- Help PCM FOR LESS TUNE
- Looking for more ponies
- ALDL pinout question 94 vette
- Tuning with tunercat?
- O.K., I'm game!
- Install help for PCMforless chip -- 87
- WB O2 question
- memcal part # please
- Normal Scan Values MAF, BLM etc
- '96 CE Alternator Connection
- Diacom question?
- Where to Buy these Chips, locally? 27SF512
- Reading chips
- ECU Swap
- Help Needed Snap ON MT2550
- Where is the best place to buy sensors
- Need Chip burned
- code 43.. ever not a knock sensor and which one if it is?
- HELP! My car will not stay cranked!
- 02 Volts @ WOT??
- Wideband Software Inputs....Questions
- Ecm replaced by DFI gen 7.. what happens??
- Injector constant
- High BLM numbers at speed
- High BLM
- Help - timing question for tuners...
- checking pickup coil ?
- [HELP]Scan tool
- Snap-On scan tool Cartridge
- 14.7?
- Ed Wright Locked PCM.. anything to get around it?
- I think I found that miss and a neat tool
- DataMaster Log
- Datamaster File
- opinion on my emissions test please
- Ohm ed my plug wires-hmmmmmmmmm
- setting my timing
- What chip......
- Do you retune after just heads and larger ratio rockers?
- Tuning Question about BLM and AFR
- LM1 Meter - RPM, TPS info
- Homemade interface???
- gen 6 pros i need help
- 383 w/92 TPI = tuning
- heater core leaking?? help Mr. Wizard
- TTS Datamaster, or other good program
- vats simulator
- Loosing Datamaster Link During Accel - Idears?
- DFI GEN 7, Code 72
- Gen 7 pro's NEED HELP !!
- Romulator Users
- Code 42 HELP
- No power at aldl
- 92 & 93 Bin request
- Qusetions on LC-1 or LM-1
- LT-1 needs ECM
- Ecm
- $32 to a $6E with no mods.
- ROMULATOR & 870 ECM
- ECM Ground?
- Pcmforless tune not letting my datamaster work!
- Megasquirt users ... pros and cons?
- SYS on odometer flashing
- Wiring for a 91' vette compared to a 86'
- FM tuner
- Whats a Good Timing Amount
- Fast system set up {Bank to Bank}
- why am I running better in open loop?
- Need help getting bin
- Plugs & Wires
- Smoke on Acceleration
- laptop for tunning?
- DFI 4 wire o2 sensor..where to get?
- Fried ECM
- Hypertech PTM Wet
- {VA} Mar 31st Dyno tuning for LS1,2,6,7/LT1/LT4 & GM trucks with Jeff Creech @ C.A.M.
- Ran TTS Datamaster - need help reading it
- Anyone Scanning '86, have questions.
- Scan codes
- BIN Request
- Megasquirt corvette is running! (video and pics)
- how many ohms should spark plug wires have?
- mounting computer and car shuts off
- L98 Performance chip.
- AC DELCO plug # Help
- LC1 AFR versus Voltage
- Need help with Tunercat timing table
- got the sensor, just to make sure i change the right one, quick advice
- Auto X-ray
- Is this a bogas DYNO sheet ?I want your opinion please!
- Codes 27, 48
- What would happen?
- winding noise from engine compartment
- Mail-Order programmed CCM? Alvin, TJWong, etc
- Obd Ii
- Tuner Cat question?
- SYS again?
- Vendors for Rebuilt ECM's
- Need info on tuning program/software
- Speedo as decoration
- Help T Wong Have a ? on fuel pump
- SES light - code P1572 - Traction Control System circuit low too long
- OBD1 Performance chip ?
- Are all 1996 ECMs the same?
- Does 32# Injectors Require Tuning?
- Installing 32# Injectors on Stock 95 LT1
- 90 scanning software
- Logging software
- otc scan code
- Doing the A4 to M6 swap
- TQ lock up...
- Computer failures
- Paging Alvin (PCM)
- Code H32 on a 94
- OBD1 Chips (Attachment piece)
- DynoJet 248X, IS it a load bearing dyno ??
- In-car Notebook PC Mounting Bracket - C4 or Generic
- Open Loop O2 question
- 91 Front Skinny Drag Rim?
- How to make a serial/ALDL cable.
- 89 white conv. transmission slips
- Communicating with Datamaster
- Code 32 (egr)
- injector ohms and plug gap
- Innovate Motorsports LM-1 & AuxBox RPM?
- 86 Ecm
- Diacom software
- Trouble code 36 on 1986 TPI Vette???
- How many records when dataloging?
- LT1 edit question
- My 96 coupe is also in trouble.....
- My 1994 vert needs help...
- Tuning info
- puff of smoke on start up
- Need info on TPS values on a 94 LT1
- AFPR PSI on a 88 TPI
- Help with codes on MEM-Cals??
- Will I Need A New Chip?
- Are ECM connectors available??
- Looking for tuner in jax fl.
- Can MEM_CAL be cause for no codes???
- Bin Offset on sf512 chip
- Wiring grounds on LC-1
- reading stock chip bin
- Sys message & security light
- Help with diagnostics
- false speed reading
- chips
- Tuner Location
- emissions failure-need help with interpretation and solution
- Tuning Educational Video: Base Fuel Table
- Anyone Using Altronics Wideband ??
- AutoXray Help - Lost my PC-Link software CD
- new opti/plugs/wires still has a skip
- PLEASE HELP TUNERS! with datamaster & tunercat
- PLEASE HELP TUNERS with datamaster & tunercat
- AEM Wideband UEGO controller
- Need Help - 1990 T.P.I.
- Hypertech programmer LOCKED ???
- Oxygen Sensor
- Datamaster
- Options for higher rpm capability w GM ECU
- Breakout box adapter part #'s please 95 Vette
- newbe broken bolts
- tune up
- Wierd Temp flux??
- scanner
- How to read data from tech1a AND/or Tech2 via desktop computer
- new to tuning!!!
- Best WB ? Recommendations?
- I broke down and got an LC-1
- Integrating an LM-1 into the OBD1 datastream
- Need Tuner in Palm Beach Florida Area
- Power Loss At Higher Rpms 91 L98
- Dyno tune w/ open exhaust?
- OBD1 and WinAldl and USB???
- Is there a "consumer" Tech II?
- cold not good
- how to use Innovate LC-1 WB
- Having trouble linking Diacom and 7730 ecm
- '86 Idle and Stalling Problem
- speedometer problem
- Datamaster Accept A Wideband Input ??
- ECM part # location
- Need MAF help
- Tampa LT1 Tuners??
- 30lb injector question
- Wideband O2- Where To Install ??
- OBD1 Cable
- Grounding "test terminal"
- No spark/Weak spark on '85 C4
- Spark Retard Help
- west oklahoma tuner
- Replacing CCM how to program?
- 85 scanner
- Knoxville, TN area tuners?
- Can you tune a PCM on your own?
- Special Kudos to GBODY5 - Tuning
- the swap
- Upgraded ESC for 85-89 L98
- Results from a bad tuner
- Typical problems can be found with datalogs
- suggestions on a laptop
- '95 - No "MIL" or Fuel Pump...Bad PCM?
- 1986 Corvette Coupe Engine(L98?) Problems
- Dyno tuning a L98 in the Chicago area?
- Customers Mail Order Tune Fiasco
- Finally got a lap top - what cable??
- '96 into a '72
- Fuel Maps
- Open Loop Learning or Tuning?
- Tech1A "Waiting on Data" error
- Open loop, closed loop, can you help me
- who has the best price on tts datamaster auth codes?
- Torque Converter Lock up, what MPH can you tell it to lock up??
- Get Codes out of a 96 Lt4?
- Tuning software
- F.A.S.T. Tuning
- RWHP -vs- Crank HP Factors?
- EASE users: Tech question
- Engine miss challange beyond me S.O.S.
- Chip(Prom) Help
- What info is needed to burn a chip?
- Will Give You A New Moates Flah Burn Unit Free.helpme1
- SES but no CODE
- Runnin' lean
- Scanner/diagnoser near Houston
- wiring harness question
- Idle System High P507 Code with Mods
- Oscilloscope selection assistance requested
- Lt4
- Low O2 readings in datamaster- questions...
- Tuner Wanted for LT1 OBDC 1 in WPBeach FL Area
- So what is the difference between EPROM checksums APYZ and ARAP
- Emissions
- Innovate LC-1 WB O2 - Appearance of output when graphed
- Enhanced Willem Programmer
- big name tuner cat fight
- ACCEL complete Super-ram kit
- Need help with 1992 ignition problem...
- Can Someone Help with This Screen
- O2 Sensor questions ??
- Anyone use this system for tuning?
- 84 Crossfire - High CO and HC
- Some scary stuff after dyno tuning last night
- Car Overheats Blows Cold Air?
- ECM 7165 Data logging.
- Went tuning, some good some bad.
- Communicating with 93 ECM
- Car electrical help!
