- how to get it leaner
- [FS] EASE scan tool
- injector flow rate
- where can i get tuner cat
- Experiences with Real Tuner?
- Batch fire anyone know how to tune these damn things!
- Fusable Link
- Any MSDOS tuner/viewer programs out there for Lt1 Vette?
- where to set o2 bung
- Getting a "Lost COM . . . PCM Recycling" error with Datamaster?
- Paging tjwong....
- Cheapest way to scan using windows?
- Cooling fans on constantly w/ edit program....
- Accel Gen 6 computer question.
- Wideband for the street? Or just Dyno it and be happy with a Wideband?
- MaStach cable ?
- burning-still the latest info?
- OBD I or OBD 2?
- O2 mv question, narrow band
- Correct way to tune a modified 86
- Latest DIACOM Malady
- FAQ
- laptop locking up on moates diagnostics program .............
- Turbo-link
- LT1 edit cable and Autotap?
- Diacom won't connect (did seach, help plz)
- Results from a bad injector
- connecting scanner cable
- Knock Sensor Pin #s
- MAF flow vs HP
- Does anyone have an epromer 5 ???
- How do I find out if my ALDL port is working?
- Burning OBD-1 Flash Chips/Sockets
- Stand alone options
- DFI Owners please step in .......... Mounting Location
- OBD-II Scanner
- Code 45
- Looking for a chip - 87 4+3
- relay test?
- Is LTFT (Block Learn) affected by fuel pressure?
- code 26
- 85 4+3 bin file needed..
- Problems with codes
- gross polluter in california
- Tuners Talk To Me
- What about the snap-on MT2500?
- need stock bin for a 90 L89 manual
- DTC's are showing in Datamaster but no check engine light?
- Tried out Datamaster software tonight my car never went into closed loop?
- BIN for '89
- Seeking tips on programming to increase 4L60E shift firmness
- Broadcast code ACKY ??
- Prom ID
- Paging tjwong... got good new!!!!!!!!
- Save 10% at VBP-Vette Brakes & Products, Inc.
- Knock sensor and Canister help needed
- What is your idle, closed loop spark advance, on an L98? and various other scan questions
- Need chassis dyno-tuner in Missouri
- /. Hack your Car. Don't we do this all the time.
- 96' CE with 95' PCM - what cable do I need and where to get for scanning?
- Tuning your car..
- NEED: LT4 Bin File (Converted OBD1)
- 1990 Vette, ECM won't talk to my laptop.....
- C4 TO LAPTOP SERVICE PROGRAM
- Tuning Protocol
- Reflash ECM/odometer adjust
- Anyone use Tuner Cat's Real Time tuner?
- Looking for free ODB2 scanner
- bad missing, backfiring.. took soem scans.. heres what i found! any help appreciated!
- Logged data w/ Datamaster & I think I'm rich, or am I?
- Diacom, Spark Advance, 1985
- PALM OS ODB-2 SCANNER
- 1990 Vert-Torquise-Auto Think i should buy?
- Help with Autoprom
- Where can I get an .ecu
- Good source for PCM?
- need advice on reprogramming
- What do I need for my '85?
- Newbie Help - What else will I need to tune?!
- MAF-do I really need to customize a chip?
- 27SF512 chips for sale - $10 shipped
- Yipeee - Newbie shouts
- timing procedure
- Zero Knowledge - Need To Start - WinALDL, etc.
- Anyone have a $8B ecu file?
- stacking bins question
- Datamaster and 86-89 ALDL
- $6E / $32B tunercat definition
- EASE - Slow O2 Flag?
- F-body program for Vette?
- TechEdge WB
- L98 IAC & TPS adjust
- New bin database
- Ran out tuning room
- code 42
- Another LV8 question
- RS-232 port replicator from Pc card for laptop?
- Need help on software Q's 03-04 fullsize GM trucks
- split BLMs while driving - normal?
- rookie mistake of the day.. need some help
- Accel DFI 6.0 - worth it?
- Car craft: Megasquirt ECU + opti ?
- help me with burning chips
- PLUG & PLAY
- O2mv @ WOT ...
- Bad Thermostat---High CO emissions???
- Anyone have a program for a hotcam'ed LT4 ?
- Needed: Stock 94 COrvette Automatic Lt1 PCM file.....
- Duct work for supercharger
- ABS Sensor Frequency Test
- What does high MAP mean?
- What will a scanner show
- Will an 85 vette ecm cut it?
- Anyone running Datamaster and Tunercat under WiN XP or 2000?
- New Combination - now MPG is way off - any advice ?
- DUMB ECM QUESTION????
- Will LT1EDIT do what Auto Xray EZ-5000 will do?
- MAF values = 0 at WOT. Any thoughts???
- Help me select
- another dumb question
- Scanner, Cables, Adapter FS link.
- Who can Do/Modify a Prom for me?
- LT1 Edit update
- Tuning education.
- ne one interested in a laptop perfect for scan an tune
- Has anyone here tried the 808/Aussie code for a 165 (no MAF)??
- AutoProm all-in-one tuning device becoming available
- Does 02 sensor wire length effect readings?
- Paging tjwong
- need 32,32b and 6e help... please
- [89 ecm] Okay, what ELSE does it do?
- for those of you with LT4s (or 96 LT1s)
- Determining DataMaster version?
- ALDL compatability
- ESC value
- High Altitude Tuning
- scanner value questions
- AutoTap question
- need tips on spark tuning...
- OBD II Question of the day.....
- Wanted: Stock '96 Vette LT4 tables
- This may be a stupid question but....
- shift problem
- help ! sys flashing in cluster on my 92
- VEMaster help needed (TJWONG maybe)
- Can MAF Sensor be cleaned? If so, How?
- 92 LT1 CHIPS
- Need a new set of injectors for my 89 vette
- OHHH NOOO i dont knwo what software to run on my 92 lt-1
- Max RPM, 5600??
- My BLM's please look.
- UPDATE!! on help needed, cable parts kit ....pics!!
- Pics of WinALDL (160 baud) interface
- Which aftermarket chip is best for my vette?
- Anyone know someone in Tampa who can reprogram fans, Tune, eliminate rear O2 sims???
- spark table quesiton & LT4 spark table needed
- Questions about which scanning software to use
- TPS Learn procedure...WTH???
- Need help with hard to find code description.
- diacom
- Some questions about the FAST bank to bank system
- ???s about some of my scan data.
- any good books on MODIFYING GM fuel injection?
- still getting split BLMs at IAC settings below 100
- New GM editing tool
- battery drain.... and yes i searched the back posts. but this ones different.
- NEED HELP!! CABLE PARTS KIT!!!
- Finally have some data logs--HELP needed
- Help with theft deterant system
- HELP!! 86 TPI- No Check Engine Light, Running Rough! Problem Solved!!
- Interior Windows fogged with Coolant?
- Question about ECM constant MAX spark advance?
- knock senser detection
- 870 ECM to 165 ECM swap
- Rear Speaker Mounting
- Total Timing for LT1
- Anyone Try the LM1 Wide Band O2 Setup?
- Hypertech .BIN file for '93 vette automatic
- looking for information on adjustment to the 'closed tps spark advance vs. rpm' table
- BIN library....
- Want to start with burning chips....
- no PCM Sync.... un-oh
- Anyone have a stock bin for a 4+3?
- EPROM's
- AIR to exhaust manifold in closed loop?
- help finding the set-timing connector on my 86
- Is a map of ~55 at idle a vacuum leak?
- DIACOM Data Trace Wanted
- Service Engine Soon Light
- what is DFCO? Its a table in tuner cat..
- Need stock bin for a 91 auto
- spark table tuning questions..
- Tunercat main spark table question?
- Strange Diacom Timing Numbers
- Need to change gear ratio in 94 PCM
- pcmforless bin file...
- Heeelllllpp cant hook up !!
- Manual Fan Switch
- Eprom problem Atmel 29c256 90ns
- Edelbrock Air/Fuel Ratio Monitors
- lt1 with hot cam
- How To Question: How can i tell i am lean or rich on my datamaster?
- newbie very interested tweakin my vette
- Diagnostics Mode in Diacom Plus
- stock 1993 LT1/A4 bin wanted.. or how can I d/l mine?
- Scanner for my 94A C4(stock)
- need help with shopping list to begin burning my own proms..
- ALDL pin layout for 91 C4
- Piggybacking ECM
- What the heck?
- 1985 and Autoxray scanner do not work properly.
- 85 2732 eprom address questions
- BAFL (16159278 $da) Hack/Disassemble file
- Lt1 edit to chg the fan's
- Help! Cal Pak kaput
- Current source for good 2732 chips (1985)
- Gonna start using scanning software soon...quick Q
- Anybody here running an Accel 6.0 ecm ?
- Vetronix Tech 1 ?
- Emissions Test Failure - High CO
- If I go from 1.5 to 1.6 rockers will it lean my Speed Density motor out any?
- Fault code diagnostic
- Minimim Idle speed adjustment assistance needed for my 86 Vette....
- Question about swapping 6870 for 165 or 730 and retaining 4+3....
- Would this work to connect ALDL to PC
- Did I FRY my ECM?
- Good Tuning Thread
- Default Setting for Craig Moates ALDL Communications for 91 L-98
- Help interpreting winALDL
- '87 v '89 ECM
- What voltagfe for a code 21?
- One Laptop running Scanning and...
- stock programming on modified engine question..
- Sftwr logging for TechEdge WB v1.5
- Scaning software....Can I download somewhere?
- WinALDL on 85
- 1995LT1 TRANSFR PROGRAM TO NEW PCM????????
- .ECU file for $DA LT-1 and WINBIN
- What dose it mean to have your ecm go open loop
- Please HELP car multiple misfire code down low......
- Will cable From Moates or WinALDL Work With Datamaster ?
- Scan tool SHOWS O2 values at WOT..is this info used for fuel trim on next WOT rn
- ARAP in '86
- Newbie guidance
- GN ECU file
- Code 42 on 95 LT-1
- Tuning Experts.Will I get any advantage using forced induction on speed density?
- Will my stock chip work for this combo or do I need a new one
- Injectors - Bank firing vs. Sequential firing
