View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26
  1. Procharger tuning
  2. 1987 to 1989 PROM calibration simple question
  3. Are 1995 LT1s OBDII cars?
  4. Help with AutoTap and bad misfire on cyl 7
  5. Does Datamaster work with ARAP bin & Win-XP?
  6. Help, two wires stuck in the ECM connector
  7. What are the differences in the bin between a 92 auto and manual ??
  8. ECM programming question
  9. Brake pedal feelin' funky~~
  10. Min Computer to purchase???
  11. Stumbles when in drive and stopped.. I'm going nuts
  12. Can any one please tell me where i can get a free wiring schematic for a '92 lt1 coupe
  13. Anyone with good tune, s/c & 30lb injectors
  14. computer is holding the injectors wide open
  15. Need help with analysing AutoXray data
  16. Rough idle...can't work it out. Considering having a new chip burned...HELP
  17. A/C clutch doesnt come on automatically
  18. Open Loop AFR Change
  19. 92 Lt1 CCM code C-12 Help..
  20. Some accel Gen 6 questions?
  21. Carbytes V2.0 for '90 (Any defination files)??? [A115 data stream]
  22. Need O2 sensor help..
  23. Trouble Code 36 ? ? ?
  24. WOT Enrichment tuning for 94 ($EE)
  25. What is the difference between AutoXray EZ-Scan 4000 & 5000?
  26. Computer problem?
  27. Which memcal APYP or ABTB?
  28. Anyone have a bin for a 91 auto?
  29. Water temperature
  30. 165 swap question
  31. windshiel wiper/passenger side power mirror/smell oil
  32. Need Help w/Data
  33. The guys at tunercat are just great.
  34. windows xp ?
  35. 165 changes for a 85 4+3
  36. Knock Retard Gain Factor vs RPM?
  37. Ignition Module Wiring Colors???
  38. MAF to MAP swap .... wiring??? (165 to 730)
  39. car idles fine, higher rpm starts missing/loses rpms
  40. Mass Air Flow Sensor on 87
  41. Need image of BDLD chip
  42. Setting "Initial Timing" in the chip. Does it alter other tables?
  43. L98 running rich I installed the wrong injectors?
  44. ECM retro-fit?
  45. Type of relays to purchase
  46. L98 running Lean - Help! (2)
  47. Knock Gauge
  48. Two injector constants for one FI?
  49. Computer time(I think) Help!
  50. Need a new Programmer
  51. Kansas City Area
  52. Speed Signal Wire
  53. MALF 43
  54. Scanning a '92 causes SERVICE ASR to come on?
  55. Little help reading a ZZ4 Conversion Bin file.
  56. No Opti ventalation = code?
  57. Burn me a chip or two
  58. Double Stacking BINS On A 27C512 Chip Question
  59. !986 OBD1?
  60. Could someone read a '93 Chip for me??
  61. 165 conversion
  62. programing your ECM?
  63. 24lb injector in stock L98
  64. Had my cable working, now i can't
  65. Non-Corvette ECM tuning question
  66. sotck fin för a 1991 auto please?
  67. block learn cell #0
  68. Computer guru's: wazzup with a "Code 9, EAS electrical fault?"??
  69. Minimum Voltage for PE Mode
  70. Help me
  71. New to scanning, Can anyone suggest which soft ware
  72. knock counts at KOEO?? (LT1)
  73. 86 with 165 not wanting to scan at 8192
  74. Hypertech Help
  75. Auterra Scan/Dyno
  76. VEMaster help
  77. Inj constant-just my scenario...
  78. 1988 - any problems with using scanning software ? 160 or 8192baud?
  79. Main spark advance tables and PE mode
  80. Any one using a 2/3 bar map on an LT1.......
  81. Injector size.
  82. Anyone interested in DIS for a HEI??
  83. Where can I find some modified bins for a stock 89 l98 auto???
  84. Help Please...
  85. Oxygen sensor check
  86. 870 to 165 ECM swap question
  87. got a cable, what program to use?
  88. WTB: I want to get a full copy of the datamaster OBDI software
  89. Strange stock PE vs rpm change AFR vs. RPM table
  90. obd-1 scan tool
  91. Speed density novice question.
  92. TPIS Level V Chip
  93. Quick Timing Question on 91 Vert
  94. Why does my hot cam make my lt1 run rich
  95. What memcal for '730 swap?
  96. Anyone have a 383 SuperRam .bin?
  97. Tunerpro RT ???
  98. Ocillascope how-to for automotive diagnosis
  99. JET Performance strikes again!
  100. Anyone using AutoProm/TunerPro RT combo listed on Moates.net??
  101. FreeScan
  102. Desired Shift Time Table questions
  103. Code 28, 32...explain in lamen terms....
  104. Hypertech Power Programmer for an LT4
  105. couple of questions guys ECM, eprom and CCM for ZR1's
  106. Moates Software help...
  107. anyone using 2bar or 3bar map sensor
  108. Idle Fueling ?
  109. NEED HELP...NEW MOTOR!
  110. Lean cond. when downshifting?
  111. what will installing 2.0/1.6 valves do
  112. Need help in the Daytona/Orlando area...
  113. Tuning for Octane?
  114. Code 24
  115. Two simple questions.
  116. Datamaster/Hypertech??
  117. Timing ???
  118. 94 LT4 programming
  119. Can somebody help me find out where I can get a 95 Camaro Z28 .ecu file??
  120. 30# injector program
  121. Anybody going to the Cruise In with LT1 Edit?
  122. Spark retard
  123. Witnessed "megasquirt" DIY ECM in person today. Very impressive!
  124. Newbie - 85 ready to try and burn a chip
  125. need injector info....
  126. Replacing Engine...Need Input!
  127. Having a problem with $32 ecu file
  128. LT4 edit/tuning megathon!....
  129. Need help with PCM programing.
  130. Dyno day soon
  131. Day 1
  132. advice, WTB: LT4 ODB2 Scanning software
  133. Any one using AutoEnginuity scanner? Does it work well?
  134. CALLING TJWONG I could use some help
  135. Good Anti-Theft?
  136. .ECU file for 88
  137. Accel Gen7 Tuning Help
  138. with a 180 thermostat ..
  139. just ordered an autoxray 5000.
  140. FAN1 vs FAN2?
  141. Someone with a stock 90 auto verified .bin?
  142. $DA2 or $DA3 .ecu files available?
  143. Failed Emission's Test
  144. ECM processor
  145. 1227727 -> 16198260
  146. Don't get mad....
  147. O2 sensor questions, WB and NB
  148. Tech1 question
  149. idle problems on L98 TPI
  150. VSS for '95 ECM and '86 DigiDash
  151. Help with Codes on a 95 corvette
  152. Best site
  153. What needs to be done when going from A4 to M6 using TunerCat?
  154. Anyone want to look at my datamaster files and tell me if anything is wrong?
  155. Anyone know who can burn Eproms for cheap?
  156. Custom Program for AutoX use....
  157. Can some one PLEASE tell me exactly where tha ALDL port is on my 95 vette
  158. Hypertech programmer
  159. PKE question
  160. TunerCat's amazing support.
  161. 94 LT4 conversion programming
  162. No O2 at 7500 feet
  163. 1994 LT1 Coupe - PKE locks but does not unlock.
  164. LT4 stroker tuning
  165. TunerPro RT data analysis
  166. Emissions Custom Tune Needed..
  167. 91 vette chip??
  168. Re-Program ECM?
  169. Looking for a free diagnostics software site(85)
  170. Lets see your HOT CAM Timing tables!
  171. ECM maps
  172. Hot cam tuning
  173. FMS/Bosch 30# Injector Offsets Needed
  174. Autoxray scan - please tell me if I have problems
  175. Guys hooked it up to a scanner for the first time, please need your help?
  176. 57 degrees advance?
  177. !st Time Scanner 1985 L98
  178. Basic Questions from Computer Illiterate
  179. Dyno Tune Day in Southeast PA
  180. Stumper: "Low PRNDL up/downshift speed threshold" ECM constant (LT1)
  181. program corrupt?
  182. Using Autotap (Scanner Software) with 94
  183. hex workshop help
  184. tunercat experts-help needed
  185. Beginners Primer for Tuning?
  186. slight hesitation
  187. Help with Accel WBO2 Needed
  188. Tuning help needed
  189. '95 OBD-I Tunercat failure to connect
  190. TECH1 HELP!!
  191. Why is a Ported MAF so hard to tune? Any suggestions
  192. Does anyone have the schematics to the ECM 16159278?
  193. Stock '92 LT1 bin needed....
  194. '165 to '749 ECU swap ???
  195. Whats a good scanner?
  196. ?? for those who have added in factory disabled options on ecm....ie rev limiter, speed limiter.
  197. question about usb , rs 232, and winaldl/ECM852
  198. Just to start
  199. How would I estimate needed adjustments for new 24lb injectors on my car???
  200. 383 SC bin needed 727 PLZ HELP
  201. moates + 2 transistor cable + '90 - one good update then nothing
  202. Can I get a dealer service history for a future vett owner?
  203. big problem? please help fast!
  204. Is there any type of general info guide that gives me an idea of what certain chip mods will do??
  205. Datamaster Histogram function- how can I utilize it on my fuel corrections?
  206. Delta TPS% vs TPS%....whats the difference??
  207. what's FF?
  208. What is this Blue chip thing out of my 1991 vette? stupid question
  209. How do I detect misfire with OBD-I scanner?
  210. Remote mounting of Prom in 85-89's?
  211. 2 transistor cable for moates scanning software? work well?
  212. datamaster tuning .drag coeffiecant..tire data etc
  213. Help with DLC
  214. checksum
  215. Who's good at burning chips?
  216. My 1st dyno run ever!
  217. chip burning setup ???'s
  218. REvised ALDL Cable interface..
  219. CCP solenoid clicks constantly during Tunercat programming
  220. Pagin conversion gurus OBD2 to OBD1 NEED some Input PPPPLLLEEAASSEE!!!
  221. will a chip keep 1-2 shift off rev limiter
  222. What is a reasonable price to pay for a dyno tune?
  223. PCM Overhaul...who does it?
  224. LT-4 OBD II to OBD I Conversion
  225. Optimum WOT AFR for stock LT1?... 13.3:1?...
  226. DRIVEABILLITY AFTER HEADDER INSTALL
  227. Need help with 92 LT1 383, desperate...
  228. Carburetted engine swap question. Please help I'm LOST
  229. 91 vette spark advance
  230. BAD INJECTORS ???
  231. Could somebody please give me a modified 89 coupe auto bin???
  232. DynoJet wideband?
  233. What is the best tuning software out there???
  234. Mode 7 and ccm mileage programming on 92 vette
  235. OBD-I Conversion, "SYS"
  236. Knock retard other than at WOT...
  237. Advice on tuning strategy for next weekend track event
  238. VE Master Link?
  239. Need a chip burned - simple update
  240. 90 L98 - Trouble with Moates Scan SW
  241. injector constant in winbin
  242. LT4 tuning
  243. bin file for 89
  244. universal eprom programmers
  245. How do you ID a injector?
  246. datamaster and serial port replicator...perfect match!!:)
  247. Learning how to tune
  248. Anyone got any stock or modified bin's for a 90-92ZR1?
  249. Arrgh, datamaster won't connect, nor will Diacom...
  250. '92 PROM size
