View Full Version : C4 Scan & Tune
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Need a chip for an 85
  2. Hard to turn over
  3. Know enough to be dangerous!??
  4. Disabling ASR with Tuner Pro?
  5. My vette gets "0" mpg, but 99 mpg Average !?!
  6. What is stored on the ECM PROM chip on 1993 Vette?
  7. Any opinions about correction factors?
  8. No Data coming from car
  9. a problem with my corvette
  10. New Megasquirt to '165 ECM adapter board
  11. Using Tunerpor?
  12. big speed bump
  13. How to tell if i have a performance chip
  14. CE LT4 Self-Tune
  15. 1996 CE LT1 Speed Calibration
  16. I need help with winaldl
  17. Has anyone heard of ....
  18. TTS Datamaster authorization codes gone?
  19. Connecting scan tool disable the spark knock retard function and increase the idle
  20. Has anybody used TPI specialties runners?
  21. Need Tuner in New Orleans Area
  22. idling issue
  23. what kind of equipment does my installer need to tune my 89 corvette?
  24. Ok guys- thoughts/suggestions on tune ups.
  25. 89 CEL Codes
  26. Help Data logging for 1988
  27. Check engine light on...Code 34 MAP Sensor
  28. Need help in analizing ALDL data
  29. High mileage LT1
  30. Hardware for LT4
  31. 5v input source for wideband on Datamaster?
  32. Tune for a small cam
  33. Multiple Codes - ECM Failing?
  34. 1991 corvette needs repairs in NJ
  35. N/A Lt1 timing tune.
  36. LT4 Crank Position Sensor??
  37. DTC 36 after Optispark install
  38. confused with no start
  39. What wide band setup?
  40. Best place for an ECM rebuild?
  41. injector constant mpg display
  42. Eprom burning for 1989
  43. meaning of codes
  44. Need tuner in Cleveland, Ohio area
  45. fair price on dyno tune
  46. Slugish vette
  47. Midnight and looking for answer's
  48. Super RICH and been through the posts
  49. 87 injectors
  50. Basic questions about the capabilities of the LM1 wideband
  51. Ugly Fat when cold
  52. Need a new tune if I add Nitrous?
  53. DFW Tuner
  54. Dyno Tuning in So. NH
  55. dtc p1441 1996 LT4
  56. Adding cam require new chip?
  57. Looking for an OBD-1 dyno-tuner in the Tampa Bay area
  58. '93 Back fires through intake
  59. Beautiful C4 REAL Carbon Dashes *PIC*
  60. Need help with ECM 1986
  61. Can't decide if I should "bother" to tune
  62. 93 code reading
  63. Quick ? with LM-1 wideband
  64. My 84 Vette Check Engine need help
  65. 95 LT-1 auto w/sulphur odor I'm at a dead end
  66. LT1 starting problems
  67. NEW PCM, car won't start
  68. Open / Closed Loop
  69. battery grounding out
  70. 85 vette NEED PROM BURN!!!
  71. Synthetic or Reg. Oil for My 95 Coupe
  72. instructions booklet for autoxray AX-400
  73. Multiple threads
  74. 1996 LT4 OBDII connector?
  75. high idle
  76. Tuning the Trip Computer MPG Calculation
  77. Service Engine Light
  78. 750-850cfm Throttle Body Inj- Not tunedport
  79. O2 Simulators
  80. Tech 1 Scanner
  81. Pinks All Out - Corvettes of Dallas - Pre Race Prep
  82. Returning User needs help.
  83. Why can't I find $DA2 definition for my '92
  84. electronic spark control help
  85. Injector testing 85 Vette?
  86. Fs pcm
  87. Has anyone used the PYPES exhaust system?
  88. Flow Rate anyone?
  89. 85 vette still surging ;( crazy idle!!!
  90. changing out old 85 computer
  91. Tunerpro RT beginner question on fan control
  92. Datamaster IAC vs Tunercat IAC 92 LT1
  93. LT-1 Edit vs TunerCat
  94. TPI's and timing vs LT1
  95. Wrong MAF ????? 85 Vette
  96. Smog pump removal on C4, what kind of problems will this cause?
  97. Mass Air Flow Sensor
  98. AutoXRay 6000 Scan Tool
  99. OBD Diagnostics Software?
  100. Motorvation Chips...
  101. Frying PCMs Programmming and Reading!?
  102. belkin f5u409 serial to USB
  103. 92 Vette Cam change
  104. 91 Scanning
  105. Melrose headers/Exh.system sale...
  106. 93 corvette
  107. if you want an awsome tune
  108. FS: ALDL OBD1 connection cable to laptop
  109. Is Autoxray 2000 a good code reader
  110. Custom Chip?
  111. need answer to obd 2 question
  112. Anyone selling the tunecat OBDII Tuner
  113. Experienced with TunerPro RT
  114. Need dyno tune in sc, is Atlanta the closest?
  115. PINKS and Corvettes of Dallas Team-Up
  116. 86 corvette ECM question
  117. Charcoal canister purge
  118. Where did the tuners go?
  119. Tuning Book
  120. Corvette Tune/Trade
  121. Re-tune question
  122. datamaster dyno calculation
  123. Having trouble finding .bin's for my engine
  124. Datamaster users
  125. 89 TPI runs bad and has code 36
  126. Thanks
  127. Code 36
  128. OBD II Software Diagnostics...
  129. Laptop....
  130. Diagnostic port differences
  131. Best mail order tune?
  132. bad idle in drive
  133. Need some advice on getting hardware
  134. Code 46 and No Crank - '88
  135. Injector Covers
  136. Tuner for 85 wanted!
  137. 93 throwing code 26
  138. what happens to the fuel curve when ....
  139. Lambo doors on a bright red c4 corvette with racing stripes!
  140. Reading a .LT1 file?????????
  141. Throwing 43
  142. Inst rest
  143. DIC warning lights
  144. Friend with 90 tach problem... Yes no. 54678 or so
  145. looking for someone that can burn the fueland advance curve off my 90 prom
  146. real time tune for obd1 has anyone heard of this?
  147. Remove MAF sensor??
  148. OBD 1 to OBD II connector
  149. Just purchased the AutoXray 3000......
  150. can someone flash an obd1 chip for me
  151. 1987 code 33 help!!!
  152. unplugged tranny sensor and when pluged it back in, screwed up Speedo and Od readings
  153. Scan tool for spark kv readings and cylinder balance
  154. 14 deg of Spark Advance at idle?
  155. Tech 1 Cartridges for 95 Wanted
  156. Question about '85 computer
  157. need help tuning 94 vette lt1
  158. L98 Knock Sensor VS. Gear Drive
  159. need stock tunercat bin file for 94M6
  160. 1989 dies
  161. Newbie tuning question
  162. Rev limiter or what? Help!
  163. Opti Spark
  164. Any Chevy have common ECM connector with an '84?
  165. Texas tuning special!
  166. Scanned my ´91 auto with autoxray 6000
  167. PCM Auto vs Manual
  168. Data Master VS my com port settings, help appreciated
  169. '93 LT1 EPROM Replacement/Tuning? (EPROM is AC Delco Part #16184672)
  170. My Heater Fan won't come on...
  171. Data scans
  172. can one tune the traction control in a 92 ?
  173. Newbie here, with a few issues...where should I begin?
  174. A couple of C4 questions
  175. Not just C5 and C6's....
  176. Smells rich but runs lean????????????
  177. help!!! 95 LT1 idles rough and stalls when warm
  178. '92 LT1 timing numbers
  179. what do you have to remove to get the chip out of the ecm
  180. Anyone recomend a book before I jump into tuning
  181. ecm case 1991 7727
  182. Ecm supplier
  183. ecm or Prom issue
  184. Prom Replacement
  185. Saving factory prom program
  186. "O" Rings - Is There a Difference?
  187. Where do I get a EZ-Link by Auto Xray?
  188. Want to start tuning, would it be wise to get new comp first
  189. OBDI Tuners in San Diego / Southern California?
  190. Need help! 1992 ECM
  191. Tuning my '96 LT4: How to get started?
  192. disassembly of ECM
  193. straightline performance new lenox il
  194. Dynometer
  195. NEED my ED Wright stage 2 FAST CHIP reprogramed for my new mods, can someone help?
  196. G-Tech Pro SS Performance Meter
  197. PCMForLess vs Dyno tune
  198. Gauging intrest Accel Gen VII Tuner Class
  199. Replacement PCM for '95 LT1 question
  200. Initial Flash for Replacement Computer
  201. Datamaster mystery DTC error. 92 LT1
  202. Rough cold start idle
  203. Just picked up a Accel Gen VII Setup
  204. Service in Texas
  205. FS:Autoxray EZlink Scanner(GM,OBDI,OBDII)
  206. Aero force digital gauges..
  207. 92-92 .Bin File
  208. HELP, wheel gurus needed on spacers 93 Vette
  209. correct timing on an 86
  210. Fuel and spark adjustment in Tunercat
  211. Logging & Editing 96 LT1: Options
  212. help
  213. obd II codes for a 96 opti
  214. Tps
  215. Best Source for Replacement PCM?
  216. 90 auto backfires in 1,2, after hard accel
  217. new cam need tune?
  218. knock sensor
  219. Where is the fuel pump relay on a 96 CE LT4 vette??
  220. What exactly will LT1/4 edit do?
  221. Rich / Lean (o2) gauge function?
  222. Auto Xray 6000 issue.....
  223. Fuel pressure guage advise
  224. engine dies while crusing or when accerating
  225. Third O2 Sensor on a 95?
  226. Best tuning software for a '95 LT1 with a blower?
  227. Stalling 95 225.000 kilometers
  228. LS3 Swap question
  229. Wideband placement on a 95?
  230. The engine knocks under acceleration with scan tool connected
  231. C4 - Acceleraton hesitation/sputter?
  232. Eprom
  233. Looking for a bank-to-bank Engine Management System
  234. Program needed to pass emissions
  235. eMS-Pro Engine Management System
  236. No More SES Light
  237. Shift Points
  238. ECS vs Prom fiddling
  239. Rochester NY - Engine scan
  240. Help with OBD1 Software
  241. Transmission Slipping
  242. Where to buy LT4 edit?
  243. lt1 edit
  244. OBDI Tuning in NY/NJ
  245. Need help with AE tuning with 32B
  246. latest prom update for 84 CFI impossible?
  247. Sourcing on a OBD I tuner/reader
  248. True or False
  249. Two OBD2 plugs
  250. Timing in datamaster
