View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26
  1. computer work for 383 conversion.
  2. WTB- LT1 edit w/ a dated laptop....
  3. What do I need to get started?
  4. Do you have EASE? Please tell your experiances..
  5. LT5 scanning software
  6. Building - tuning
  7. can anyon eburn me a chip for almost stcok LT1????
  8. '7730 ecm & linking diacom help
  9. Romulator
  10. BLM & Integrators & O2 Sensor mv
  11. [Data]: Diacom files from this weekend.
  12. Need help making a cable for reading '85 ECM(870)
  13. Hack Hypertech PPIII?
  14. going to dyno tune any suggestions?
  15. Can I set 'fans on' temps w/ laptop and free software?
  16. --- NoVA --- Anyone with an OBD-II Diagnostic tool ?
  17. 32B vs 6E
  18. Two more diacome files for you to look at.
  19. These block learns and integrators mean anything to ya?
  20. My spark tables seem weak
  21. Which scan tool to buy?
  22. Jesus help me. What to do with 93 chip programming.
  23. WHAT SENSORS CONTROL TORQUE CONV
  24. TC Lockup parameters?
  25. When does the ECM go into open loop???
  26. Need to burn chip for gear change on 92????
  27. Criteria for dropping out of PE
  28. Just curious ....
  29. Open loop tables for an 86 vett ecm question
  30. % TPS to Enable WOT vs. RPM
  31. Notice the name change!
  32. question for those who have tune the hot cam
  33. NEED HELP IN DALLAS AREA...PLEASE HELP!!!
  34. Help with Craig Moates Software
  35. Elimination of CSV.
  36. [4+3]: Tunercat has definition files.
  37. Burning Chicken ?
  38. Knock retard!
  39. ECM telling tc to unlock
  40. What programming can be done on 94 OBD1
  41. Burn a chip for new Injectors???????
  42. Tuning for a SC?
  43. Dallas area software owners...please help!!!
  44. How much more apparent does it have to become?
  45. IAC counts
  46. Ontario ECM re-programmer needed....!!
  47. K&N Air FIlter Causing Low and Locked BLM
  48. '94 tech one
  49. Tuning challenge--'90 383 with big cam
  50. Help!!...New 4+3 OD unit won't work with new 3.73 gears on my 86
  51. 92 chip needed....soon....maybe??? Speed density / mass air??:confused:
  52. WinBin .ecu file for 1992 Vette??
  53. PROM needed for my 383
  54. Questions for those tuning an 86 computer.
  55. Convertor not locking up after 165 to 730 swap
  56. Ecm & Prom Question
  57. HOT CAM is what parameters do I need to adjust ??
  58. DIY WB / anybody have one?
  59. How Difficult ????????
  60. Looking for ABTB bin file.
  61. service lights & ASR
  62. Does anyone have an OBD1 scanner they want to sell?
  63. help check engine code!!
  64. Anyone willing to Help me out with 93 Chip tuning????
  65. Still fighting with BLM's
  66. 383 timing map
  67. Craig and anyone else that knows, 90ns vs. 150ns.
  68. Will "Cut Plugs" mess up my custom chip?
  69. How many frames per second??????
  70. Anybody have a base file for a 385CI Vortech?
  71. New Hardware Link for Craig Moates EPROM Adaptation
  72. New to burning chips...
  73. Zap Pcm phone number????????
  74. OK, I have data from a nitrous run and a motor run!
  75. Question for (ski_dwn_it)
  76. ECM Chip Burning...Anyone around here can teach me how to get started?
  77. MAP Sensor On A 88 L98
  78. Source for 85 ePROM chips?
  79. Dyno'd my 383, Need help/opinions with the Tune
  80. Maybe ECM Problems on my C4 ??
  81. Ed Wright Chip? Buy the PRoGram Myself? Covert to MAF?? HELP!!!
  82. accel dfi help
  83. UEGO Five wire Oxygen O2 sensor
  84. [Paging]: Craig Moates
  85. Anyone know about reprogramming a CCM - Central Control Module for a 1996 LT4
  86. can someone give me 1996 grand sport / lt4 car vin so my dealer can re program
  87. Installed new Chip, no longer shifts
  88. Zimmer contact needed
  89. -=Please Help - Looking for a DFI Global File - 383 SuperRam=-
  90. LT1 Edit guru to look at my file.
  91. they should warn you about this
  92. Reprogramming PCM??????
  93. L-98 Stuff...
  94. IAC setting in chip question
  95. LS1 edit vs. auto tap & maf tanslator
  96. I unhooked egr and air....a chip question???
  97. 1st Custom Chip!!!(Thanks to "ski_dwn_it")
  98. Injector constant
  99. Digi dash functions with 730 swap?
  100. Stupid question: Wide Band AFR Meter
  101. WTF am I doing wrong
  102. What causes split BLM?
  103. Does 870 and 165 ECMs use same ePROM.....
  104. Upgrading 85 ECM website?
  105. burnt some e-proms (1st time)
  106. New to computers...HELP!!!
  107. Tuning....please help
  108. Anybody Here Have Ease Diagnostics Palm Scan Tool?
  109. 870>>>165 or 730? and why(long)
  110. Nedd to Know if my ECM is Bad.
  111. Have Laptop Will Tune (maybe): Advice sought!
  112. Accel DFI?
  113. new ecm worse than old ecm?
  114. who do i talk to to get a chip burnt for me
  115. Best place to order AT29C256 ?
  116. Pocket Programmer problems
  117. 165 eprom
  118. Anyone familiar with GM 'Field Service PROM'...1227805...for an '85??
  119. Mile high vs sea level prom
  120. 730 swap and knock sensor (quick?)
  121. Fan control module overheats? '96 C4
  122. High beams on with fog lights? C4
  123. How to prog for a cam?
  124. Bad ECM ?
  125. Help, Looking for info about 1981 vette ECM
  126. Monitor WBO2 and ALDL at once?
  127. Please help!! change 870 to 165
  128. Diacom in DOS window ?
  129. Pinging with ZZ4 -- now I have data!
  130. Best Chip for your $$$
  131. EASE problems with parameter files
  132. What is best eprom editing software?
  133. Can I swap the ECM for a PCM?
  134. Wide band AFR meter
  135. changing ecm
  136. couple of questions
  137. Help Speed density VS Mass air Flow
  138. need chip burn on 90 6spd, have cash
  139. Should I change my PCM?
  140. Need help quick
  141. CODE 32
  142. Check out this Fuel Injection controller...
  143. What kind of performance increase did you see in your Lt1 after a chip?
  144. Which setup best for analyzing data?
  145. FS- Craig Moates PROM adapter....
  146. Chicago Sunday Tribune Article: Brian of BV Performance
  147. Running Craig's Software, and trying to diagnose car lurching/bucking
  148. WinALDL Help
  149. MAF or MAP?
  150. New Trick!
  151. Can anyone help me tune my...
  152. Spark advance question
  153. Warm weather wierdness......
  154. Ok...so who figured out what address is the odometer info is stored???
  155. I need a chip burned for my LT1 wth Hot Cam
  156. Help! installing PCM
  157. How do I read WinALDL.....
  158. Code throwing..
  159. Paging Marcho Polo
  160. New PCM
  161. Just Got Back from Shalin's
  162. MAP (hg) vs KPA conversion
  163. Looking for an 86 $32b '165 ECM WinBin ecu file... anyone, anyone?
  164. 165 Collecting dust ??
  165. How hard is it to tune for a HotCam
  166. Can the ECM compensate for too much fuel pressure?
  167. Need a chip for my 1985 Vette, am a novice
  168. Back at home ... time to start working on my tuning again :)
  169. Craig Moates ALDL Software Updated to v8.51
  170. 1985 ECM diagnosis?
  171. ok, whats needed
  172. CODE 21 HELP
  173. Need help interpreting Datamaster 1/4 runs
  174. Blew My PCM Flash Need Link to Flash Chip Replacement
  175. Anyone using Accel CALMAP setup?
  176. Knock Sensor Defeat Option..
  177. Changing ECM
  178. Craig I put your chip in today.
  179. Running Hot in S&G Traffic at Idle w/ A/C on and 3000+ Knock Count!
  180. Diacom, MPH, & 730
  181. Must I get a Chip with this set-up
  182. How can I tell if I've got 160 or 8192 baud?
  183. polo, chip burn, zz4 in 1990?
  184. How much timing in stock chip in a 93 LT1??
  185. 8D AB version
  186. WinALDL knowledge
  187. Autometer EGT prices?
  188. Engine management system....
  189. Best way to reset ECM??
  190. TT DATAMASTER INSTRUCTIONS
  191. '165 Tuning questions <searched through 2 years of articles, cldn't find>
  192. '165 Tuning questions <searched through 2 years of articles, cldn't find>
  193. Chip tuner... A little upset.
  194. Car just died?
  195. WinALDL working
  196. Greg Moates sftwr??
  197. LT1 Edit software for OBDII users
  198. Which winbin ecu file do I need to read my 1988 bin?
  199. Big thanks to warlock, and others
  200. Custom prom and Throtlebody sizing question...
  201. Do I need computer programming first, or...?
  202. HELP: I need a custom chip for my winter mods. Who should I go through?
  203. What should I do? 396 MiniRam etc ...
  204. few questions about chips
  205. Would this be possible????????
  206. What do these codes mean, I pulled them using an Actron CP9035 ODBII scan tool
  207. can anyone help i.d. this chip please?
  208. Craig you around?
  209. Auto Tap?
  210. TT Datamaster
  211. What was most ET gained by Chip change only??
  212. Tuner Cat help needed for DA2 Def. file (92 vette)
  213. Which is best diagnostic tool for C4 (OBD-I)?
  214. Help with o2 sensors, which one is bad or loose? What should i use to find out?
  215. Duty cycle question
  216. How do I download my stock bin?
  217. Need good used AutoXray
  218. LT4 Hot Cam Speed Density Tuning
  219. Help with new gears!
  220. Does it sound like my ECM is bad? (short)
  221. ECM change for 2 bar MAP?
  222. Tuning Newbie seeks advice - what diagnostic software?
  223. Tunercat or LT1_Edit??
  224. My Injector Base Pulse Width stays constant during run. Could this be right?
  225. Diacom laptop requirements?
  226. Schematic for ESC module internal circuitry?
  227. EPROM Erase?
  228. Any tuners in South Florida to burn me a chip?
  229. AT29C256 and Pocket Programmer
  230. Fuel problem
  231. Results from ECM change?
  232. Super Ram users please take a look....
  233. Bought a great book last night!
  234. EGT to tune air/fuel ratio?
  235. EASE scanner, anyone know about that?
  236. How to recover codes on obd2 data link
  237. For tuning a car w/ head work and a blower what guages should i have???
  238. Does this wiring idea sound right?
  239. Question on Blower Tuning.... How To read Boost
  240. Anyone using the Accel dfi Gen 7 stuff?
  241. O2 reading are 930 in hi gear!!!
  242. Gear swap and Speed density=new chip?
  243. 17.5 air/fuel? Rich or lean?
  244. Anyone use a OTC scanner??
  245. ECM/Memcal/Eprom/Flash Adapters
  246. Diacom on a 85
  247. What does the '87 computer do at ~ 63 mph?
  248. Need someone to burn me a chip to lower fan temps
  249. Question about 727 ECM vs 730 ECM
  250. Cost for LT1_Edit
