View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26
  1. ECM guru's help - can you interpret this data?
  2. Help! Need Accel Calmap 5.0 map
  3. ECM numbers???
  4. Laptop with tunercat and datamaster for sale and OBDII connector
  5. Need help, Orlando area, 94 ECM programing for fan turn on temp.
  6. Dumd newb question, which way does the PROM go in?
  7. # 16198260
  8. got OBDI, got AKM Cable, Got Laptop... what software??
  9. HELP knowledge wanted
  10. Just upgraded my ease tool to the pro edition
  11. Batch fire to sequential fire? (92 to 94)
  12. Oil Temp
  13. This might help on injectors?
  14. Ed Wright chip in exhaust is (HOT) Stock Chip Not (warm)
  15. Accel enrich in the 730
  16. Who is running 24# injectors, and/or stock fuel pump with their 383?
  17. injector pw
  18. Tried to burn my first chip??????
  19. Forced induction guru's
  20. TechEdge WB O2 unit
  21. 85 and 165 ECM upgrade issues
  22. limits of the 730 ecm.
  23. Carputing Responds!!
  24. auto trans settings
  25. ASR/ABS service lights came on!
  26. Battery Light just popped on and stays on now..
  27. At what setting do you put a voltmeter to set the TPS at .54?
  28. Kudos to Craig Moates.
  29. LT1 intake manifold swap, Chip programming.
  30. Where can I buy ECM pins?
  31. VE Master question.
  32. 1990 Corvette
  33. Who can overnight me AT29C256 chips?
  34. Disable ASR!?
  35. Where to buy a stock chip/memcal?
  36. Intermittent VATS Problem After Reprogramming PCM
  37. POCKET PROGRAMER II AND 01227165 GM ECM FOR SALE
  38. 1996 owners idle question
  39. Overheating 93
  40. 396 LT-1 tuner please read
  41. looking for $42 BIN file
  42. WB-02, anybody using this one?
  43. What do I need to run TTS datamaster on my 93, laptop? Cable?
  44. PCM download failed. What are my options?
  45. TTS datamaster scan software for 89
  46. Wild data log of bad run
  47. Romulator
  48. Tuning tables after 730 swap?
  49. Anyone do the later MAF ECM swap into an '85?
  50. Tuners: WBO2 meter up for grabs
  51. 727 vs 730???
  52. help no com 1 on laptop ???
  53. PCM Programming - Now PCM Dead!! HELP!!!
  54. Code 13 Oxygen Sensor Circuit (open loop)
  55. Modification questions
  56. start up enrichment VS coolant temp?
  57. Problems with 86 Security system/ PLEASE HELP!!
  58. Great transaction with SBNova!!!!
  59. TunerCAT - Dowload/Upload PCM Flash Memory?
  60. Could I get some help from someone in the Phoenix area?
  61. best pda for scanning
  62. MAS READS LOW AFTER ECM SWAP
  63. Another ALDL <-> RS232 schematic for you
  64. Ease OBD1 GM software updates v2.0 ??
  65. scanning at Idle....QUESTIONS!!
  66. Needed: '92 LT1 6-spd Bin
  67. O2 sensors
  68. (4L60E / tunercat) Improving downshifts
  69. DIACOM cable, will it work on TTS datamaster?
  70. (tunercat) "vats select" and "crank air select"
  71. Is the romulator a permanent replacement for a chip??
  72. Getting codes 34 and 36 on my '87.....
  73. Need 94 A4 stock PCM file
  74. No response from Carputing...
  75. Parked battery drain?
  76. September Code sharing agreement?
  77. what changes
  78. romulator
  79. SD 730 ECM conversion kit for sale
  80. Looking for 92'-93' Datamaster logs for stock or modified vette
  81. Needed: 93 Corvette 6sp stock BIN File ($DA2)
  82. beginner
  83. wideband questions
  84. Recommended Diagnostic System
  85. TunerCat or LT1EDIT?
  86. Reprogram for different injectors
  87. Idle problems, IAC counts ??
  88. How to display GM calibration info on 1993+ cars?
  89. SES LIGHT FLASHES, O/D LIGHT AND COOLING FAN ON WITH KEY TURNED ON
  90. DIACOM plus users, what is the longest you can record?
  91. Finally!!!
  92. O2 sensor mv at WOT for LT-1's?
  93. Pocket Programmer 2 software password?
  94. jet chip
  95. 93 LT1 Problem
  96. Split BLM values?
  97. HELP Please! 1988 and Diacom -- I can't link
  98. DFW-Scanner needed
  99. Baseline tune for a Supercharged Vette, How much fuel?
  100. Low oil pressure light
  101. and after the first burn
  102. Romulator Question
  103. i need computer help..
  104. 1227165 with supercharger and 2-bar MAP
  105. Diacom pull with Long tubes installed, can you tell me if I need tuning?
  106. 1993 Corvette LT-1 Chip, what kind do I need to buy?
  107. Code help
  108. Help with upgrade from OEM to Pioneer Supertuner III
  109. FOR SALE FAST ENGINE MANAGEMENT SYSTEM
  110. I need a cable !!
  111. TPS Percentage
  112. adjustable fuel pressure reulator
  113. 85 switching to 86 computer
  114. Where to buy stock ECM chip for a 92?
  115. How to tune for startups....
  116. I need a chip burned!
  117. P0171 Fuel Trim Lean 96 LT4
  118. Question for Romulator users
  119. ALDL/Serial wire voltage question..
  120. Miss Driving Me Crazy
  121. Romulator users: does your unit work Ok when HOT?
  122. HAVE LAPTOP & 1993 LT1 OBDI (Cheapest way to scan sensor volts, knock count spark advance)
  123. Would my car benifit from a reprogrammed prom with the miner mods that it has?
  124. won't start
  125. Problems after 730 ecm swap
  126. Palm Pilot
  127. adjust the knock censor..
  128. tuning advice
  129. Code P1441 Evaporative Emission System Flow During Non-Purge (GM) ? Help
  130. crazy knocks.
  131. ccm code h 74 ?
  132. LT4 TROUBLE CODES
  133. FAST Bank-to-bank or Accel DFI???
  134. Do I need retune on my 396 LT-1 after installing Long Tube Headers?
  135. Anybody got a stock '89 6-speed BIN?
  136. Who's using the Lamdaboy or Lamdaboy Jr. ???
  137. Professional Grade Help Needed!!!!!!
  138. Used or new Accel Gen 6???
  139. Datamaster Expert Needed
  140. otc 4000 enhanced/laptop link?
  141. Pin connections for the "8051" PCM (F-body)
  142. Any Supercharged guys get Ed Wright chips???
  143. Mass Air Flow GM/SEC Low Code 34
  144. Real Knock False Knock ECM Gurus Help Please
  145. 95 LT1 auto Bin
  146. Supercahrged Minirammed help needed - stumble and intake pop
  147. 90 Timing Problem
  148. ZR1 to Northstar
  149. Tuning in Atlanta North GA area
  150. OBDII Scan Software
  151. Adding wires to aftermarket harness...
  152. Just cranks need help
  153. First Flash Using LT1 Edit for OBDII!
  154. Hard Starting 87
  155. Paging MarkLT1
  156. Cant find Ed Wrights email...
  157. WOT Tuning...
  158. Getting back in....
  159. how can i scan my 85 ?
  160. Scan Software
  161. ACCEL DFI 6.32...Can it read an O2 voltage greater than 800mV?
  162. 94 lt1 auto stock bin
  163. 730 ECM SD location/swap
  164. Lt1-Edit files for 1996 with Mods- Compare Notes
  165. mod MAF question
  166. Sorry for the cross post, but selling my car with LT1 Edit
  167. VATS Fuel Enable Error???
  168. NE1 know settings for Drag racing using of CAGS?
  169. console
  170. How do you log your Data???
  171. Hope this isn't too silly of a question...
  172. Anyone have problems with Datamaster and a max232 based connector (92 vette)
  173. tuning with datamaster
  174. Ez Link Question?
  175. start up with sc
  176. Service engine light not functioning
  177. tunercat ecm files..which to use?
  178. Diacom adapter 91006
  179. Good dealings with AKM Electronics
  180. ECU/definition file for 1985 L98 4+3 needed
  181. BLMs 108-120 Question
  182. Laptop mounts?
  183. WinXP Laptop, no serial port......Any Hope For Scanning Woes??
  184. 870-165, OD turns on automatically when shifting from 1st to 2nd
  185. Predator reprograming?
  186. LT4 Tuneing....
  187. 1985 vette, zf and 3.73 gears....what about speedo?
  188. Kick panel removal-- speaker at the left foot (more)
  189. BLM's on LT1 with mods...Help Needed..
  190. Someone really good with LT1-edit 96/97 OBD2...
  191. DataMaster GURUS Please Help.
  192. Broadcast Code ASWH ??
  193. lt1 tps vs tpi tps
  194. 870 to 165 and have 7 error codes?
  195. Initial Spark Advance Parm. Question
  196. Spark knock using the Hypertech Power Tuning
  197. Moates S/W and 91 Auto Bin files
  198. TPS Voltage ????
  199. Newbie needs tuning help with an 85 383 super ram car. located in northeast TN
  200. What is "secondary air injection system valve A"
  201. How dod you tune WOT?
  202. Tachometer Calibration?
  203. What are you setting for C.Moates for a 92
  204. Bin and ECU Files?
  205. base pulsewidth for a 383 w/ 24# SVOs
  206. 1991 manual bin file.
  207. MAP 730 ECM tech Q's
  208. How should PE AFR be set?
  209. VATS KEY CODES
  210. 85 ADL and 165 ECM, do they conflict?
  211. HyperTech Power Scan Modual Software...
  212. Chip Tuner Options?
  213. BLM cell boundaries
  214. ODBI and EEPROM Question....
  215. vemaster
  216. PROM 1227805 and WinALDL
  217. Stock bin for '86 Corvette with iron heads.
  218. Wanted: Hypertech Tunngin Modual pn#5001
  219. bin files
  220. Block Learn w/ 24# injectors?
  221. PROM burning help
  222. Scan/Performance Tools.... What's The Best?
  223. Daicom HELP!!!!
  224. My Research into the $$ of Tuning
  225. newest TTS DATAMASTER scan!
  226. Service Engine light (checked the code for TPS) and need help
  227. what are you other guys with 96's doing to edit your ECM?
  228. ed wright says i won't be able to change his tune?
  229. Stock car runs rich and gets timing retard, help me fix it! Dyno info inside
  230. my first DATAMASTER scans.
  231. ECM/PCM
  232. FINALLY-It starts
  233. What am i doint wrong with Datamaster Dyno
  234. Datamaster logging sort of new at it but... Knock at 100%TPS
  235. knock modual
  236. Fan Hysteresis.. what's it mean?
  237. O2mv
  238. Looking for Lt4 Injectors
  239. 383 Backfiers
  240. looking for used pocket programmer
  241. New 383 with stock LT1 program, will it run?
  242. Tuning for larger injectors
  243. Ease with no db9 port
  244. test
  245. Check this out if you haven't seen it on the tech section...
  246. PROM burning
  247. here we go.
  248. VSS/ECM relation question
  249. converting to 92Fbody 730 ECM MAP system. Q about VSS
  250. cooling fan
