View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26
  1. Stock Engine Computer Control Program
  2. Supercharged tune?
  3. what is the easiest way to fine tune ve tables
  4. Rampage ECM question (Ramp Chevrolet)
  5. converting kpa to ve tables
  6. ecu upgrade
  7. Actron Code Scanner
  8. Question for ski_down_it
  9. Ccm C4 -94
  10. obd2 system for 93 lt1 vette
  11. Question about chip burning ?
  12. 150hp shot, how much timing should I take out? Or use a BTM?
  13. ZR-1 bin file
  14. Datamaster Run
  15. which tables/constants
  16. Anyone datalogging a 90-91 vette?
  17. SES ghost!
  18. PROM ID Chart and help needed
  19. #4-#7 lobe swap cam
  20. '85 hunts at idle
  21. Dorks at AutoZone
  22. ASR code 62?!
  23. I don't know
  24. Excessive Cranking when cold ('95 LT1)
  25. AutoProm Emulation issues
  26. Datamaster Help!!
  27. central controle module
  28. 1996 LT-1 General Maintenance Questions
  29. Gasohol air/fuel ratio for max power
  30. Help! What goes in this hole in the intake (87)?
  31. Order of spark plug leads
  32. ECM Help
  33. 1990 vette bose
  34. FAST system on an '85
  35. washed engine
  36. win aldl help
  37. ECM or wiring problem '89 L98
  38. CCM not reporting PCM codes on '95
  39. Looking for a TUNE?????????
  40. bin. selection
  41. 870 To 165 Ecm Upgrade ?
  42. 1996 LT4 tuning software?
  43. m.s.d. dig6 plus
  44. Diacom Plus ~ Datarase II ~ EMP-10 Programmer ~~ all for sale PRICE LOWERED
  45. Laptop mounting for data logging
  46. Any Body got an old (stock) Mem-cal???
  47. Does anybody know of a site where I can down load a free scanning....
  48. 1992 help wont restart hot
  49. How much HP ported stock TPI intake is good for??
  50. Datamaster Results ?
  51. Finally done with 6 spd swap. time for injectors
  52. Chip burning stuff for sale
  53. Help me PLEASE!!@!
  54. Need ASR help
  55. Who sells blank PROMS?
  56. wide band o2 kit
  57. corvette tuner in florida
  58. L98 Chips & SD vs. MAF: For Chip Is It Easier to Recalibrate?
  59. 1992-1993 FAST plug and play harness
  60. very rough running when cold 85
  61. 6870 upgrade
  62. Need help with TunerCat and changing Gears
  63. Craig Moates' Ostrich rocks
  64. Swap SD for MAF?
  65. about ECM programming 1990 Corvette
  66. What would be the downside of putting a Camaro chip into my 89?
  67. Will this cable work with my 94?
  68. Car does not go into open loop when WOT
  69. I hope you can help me out there ski-down-it or anybody else with the ease program ".
  70. Anyone solve this mystery?
  71. 96 Lt4
  72. OK, I'm gonna try asking this once more, I hope you can help me out here.
  73. This thing just won't idle
  74. 88 ECM recalibration ???
  75. 96 LT1, code P0300 thrown.
  76. Timing issue from open to Close loop?
  77. This thing just won't idle
  78. Modified stealth ram plenum
  79. Selective Ride codes
  80. Questions about Actron CP9110 Scanner
  81. Logging MAP at track or on dyno.....
  82. send me a datalog
  83. Dam high speed miss still...
  84. $6E update for 86 memcal...
  85. help with timing please
  86. Constants - Questions
  87. Help!!! ECM Programming on a 92 383.
  88. 92 383 Tune
  89. datamaster on windows xp?
  90. Will somebody please send me........
  91. What seems to be the best timing.......
  92. 1993 LT1 WOT Ignition Timing
  93. Injector Duty Cycle/High Speed Miss/PE table q's
  94. Hose Help Required
  95. Diacom Plus
  96. $6e
  97. Custom Chip
  98. spark tabel questions.
  99. Code 28 QDM 3
  100. craig moates' "Ostrich"
  101. Tuning for Boost
  102. lowering the #'s in the ve tables.
  103. Free scan
  104. problem with my 85
  105. How do I turn the Check Gauges light off
  106. ok need help please!!!!!!!
  107. Is this Cheap horsepower
  108. hotcamed L98 with miniram or lt1 intake
  109. writing to stock prom???
  110. forced lockup
  111. 02 and injectors
  112. Autoxray EZ-SCAN 5000 or 6000 Scan Tool?
  113. '95 Stumbles on cornering...
  114. T or F....AFPR on an LT1 obd2 car isnt useful for tuning....
  115. fuel trim cells - $6E
  116. At wit's end with idle - 383 superram
  117. BL Cell Table
  118. procedures needed for datalogging 630 ECM in 8192 bps
  119. anybody have AXCR BIN file?
  120. 92 Automatic stock chip
  121. Different Battery Draw
  122. scan/tune software - newbie question
  123. Vette no go
  124. Anyone using moates chip burner?
  125. 91 vette. what ecu file to you with autoprom.
  126. Chip /ECM question
  127. Anyone ever get an '85 ECM to...
  128. usb to serial adaptor?
  129. Need a 95 M6 bin
  130. Question about the Hypertech Power Programmer...
  131. '92/93 Hot Cam Bin
  132. Advice on diagnostic tools
  133. ZR-1 TPS Sensor Volts
  134. Problems with TunerCat connecting to PCM
  135. Huge Data Log for review, few questions, thoughts and comments very welcome
  136. Need Advice!!!
  137. Got my hands on a hypertech chip for a 93
  138. I can't datalog in 8192 mode...Need Help Please..
  139. Code 12
  140. no start
  141. I think I need a Prom
  142. Does it work this way
  143. Ed WRight hot cam chip on 93 vert. Car runs rich at idle?
  144. 383 running on 350 file?
  145. Ecm Testing
  146. ECM-Func. Specs - do they exist??
  147. Need Ease scans of Hot camed LT1.
  148. VE values vs BLM?
  149. educate me
  150. High speed miss...???
  151. Enrich Async Pulse Width ???
  152. 95 with wierd lean condition
  153. injector conversion
  154. Injector Constant
  155. Doing dyno runs for tuning - Ski_dwn_it?
  156. Anyone using WinALDL......
  157. Tunning?
  158. What does "DRP Occured" mean in WinALDL??
  159. Upgraded ECM to '259 -- how to scan at 8192 baud?
  160. LV8 Table Question
  161. ALDL connect using Moates hardware.. HELP!!!!
  162. WTB:92 383ci BIN
  163. Headlights '85- unequal light output
  164. Dash and Diacom Disagree on Temp
  165. Chip removal
  166. Needs Some Advice on Scan Info
  167. 870 ecm guys in here please
  168. Anyone got the $02 ecm definition file?
  169. Which pins on the ECM are rear O2's?
  170. PCM Proplem ´95
  171. ZR-1 DFCO Disabling
  172. LT-1 "HotCam" Tune
  173. my car is running pig rich
  174. SA main table change for modified L98
  175. Tuning shops for '89 ?
  176. Need a bin file for a 86-A4-307
  177. ECM Conversion/ Chip Question
  178. Tuning masters/ please check this thread
  179. Rapid fire plugs looking for comparison
  180. Code 1416 port air circuit malfunction?
  181. High Idle/ setting problem
  182. Programming problem
  183. Anyone using the ARAP bin
  184. 84 VATS problem "Help please"
  185. Lowest price on scanner?
  186. I need datalogging software...
  187. IAT Scale vs. Air Flow question
  188. Code 45 on 90 L98
  189. Nite-mare
  190. Problem w/scantool, forces open loop
  191. Help w/ Service Codes for my 93 LT1
  192. Help!! Problem with starting and idle.
  193. Tuner and Dyno gurus - please read
  194. Hesitation off the line
  195. chip socketing, Tjwong please look
  196. Anyone ever use this ODB1 Interface Adaptor?
  197. 85 to 86 ECM Conversion
  198. 95 LT1 PCM replacement problems. newbie
  199. ECM Repair
  200. need custom chip for 85 4+3
  201. 95 LT1 tunning
  202. Maybe a stupid question re/ 02 sensors
  203. Help w/ fuel guage for 85
  204. Looking for someone to do a Chip Tacoma WA
  205. ISO DFI 6 serial comm. protocol
  206. error code 53 on 92 6 speed
  207. Tuning Hardware and Software POLL
  208. Anyone got version 1.98 of Tunercat??
  209. Where can I get this?
  210. I need help with Azzato chip
  211. Pocket Programmer, I forgot the password again. :(
  212. Code 12
  213. Pocket Programmer 2 help needed
  214. SA question
  215. Uv Eraser
  216. Spark advance question
  217. completed my first datalog
  218. 94 ecm question
  219. porting the plentium and change the runners ??
  220. Trying to establish a good starting point
  221. Hypertech Stage 2
  222. Calling Mo Brandy!
  223. Input on chip
  224. Timing setting
  225. Help with codes.
  226. L98 spark retard mode questions
  227. Andrew@AKM Electronics are you on here?
  228. Will Datamaster run on Windows 2000?
  229. Est Help
  230. LT1 Edit files
  231. newbie scan help
  232. Any Dataloggers for Pocket PC?
  233. optispark / CRANK HUB removal question..
  234. AutoTap Serial or USB
  235. What computer needed to run WinAldl?
  236. Anyone using Datamster on 165 ECM
  237. Datamaster and burnt chip?
  238. wtb Auto Meter Fuel Pressure Gauge
  239. tpis headers and egr tube??
  240. ? Concerning Chip Burning
  241. What other software works with Datamaster cable?
  242. Catalyst Monitoring on OBDII
  243. OBD I cable and software
  244. Needed: Correct Values For 1987 Ecm
  245. ECM Questions
  246. Unknown Codes
  247. Injector size,Map conversion and SS internal ratio
  248. What should knock count be for an '86?
  249. Car has a SYS message in speedo, but doesn't display any codes.
  250. Help with code 34 please in 85 L98
