- L98 ESC mod
- Need Software Suggestion
- I hope this is the right section, to ask
- Tuners, what combonations of motors do you find are the easiest to "tune"
- Replacing torque converter because of a problem
- Just Got Burn 1/ Any One Have A Good Bin For My 87
- How do I get the scan codes on a 1995?
- '93 Zr-1 ECM/PROM part numbers?
- L Term Counts
- Results of a little more testing with this Split Block Learn Values
- AE, how to adjust?
- new heads and cam help needed
- Attention Scantool experts! Need help decyphering this!
- Paging Alvin and tjwong.
- NOOB Questions about basic settings...
- quick chip question
- Burn 1 showed up with UPS today, any advice before I play with it
- Relocating 89 ECM
- P 401 on 96 LT1
- Need Holley commander help please
- autotap scan configs
- pulling codes on a "90"?
- Help Group buys
- Paging TJWONG
- That was wierd!
- Uwebaby
- thinking of trying my own tuning help
- SCed 94 C4 LT1 moving from high to low elevation
- Closed Loop Lean condition - HELP
- Need expert assistance with tuning FAST ECM
- A little surge with longtubes?
- going to take the eprom challenge
- What forum members.......
- Noob needs help bad!
- Reset Stereo
- DFI computer box ID
- Question for the LT1 guys.
- 89 chip in 88 a-4 car
- Spedometer jumping after tuning
- fuel pressure regulator...how to use..
- Understanding diagnostic codes
- Pertronix HEI Upgrade kit
- mods that will affect the chip?
- help is ecm bad?
- wtb- data logging cable for a 91..
- 27SF512 Chip & Pocket Programmer 2
- L98 Engine Knock
- AutoXray shows car at only 99% when floored
- Needed - stock bin or broadcast code
- '95 ECM Vs '96 ECM and tuner software
- Pulling codes on a "94
- Newbie pulling codes...
- remove A/C...belt? tensioner?
- Anyone make an adapter for the ECM?
- ATI 383 needs too much fuel to idle?
- DTC set in Datamaster
- Anyone Using Innovate's LM-1??
- Area 51
- ECM Question-Long
- holley commander 950 tuning????
- Where to get LT1EDIT?
- Error code 36 Optispark?
- Help, need Ecm reprogrammed in AZ
- Different rod lengths for different cylinders?
- Shift light
- Help! 383 running rich - knock sensor issue?
- Door Panels
- 1990: Datamaster having trouble connecting?
- Datamaster RPM question
- PCMFORLESS Experience
- need a stock bin
- Optispark Vs Air Pump
- Knock Sensor and Low coolant temperature reading
- Datamaster Readings
- Lterm 155L and 149 R = Bad Idle?
- Newbie Questions Inside, Help Please
- Noob's first scan, what does this stuff mean?
- Scan Software for Macintosh?????
- Difference between 1087 and 1988???
- Scan tool question
- How to get the IAC to zero?
- CODE 41- EST - ok...i'm lost now.
- How Do I Floor Jack Up My Vette?
- Coolant Comp Table
- Exhaust?
- attn: CFI-EFI & others
- AKM Cable wont connect to Vettes computer
- PE vs coolant temp (WOT)
- What's A Good Teardown Manual For 96 Vette?
- An other software work to program a pocket programmer II??
- Scan Tool !
- Datamaster for Dummies help
- Codes 15, 23, 32 after Hi Flo install
- scaned timing on a 96 LT1
- P0301 Code? What Do I Do? What Could It Be?
- '95 383 project, tuning tips needed.
- Datamaster 92 auto, Injector 1&2 faults, etc
- Need help reading chip
- Any Known Recall Notices For 96 Vette?
- getting code 44 on 90
- Any Prom Tuning Gurus reside in Phoenix ?
- Can someone look at my chip?
- Optispark Question
- stock datalogging for 96 LT1 auto
- Codes C12, H64, and H72 ???
- Help!!!!!!!
- Datamaster Scan Reading..
- help
- Hurst Shifter for 1993 6 speed
- It's a shot in the dark, but maybe....81' chip
- Various Chip track results
- NOOB questions...Spark Tables...
- Scanner tool Autoxray do not operate properly with 1985 ...870ECM
- ALDL Link
- PROM orientation
- Do you need EGR, I am getting knock counts still
- ECM density altitude question.
- Lots of data errors
- New PCM for a 95
- ALDL pin out?
- selling my ACCEL DFI ECM / ECU GEN 6 W/ 1227165 ECM HRNS & CALMAP
- Where can I get a fairly cheap OBD interface cable?
- Some dyno questions
- Scored myself a laptop - Tell about the free monitoring programs please
- Tuning for Increased volume
- blm read 108 and a/f ratio meter read 22/1
- PE timing
- has anyone had good luck with ve master.
- Sticky Park Brake
- Tunercat vs Tunerpro RT
- Stubborn 96 Vette
- 96 LT4 "service soon light"
- is this laptop decent enough to run craig moates, etc?
- Tuners In Northern Utah
- AutoXRay: Which Of These Are Critical, And What Values Should I Be looking For?
- Bins/Def Files?
- 85 Open Loop Tuning
- mailorder chips unlocked
- Good tuner is Ft. Lauderdale ?????
- What Chip would be the best for my car?
- ?? about at29c256, replacement chips
- Mail Order Chip & AutoXRay....What Parameters Should I Look For?
- 27SF512 problems...
- 92 auto datamaster run with Delteq
- 85 c4 logging, yes i searched
- Would it be worthwhile?
- code 22
- what hardware and software is needed to modify chips
- Chip Copying
- datamaster, anybody use it?
- Free tuner ware for '92 LT1??
- new 383...tuning problems
- New DA2 definition file changes. What are these fields?
- Need file for TunerCat $EE (v2.08)
- Killing VATS in chip, slightly different question, need help fast
- Tuning Question just installed 3.45s
- new member,need help,code 32
- Newbie SF512 chip questions...
- Looking for Winbin ECU file
- Anyone have a stock '92 bin?
- I think I'm gonna do my own burning?
- A 1/4 mile run recorded on TTS, Can someone analyze?
- 94LT1-pcm codes 67 &70-no a/c-how to fix?
- stalling problem with gen 6 dfi
- CCP DC in Datamaster what is it?
- TC at TUNER CAT ROCKS!!!
- The ole split BLM issue
- 1995 OBD question
- 1987 Replacement Memcal
- Looking good for tuner near Chicago
- AutoTap - Good or bad? Looking to buy.
- anyone know of a dyno tuner in central PA? (MAP/OBD-I)
- Got datamaster scans need analysis
- Need 383 Numbers/Assistance
- Constants in Tuner Cat, Tables That Are Most Modified.
- need help with info about wideband o2 sensors
- DIY 101 - TC Lockup Configuration Question-
- Scanning Opti pulses??
- service engine light
- What is a 'mask' {ecm related}?
- 96 LT4... Speedo Fix Gear Change HELP
- 85 comp question
- Stock dyno numbers for LT-1 A4...
- Tested my 383 on Dyno (Tom Wong Rocks!)
- TPS Learn Procedure, will Datamaster work for this?
- Auto trans stalls when putting it into gear
- Need help 90 SD 8D upgraded to 383 superram...
- Tuning Classes for DIY's
- New scanner some questions?
- Turning off ABS and Lateral Accelerometer
- SYS light flashing 3 times
- Vacuum line -rts-open vac line under TB
- OBDII Scan tool.....recommendations??
- what are the limitations of ecm/pcm
- Mail Order Chips
- anyone use bigstuff3?
- pocket programmer anyone????
- Diacom and Laptop for $300
- 85 Ecm
- Cable??
- LT1 edit in central jersey/bucks county PA area
- How do you change injector constants 1985?
- 1985 Vette CRAZY Idle from 400-1200
- code issues
- ECM code ?
- knocking when bliping the throttle
- 165 ECM RPM Limits
- Scan Program
- Code 34
- Man, that was easy!!
- OBD2 TCat,.... feedback
- Winaldl advice
- O2 sensor in H-pipe-- question from a C3 guy
- Spark Advance Questions - $8D Specific
- 730 club Q-pin c15 to???
- PROMinator installed and running
- 87 idle hunt success story
- Dyno & Tuner Questions
- WTB: Scanner
- Emissions testing and codes.
- Much Better Performance before fully warmed up
- weird scanner readings?
- LT1 edit - Charlotte NC Area
- Diacom Software..Anyone Using This?
- PCMforless any comments?
- Calibration file .BIN
- Voltage to Maf
- Legitimate IDLE tuning thread (tables involved)
- Injector change and tuning?
- Craig Moates APU1 device.... exceeded power on the bus?
- Scanner Question
- L98 4+3 Overdrive Program Change?
- DTC's
- Advice on OBDII scan tool
- Need help downloading my stock bin -7165 ECM
- Anyone looking for a Laptop? FS
- look at the ve tables..is there a guideline to where i should be at
- Datamaster License AKM Problems
- 96 LT1 edit in Atlanta
- Calibrate Speedometer
- Anybody using DFI 6.X and SR/219 cam?
- Flashed A4 PCM with M6 bin, can't reflash now
- Correct fuel/air ratio?
- Help with a 96 Lt1
- got a ALLTEST model3200
- Anyone had experience with this system?
- Supercharged with Gen 7
- 1993 corvette
