- •► ► Corvettes of Westchester - is not just C5 & C6s ◄ ◄•
- Tune Error?
- my 396 cui is running rich
- 95 A/C CONTROLS (Auto climate control)
- 8th letter in VIN
- 92-93 chip 383 laying around?
- Need help finding ALDL pin wires
- Win ALDL numbers
- which aldl cable to buy?
- Anyone using TunerPro V5 on their LT1?
- What type of equipment do I need to program epprom and where to get it for 85 vette
- 93 lt1 cable
- MAF Tune Port Accell Enrich Questions
- Ordering tune equip. need help.
- ASR System
- Rom master
- pls look at my data
- What do I need for datalogging?
- 1994 LT1 - Have AKM Cable and Questions
- Ordered my tuning stuff from Moates
- TPS Voltage
- New cam, had to increase VE to idle.
- Aftermarket ECU on -1992 with Auto.
- 96 OBDII software
- lowering block learn
- ALDL and USB Q's
- Accel Gen 7 with dual sync dist
- Need help with HSR tune / tunerpro
- ECU troubles
- Avg MPG increase after tune
- C41 and C51 Errors Codes on 1991 6 Speed
- SD Tuning - Please Confirm My Process
- Need a $DA3 bin
- Anht, bauh, aujp - help!
- Won't start warm...
- 1990 Coupe A/T Surging on Deceleration
- How long should it take to dyno tune my motor
- What is being controlled by my MAT (manifold air temp) sensor? 93 lt1 ?
- TunerPro
- Help!..I can't get my usb cable to work.
- 383 tuning question
- Airflow restrictions in intake track ?
- Dyno run... huge spark advance spike after runs
- deverting the AIR pump for a Dyno Run
- Using ALDL software
- O2 question
- Diacom Software
- Any one Program Their Own Chip - Help!!
- Please enlighten dyno and a/f meter
- Dyno tune problem
- ECM trouble?
- Where did the VSS table go?
- ECM/Eprom changes required for 383?
- 89 idling problem hheeeelllppp!
- Erasing service engine codes
- ECM change vs. New Prom chip
- Wideband O2 behavior
- Tuning issue
- Would anyone share their tune?
- New injectors, how to tune?
- Lc-1
- INT looks good BLM is very rich
- Cold start problems - using FAST ECM with wideband O2
- Tune advice request
- I need software to tune for boost.
- WinALDL and USB
- Tuning my 94
- Is there an easy wasy to test if an ECM is fried?
- '93 Convertable
- LT1 ODB1 - No Spark: Any LI NY Mechanic recommendations?
- not a vette but its GM
- need tuner in ohio have moates but dont understand
- Which Scanner to Purchase
- Will tech 1 program a ccm in a 1990?
- Injector Constant vs BLM's
- Anyone have a copy of ANHU BIN file?
- Electrical issue
- question on C4 tuning
- Former LT-1 Edit Now Trying to Use TunerCat Tuner
- PLX Wide Band
- Newbie has Problems with lights
- chip
- Need help with tuning my '86 from scratch..
- Can someone recommend some scan software for ODB1
- Newbie need help really bad...
- tunercat vs. tunerproRT, whats the diff. tunercat doesnt reply
- Wide Band O2 Sensor go in place of stock o2 Sensor?
- Good tuner in NE wisconsin
- Can you permanently mount a Ostrich in the Engine Compartment?
- anyone wanna program a sd prom?
- SLP tri claw question
- Going to try tune on my own
- Va Speed. We'd like to apologize.......
- Good LT1 tuner with FAST XFI computer in SoCal area!
- tune out vats
- Need Stock Prom
- Painless wirings Engine control system
- **** 8th Annual Corvetteforum St Jude Fundraiser****
- Correct bin for a 91
- what should my A/F be - closed loop at idle?
- LT1 F body vs. Y body tune
- anybody have any experience with wideband O2 sensors?, is so step inside
- Bin File
- *** Error Codes 43 & 54 *** How do it get rid of them ??
- occasional miss w/94 LT1
- edcmat-l1 tuning in Pittsburgh.
- Tuner in Central Florida to burn a ECM chip?
- Scanner
- OBD1 Tuners near Cleveland Ohio
- More power out of the LT4?
- 93 Sometimes missing when driving
- what happen to Fast Chip website?
- Memcal interchangeability for 93 LT1
- Car just stopped running. Checked codes and I need help!
- codes P0335 & P0336 cranksft posit indicat
- nyone know of tuning software where cyl. or bank fuel trims can be adjusted? 93 lt1
- TTS datamaster not working any more. am using an ostrich and tunerproRT on 93 lt1?
- 94 Corvette PCM Mystery
- Changing 4+3 Control Tables?
- '89 probs-typical scan data
- I need help getting tuned
- datamaster histogram question
- please lead me in right direction
- Datamaster problem w/92
- Dyno-Max 2000 Pro
- tried accelerating and engine died
- I know you guys hate this, But only way to lurn is ask.
- "SYS" flash
- what software to use
- Scan Software For A 1985 Corvette
- Tunercat injector flow rate
- In need of a stock 94 M6 tunercat file..help
- Driving Technique for Data Logging?
- Ignition tune vs cam
- Question about Knock
- running rich
- '95 4L60e delayed shifting...
- Fuel Injectors Question
- fuel pressure
- Does this look close?
- accel gen 7 pain in the backside
- scanning software
- HP mini & ALDL cable USB - works great
- Look at this WIERD Diacom data from stalling problem
- I don't understand how to get to these bolts to remove the rear bumper.
- Paging STL94LT1
- How to reset codes
- tuning me 95 with tunerpro,info needed
- help with tuning my 95 with laptop
- nasty miss
- Need tuning in wisconsin
- Tuning 1996
- trouble with my 91 idle
- Anyone with spare time on their hands? Accel Gen 7 ver 5
- CL Mode Value vs Airflow
- need tuner for '85
- Code 33 but MAF ok
- trouble with my 85
- 1994 LT1 - which pin is data in the ALDL?
- Problems on 85 Vette
- Need a stock Vette 1989 - 1227165 bin
- TunerPro RT 87 MAF
- 1994 LT1 Datalogging/Reflashing
- programing your own cars fan ,shift ect.
- Air Fuel Ratio Question WOT
- Just threw ECM Code #26. Looking for some help.
- Accel Gen 7 question
- C-4 injection systems and stroker motors
- Wide Band 02 sensor-What to get?
- Ri state inspection
- Will this cable work with my 85?
- bin file
- OSTRICH?? Point me in the right direction PLEASE!!!
- How to make the Winaldl SW read BLMs and INT numbers
- I'm finally headed in the right direction
- Programming Questions
- Any tuners left? autotap logs
- '870-'165 swap
- cruise control diagnostic tool for a 94 vette
- 1985 with high NOX
- Tools and equip.
- 1985 Corvette won't pass emissions?
- Problem with TunerPro RT dashboard
- COP2<54ms???
- Innovate LM-2 “basic” group purchase
- Code 43 and 52 Help, Please ! 90 model L98
- Tunercat proRT logs for a 91
- Anybody use the DCS chip on their '84?
- code 42 help
- Rough idle and missing
- 90-95 zr1 tuner needed in socal/nor cal
- swtuning.com reviews
- Scanner for 94
- DFCO doesn’t work, why???
- Programming o2 open loop?
- 1994 Coupe 6spd - Mod 9 - code 62
- HELP!!! Rich L98 and idle drops/surges
- 1991 corvette c4
- Help! looking for PCM for '92
- Fast Burn Tune?
- Dual Band O2 Set Up
- Chip for LT1
- anybody use same-year L98 IROC memcal in a C4 ECM?
- $32 383 406 chip?
- Laptop and cable
- how tune
- Lt1 wire arcing
- How to lower hydrocarbins
- Picking up the RPM signal in a '93 for Zeitronix?
- painted top
- Questions on scanning with Diacom plus. Long
- high idle
- Very rich 1985
- What happens when the knock sensor is disconnected?
- Rough Idle HELP
- FIC LT4 fuel injectors work..........AWESOME! (Caution: long read!)
- Code 32 EGR Switch -86-
- 02 sensor
- P0100 Mass Or Volume Air Flow Circuit..Need Some Info
- can I convert a $6e tune to a $32 tune?
- code c13 help
- Anyone want to look at my Datamaster file?
- Can an 86 Supervette Chip be reprogrammed?
- Scanning Software Help
- Need help starting car.
- Datalogging AEM UEGO WB o2 sensor
- Where to get into the O2 signal?
- Body grounds?
- what is single fire mode?
- Any one with datalogging capabilities in Central Wi?
- Change your o2 sensor to fix bad idle
- What is the best method of tuning a LT1?
- Any good reference books on C4's?
- Does a good laptop mount exist for C4s?
- code 43 problems
- my oil pressure reading is way off
- SES Code 32
- "sniffer" test done today, got some questions
- anyone have a stock 86 4+3 bin
- Service ASR with Datamaster?
- What files needed?
- "Unsupported PCM type" DataMaster error
- WTB : OBDI '87 Programmer /hardware/software
- Data Reader for a 1985
- FS...FastChip '92-'93 6-speed
- 91 coupe L98 auto ecm
- 93
- how did I solve high initial oil pressure & VE
