View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. jet dynamic spectrum tuner?
  2. idle specs
  3. Tuning Help?
  4. P0300 code on 1996
  5. Info overload: datalogging
  6. Rev Limiter on '85
  7. Help help help please
  8. scan tools
  9. is the chip gonna work?
  10. dim dash lights
  11. Running rich.....why?
  12. 94 throwing codes H16 and H77 in module 4
  13. l98 v 8 running rich
  14. How to prep for head/cam swap?
  15. help needed
  16. superram issue : bad gas mix
  17. Electric fans with aftermarket EFI
  18. Tuner Cat
  19. At what point is a chip required?
  20. flooded
  21. Scan Tool Help
  22. How are to burn a chip?
  23. Where is it
  24. switched injectors, Do Ineed a new tune?
  25. 95 flashing sys and H25 code
  26. Custom Chips can you help me?
  27. Please advise! I'm at my wits end!
  28. How does the O2 sensor work/E10=crap mpg
  29. Anyone just start from scratch?
  30. New Battery and Alternator - C-4
  31. Battery disconect / difficult startup?
  32. New to scanning/data logging
  33. SYS and low throttle response
  34. I put a MegaSquirt2 together with stock ECU in my -90
  35. ECM EGR Test Concept
  36. 94 LT1 how do I affect the instant MPG reading?
  37. Mileage Drop after Injector Swap
  38. Searched but still have a WOT question
  39. 86 Corvette Code 41, won't run
  40. 96 vette, Scanned code P0102???
  41. Ostrich 2.0
  42. pulling a code 15
  43. 92 LT1,no-sieze on spark plug threads????
  44. pcmforless - My experience so far
  45. The VERY BEST Reader/Logger/programmer OBDII???
  46. Trifecta Performance?
  47. Diacom-p
  48. Looking for good Electrical shop in LA
  49. FREE TICKETS from COD
  50. tuning for better mileage
  51. hey moderator!
  52. egr and emissions datamaster scan
  53. Where to put aftermarket ECU
  54. high BLM's
  55. Adjusts brake pedal play after booster replacement???
  56. hazard lights stay on
  57. stock ecm with 600+ rwhp?
  58. EGR sensor
  59. scan tool for 86
  60. Need help, what can you make of this.
  61. TCC Unlock strategies
  62. 2nd Accel Dual Sync distributor failure
  63. 96 LT-1 P0300 code
  64. Datamaster question
  65. Engine service light
  66. What can be programmed "OUT"
  67. 91 service soon light
  68. '92 zr1 looking for xdf and ads
  69. Scanning an '85; help.
  70. Gen 7 EFI Electronic Distributor Advance
  71. Motor???
  72. Gen7 datalogging
  73. Need help - car dead!
  74. 94 tuner options
  75. 90 6 Speed L-98 Broadcast Code
  76. Looking for Service Help in Northern Illinois
  77. Basic scanning questions
  78. dash lights
  79. 95 LT1 Vette Rear O2 sensor functional?
  80. From TPI to Carb Details Please
  81. Oil Change
  82. Mass Air Flow Sensor - High Performance - (remanufactured)
  83. Climate Control Fan Not Working On 1988 C4
  84. OBDI TO OBDII Conversion?
  85. Need prom burned for 85
  86. Any tuners in Nashville, Tn
  87. Need serious help
  88. Scan and tuning software
  89. Corvette Consultants
  90. LT1 idles rough and stalls when warm, Long term counts high
  91. 1984 carburated conversion overheating problem!
  92. LT4 advance table
  93. 96 LT1 Cooling & DTC P125
  94. Custom EFI Idea
  95. Datamaster ?'s
  96. 6E vs 32B
  97. ALDL To USB cable ????
  98. What are the symptoms of a bad VATs
  99. Split BLMs, or close enough?
  100. Must part with new complete DFI Gen 7 and harness
  101. Running Rich on the Highway - scan attached
  102. Anyone in St.Louis MO able to data log?
  103. has anyone installed EFI on a 1970 LT-1?
  104. Guess I've got to yank the engine
  105. Cooling fan Switch???
  106. 1984
  107. Best scanner to start with
  108. Went from TPI to miniram
  109. LT1 plugs
  110. 94 LT1 Rough running
  111. High Idle???
  112. C 12 ???
  113. No communication w/ TunerCat (DataMaster fine)
  114. 85 Vette HP boost
  115. Injectors will not fire
  116. What Is The Difference In .xdf and .ecu
  117. any Accel Gen VII wizards here?
  118. accel thruster efi controller
  119. Any Tuners in NC???
  120. any tuners in colorado?
  121. Questions about scanning tool Winaldl for the 1226870 ECM for an 85 4+4
  122. Time for a road tune?
  123. Time for a road tune?
  124. help
  125. Little puzzled.......
  126. MAT Sensor???
  127. pc odbII tune?
  128. accel gen 7
  129. 4+3 and 7730 ECM
  130. DTC 73 on 94 coupe six speed
  131. High HC emissions
  132. Where To Find TCC Lockup Command
  133. 93 DTC-36 ignition problem, any hints?
  134. reprogram cooling fan w/GM Tech II?
  135. 85 L98 will not idle when warm
  136. CCM Code C81
  137. Plugin system to a Vette turbo 1992?
  138. need help with understanding PE
  139. Accel gen 6 to gen 7
  140. Rough Idling
  141. Help 95 runs terrible
  142. AFR Heads in stock...NOW....
  143. I am new to tunerpro
  144. ? for 96 guys using ODB1 94-95 computers
  145. My dyno chart
  146. Data from scanner...are they within limits
  147. Sensor???
  148. Stock LT4 File
  149. 96 Codes
  150. Need help, advice, all that stuff
  151. LT4 Tuning Options... [HELP]
  152. Is it necessary to tune on a dyno?
  153. Thinking about Wideband o2 sensor
  154. ECM connector schematics for -90
  155. Small Miss
  156. High HC(PPM) reading at idle during emissions testing
  157. 96 PCM Diag check
  158. rough after warm up
  159. Need help with Injector Constant Bosch Design III 24lb injectors
  160. Tune Up Or Not to Tune Up
  161. Is MAP a backup for MAF failure? ('95 LT1)
  162. Codes
  163. Rough Idle & sparks knocks
  164. msd 6-btm experts!!! help needed...
  165. Mini Ram or ported TPI
  166. Tuning a f/i stock computer 92- 2 bar tune or 1 bar?
  167. how to turn off or reset the change oil light?
  168. Mass Air Flow Sensor
  169. New to this scanning thing
  170. Odd results. VOM vs. Scan
  171. Does ALDL work with engine off?
  172. help 91 stock vette overheats!!
  173. cold start 85 vette
  174. Help me fix code 34
  175. Looking for an XDF file for a 91 ZR1
  176. Code 33 and 36?
  177. 1994 Overheating Problem
  178. 85 Hard to Start
  179. LT4 Major Issues, data logged, suggestions wanted
  180. Can it be my ECM?
  181. paging Edmcat1
  182. C4 Intermitent Problem When Warm (please Help!!!)
  183. Hessitation, and pop during acceleration.
  184. Need CF Help with Mods installed
  185. Battery Disconnect Changes?
  186. Digital gauge Convert
  187. air fuel ratios
  188. Where is the ESC located??
  189. Speedo calibration?
  190. How to read codes on a 1994
  191. bay area dynos?
  192. Problem with new chip
  193. 27c512 start address
  194. Datamaster Data File Extension & Creation
  195. Anyone here tune boats (MEFI)?
  196. Can somebody help us with this darn tunercat?
  197. xtronics chip burner and AKM cable for sale.
  198. Holley Commander 950 on tpi, anyone running it?
  199. VATS key
  200. costum chips 85
  201. TPS voltage too high
  202. Accel DFI vs. Stock ECM ??
  203. replaced TPS, now code 43? Help !!!
  204. MAF Sensor going bad?
  205. scanner and 85 get divorced
  206. Tuning for Dummies..
  207. what's correct idle speed
  208. code 21 on my dead 1993 LT-1
  209. 1985 EFI questions and motor swap questions
  210. buy a tune or tune it my self
  211. e85
  212. Bad MAF Sensor?
  213. Code 51 - faulty memcal
  214. Do I need to tune my chip?
  215. Where do I plug scanner?
  216. Using winaldl: When to reprogram chip
  217. XFI vs. BigStff3
  218. Custom tune by email
  219. General Info
  220. 90 vette runs for ten mins then dies wont start again
  221. possible to use V6 prom w/programming?
  222. The carb Convert from TPI
  223. Any good experience with a USB cable?
  224. auto scanner
  225. USB Logger
  226. Surging Idle
  227. Madtuner???
  228. dead 93 LT1 help please
  229. A/c ??
  230. Service ASR - Engine won't stay runnning
  231. %&$#@!!! SES Light
  232. Your recommendations for new tune
  233. To remove or not remove before ordering new tune
  234. Problem after using Hypertech programmer
  235. Rough idle after new install - LT4 Hot cam kit
  236. Laptop
  237. Melrose Header System
  238. Throttle Cables 87-89
  239. AFR results with Innovate LM-1 - what do you think?
  240. Couple quick tuning questions.. $ee
  241. Help with WINALDL
  242. 94 vette digital temp display stuck at 142
  243. please help the village idiot [me]
  244. 1994 LT-1 starting problem
  245. 92 Window
  246. LT1_Edit file to C.A.T.S Tuner BIN
  247. Scan Tool info needed
  248. help with moates for 92
  249. usb cord
  250. Swapping 345s for 373s programming issues
