View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26
  1. Need chip Retainer
  2. What's causing this-upshift light
  3. Check List for a 85...
  4. Morgon Motorsports
  5. MAF question
  6. Question On Datamaster
  7. need mail order tune for a 93
  8. Chip burning
  9. Anyone have the PowerScan software???
  10. What do I have? (newbie question)
  11. typical scan values for stock '91??
  12. wtb new prom fo an 85
  13. Anyone want to burn another chip? 91w/mods?
  14. LT4 drivability issues
  15. Checking a 89 Vette when buying it...
  16. Tachometer accuracy with "tuner prom"
  17. Need OBD I software?
  18. OBD2 Tuning
  19. 94 Vats
  20. SC'd car with strange part throttle surging
  21. battery disconnect resets what?
  22. 85 ONLY corvette's "special" injector size?
  23. idle stabilizing questions..running cams
  24. OBD 1 Plug - WTB the hardware ?
  25. Can I do this with my 93?
  26. Chip for my '89 six speed???
  27. lucas injectors
  28. HEI module check
  29. Cold start & hesitation Issues
  30. Ed Wright Fastchip Question?
  31. Need .ADS file for Datalogging a '91
  32. 1996 LT-4 SYS light blinking after OBD II to OBD I conversion
  33. Eprommer help
  34. Need USB <->serial driver..
  35. ODB1 connecter under dash?
  36. Tune OBDII for Boost... many questions
  37. cold blooded
  38. Need help with TH 700 R4
  39. 87 ECM part numbers
  40. Code 32.....
  41. When hooking up a scan tool...
  42. idle fueling
  43. What is scan and tune?
  44. ODBII Tuner in SW Virginia Area?
  45. Need Chip Burned
  46. Programmers?
  47. '90 Distributor Ref Signal
  48. 95 LT1 hesitation when first started
  49. Light acceleration WB02 tuning question.
  50. Comparing DataMaster and WB Meter values
  51. Suspension Question...
  52. Ease Software Rep..
  53. Please help Rich condition
  54. "target AFR" vs o2 sens. in $6E
  55. L98 Tpi Intake for 85
  56. 1990 c4 problems.......
  57. Datamaster help needed
  58. Worth moving Air Temp sensor?
  59. 95 LT-1 wont start
  60. dfi jumper harness
  61. I need to get a copy of somebodys scan sheet so I.....
  62. lt4 tabels
  63. can you program with laptop and no chipburner?
  64. Bryan Herter Dyno Tuning in DFW
  65. What is a good shock
  66. WB o2 Wiring Questions...
  67. Gen. 6 and knock counts
  68. L Term and S Term Counts
  69. Hunting idle with modified engine, how do I cure?
  70. WINALDL Good Numbers?
  71. Software needed
  72. Should I recheck A/F when changing timing?
  73. still having troubles with computer
  74. '89 L98 running lean/rough idle when warm
  75. Programming your own.
  76. Code 34 and 36, 88 Vette
  77. 92 conv. install a chip?
  78. Virus on computer mess up chip flash
  79. Injector constant
  80. runs for a few seconds.. stalls
  81. MAP sensor readings at idle
  82. HELP car is so rich it won't idle
  83. High Duty cycle = fuel cut off???
  84. Spark advance (1992 LT1)
  85. Concerned about what I see in Tunercat
  86. Do you use the WB O2 LM-1 or PLX?
  87. OBD2 PCM into a '94?
  88. Fuse for 96 OBDII connector?
  89. Dragstrip WB logs
  90. Do any of you use 'fuel injector cleaner'
  91. Engine Cutting Out
  92. Help with CCM codes
  93. Lean Misfire or??
  94. ANHT.bin
  95. TC lock-up/un-lock-Speed vs. TPS%
  96. 1987 Oldsmobile Tornado With OBD 1: Read Out
  97. Knocks like crazy when cold
  98. '93 vette -- With ECM posessed by the Devil!
  99. Newbie o2 sensor question
  100. OK, How Do I Tune My '94 ??
  101. TPS preferences
  102. adding more fuel?
  103. HELP: Need SPEP+ burner software
  104. Zeitronix WB-Meter
  105. Ecm Compatability Question
  106. which gtech should a guy buy?
  107. Tuning with wide band on dyno
  108. 4+3 shift problem
  109. Tuned Port Injection
  110. Injector Advice???
  111. False Knock counts??
  112. Reflash
  113. Like New ATI P1SC For Sale!!
  114. Need help on my digital readout window on a 93 cluster.
  115. Anyone know the broadcast code for a 90 Vette 6 speed
  116. CCM codes
  117. Lowering Overall A/F on ECM 165 32B
  118. Need $8E .ecu file for WinBin/TunerPro
  119. Def (ecu) files...
  120. OBD 1 How to DIY
  121. Do we have a list of chip opts for E C4s?
  122. O2 sensor - Closed Loop
  123. Chip burners/programmers...
  124. Need Help with a Code 45
  125. Stock '90 L98 Running Very Rich
  126. Knocks/Tirespin (long)
  127. good repair place near oceanside calif
  128. 93 with extremely high Inj DC's. Why?
  129. Need Tuner in Maryland.. HELP
  130. Diagnostic troubles
  131. PREDATOR Flash Tuner
  132. Do I need to have my chip reprogrammed?
  133. WINALDL Who's got it?
  134. Fuel injector cleaning
  135. Anyone Using LT-1 Edit?
  136. Adjusting the spark advance table.
  137. Fuel injection question
  138. Analyzing Data
  139. tunercat software??
  140. Anyone using Ease software?
  141. Where to mount wideband O2 sensor
  142. Calling FAST Users: C-Com WP 1.02
  143. Need custom made chip
  144. Injector ID?
  145. code 51 prom error,need help please
  146. OBD1 Cable for Sale
  147. Different DataMaster question.
  148. 91 vette
  149. Some advice about DFI Gen VII interface harness
  150. DataMaster help needed
  151. Question re scanning ARAP in 1987 Vette
  152. Paging tjwong
  153. Can Anyone decipher a couple of Broadcast Codes,Please??
  154. Scanning software for 87 C$
  155. Still won't read data.....
  156. Help!!
  157. Boost and air temp sending unit
  158. Idles too high with hotter cam
  159. 1994 Codes H44, H77, H78
  160. Closed loop perimeters?
  161. how to modify cold start in ARAP
  162. 91vette block learn???
  163. 86-89 ECM needed
  164. Help!!! My 95 convertible wont start.
  165. Tunercat program
  166. Got my Autotap yesterday and.......
  167. Accel DFI gen VI users...
  168. codes
  169. What is needed to tune this new setup
  170. Computer type
  171. LADL connector ?
  172. Dyno Tuner in Atlanta ?
  173. Any good internet FAST resources?
  174. Ease Scan Tool For Sale
  175. Accel Dfi users...
  176. WINALDL doesn't run
  177. Anyone/w equip to change timing Around CT
  178. '87 eprom
  179. Best Scan Tool
  180. How to get codes for a '94
  181. I want to start burning my own chips
  182. fumes
  183. WB02 sensor mounting Q
  184. Looking at the AutoXray Scanner
  185. 91 tune up 1st timer
  186. what support file can be used with datamaster for...?
  187. AKM Cables Serial Interface Question
  188. Error Reading PCM (no ticking)
  189. Checksum
  190. 88 with trouble code 36 please help
  191. Guys I REALLY NEED HELP this time!!!!!
  192. South Eastern Virginia
  193. two O2 sensers
  194. Power Enrich. vs RPM question:
  195. Intial timing
  196. 91 vette oil presure??
  197. 91 Vette Startup RPM Flareup/Surge on Speed Density
  198. how do YOU guesstimate your Injector constants?
  199. Reprogramming computer chips
  200. Hopefully simple tune up question
  201. Pocket Progmr 2 & the 7749?
  202. Searching for Programmer for '89 L98
  203. 88 L98 missing after 4200 RPM...CAUSE??
  204. 1994 Lt1
  205. Gathering data
  206. Code 41???? Fixes????
  207. heavy on fuel
  208. FORD 24LBS INJECTORS
  209. -90 diagnostic tools
  210. injector flow rate?
  211. new program for HotCam in an L98
  212. hesitation from Park to Drive
  213. Code 33, MAF Sensor, Check engine light at 2000 rpm
  214. [Fl] Can Anyone in Jax Reprogram My 94 Speedo?
  215. Need help with '90 Auto L98 ECM Programming
  216. Best Wide Band O2 meters??
  217. IAC Counts
  218. How do I check the TPS voltage on a 88 Tuned Port Inj?
  219. DataMaster question
  220. IAC Maxed out at 145?
  221. Am I going into closed loop ????
  222. VE tables and timing
  223. need help with datamaster
  224. '91 gauges show "odo err" please help
  225. Got my baby back from the shop today...
  226. Knock counts gone wild.
  227. BLM tuning
  228. Potentially inexpensive WB02
  229. Burning my own chips
  230. Chevrolet Corvette Collectors Edition odometer reading
  231. Brought it to the Dealership this evening....
  232. Updating '92 PCM to 95-96 w/ MAF???
  233. newbie with some tuner cat questions ('90 MAP car)
  234. need help adjusting throttlebody butterflies
  235. is there a chip/tuner for an 84 crossfire engine out there?
  236. VOLTAGE DROP!!! HELP!!!
  237. Help me interpret some results
  238. Orange County CA 96 owner with a tuner needed to set my fan on/off temps
  239. I'm seeing 450mv with the o2's disconnected - normal?
  240. Want to start burning my own chips ... what all do I need?
  241. Chip burners...what info do you need for a burn?
  242. wanting a few chips for my 90
  243. chip reprogramming after gear change
  244. Newbie needs some assistance with tunercat for my 90 ZR-1
  245. Newbie cannot get his new 383 to run.
  246. Intake leak cause high IAC count?
  247. advice on scan tool
  248. Where can I buy a custom burned chip?
  249. OBDII programming?
  250. Procharger tuning
