- anybody have feedback on EP ROTORS
- One other question about pin assignments for 165 to 727 swap, sorry.
- Engine oil temp connection-converting from 165.
- Tunercat with a 1993 hypertech chip file ......NEED HELP!
- '86 intermittent TCC/mpg and odd scan data values
- TunerCat Table HELP...where are the rest???
- 870 to 165 Conversion Instructions
- 870 to 165 people
- 1993 MEMCAL question
- WinALDL version 1.09b
- Need Help LTPWS Light on
- 92 Ignition Wires
- Engine recommendations?
- 85 ECM to 88
- How to tune a 92???
- WTB: 727/730 Memcal/PROM
- Engine Run Time
- general tuning questions for 96 LT4
- LT-4 With Hot Cam using LT1 edit. How much can you advance the timing?
- 7747 to 7727 swap nightmare
- 1995 PKE Diagnostic Check
- Can't read my PROM.
- What is the EOT sensor?
- Another 727 pin question.
- Injector offset table needed for Z06 28.8 lb injectors
- 7727 wiring question on 12V power
- Any Vette tuners in S. Wisconsin or the Chicago area?
- 7727 pinout
- What computer problems might I soon have or need to prepare for.
- Need 1993 Ruby PROM file for evalution ASAP
- Haltech E6GM ??
- Any gains by tweaking a stock L98?
- Autotap?
- Help removing wires from 727 ecm plugs, please.
- 88 c4
- stumble
- Need help with DFI car stalls every now and then...
- What is the purpose of the Bleed Valve on a LT1
- CHASSIS DYNO RATES NOW ONLINE>>
- Calmap 350 LT4 hot cam files
- Can I tune out cutouts in the 1500-2000 rpm range?
- New to this board - looking for L98 tuning info
- Need Quick Answer. What type of speed signal for computer?
- p1416 air system bank 2
- Sweet! Needham's EMP-31 - burn a prom via USB!
- if some one is willing to burn a chip for me, i can trade with CASH!
- WIDE BAND O2
- OBDII programming software
- Already have a laptop, still need scantool?
- Jumpy timing????
- Help interpreting TTS Datamaster data
- New to the section
- Connecting DIY WB 02 to 165 ECM
- BLM's (Long-Term) stuck on 108...help!
- Why would a scan tool do this?
- custom PROM, Holley commander 950, FAST, or DFI??????????
- Ecm options?
- ecm upgrades
- DataMaster says "Selected" gear is not same as "Active" gear...HELP!
- conventional distributor in an LT-1???
- Help with Hypertech
- Pulling codes on a 94 with out scanner tool
- Which is best scantool/software for '96 LT4?
- MAF Frequency on a '96 with Autotap
- Long tubes after shorty's, do I need to retune PCM?
- Good source for cables..
- $32b Tunercat now allows cold start programming.
- Intronics Romulator
- Buying a new scanner???
- e-prom burning eqiupment?
- Looking for someone in Southern CA to dyno-tune (program) an '89 MAF L-98
- [Paging] Marcho Polo
- 94/95 LT1 Tunercat updates....
- WinALDL
- Code 34 Bye Bye - SO FAR!
- Knock Sensor Location
- Split BLMs on LT-1, when fixed does Idle and HP and torque improve.
- I need impartial feedback on the haltech E6GM
- This stuff can't be that hard...
- tunercat
- Trouble code P0100
- 92 VETTE WITH 2151 LONG TUBES
- 870 to 165 conversion question---which MAF do i use?
- aldl cable to laptop,where to get one.
- If you were buying eprom burning equipment....
- Paging Scandinavia
- need advice for tuning my 96
- I might need a new ecm, do I need to redo my Fast Chip?
- DOC'S LAKE SHACK "CORVETTE GIVEAWAY" Benifiting AMBUC'S & HELPING HANDS
- Recommended scanning stuff for 91 L98
- How do you get a stock ECM to deal with a big cam?
- What tells PCM which gear car is in? / DTC Code 97?
- False BLM Reading from Scan Tool
- Opti debugging...
- Diacom for Dummies
- Reprogram needed with different injectors with adjustable FPR?
- hypertech III vs Carputing
- SLIGHT MISS?
- Pcm tuning software HELP
- Tach going crazy
- scantool question
- how high can i go with compression ratio? 96 LT4...
- VPC??? MAFsux
- Any ideas on code P1416?
- What programs allow change of VIN to .bin/.lt1 files besides VinEdit???
- Help! All I need is info... MAF voltage
- Signs of a dying (or dead) PCM?
- any scanning software that works with the parallel port???
- Read and Duplicate once
- Datamaster Cylinder ID#'s ?!
- Interpret DataMaster scan files?
- Always get "Security Violation" when trying to read PCM w/ TunerCat???
- ECM blackouts
- Reading PCM w/ TunerCat & WinNT???
- ECM Program logic?
- Chip#1 Trouble
- bad ecm or what
- resstting a Hypertech....Does anyone know how?
- My " SERVICE LTPWS" light is on
- What do you know about MAF meters?
- SD and Super Ram base
- Is my PCM from a 4.3L Caprice!???
- DTC Code 43??? Datamaster data...
- Code P1133 and P1153? WTF?
- New to the chip area
- baby steps
- CalMap 5.0
- MiniRam 396 ... what to do???
- What the.....I don't have a MAF BUrn off Module on my '85??
- Painless Harness + Memcal
- AutoXray code deciphering...help!
- Done a bunch of research, but I'm still lost
- I need a BLM genius
- I spoke too soon. Code 33.
- how do you recognize a non GM prom
- code 52, cheap source for a prom?
- Any chip burners in Va Beach area?
- Thanks for the code 33 help!!!
- OBD-1 Trans help needed
- BLMs @ or near 128, and car is now getting slower?
- O2 volts ???
- stock chip from '88 auto same as from '87?
- Diacom connection cord
- Great Custom Chip
- How do I unhook the ECM? (86)
- Supercharges and VE curves (Speed Density)
- 8th Digit of '95 F-Body w/ A4 VIN???
- What Laptop Do I Need?
- help needed
- 85 MAf burnoff removal ?'s
- Code 33 is kicking my butt. (86)
- Win95 on floppy???
- I want to drop an LT5 engine into a 1989 convertible…
- Looking for stock prom load AYBK for ECM 1228331 (for 90' ZR1)
- 160º T-Stat + Stock Chip = No Open Loop?
- LT4 running rich on cold start / autotap question.
- What is the difference between a 870 and 165 ECM?
- What kind of 'puter runs ECM/PCM?
- Wide Band Sensors
- Scanning???
- TunerCAT
- Problems scanning
- Problems with Tunercat....need help
- LT-1 Cold #1 & #8 cyl??
- 383 SC bin file needed
- I'm Cornfused.
- Reading from, Writing to, and Logging PCM data...how MANY things are needed?
- TURBO L98 project
- WHat is highest possible redline for LT1 ecm/pcm's OBDI
- BLM's too high?
- LT1 knock sensor
- Data Master Web link?
- Turning Off and Deleting AIR System?
- Do I need a custom chips?
- BLM numbers?
- High CO output
- I PRESS SCAN AND TUNE AND GET ZR-1
- What does the broadcast code do exactly?
- I just need to retrieve the codes...what to use???
- MAP voltage vs. Kpa values
- TPIS ZZ9 vs. LT4 HOT Cam Comparison - Looking for Hard Data
- ACCEL DFI 015016 Linear O2 ECM
- Auto X-ray Timing data
- How can I change my 92 ECM settings?
- Need to help forum member.... anyone have a '86 4+3 bin?
- Programming for no cats while they are still in the car?
- Tunercat Speedo Calibration
- ok I will ask you guys 87 idle prob
- What is causing my rich idle?
- IAC driving me crazy
- LT4 edit?
- Where can I find information about the CCM?
- Help a brother out
- Anyone have a stock '95 A4 Image?
- Timing problems on carburated 86
- Newbie first scan ???,s
- Static injectors ????
- MSD Injector Matching Software
- 165 to 730 swap-ecm then fits how???
- easy way to convert 165 to speed density ECM
- Santa says "she'll" bring me a diagnostic scanner for Christmas...any suggestions?
- Paging -=Jeff=-
- 95 OBD-1 With 3rd O2 Sensor On Pass Side Can It Be Programmed Out?
- ECU swap? My VE table poops out after 5600rpm
- SVO Injector tuning problem
- Brand new EPROMER5 Eprom programmer
- My car will start and run for about 5 seconds. Any thoughts?
- Anyone here tune for Mini Ram?
- Tunercat & Windows XP
- Which Side Is Which On Datamaster Software / BLM's O2 MV ETC
- Is Datamaster Injector Duty Cycle Accurate?
- Can exhaust leak cause KNock Sensor codes?
- DYNO numbers with and withoust FAST computer??
- Did my first data log, timing experts step inside please
- Need chip('93 LT1 w/hot cam)
- How do I read the stock bin? 93 LT1.
- Can anyone interpret my ATAP for me..Please!
- Can't connect scanning software to 165ecm
- Haltec F3 EFI
- code reading
- Predator-Any MN6 Comments Yet?
- DATAMASTER AVAILABE FOR 86-89!
- Another can this possibly be right question, VE tables now!
- Can someone burn me a chip for a 93 LT1. Stock motor.. only need.....
- tune a 96
- Disabling VATS in the chip doesn't work?
- Can this possibly be right? Spark advance tables?
- pcm for less? what do you think?
- Anyone here dropped a Vette LT1 in a non-vette body? (retrofit)
- EGR code with Hot Cam
- Tunercat, make sure you are up to date!
- Need LT1 Corvette ALDL related help
- custom Eproms
- Injector ECM calibration
- Hot cam timing table
- Accel DFI ECM 015013 questions
- Who here can burn me a chip?
- [TC]: Fuel % means what?
- 2 Part Q. --- Change fuel at high LV8 or in WOT vs. RPM table?
- Lambaboy logging....
- [TC]: % Change Air/Fuel Ratio vs. RPM
- Scanner recommendations??
- Tunercat
- MAF maxes out, O2mV goes to hell.
- Looks like I fried my ECM somehow....
- I changed the cylinder volume constant and.................
- I need FAQ pages....
- Can I use a 27C512 in place of a 27C256?
- What programmer do you guys recommend for 1995?
- Anybody know how to make this programmer work for me? Needhams PB-10
