View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26
  1. Adjustable Regulator and SVO Injectors
  2. 165 ecm + Scannign tools questions.
  3. WHAT's THE BEST FUEL INJECTION SYSTEM?
  4. First time using WinALDL & Cable -87
  5. Should my stock prom be doing this?
  6. Can Anyone Help Shed Some Light On Moates Scan Info
  7. LT-1 injector questions
  8. Running Speed Density on 94 6 speed.
  9. Removal of AC Compressor on 86 Vette
  10. 85 383 into an Astro Van
  11. Intermittent Low Idle...
  12. LT-1 edit similarities to LS-1 edit???
  13. Software Reviews - number 1
  14. Need to locate a programmer for my OBDII ECM
  15. ASR Problem
  16. BLM Cell Boundaries-TC2 bug or?
  17. Code 42
  18. injector pulse width equation
  19. 1996 LT1 codes p0507 and p1509
  20. LT4 file for OBD-II LT1_Edit
  21. odd IAC behavior
  22. '96 dashboard/speedo/cc dependency to ecu
  23. P0300 random misfire HELP
  24. what's the best computer for my 91
  25. rich ONLY at idle...
  26. Translation documents 94-95 pcm
  27. Wanted any/all Corvette Specific VIRGIN BIN files
  28. Xtronics Romulator
  29. split BLM's - HELP!
  30. Monitoring Software - Your opinion counts
  31. 1997 Rims on a 1994?
  32. Need some advice...
  33. Scantool, adaptor, cables for sale if anyone is interested.
  34. OBDI? OBDII? What scanner do I need?
  35. Diagnosing engine problems with Data Master
  36. WinALDL Info...
  37. Best way to go ?
  38. Ski Down It / Others? Need Help with L98 Setup '85 ECU - Don't want to blow Engine - Again
  39. I am computer stupid!! Have?
  40. Anyone need a Diacom laptop?
  41. Win ADL and Mastach cable
  42. autotap says no short and long term fuel trims cuz i have O2 simulators??
  43. I think I have serious problems!!!
  44. Diamcom+ wont link to 86 ECM
  45. runs rich on one side
  46. Lets start a BIN collection!
  47. Mixture tables and WOT
  48. Injector Replacement
  49. Thought it was a code 52... Other symptoms say NO
  50. prominator....
  51. xxCxx eproms are cmos type re/writable without erasing, right?
  52. OBDII codes
  53. laptop recommendations?
  54. ECM Protype
  55. [Need]: Virgin BINs or Broadcast codes.
  56. New Heads - Backfire
  57. 86 vette code 33
  58. Stock injector how many lbs (1989)
  59. mr. gasket co. chip in 86 vette
  60. what do i need to burn my own chips? 1993 OBD1 - LT1
  61. O2 problems
  62. Diacom Trouble
  63. FS: UV eraser, Pocket programmer etc.
  64. '96 LT1 Code P1441...What causes this?
  65. 1993 Programing.....
  66. NEED HELP QUICK! what scanner to use for 96 with OBD2???
  67. i believe i'm gonna need lots of help...
  68. ECM Wont recognize chip in 1990
  69. 4+3 Tuning
  70. Pocket programmer v 1.90, anybody have the password?
  71. How can I tell if my car has aftermarket chip installed?
  72. O2 voltage bouncing around
  73. stock ecm bin for 92
  74. 92 LT1 ECM
  75. Diacom Cable
  76. USB scanning
  77. Unable to open serial port
  78. Need someone reputable in N.Dallas foe an LT1 "Edit"
  79. Another ECM bites the big one!
  80. ECM 165/32B Tuning Table/Scale
  81. going to 89 ARAP, please help with some questions
  82. question about moates software
  83. Can't get and maintain Closed Loop!
  84. program for 1994 corvette
  85. I need a 10V power source (SPEP Plus burner)...
  86. .bin for an '85. Do you have one I can compare with?
  87. tuning while on the dyno (171 rwtq gain)
  88. Prom Burning???
  89. How do I remove the ECM?
  90. Looking for 2 ZR1 BIN Files
  91. Having problems getting EASE to connect to my 90 ZR1
  92. Who does the best job custom programming for LT-4's??
  93. You guys that can read Diacom data, any opinions on these two saves?
  94. Need a better chip Help Help
  95. Cold Start since putting the SuperRam on
  96. Gas Mileage gauge way off because of fuel injector change
  97. Spark Advance in Diacom
  98. TX (North Dallas) Chip Burner Needed
  99. Best laptop to use.
  100. engine harness, 1985 to what year? 86, 87, 88?
  101. Anyone have a good basis for a super ram/ LPE 219 cam/ auto '91?
  102. Wiring Nightmare
  103. OBDI or OBDII
  104. ADS Chips?
  105. Fuel injectors opening time??
  106. Help code #36
  107. Late 86 Should I go With Moates or WinALDL ??
  108. Building WinALDL Cable Need Help
  109. Anyone used Westers here ??
  110. WinALDL / Cable problem (another one):
  111. $600 Wide band O2 sensor-Good Deal?
  112. Make your 89 start quicker.
  113. scanning my engine, buy a scanner or software?
  114. Want Software to read my L98 CPU please send me links here --->
  115. Safe LT4 rev limit?
  116. I got a hypertech chip for a 1991 stick
  117. turner cat, and 730 ecm users quick question
  118. "SYS" Indicator Flashing - What's up?
  119. [Update]: Tip-In fuel update & when to add timing?
  120. HELP ... 396 MiniRam almost ready to fire
  121. NewBie..
  122. Buddies of the tuning world....:)
  123. win aldl cable problems????
  124. What bin on an Late 86?
  125. 91 vette knock retard
  126. 91 vette
  127. An Unusual Request
  128. `86-`88 BIN files
  129. Tunercat? OBDII?
  130. Spark table Question??
  131. Pocket programmer and EPROM problem
  132. Engine break in / tune dilemma
  133. Help Please,,,Car won'Can someone checkout a datamaster file for me?
  134. [DFI Gen VII] cool snapshots we took today(no pics yet)
  135. reference signals
  136. Trying to tune with a scanner
  137. Is there a maximium amount of knock retard?
  138. NEED OVERNIGHT; 27C256 SD chip
  139. WON'T PROGRAM!!!
  140. Accel. Enrich. How to tell when in it?
  141. 91 VETTE KNOCK RETARD
  142. Passenger side valve cover removal
  143. Any one familiar with ProScan OBD II 2 Diagnostic Scan Tool?
  144. Hypertech Stage III
  145. WTB: 27C256 MEMCAL
  146. O2 sensor volts question
  147. EPROM questions on Fuel regulation vs. engine temp and also adjusting this curve.
  148. When opening file in CATs, everything is zero.
  149. Code 32 & engine miss
  150. Where to buy the plastic holder/insert for '870 chip.
  151. Need Help with programmer software
  152. 7730/7727 experts
  153. Timing at idle...
  154. Rich idle - possible causes?
  155. Convert L98 727 ECM To Boost Aware Sy/Ty 749ECM?
  156. [EASE]: Question on max frames saved per-scan.
  157. Making sense of the data
  158. anyone have news on diy-efi.org?
  159. [Tip in fuel?]: How to program it?
  160. VATS bypass for vette work on others?
  161. BLM's @ 110 (Idle)
  162. '85 ECM : Delta TPS Accel Enrich Pulses vs. Coolant Temp
  163. Carputing LT1/4 edit
  164. Mid rpm question
  165. low-end torque and programming
  166. Will This Laptop Work With Winaldl ?
  167. [Update]: Did some tuning.
  168. 86 ECM update and AutoXray Scanner
  169. ? about vats and 870 to 165 swap
  170. 'Detuning' spar/fuel at low rpms for less spin?
  171. ALDL Port differences for '830 and '165?
  172. Help with Scan Codes
  173. tech 1 scanner????
  174. WINALDL question
  175. [Diacom]: Ugh, check these scans out. :(
  176. Best way to correct MPG readouts?
  177. MEMCal adapter??
  178. Just ordered EASE.
  179. anyone know anything about the OTC MINDREADER 3750 SCANNER?????
  180. 1984 C4 Battery Draining Short Dilemma HELP!
  181. Have a check engine light, but can't get the code?
  182. Cheap eprom burner
  183. Someone 'Splain to Me.
  184. Electrnic Spark Control Failure??
  185. Basic upgrade chip Q's
  186. Anyone selling a pocket programmer?
  187. Anyone know these tables in Tunercat?
  188. Which injector is going bad?
  189. SV 24# injectors, BLM 108 - where do I start?
  190. Who does dyno tuning and chip burning in MA/NH/ CONN area
  191. High Idle
  192. 1996 Check and Clear Codes
  193. [Paging]: Mike_88Z51, EASE question.
  194. update to ARAP Bin?
  195. PALM OS scan software for my '88?
  196. Do they make ........
  197. help with selection
  198. [Graph]: Narrow vs. Wide O2 readings...
  199. Anyone have a Miniram Bin for a 91 they can share?
  200. ACCELL DFI 6.0
  201. Where did DIY-EFI.ORG go?
  202. Diacom: Parallel Port Mode? Not connecting.
  203. Need "Older Style" OBDI Connector
  204. Change oil light won't go off !!!!!!!!
  205. What do these error codes mean????
  206. NEED HELP !! WHat aftermarket pcm system to go with for LT4????????
  207. N E 1 Switched 96 OBD2 to OBD1
  208. What is controlled by the ECM ?
  209. 4 speed to Auto swap.
  210. Quad driver question
  211. Need Info on romulator. Considering trying it.
  212. Eprom Burning Question
  213. tire sensors
  214. Cable for Datamaster
  215. Any one tune in combination both a DFI and Carrol super fueler?
  216. Anyone have 1/4 mile times for a car with these mods
  217. Anyone scanning their '870 ecm, 1985 vette?
  218. "Field Diagnostic Enable" mode for 94
  219. 92 LT1, does the ECU use the O2's at WOT for air/fuel ratio?
  220. finally got some datamaster scans
  221. Hypertech or Jet
  222. AKM Molded cable with EASE, will it work???
  223. Tunercat $8D tuning help
  224. CHECK ENGINE LIGHT WILL NOT GO ON TO GET READING
  225. A little help from the experts please!! (lots of info and details, looking for some info)
  226. CAn anyone tell me if this cable will work on a '95 (ALDL programming)
  227. help with datamaster abbreviations please..
  228. Any LT1/4 guys using a DFI ?????? Need help with tuning the stock pcm/ecm.....
  229. ECM problems?
  230. Tuneable Aftermarket ECM that plugs into factory spot??
  231. [Screwed] How do I get this thing out???
  232. Prom Id need help
  233. [Update] TPS and MAT readings...
  234. C4 Scan Software for Diagnostic
  235. Quick Question on ALDL..help, please
  236. Reading Codes for a 95
  237. digital speedo on my 91
  238. need help with running prob. (miss) on 85 vette tpi
  239. TPS and MAT readings...
  240. AKM Interface Cable For Sale
  241. WIRING GREMLINS
  242. VE question
  243. Who here uses Scan Ease
  244. Opinions on Scanner
  245. Can't get WinALDL to work right.
  246. scaner
  247. HELP!!! Looking for someone to do custom computer chip
  248. Diagnosing the LT1 Ignition Coil
  249. Think I fried the ECM - DAMIT!
  250. Looking to borrow W/B in SW florida
