- Idle RPM adder function, 1993 PCM Corvette?
- Code P1641 ?
- For Sale AKM cable
- New datalog and a few questions.
- Beware of so called Tuners, or rather know your tuner
- Couple questions about tune.
- Scan Software
- Scan Software
- Speed density on a dyno?
- Laptop programming?
- SYS on a 91 L98
- 85 with 23 -42-44 codes
- problem - NO injector pulses
- ECM question
- Datamaster-BLM
- # 34 on a 1987
- Good Dealings w/C. Moates apu-1 etc.
- Code 32 and now 33 too!
- Selective Ride Codes
- 1/4 mile times
- cut back plug gap?
- DFI sys
- 93 383 lt1 datamaster scan
- Gen 7 & closed loop corection
- OBD I Scanner
- No Codes from ECM
- need tech2 and/or tech1 help ccm transfer
- DTC CODE 301 help
- Can anyone post a timing map of a stock LT4 or .....
- Fuel Injectors - 94 LT1 - Ford 24lb
- Timing Light
- 1988 Corvette Starting and Running Problems
- AutoProm / TunerPro Chip Reading Question
- Shift firmness 4L60E (1995), how to?
- Looking for an OBDII Scanner (Laptop Based)
- Gen 7 KINGS need some help !
- Rough idle and stalls. - 89 Vette.
- off idle stumble
- Idle problem
- Basic code Question?
- injectors
- no refrence pulse
- winaldl, is it me
- How do you get A/F ratio to show up on Run files
- Help - Interpret my TTS Logs Please?
- Error code 43... knock sensor?
- Knock issues with centerforce dual friction?
- No help in C4 tech so far, AutoXray cable question
- 85 with a check engine light and code 21
- More rich issues....
- EGR Diagnostic Switch
- A little help finding/choosing cables!!
- Gen 7 help
- Help Diagnosing Code 32
- WINaldl data log
- Help with Datamaster and Tunercat
- '86 won't start
- Check Engine Light?
- 94 lt1 running rich
- Serial to USB Adapters?
- Need Help with new Actron!
- Wiring Problems?
- 94: Beginner, advice needed
- Stalling LT1
- ECM serial data lines
- scan look ok?
- HELP! How do I replace power motor on 1993 Corvette driver's seat
- Ecm Removal
- How do you determine timing ? (LT4)
- PCMCIA cardbus-serial adaptor for non serial port laptop?
- It was the Relays !!!!
- Scanning software advice please
- Tranny swap info
- EASE or AutoEnginuity Scan Tool
- Failed Emissions - What do the numbers mean? {56k}
- Is this what I need?
- What is that hot water check valve for?
- who could help diagnose a problem with datamaster?
- Who would help tune 86 Vette in California
- Stock vs. Scan
- Anyone with a NA 383 setup on an LT1/4 with a Gen 7 DFI ??
- 85 L98 automatic with codes 15 and 32
- aldl, no RPM
- Code 32 and 36 problem on 89 tpi
- pulling injectors???
- First Burn! Success! Few Shortcut Questions
- GM Code key
- LT1 'Road Speed Constant' setting in Chip.
- Best book or place to get data for learning to tune etc
- Can I use a 96 throttle body with 90 ECM
- Gen 7 step by step ?
- MAF Help
- SES and O2 Problem
- 96' Lt4 Overheating (not Simple)
- Tuner Cats qestion
- Injectors wont fire/right bank/87'
- Is it normal for the computer to be retarding the spark?
- Motec
- New Injectors, 49lbs fuel pressure....cars running lean?
- Need ECM Tuning Advice 94 VERT 6spd
- What ALDL pin configuration should I have?.
- Throttle body IAC
- 1990 Vette and wbO2 datalogging
- What's best way to position the ECM when using the Moates AutoProm
- What's a Wideband o2 do ?
- Chip Location
- Timing vs Load - General Question
- Noob to scanning, what do I need?
- Anyone want to look at a csv from Auto-Xray?
- How to get codes with a paper clip?
- 92 running rich at idle. HELP!!!!
- Is live data possible or can you only record?
- TPI popping on decel, most common causes on modded car?
- ALDL Cable...how many pins suppose to have?
- Question about 85 ecm vs 86 ecm
- Romulater RT Tunercat ?
- timing trouble on 91 L98
- accel gen 6 question
- Serial > USB adapters? (About to buy ALDL cable)
- TTS Datamaster and AKS cable linking issue
- Relays
- Which laptop do I need to use TunerPro RT or Datamaster?
- EEPROM - Can anyone test one?
- Auto-X-Ray EZ-Link scaner & 1985
- Split BLM at idle question..
- 1987 overheating - Help - sequence ???
- [Autotap] 96 LT4....
- Problem pulling codes
- problem with maf sensor and computer ECM
- Communicating with a 6e mask in 165 computer help please?!?
- www.pcmforless.com chip ordered
- Cam Install Question
- o2 readings and other questions
- '92 LT1 scan problems?
- USB Driver help for Moates Flash & Burn
- Need $32 xdf file
- Need LT1 (92-93) BINS.
- Datamaster DA Timing Question
- 89 Convertable air / heater control unit electrical issues
- Timing in chip doesn't match datalog, '92
- qustion about the 870 to 165 ecm swap
- Help a Noob learn !! Gen 7 DFI
- Looking to Tune
- Whoops. Reversed Polarity need help.
- c4 targa headliner
- 91' service manual vs. wiring harness ???
- Can't Read PCM (94)
- Transmission Problems
- OBD clarification
- Can someone look at my TTS files at idle and see what may be causing the richness?
- F Body bin to bypass CCM '90 ?
- Any one have an ARAS bin?
- AutoXray stops at 6,375 RPM?
- Strange Start / Idle tuning quirks on H/C '92
- Problems With my Radio
- DataMaster log file help
- Electrical Problems
- 350 L98 superram tune
- How about a recommendation for an OBD-II Scan set-up
- Hot !!!!!hot!!! Headers
- miss at 7,200 RPM...
- ALDL cable and program needed
- Explain this data field to me in PCMCOMM
- IAT sensor question and others..???
- How to reprogram for new rear gears.
- Need help, bad tts interface between laptop and car
- Whos tuning package is the better???
- Hypertech Chis vs. Tuning
- Knock - knock during scan
- When does the ECM call for a TCC lock
- this has got to be simple (not)
- I am a melon head (but I have some tuning questions)
- hard start, extended crank
- CORVETTES OF WESTCHESTER's CORVETTE "SHOW OFF"
- What does this all mean? what sense makes the O2 readout?
- Could my intermittent stalling problem....
- suggesitons on tweaking my car for the track
- 6e TPI Highway Mode - huh?
- Will this cable work for my car??
- Getting rid of the egr
- O2s are no good.
- FreeScan program works half way
- Failed emmissions again
- Best definition file for TPI swap 32, 32b, 6e? Best broadcast code to start with?
- Win_Rom1.12 install password: I remembered it!
- Reprogram For 1.6 Roller Rockers?
- Custom Chip
- Need Programming Help: Alvin or others
- [pic] tell me what's wrong here
- ALDL Cable - ?? Watt resistors
- I'm getting data but...
- Is the distributor reference pulse to ECM a 12 volt pulse wave ??
- another problem
- rebuilt 85
- Fuel pump relay
- 1988 Head Lamp Motor
- Stalls after a warm startup?
- MAF went bad, but MAP didn't take over???
- LT1-16159278 O2 sensor readings??
- OBD II Coad Reader
- Battery DEAD
- tach signal input for 96 vette...
- i too have code 36
- PCM for less
- RPM Wideband Input ???
- Ran the scanner again today-no codes
- the old vats agian
- getting ready to scan myself on 86
- Typical Lt1/4 Tuning Cost at a Dyno Mechanic?
- Chip Question?
- scanning-WOW-step in, Ray, Morley RRT everyone
- so now I need an adapter for the adapter
- OBD1 whats the best and easiest software to use
- How do you idle it down?
- Any suggestions-scanner not connecting?
- Running rich at idle, hard to start
- Want to scan/monitor my 1990 but can't get it to work
- Need help with final tune on 86!
- MST sensor on DFI Gen 7....??????
- Is there a driver required for the akm cable to work with datamaster?
- first datalogs would like some one to take a look
- tried scanning-now what?
- RAIN or SHINE! CORVETTES OF WESTCHESTER @ NEW YORK INTERNATIONAL AUTO SHOW - JAVITS
- I'm ready to scan-few QQQ
- Is it ok to request a bin and xdf in this forum?
- Interesting data
- Stock 95 datalog
- 85 skips in WinALDL
- What is a good software package for my laptop
- Corvettes Of Westchester @ New York International Auto Show - Javits Center
- Accel Fuel Injectors
- What is best program for laptop
- Craig Moates is the best!
- PP2 help
- Edelbrock ProFlo ECM "kit"
- 02 Sensor voltage erratic
- so many questions don't know where to start
- When is a new chip recommended ?
- injector trouble?
- Code 36 Mass Airflow sensor?
- injector troubles?
- Running a scan on my 85
- Second right O2
- LTC 145-150 engine running lean?
- CCM problems with aftermarket EFI???
- Iac ?
- Need Computer/Tuning Basics
- Tuning ?
- Questions about the TPIS Super Profile L98 cam
- SLP Cold Air Worth It?
