View Full Version : C4 Scan & Tune
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Timing jumps, normal?
  2. does anyone know of any tune software, for 92-93 lt1, which allows ind cylinder fuel
  3. 1995 Convertible Tuning Validation
  4. Time to take my first steps in prom tuning
  5. Autometer tach question on LT4
  6. How to wire up a Dakota digital box for your 4.10 gears
  7. Emulation
  8. Problem retrieving codes 89 vette
  9. Prom Tunning Equipment Advise for a 90 L98
  10. need dyno tuner
  11. Scanning software for a 1996?
  12. What is the best program to use to tune 1994 383 with Pro Charger F1?
  13. who makes the best chip
  14. I need ALDL Class 101
  15. ALDL Spark Adder Question
  16. Best scanner???
  17. FYI: GP on Wideband O2 Kits
  18. Tuning help, Newbie and Meth Injection...
  19. 1995 tunning
  20. 57 LT w/4l60E
  21. Switched to ARAP, no MPG readout? 87/Auto
  22. idle too high after new chip?
  23. Need to talk to my 93
  24. min % TPS to enable power enrichment
  25. Looking for a tuner in houston
  26. Question on BPW constant / switch
  27. LT1 Edit price
  28. Need Help.........
  29. unstable idle during warmup - fixed!
  30. need some help
  31. It was a 1990 now all new and.....?
  32. is this the FSM I should for my 86 ?
  33. •► ► MERRY CHRISTMAS & HAPPY HOLIDAYS from CHUCK CoW & CORVETTES of WESTCHESTER ◄ ◄•
  34. BLM advise needed
  35. old school guy went FI
  36. MAF Switcheroo
  37. Car idles better with A/C or Heater on?
  38. Optispark, here we go again?
  39. Optispark, here we go again?
  40. Where to start?
  41. i'm new 2 datalogging......will u help please?
  42. axcr.bin file needed here pls
  43. tech 1 cartridge on ebay
  44. 94 LT! "esc" circut board rt side rrear of engine
  45. Engine Check Light Question?
  46. Bins and Definition Files
  47. Whats best obd2 code scanner?
  48. ZZ4 Cam timing advise
  49. Need Help Understanding OBDII info
  50. C4 ALDL Codes
  51. Pull codes of 1985 with paperclip
  52. WOT vs Open Loop AFR settings Question
  53. C4 electrical issues
  54. Buying a scanner need advise!
  55. Enrichment Question
  56. Anyone have a Burn 2 they don't use anymore?
  57. Custom Prom VATS Disable
  58. If you need a tuner in Arizona . . .
  59. HP nc6220 P4 M 1.7GHz Notebook-$179.99-GREAT FOR TUNING! FREE SHIPPING!
  60. Interesting fact about Winaldl
  61. TTS DataMaster vs GM Tech 1
  62. How do I disassemble a 1992 ECM?
  63. Datalogging on an 84
  64. Need help with a DFI GEN VII Tuner with dyno in Houston
  65. C4 Break up, stutter, stammer or whatever.
  66. '92 LT-1 Starting issues. Not reading ALDL connector.
  67. Tech 1 Functionality with Other Software?
  68. GM Auto Computers
  69. If you need help with accel dfi.......
  70. VATS Module question
  71. Intermitant failur: Engine cranks, will not run.
  72. remanufactured ecm chip problem?
  73. 85 chip
  74. Prom
  75. Ecm/pcm flash or chip?
  76. Troubled
  77. question on chip and transmission
  78. Mini Ram fuel issue
  79. timing 1990 L98 ?
  80. 1993 z28 ecm?
  81. Is seal replacement possible?
  82. Codes in TTS Datamaster
  83. How do I reset the fan temperature in the ECM on my 88 L98?
  84. Hypertech Power Chip?
  85. Hypertech Power Chip?
  86. will it run without it
  87. BlowerWorks MAF update
  88. TTS Datamaster scan
  89. 85 Vette Idol Problem
  90. when close to stock how much does tuning really help?
  91. tuner pro problem
  92. Recommended Free ODB1 Scanning Software
  93. Solenoid Maintenance How to
  94. idle relearn
  95. 85 corvette 9th injector
  96. 96 PCM in 94
  97. '95 LT-1 factory stock tune
  98. Blowerworks MAF
  99. Installing Accel Thruster on 1985 - harness question
  100. 1996 tuning software
  101. 86 Roadster - Ck engine light - no codes???
  102. Dayton area help
  103. Optispark Units
  104. F.A.S.T. part number?
  105. Blowerworks MAF
  106. 93 LT1 6-speed: how conservative is the tune?
  107. Strange intermittent code 43
  108. Using ECM with ZIF socket ...Cover removed ?
  109. F.A.S.T or Gen 7
  110. How to check if your fuel pump is bad?
  111. Is anybody using a 0-60 mph calculator ? Datamaster maybe ?
  112. Timing Is Retarding During Acceleration
  113. oil pressure low?
  114. New Engine, do you have a tune for it.
  115. Typical pulse width??
  116. Knock question
  117. help pls! my car is running too rich!!
  118. LT4/Manual into '94 LT1/Auto
  119. To Tune Or Not To Tune
  120. Fuel injector constant
  121. fuel presure help wanted here!
  122. My first Datalog ,87 L98 ,TunerPro RT (LEAN CONDITION)
  123. TPS voltage setting on 90 ZR1
  124. Dyno tuning a 383
  125. O2 Sensor Upgrade from LT1 to LT4 - WIRING
  126. Please help!
  127. 1987 Tune ...just starting to getting into it
  128. Anyone used Tech1 on 86-89?
  129. Smelling Fuel- loss of power ?
  130. spark advance and rich tip in shown on Wideband
  131. scantool/how to monitor knock question
  132. 1994 c4 finding top dead center
  133. Tune a 95 what do I need
  134. 85 surges and irracted idle
  135. Accel Gen 7 DFI with dual sync no spark
  136. mastertech "waiting for data"
  137. radio antenna
  138. paint code
  139. 1992 chip question
  140. Couple of wiring questions
  141. Fuel Octane Ratings...... who's knocking?
  142. Whats the best cheap laptop for tunerproRT, needs USB and Serial ports.
  143. Tuner Pro RT / 1987 Vette
  144. optispark, installation-finding TDC?
  145. cranks too long before it starts
  146. Code 41 Cylinder select error...please help
  147. OBD I scanner on laptop
  148. Idle hangs a little high until I come to a complete stop
  149. ECU to ECM Piggyback Harness
  150. Clearing Codes
  151. changing stoichiometric AFR
  152. ostrich? can i just leave it on there? is it reliable for a daily driver?
  153. Getting Started with ALDL/OBD1 Cable...Help
  154. I Need A New ECM
  155. need help
  156. Datamaster: Over 1000 KPa (145 PSI) of A/C Pressure?!
  157. 160/108 blm split after cc503 install. logs attached - Help...! :)
  158. What is that thing
  159. Computer good or bad?
  160. anyone else done a 2 bar tune?
  161. MAF or MAP ?? OBD1 or OBD2 ??
  162. new guy has many ??
  163. 86 voltage question while hunting down code 33
  164. 86 voltage question while hunting down code 33
  165. 1996 Tuning Question
  166. Ostrich 1.0?
  167. datamaster da question
  168. DTC #36: Distributor Ignition System High Pulse.
  169. Anyone local have this ECM???
  170. 94 corvette trouble codes
  171. Need help with APU1 / Tunerpro datalogging
  172. Spark Plug's Brands Hints
  173. Is it safe to load in the ARAP Bin into 87 C4
  174. Help what power inverter do i need for a laptop with no batterie? sine wave question
  175. scan tool 1985
  176. Tuning for drag racing
  177. My first good prom burn
  178. Anyone dyno tune an '85 in Illinois
  179. 87 C4. How do you access the ecm for tuning?
  180. Anything out there better than a gutted MAF
  181. Anyone have experiance with a TPIS ZZX Cam
  182. Using F body ECM
  183. Bad PCM Symptoms, please help!
  184. Wide band questions
  185. Tuning problem
  186. TunerPro RT V5 Twitchy Connection, need advice
  187. TunerCat files LT1 6sp
  188. Vacuum diagram please
  189. Help ! Please !
  190. soooo... early model fuel injection
  191. 96 lt1 dyno tuner needed
  192. TunerCat assist for FORD 42# injectors
  193. Inverter?
  194. Help with new Throttle Position Sensor
  195. 87 Chip Mods - Worth doing?
  196. In need of the center cluster.
  197. need chip help
  198. 96 LT4 newb help
  199. 94 ecm swap, fbody into vette?
  200. ECM/PCM programmer needed for 87 C4
  201. no fuel pulse: basket case 1991 vin 8 corvettee
  202. Sunpro CP9127
  203. TPS % to trigger PE mode, forced induction 93 lt1.
  204. Gen 7 to 165 cable adapter?
  205. Free eprom programmer and eraser
  206. Reflashable chips for a 1990?
  207. Accel 74002-C
  208. DFI on a budget
  209. Software?
  210. Dyno Tune Near MD?
  211. 1992 display injector flow rate
  212. Basic Tune To Start?
  213. ALDL scanning issue
  214. Tablet PC for Sale
  215. Unmolested ANHT bin anyone???
  216. Where to Buy AC Delco Tune Up Parts
  217. Are All Ostrichs The Same?
  218. Will This Laptop Work For Datalogging?
  219. TunerPro Question
  220. Scan Data Review
  221. 1992 A/C problem
  222. So what do I need to get goin?
  223. Tuning noob needs help
  224. Tuner Pro RT won't save changes
  225. APZB or ARAS bin anywhere?
  226. whats needed to tune???
  227. max TPS voltage only 3.61 v
  228. Interesting ECM Pictures from Gathering at the Museum
  229. codes in 94
  230. Efi connection 24x
  231. TTS Datamaster sync problem with 92 Vette
  232. TunerPro RT no spark advance
  233. WINALDL Data
  234. what scan tool to use
  235. FS: Dell Latitude C840 Laptop - great for tuning w/ serial port and large screen
  236. help reading and then burning a chip for 89 corvette Moates G1 Adapter
  237. DVD car stereo possible in C4?
  238. ***Houston Dyno day/Car show - May 22nd
  239. EPROM guide
  240. lowering 95 vette
  241. fun with the 85...part deux
  242. somone burn a chip for me?
  243. Best Dyno
  244. Air Bag Light On And Code 16
  245. Upgrades and Chip program question
  246. Code 42
  247. fun with the 85
  248. Bins for '92
  249. Tuning Question
  250. First scan and blm question
