View Full Version : C4 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Car electrical help!
  2. 1995 Owners (What Scan Tool)?
  3. Will this cable work?
  4. EGT's
  5. Cable
  6. Datamaster issues
  7. Stock Eprom
  8. Help Needed on LT1 Tunercat $DA3 System
  9. Tuners in the Northern VA area?
  10. 93 scanner problems
  11. ttspowersystem help scanner trouble
  12. In need of a scan...
  13. Shift Time, what's the point?
  14. Sos Ses !
  15. Slightly OT - Installing a 730 ECU on my Ford too
  16. Can You Install the EPROM Wrong In the ECM?
  17. Injector fuel trim multiplier
  18. NEED HELP! I cant find whats wrong!
  19. NEED HELP! I cant find whats wrong!
  20. What does this mean?
  21. Ecm & Ccm
  22. ECM&CCM
  23. ECM & CCM
  24. ECM & CCM
  25. Anyone have a working BIN from a supercharged L98?
  26. Gen 7 start up program
  27. FS Pocket ROMulator,The pocket programmer2,D_Erase 4 chip UV chip eraser etc...
  28. Where to buy an ALDL cable
  29. Please help I am looking for a tech 1 or 1a cartridge
  30. Code that won't die...
  31. dealer added better program to computer?
  32. holley commander 950 ecm for tpi? or ?
  33. Code 36 on my modified '92
  34. Can anyone in SF Bay area make a custom chip?
  35. Need '870 ECU file for TunerPro RT
  36. Scan Question
  37. Need use of a scanner
  38. anyone have a chart for AC temp sensor outputs?
  39. Engine creating slight vacuum at WOT (96-98KPA @ WOT)
  40. Help identifying my chip?
  41. Still can't communicate - 93 LT1 ECM...278
  42. In need of a .bin file!
  43. Datamaster says my tcc isn't locking
  44. Computer setting in D vs OD- any difference?
  45. Found it!!
  46. best bag 4 the buck mod?
  47. paging alvin from pcm for less
  48. Need a stock 92 file
  49. Too Rich!
  50. Block IAC for Idle Cure?
  51. Trying to Use DataMaster - Please Help
  52. new BCM....help my 1996 Collector
  53. Computer Controls-Simplified?
  54. 3700 RPM max?
  55. dtc 48: MAF system fail ?
  56. mass air flow sensor bad? codes 33 and 34
  57. Which is failing? ECM or CCM?
  58. What inputs does the ECM look at to lock the converter?
  59. ECU flag/item questions
  60. Ed Wright Programming
  61. Limitations of Pocket Programmer 2
  62. Auto Tap users
  63. Need Help with Diacom Plus Software
  64. Aarrgghh
  65. TTS data help needed. What should the numbers be for an 87?
  66. Updating an 1988 from OBDI to OBDII ???
  67. Electronic Climate Control - Out of Control
  68. 84' won't start, sledge hammer or dynamite?
  69. Water Pump (help)
  70. Question about shift points with gear change (4L60E)
  71. I need something simple to pull codes on my 89'
  72. Craig Moates' ECM 851
  73. '88 EPROM can someone ......
  74. DFI, Fuel/Utilities/Feedback option
  75. Can one of you experts take a look
  76. Auto Xray Scanner delimma 85 ecm..
  77. 85 -Weird BLM readings
  78. Tuners Please - 22lb or 24lb Fuel Injectors? Advice Reqd. Can't Decide
  79. C4 Suggestions Mounting locations for MSD 6AL
  80. 85 Won't Start
  81. New Cam vs ECM changes?
  82. Help Mounting Location for MSD Box
  83. Replacing Distributor Cap Mess
  84. ECM Table for fuel injectors.
  85. Tuning new motor with hotcam
  86. Anyone interested in a FAST system?
  87. What Kind Of Luck With Moates...
  88. 1984 newbee Bob
  89. 1984 newbee Bob
  90. Memcal question for the experts.
  91. 83 Regal with 92 Vette Lt1...low speed miss HELP!
  92. "86 convertible='87 ECM???
  93. O2 Sensors on 94 LT1
  94. NuBEE stuck at the beginning,
  95. 88 wont start
  96. Ordered a Craig Moates Ostrich
  97. LT1 Edit
  98. TCC Lockup Problem
  99. Tuning a Speed Density LT1???
  100. Need Help Code 1886
  101. Help finding Hardware/Software
  102. Datamaster and 1227165 ECM.
  103. Cam'd LT1's lets see your timing tables
  104. 1992 code 26
  105. Datamaster Dyno Graph
  106. What does increasing or lowering TPS voltage do on LT1?
  107. ALDL Won't Connect
  108. TunerProRT Problems
  109. PCM Upgrade
  110. Chip Re-Install help
  111. closed loop lockout
  112. Water in intake
  113. Can Someone Verify This Prom (late 86)
  114. Superchip or Jet chip?
  115. 1985 - AIR injection cycling
  116. "ECM852" work with a 95 6spd?
  117. Ran First Scan; Questions, Questions, Questions!
  118. No Start - PCM Dead?
  119. First Scan Tonight - What Do I Need To Know?
  120. can someone make a bin file for me?
  121. LM1 users, newbie user here!
  122. New chip help needed
  123. WBO2 Sensor/Definition Files
  124. Tuning and Altitude?
  125. speedometer
  126. trouble code 26
  127. One ignition key
  128. Anyone use a laptop mounting bracket in their car?
  129. Unusual Problem with running hot
  130. 94-95 ALDL, DTCs and severe hesitation
  131. Diacom GM +
  132. Who Can Burn Me Stock 86 Prom With A Few Changes ??
  133. Wiring diagram for DFI VII?
  134. [Dyno Graph] Is my opti dead?
  135. Smog Tuning
  136. Make chip or Buy Chip?
  137. Duty Cycle and Datamaster
  138. ECM vs PCM? Data scanning problems!
  139. Homemade cable question
  140. Heated O2 Sensors and harness extentions
  141. Help a noob out please - just about to get started
  142. scan tools?
  143. [New To Scan And Tune] Anybody Using Serial To USB Adaptor
  144. Back from the Dyno - a tad dissapointed..
  145. OBDI and OBDII??? Newb question
  146. Group PROMinator buy on another forum
  147. Dyno Wide band A/F ratio vs. VE table quesiton..
  148. ignition cutting out
  149. 1989 L-98 running terrible
  150. Wiring diagrams?
  151. ideal A/F ratio??
  152. If your timing tables look like this....
  153. Code sheet?
  154. '95 Radiator Removal
  155. MEMCAL problems: Not solved, but much much better
  156. C4 Processors and Programming
  157. Why all this Tweaking?
  158. Received Binary File -- Now What?
  159. Bob Bailey has done it again!!!!!!!
  160. help car is messed up
  161. Code 55
  162. HELP!please tune after procharger!
  163. who uses the apu1 from moates
  164. lean or rich? throw a code? 1986
  165. Successful DFI install
  166. Motor died
  167. opinions: TunerCat vs TunerPro vs ???
  168. CCM Codes 31 thru 38????
  169. Do I need a programmer?
  170. 94 vette
  171. Which Blank Eprom do I need??
  172. PE vs. RPM Trouble - Help Needed!
  173. Auto ,Manual, 92 LT1, Same ecm?
  174. 94 vette is now running good
  175. Calling timing experts
  176. Won't Stay in Closed Loop
  177. Tbi Chip!
  178. MEMCAL problems part II
  179. ALDL Terminal - Repairable?
  180. AKM Cable Question
  181. Shift Light
  182. Corsa Exhaust = Changed Fuel Trims
  183. 94 vette will not run-continuing saga
  184. Slow to return to idle speed, Help Needed!
  185. Considering more HP
  186. Main spark advance v.s. RPM v.s. load
  187. Timing adjustment via TunerCat?
  188. Torque Converter lock up / Mileage.
  189. Help DFI gurus (please)...engine shutting down at 5800rpm
  190. 94 vette will not run
  191. getting a smoother running vette
  192. Zeitronix WB installation need help. DoctorJ?, Ben 73...Sb Nova??
  193. Definition files remain same when ECM is upgraded?
  194. Need to change Idle RPM, need help!
  195. WinAldl Data Stream definition
  196. ALDL cable adivce for noob, please...
  197. Cold Start Problem
  198. Tuning "book" pt II
  199. '95 PCM - Low Octane Compensation Parameters
  200. Datalogging For Optimum Octane Level
  201. knock count
  202. injectors
  203. Another tuning question
  204. Power enrichment question
  205. 94 vette will not run
  206. Paging Alvin
  207. Tunning question
  208. trouble w/ usb to serial adapter
  209. Code 400 question...
  210. Tuning "book"
  211. Code 36 Question
  212. DTC 24 ('95LT1/4L60e)...Help!
  213. Clunking Transmission?
  214. Where to find MEMCAL?
  215. TTS Datamaster comport settings for 93 LT1
  216. ECU: Dead or just unhappy?
  217. help chip burn.....
  218. Desired Idle and Stall Saver
  219. TCC 4th gear question.
  220. Injector question
  221. Fuel Pressure Tester
  222. Burn ! success
  223. Definition files for Tuner Cat?
  224. Check what I got working
  225. engine skip
  226. Aldl Obd1 Diagostic Help!!!!!
  227. Easy question...
  228. Adjusting AS&M 58mm TB - IAC
  229. Wah Freekin Whoo!
  230. problem with new injectors
  231. Voltage to maf
  232. Time for a tuneup !
  233. Couple wiring ?'s on Accel DFI
  234. '96 LT1 W/auto--Ecm editing?
  235. Name this PROM
  236. who repairs 92 LT1 ecm,s?
  237. ANYBODY REPAIR MY 92 lt1 ECM, COST?
  238. What exactly happens under PE?
  239. Help me understand LV8 values
  240. what does these codes mean
  241. wtb ecm 92 LT1 ,Auto, stock
  242. Desperatly need the pinout to the 9278 (93)lt1 Ecm
  243. Files for 93 Chip LT1 Auto or whatever
  244. Can I Use Datamaster...
  245. will #16214399 ecu work in 92 LT1 properly
  246. DFI help on VE tables vs timing vs inj DC
  247. Pulled two 02 Sensor codes...
  248. O2 Program Out with LT1 Edit
  249. Bogging Down at WOT
  250. Codes H52 and H62
