View Full Version : Factory Correct Resto
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15
  1. Master Cylinder dating question
  2. Emissions Sticker
  3. C4 Floor Color Question
  4. 73 BB Casting # Bellhousing & Exh. Manifolds
  5. Tank sticker preservation
  6. 1968 Hardtop Vinyl Question
  7. Some Refinished Goodie Pics
  8. Seat Belt Date Codes
  9. Shimming the body after putting it back on.
  10. I'm doing it!
  11. Gas Tank Finish
  12. Frame Repaired, not replaced!!!!
  13. Small crack in fender of C3--easy to fix?
  14. paint repair/restoration question, black paint
  15. Judge's Wanted
  16. Installed C2 cluster - 4 quick questions
  17. Judging question too... - BB w/aftermarket radiator
  18. Owners Manual
  19. 502 in a 66 and light blue convertable top
  20. WTB #270 coil
  21. Rear Spring on Mid year
  22. Radiator Caution decal
  23. Is Anybody Here Restoring Early C4s?
  24. what is the thread size of the body mount bolts for a 69?
  25. (OT) Early 70's Delco radios
  26. Making my Christmas list - where to get......?
  27. Dealer info needed.
  28. Corvette America
  29. Interesting Fact #2 69 Side Exhaust Chrome Plating
  30. Interesting Fact #1 Truck Freight
  31. Power Antenna Switch - 65
  32. Fan shroud on a 64
  33. 70 Headlight Switch
  34. Remember that EXTREMELY original 69' I posted about......
  35. Front Spring Removal
  36. Rally wheel codes
  37. Restoration Battery Tips
  38. Frame measurement
  39. Frame refinishing
  40. Help a C3'er out
  41. Frame, would like opinions
  42. Jack Restoration Revisited
  43. How do you pull wiper arms off
  44. Help, anyone have a body off a midyear
  45. Disassembly and removal of "65 dash
  46. redundant Question..69 BBvalve cover
  47. NCRS judging and original radios?
  48. Time to play where's that wire go? ('68 wiring question)
  49. Midyear Gauge Cluster Rebuild...
  50. AC 45 Spark Plugs
  51. Body is off the '65
  52. Ok...It's Time For Another Round Of "Stump The Experts" WTF Are These???
  53. Where to find lacquer to repair paint?
  54. Steering Wheel Restoration
  55. No Flight - New Installment
  56. Detailing a 63s undercarriage.
  57. Is this a good block for my 68 ?
  58. From Driver to Show - Suggestions for plan (A few questions)
  59. Exhaust Paint
  60. Floor is in...
  61. Best 63 Master Cylinder Rebuild/Restore
  62. My Completed Lift Installation
  63. Additional Frame dimensions needed.
  64. 68 valve covers - SB
  65. Orland winter meet
  66. 63 Valve Covers
  67. 63 Master Cylinder
  68. Anyone know what this starter is off?
  69. Could anyone near Boise, Idaho that can look at a car for me please IM me as soon as possible?
  70. WTB BOLT ON WHEEL SCREWDRIVER
  71. Chuck Gongloff
  72. Shades of semi gloss black........
  73. Clutch Fork Push rod
  74. what are hard to clone l88 parts(asking because I want to buy a l88)
  75. Steering Wheel Identification Help
  76. I've never worried about factory correct before, but I am now.....HELP......
  77. 1969 windshiel pillar vin ?
  78. Were there any *real* COPO C4s?
  79. Put on your thinking caps.
  80. Radio Delete (block off) Plate - still looking
  81. correct caliper castings for jan 67 j-56 option
  82. Frame Advice
  83. A C Square Mesh Filters
  84. I need some help and advice on originality of the rear compartments
  85. Need color treatment info for 65 radiator core support !!!
  86. How "Correct" do I want?
  87. body rotator
  88. 69 seat belt question.
  89. Ignition Coil
  90. Steering column sticker
  91. Correct date for a starter?
  92. Torque Converter Cover 89 auto
  93. career couseling needed
  94. C3 wiper solenoid.....
  95. C3 Rear Window Defogger
  96. Early C3 factory radio
  97. Anybody here going to be in the NCRS gallery at Carlisle?
  98. Vacuum line's on a 1980
  99. Need some good under car pic’s of a ‘66?
  100. missing trim tag on 73 what to do?
  101. right tune up parts for 67 L79?
  102. Dale Pearman
  103. 75 REAR BUMPER
  104. replacement carpets
  105. IS Allens aluminized exhaust ( under car) systems ok for ncrs ??
  106. Picture of C-2 rear suspension / differential area?
  107. Need correct intake and carb #'s for '66
  108. r-12 to 134a question
  109. 62 340 HORSE
  110. 68-69 seat belt guide reinforcements (and guides)
  111. C2 Front Clip Bonding Procedure?
  112. A few questions on judging.
  113. Exhaust Manifold Stud Nuts
  114. Engine's out, got some questions
  115. Is stock style stainless exhaust considered factory correct?
  116. Normal people don't understand!
  117. Correct valve covers
  118. Where to find instructions to install backup lamp switch?
  119. Happy and sad at the same time
  120. NCRS Hershey National. Got My Top Flight Award.
  121. Need correct "silver" for 58' wheels...................
  122. C1 Rear license plate holder & lamp housing color
  123. Need HELP with removal of tank sticker!!!
  124. has anyone ever remove there fenders to fix them then reinstall them?
  125. Help with spare tire tub lock
  126. C-3 paint color question
  127. Leaving For Hershey NCRS National Tomorrow
  128. rubber rear sway bar bushings for C-2 BB ?
  129. original carb question
  130. NCRS national road tour ????
  131. dwindling original parts.....
  132. Long term project
  133. Correct '69 350/350 intake manifold?
  134. NCRS Deduction - underhood light
  135. What is the correct finish for wire harness and other wires under the hood for '67?
  136. Eska Corvette Pedal Car
  137. Late 69 vaccum Diagram
  138. I want to drop a LT5 engine into a 1989 convertible…
  139. How come you don't hear from more guys that actually worked on the assembly lines?
  140. Just a couple of 73 questions
  141. [Help] with Muncie 4spd shifter inspecction plate install...
  142. Has anybody cleaned or refurbished their a/c POA valve themselves?
  143. Tunnel Insulation
  144. need engine detailing tips!
  145. @#*#@ repro parts.
  146. Finally Bought My Lift At Bloomington Gold
  147. VA Vintage plates anyone know where I can buy them????
  148. ok here' s one for you! need help iding this trany
  149. (CF Tour) Saving Face.
  150. It's July 1st, time to infuse some life in this ol' board....Are You Ready To Rumble?
  151. 66 427/425 block fittings
  152. Happy 50th Birthday to Corvette
  153. Harrison foil a/c tag?
  154. Door labels / DOT stickers for a C4
  155. Painted the garage floor today....
  156. Time to reply...before they shut us down...
  157. Gas tank restoration.....
  158. Radio Delete Question
  159. 73 Center Grille
  160. 58 VIN tag and other ?s
  161. metal wireharness clips on a C3
  162. Corvette Hall of Fame
  163. Paint Problem-Anybody Seen This?
  164. Title Defense
  165. Odometer Queation
  166. whoops! I missed the deadline
  167. Correct Shocks for my '70 454
  168. T-Top puzzle
  169. 62 FUELIE
  170. C4 Body Removal Questions
  171. Air Tubes in Exhaust Manifolds
  172. Project No-Flight Update
  173. brown distributor cap ??
  174. mfg tag on driver door
  175. Interior metal trim color?
  176. Dealer installed fire extinguisher?
  177. R12 to R134A air conditioning conversion...
  178. distributor tag reproduction ??
  179. 69-70 ZL1
  180. Chroming question (Will NCRS care?)
  181. Gas tank support bracket question...
  182. Will the SUV's and trucks of today ever be as collectable as our beloved '50's -'60's classics?
  183. Resto Paint Questions on a 1976 Vette
  184. Aux hardtop rear window clips
  185. Going to Bloomington Gold?
  186. Should I replace my rear cross member bushings?
  187. Couple of questions about 81 Vette engine bay
  188. Windshield Frame
  189. Vehicle Cert. Label
  190. How to remove 81 glove box latch???
  191. Correctly Dated Glass Codes
  192. Heater hoses on 74 LS4 - 3/4" -AND- 5/8"???
  193. Radio Repair
  194. stencil kit
  195. Need a paint and body man in Michigan, preferrably within 1hr of Detroit.
  196. Posi-trac Experts (If it ain't broke, should I fix it?)
  197. 1966 paint formula
  198. Found during Restoration, second Corvette Order Copy!
  199. Where is the Dome Light Delay Relay?????
  200. Front coil springs
  201. 74 LS4 Auto - starter and alternator numbers?
  202. Interior parts
  203. Does adding A/C to my 71 effect NCRS judging negatively?
  204. Hose Clamp Plating
  205. '68 Rally wheel question
  206. Motor mount heat shields - 74 LS4
  207. AIR pump siezed - any worry?
  208. Grease Questions
  209. Fixing an oil pan drain plug leak?
  210. A.I.R. pump on a '74 ? how to tell ...
  211. "Correct" Color & Finish Help
  212. Central NJ Chapter Meet
  213. parts on CD for resto
  214. Removing a wiper line on the front glass
  215. Alternator & Smog Pump Finish Lousy
  216. false advertising and paperwork on 66
  217. Interior Paint to Use?
  218. Please offer your condolences to one of our Moderators
  219. Advice from experienced painters needed: Is an HVLP gun worth the expense?
  220. Is it just me? (Re: NCRS.org)
  221. 91 carpeting
  222. Do you own 1966 Vin#15387 or know it's whereabouts?...Please look
  223. Insulation Installation - Use Glue?
  224. Dash Vent Piece Missing?????
  225. '71 BB Valve Cover Sticker
  226. Opinions?
  227. Engine bay color questions:
  228. 74 seat belts on a convertible
  229. Correct Transmission for 65 327 300hp Muncie
  230. Paint colors for 67 engine bay
  231. 67 big bloch engine ID What is it?
  232. EGR Valve - repair, restore, replace? How about some ideas
  233. 69 Map-pocket
  234. '68 back up lamps
  235. Texas Legislative Alert
  236. C3 Speedo Cable lube
  237. Best time of year for paint?
  238. 1966 Steel Wheels
  239. '64 spare tire tub, painted or not?
  240. 68 with air conditioning
  241. Need help identifying this hood, is it correct for a 69
  242. Important Technical Information :D
  243. Uni-points vs. seperate condensor
  244. Vintage License Plates
  245. Black oxide/tin-zinc plating from Eastwood
  246. Looking for Vette Registries
  247. 73-up altenators will fit 68-72 models?
  248. I thin what this section needs is...........
  249. Factory accessory bracket bolts?
  250. Theft Alarm Wiring
