View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26
  1. 90 SEAT BELT LIGHT STAYS ON ANY HELP
  2. I can't read my chip :(
  3. OBD1 cable recommendations
  4. Guys with A4s... what do you use for changing shift points?
  5. Holley StealthRam modifications to clear hood
  6. 165 swap and injectors... I may be having problems...
  7. L98 MAF idle tuning with 110 LSA camshaft
  8. Help getting me started.
  9. Anybody here with 1990 Corvette L98 with 6-shift?
  10. Disable Cold Start Injector
  11. Performance chip question
  12. Serial Port to USB
  13. newbee looking for files
  14. Cylinder Volume Constant and Injector Questions.
  15. ECM for a TPI swapped into a TBI vehicle?
  16. Switching from Bosch to SVO Injectors, any advice?
  17. Anyone logging WBO2 data to ALDL stream?
  18. picked up complete tpi motor, how hard is it to....
  19. Here's a list of C4 codes and their likely cause...
  20. Code 545
  21. Programmable Tunercat Fields
  22. Need to upgrade to Windows scanning software.
  23. anyone using winaldl with an 85 870
  24. How can I reprogram without...
  25. Need help ... 96 LT4 SES light question
  26. Bought it
  27. Does anyone have a wiring diagram for 85 burnoff module?
  28. Bought the whole shebang
  29. Help! 86 stock bin
  30. What can LT1 Edit do for me?
  31. Diacom data for my 396, is it good enough for a tuner chip?
  32. Is there a way to adjust "pump-shot" on 92-96 LT1s?
  33. Anyone have their stock LT4 flash?
  34. Accel DFI / Calmap questions
  35. Car runs bad in open loop
  36. How much to burn me a Stage 2 chip (Ed Wright) for a 1990 Automatic 2.59 rear?
  37. [LT1 Edit] LT4 file has wicked A4 program for 2.59's :)
  38. 727 or 730?
  39. 89 corvette automatic stock bin needed.
  40. When should I go to Closed Loop?
  41. Can you electrinically adjust left right BLMS
  42. Overdrive light stays on with ARAP
  43. 396 LT-1 data needed.
  44. What is the best programer out there?
  45. Ok who burns chips for ZR-1s in here?
  46. Big Cam Idle problem - Chip Tuning, Torque Converter? [HELP]
  47. Does reprogramming void the warranty??
  48. Anyone using LT4-edit... ?
  49. 1/4 mile success with tuning
  50. Is my problem the knock sensor?
  51. Is MAF monitored at WOT?
  52. database resource for Forum tuners
  53. Need a little help from you 87 vette owners.
  54. aldl-interface
  55. website for 870 to 730??
  56. 84 C4 Conversion
  57. 85 stock eProm bin file
  58. Injector pulse width on '86 MAF 165 system
  59. Cold Start Injector - Like to program it out.
  60. Wolf3D system... Has anyone used it?
  61. Wher to time spark?
  62. Error code Questions What does it all mean!?
  63. Any one in St. Louis, MO have LT1 Edit for OBD II?
  64. What to change?
  65. Can I use this Ed Wright Chip in my 1990 Coupe?
  66. cross post from tech
  67. Knock sensor
  68. Got the Knocks
  69. EPROM burner, eraser, cable, etc..
  70. Scan Values???
  71. trouble codes and 94 vette
  72. Need a Memcal/Calpak
  73. Scan and Edit tool
  74. Pulled codes from the 84" today
  75. what ecm am i running? this is a stock configuration
  76. 870 to 165 conversion successful
  77. Anyone burn there own chip for a LT-5
  78. Preferred software for LT4?
  79. Programming for a 95 LT1,Who is the best?
  80. Data Cable Connection Question...
  81. Found an ALDL connector, now I need software.
  82. has anybody used the holley 950? Is just a chip better?
  83. Won't start/idle -- Ideas? I have data
  84. Diacom Comm. Prb's to a 92
  85. Where to get modules for 90 vette ECM? GM part#?
  86. Where to buy software for the 96 LT4?
  87. Loss HPP tuner
  88. Code 43...Knock Sensor. I need help
  89. Woohoo WB O2 !!!!
  90. LT1 Edit vs Tunercat
  91. anyone using a DFI Gen 7?
  92. 93 LT1 timing chain / ecm coversion. Plz read
  93. 85 burn off module fix?
  94. What do you think of these air/fuel numbers? Need Help.
  95. Jerking
  96. Any shopps out there to help tune my 93??????
  97. just logged some time with datamaster, now what?
  98. 85 Tune-up HELP
  99. Spark knock, or NOT?
  100. Im StresseD = ( i have a 93, building a 388 solid roller. how will i tune it??
  101. First PROM, 200 more to go :)
  102. Quick note about MAF
  103. O2 sensor volatage?
  104. Question about CALPAK and LIMP HOME mode >
  105. Fedex brought me something today :D
  106. I have the perfect laptop for 200.00 to use with datamaster or tunercat
  107. LT-1 Edit (help) Web Sites
  108. Chip numbers
  109. What's the best route to tune an LT1 (396) Florida
  110. Maf Tuning
  111. chip and thermstat for sale
  112. chip wanted
  113. Need LT1Edit guru's inside...
  114. Help newbie get started burning chips
  115. Laptop Diagnostic connection ?
  116. Can 85 MAF be used with 165 ECM?
  117. Ease diagnostic software and hardware, potenially for sale.
  118. is there some instructions around here to build your own cable for the cmoates software?
  119. ECM interchange for 1226870?
  120. Success
  121. Burned my first few chips yesterday
  122. Anyone have the latest '85 CHIP ?
  123. Calling all ECM tuners in NC!
  124. Paging Craig Marcho...
  125. '95 Vette PCM vs. F-Body PCM
  126. Sanity check 89 ARAP code in an 88 auto
  127. FX-3 with no ABS ? in 90
  128. Stumble
  129. Trouble Code
  130. Prom chip change HELP?
  131. Looking for bin file for my setup to maximize for timing/ fuel etc.
  132. Modifying cylinder volumn in bin
  133. LT1 ScanMaster ?????
  134. Corvette Tables in an F body?
  135. TTS Mastertune?
  136. Help with '85 Vette computer
  137. diacom+excel for tuning VE tables
  138. Any suggestions on performance gains with tuner cat?
  139. MAF to MAP
  140. Paging Craig Marcho
  141. Datamaster Question
  142. Needed: LT1 Edit file for a stock '96 LT4.....
  143. Making up a spreadsheet for VE tables..
  144. dead PCM
  145. Has anyone ever thought of a Group Buy from carputing for their LT1/LT4 edit stuff?
  146. Cable compatablility
  147. Deleting EGR...
  148. Ok i give up, somebody help PLZZZZZZZZ
  149. Best stuff to get started with.
  150. CCS Motorsport in Hutto TX
  151. Anyone in West Mi. burn chips or reprogam ecm?
  152. Can someone look at this Datamaster file, this is my 1st run..?????
  153. Is there anyone in the Austin Tx, area with LT1 edit?
  154. Well, its official... I'm ordering the FAST Bank-to-Bank w/ wide band O2
  155. Thinking about getting a diagnostic code reader
  156. Bad Sensor or Computer? CalPak?
  157. Anyone running the F.A.S.T system on their 1992-1996?
  158. Strange BLM issues...
  159. Anyone have a bin for a MAP ECM with Hotcam and ported heads??
  160. NEED A BLOWN 96 VETTE COMPUTER PROGRAMMER
  161. ECM code 45
  162. Winbin ecu definition file for the 870
  163. Semi-Custom chip wanted.
  164. AIR delete tuning
  165. Whats the correct way to set Idle on my '85 Vette?
  166. HEY SCORP!! EASE Screen shots (links)
  167. Moates ALDL software HELP… 1990 Convertible
  168. How to......swap newer model(faster) ecm into 1985 vette?
  169. What do I need To tune My LT4??
  170. 10k ohm resistor in ALDL?
  171. Auterra Scan tool
  172. New AKM Cable for sale
  173. Difference between Short Term / Long Term Fuel Trim
  174. New Snap-On ODBII handheld scanner.
  175. 1985 ECM is bad, what to replace it with?Don't say "a good one!"
  176. OBD1 and Palm Pilot: what scan software will work...
  177. 165 to 730 swap guys, quick/easy question
  178. Needed: LT1 Edit file for a Stock '96 A4 3.07 Vette
  179. Auto and Manual ECM differances?
  180. 85 MAF, what type of signal is it sending to ecm?
  181. 86 Prom/Diacom
  182. scan software? does anything work with win XP?
  183. Need help for new CHIP in CT.
  184. Best scan tool for my 87
  185. The Saga continues......
  186. Trouble shooting and Diacom Connecting Issues (complex)
  187. L98 with hotcam and mods, where should i start with tuning?
  188. Coolant Temperatures
  189. P/N Safety Switch and Standard to Automatic.
  190. LT1 edit or tunercat?
  191. Just found a tool to make repinning a breeze!!
  192. what can i change on a stock 90 chip
  193. A/F ratio readings
  194. ECU file for a 16159278 ecm
  195. Shes getting hot after a hotcam install
  196. .def file for 93 LT 1
  197. New heads and cam.. first time programming
  198. Does the ECM buffer the program then run?
  199. ecm codes
  200. accel gen 6 question
  201. Speed-O-Meter
  202. ? about '94 Vette OBD connector/ECM
  203. EASE or Diacom
  204. Clearing ABS/TCS codes for a 90 C4.
  205. First Scan & Timing Retard
  206. Timing table example?
  207. WinBin .ecu file for a 1227165 ecu?
  208. Is my ECM broken? :(
  209. 870 ECM to a 165
  210. 1994 ECM/PCM question
  211. dyno tune, results
  212. New FAST ECM and car won't start - can anyone help me?
  213. Fitting a F.A.S.T. ECM to an '85 C4
  214. Tunercat 32Def Tables
  215. Does anyone have diacom plus that will work on a 95 vette.
  216. Is it me or does this sound crazy?
  217. LT4 heads & Hot Cam
  218. Help!!!.... I'm in PCM Hell!!!
  219. Need some help with ScanTool OBD1 use
  220. Calibration table
  221. looking for custom chip
  222. What resistor to use and where? 165, 7730 and knock sensor
  223. Replacing stock chip
  224. $600 for hal shocks and both top front bushing ripped and pushed the shock thru
  225. Is 1995 OBDII?
  226. Diacom Question...
  227. Is there such a thing?
  228. Marco can you read Datamaster files???
  229. OBD-II Observations
  230. I'm confused about AutoTap software...
  231. My car hates our chips.
  232. chip guy ?
  233. ALDL Connector Cables? Where can I buy...? Price?
  234. What is needed to burn 29C256 chips?
  235. Diacom cable
  236. Bin needed
  237. ASR and ABS ligts come on under hard acceleration, interm. chk engine
  238. How hard to repin for 1227727 or 1227730?
  239. Where does speedometer get its info from?
  240. How dificult is it to program for my 36lb. injectors.
  241. system staying in "fuel trem cell 4" after 730 swap
  242. Replacement EPROM question
  243. Fastchip expectations?
  244. GenVII engine management system
  245. Turbo 400 and speedometer gear ?
  246. Do I need a chip programmed and what can I expect in return ?
  247. Higher fuel pressure and leaner mixture
  248. Looking for bin file for 93 383
  249. Stall during warm-up
  250. AXCR.bin not working/causing ihunting idle?
