View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. IAC counts for A/C on and Off with big cams? LT1/4's
  2. New Spark Plug Gap?
  3. Datamaster Help Please
  4. Macintosh software ??
  5. 1985 / 1226870 .ECU File(s)...
  6. reading fault code on aldl causes cooling fan to kick on
  7. Cylinder Balance Function In LT1 Edit LT1 v.s LT4
  8. Air Fuel Ratio on Dyno Too Rich
  9. O2 Sensor
  10. Code 27 QDM 3 = New ECM for 92 LT1 ?
  11. Follow up questions to: 1985 scan with AutoXray 5000
  12. ASR Problems?
  13. Re-tune for long tube headers?
  14. Better gas mileage when ALDL connected, WTF?!?!
  15. code 43 switch programming question
  16. Compatible ECUs?
  17. Newbie, too
  18. need a scanner???
  19. got a pinging problem, I tried adding gas, but Im not sure Im doing it right
  20. Help Newbie
  21. New to tunercat, need $EE definition
  22. 1985 scan with an AutoXray 5000
  23. SES Quicky ???
  24. Running open loop
  25. Datamaster Help
  26. Programming question
  27. Reading sensor read out on digital dash
  28. Scan Software - Let's start a master list - both paid - and especially FREEBIES
  29. Wideband O2 recommendations?
  30. Maybe? - My problems are....
  31. Po400 ???????
  32. Who makes a good scan tool for a 96 Vette ?
  33. Injector/rich condition help
  34. Able to connect to ALDL. Now suddenly funny BLMs
  35. Ccm_hac?
  36. Aussie Vette
  37. Question about willem Eprom programmer
  38. Weird Tranny Shift...Datamaster File
  39. DELTEQ users please help!
  40. How do I make an ALDL cable for my Laptop?
  41. Seems like flooding on start
  42. Diacom and newer Laptops
  43. No response from ALDL
  44. Dash problems, need quick advice !
  45. 1985 - Is 16:1 normal at idle?
  46. Has anyone used VEphd for $8D?
  47. Tuning cell no 4...
  48. 88 4+3 Gear Sensor
  49. Anyone burn custom proms?
  50. Use of Actron CP 9150
  51. Help interpreting DataMaster file - Source of knock?
  52. Need Help w/Datamaster data file
  53. 85 tuning
  54. Program "glitches"...what causes them???
  55. Heated O2 sensor installed, re-tuning required?
  56. Datamaster 02 locations?
  57. noob with comp. can"t get car to talk to comp
  58. few ecm questions??
  59. Diagnostic Software for 86 L98?
  60. Which Bit indicates the COOLING FANS are ON? DataLog From DataMasters.
  61. Re Tune
  62. Anyone else have trouble with a Needham's EMP-10 and windows XP?
  63. WTB ECM/PCM for a 1996 LT4 OBD II
  64. How to Clear Code 42 - 90 L98
  65. 1994 ABS troublecode help
  66. Optimal BLMs for performance vs. optimal BLMs for economy... some Qs and comparisons.
  67. WOT - Fuel Tables or MAF?
  68. Dyno Tuner in DC, MD, VA area
  69. Speed Density Cam Selection
  70. Reading my bin
  71. misplaced manual need fluid info
  72. amsoil ? have u heard of it
  73. Fuel Pressure reading
  74. Scan tool won't communicate with ECM
  75. "Tuning out" cam surge
  76. Sparking Brakes on Dyno Pull?
  77. Tuning Gains on Stock 94?
  78. What #'s are you using for the dyno section of tts data master?
  79. code 15- engine coolant temp sensor
  80. 7749 communications trouble (need help)
  81. Datamaster question re gear display
  82. interpreting the O2's. What does it mean?
  83. 89 Vette intermittent service engine soon
  84. where is the serial port so that I can connect my akm cable?
  85. First time tuning...Help !!
  86. Byte 0x7FFE in ANHT_8D.bin...
  87. Is ARFP for 90 Vette with manual gearbox?
  88. alcohol question
  89. PO400 EGR Problem
  90. Any experts out there?
  91. MAP(Kpa) question
  92. I think I fried my ECM
  93. How do you check codes?
  94. Got the vette back today
  95. Help with '85 poor idle
  96. CA smog suggestions
  97. How do you disconnect O2 sensor connector
  98. CCM codes
  99. Reading datamaster for 94
  100. I need general tune advice for L98
  101. Need camshaft advice for 383 LT1
  102. questions about computer
  103. What is a fair price for blown head gasket repair?
  104. Mixed up Mem-cals,,,help identifying????
  105. need a 92 bin
  106. AC: How to change R12 to 134?
  107. rpm in $8D
  108. 95 auto .bin needed
  109. Question about prom vs ecm?
  110. snap on mt2500 vs laptop
  111. Good book?
  112. Bank 1 Sensor 1 only lasts 500 miles
  113. Rear axle gear ratio question, ANHW and ANHU wanted!
  114. DataMaster File: Does this look OK for Nitrous?
  115. WTH? Idle Speed Timeout IAC Steps vs Coolant Temp??
  116. FreeScan Users - What Microsoft OS are you running?
  117. '93 ECM issues (?)
  118. Do I Need A Wideband O2 Sensor?
  119. EASE users...
  120. 1985 L98 stock BIN
  121. Removing AC require chip reprogram?
  122. 96' won't stay running
  123. service soon lite ? (1994 lt1 vert)
  124. Scanning software for an 85?
  125. Good Tuner
  126. I Need 90ZR1 bin file with the power key turned on.
  127. 410 mhz Laptop OK for Diagnostics???
  128. RPM input from ECM for Zeitronix WB ?
  129. code 44 lean
  130. How do I raise my idle w/ac on using LT1 edit
  131. Anybody using a cable from forum member MORLEY? got a question
  132. New ECM, Problems help!!
  133. Dyno tuning in Phoenix?
  134. Sorta doesn't like the A/C
  135. Re-Installing a performance Chip
  136. Code 45, 1986 L98
  137. WOT AFR -BASE For NEW MOTOR
  138. How to get 550 HP from 383 LT1?
  139. Tuning update
  140. maf test
  141. cruise control
  142. Tuning help (Long)
  143. Accel Calmap software 6.0 needed!!!
  144. Adding fuel
  145. VEmaster
  146. 1996 Lt-1 Tune up
  147. Reading a Datalog?
  148. Shift Firmness - How to make the shift firmer
  149. Tranmission Downshifts are happening (LT1 Edit /Tuner Car inside)
  150. VA/MD/MidAtlantic Dyno Tuners??
  151. Need advice on these codes and how to fix myself
  152. datalogging for an idiot?
  153. Is this a possible chip issue? Fuel loading when hitting the accelerator..
  154. Baton Rouge LA
  155. Quick Battery Light Question
  156. Superram and #24 Bosch injectors, stock ecu and MAF Q's/problems. What should I do?
  157. Overheating Problem
  158. OBDII Tunercat for '96 Vettes
  159. Help - going in for the first time - Long
  160. 92 Lt-1
  161. Hot Or Not ???
  162. Jump Pins on a 90?
  163. Help with CEL Codes on 93
  164. Low Oil Pressure Reading '96 and '95
  165. Airbag Light in '95
  166. PROMS n' gears
  167. FreeScan How do I get it to work?
  168. starts then dies?
  169. Code 72
  170. Alarm problem fixed-Performance Chip Screwed it up???
  171. Who makes a 1994 OBD 1 corvette code reader?
  172. Screen caps of Datamaster scan: this look like knock from bad gas?
  173. Idle speed during warmup
  174. Diacom plus software needed
  175. exhaust smoke
  176. have lt1edit software- what cable?
  177. New to Scanning/Diagnostics
  178. Anyone had a code 43
  179. sporadic service engine light
  180. P0100 MAF insufficient activity. '96
  181. Dyno Tuners in CA??
  182. $EE defintion File
  183. Alarm installed, car won't run, ECM problems
  184. Ecm swap,Whats required?
  185. Rear O2 mv output level.
  186. EASE software owners/users
  187. I'm new to the C4 but shouldn't it run when I want to drive it?
  188. Swapping Bin Files
  189. New To The World of Tuning
  190. 95 code help???
  191. 92Droptop intermittant start
  192. dfi gen 6
  193. Chip Changes during Dyno Tuning
  194. Invalid Response from PCM
  195. Ever get an imposible DTC?
  196. Took timing Advance away and Got More Pinging...? Tuners Chim in Please
  197. Clearing codes from the comp
  198. Increasing Shift Firmness on A4
  199. tech/force by otc. is this the one?
  200. Diagnose rich condition
  201. What is Code P0300b and P1133b??
  202. help
  203. need input please!
  204. Age Old Split BLM Problem
  205. please i need help---oil
  206. TECH 1/2 and OTC Scanner info.
  207. Can someone double check this?
  208. HELP>>How to read Codes on my 96 LT1???
  209. No code 92 LT-1 Corvette
  210. I want to rule the world.
  211. Slight Ping/Knock under light throttle? LT1 Edit & AutoTap Inside
  212. SES Help please (H13, H43, H44) {56k warning}
  213. Will it work? Should I buy?
  214. code
  215. Timing, Which to Believe?
  216. Rear O2 pins (again?)
  217. Wandering A/F ratio?
  218. Block Learn Question
  219. capturing ODBI codes real time 1993 LT1
  220. Reset PCM, BLM=120?
  221. Code 43
  222. New To Vette'ng....
  223. need cheap obd1 cable to pc
  224. Note to all
  225. Logging wideband info with Datamaster?
  226. noob questions
  227. Where di I get a bin that will be a close starting point for my mods?
  228. AutoTap and TPS Voltage Readings
  229. Need 94 M6 C4 stock tune.
  230. Need opinions on who to get a chip from
  231. manual fan switch install help
  232. WOT/PE Mode using Datamaster
  233. Radio Issue--Need Help
  234. BURN1 worke worke
  235. Spark plugs for LT4
  236. Need a custom chip made for my 88.
  237. 92 saying change oil! can i turn this off with Diacom?
  238. Speed-density ZZ-4
  239. Tuner in the Reading PA area???
  240. 92 LT1 6speed Acceleration Problem
  241. Diacom on a P 1
  242. System in Limp Mode, SES Fans on
  243. Looking to buy a laptop for scanning / data logging - need suggestions!
  244. ""I NEED A BURNED CHIP""
  245. EPROM and Mass Air Problem
  246. How accurate are the DataMaster Calculators?
  247. Newbie questions about richening A/F misture...
  248. Memory address for 3rd O2 sensor for '95?
  249. LT1 - Picture of benchtop tuning cable?
  250. tunercat
