plecan (Grumpy) passes on
  235. Anyone with a 383 LT1/4 mind sharing their timing tables ?
  236. climate control, idle speed?
  237. Feedback on TPI Parts chips
  238. 1992 Corvette no start
  239. Just got laptop hooked up to car, novice needs help
  240. c4 tuners in chicago
  241. 94 shift points
  242. "85 Anit theft door lock broken
  243. 1993 C4 chip upgrade question
  244. knock counts and fuel octane level
  245. HELP !!! Speedometer recalibration
  246. TTS Reading 99.6%DutyCycle@6000RPM
  247. backfire
  248. '96 LT4 failed emission test, need tune
  249. TPS on 1989
  250. Memcal question
