- L71 Shroud
- 1968 convertible interior pillar post
- Tom
- Other Forums Devoted to Restoration??
- Correct Alternator Clocking & Wire Connections
- Brandywine Red
- Birthday book
- c3 Vaccuum Manifolds
- 1969 big block TI ignition, weak spark, won't start
- Is it Possible to Still Find a Good L-71 Car?
- want to make my master cylinder on my 68 look new, what should i use?
- Please Say No to Original Block Resurfacing!
- web site of all corvette specs
- is quanta chevy orange the closet color wise for my 68 bb? don't want it too red
- corvette debut
- Original 70 Rocker Cover Resto
- test only
- 69 corvette radio
- 70 "Black Fiberglass"
- Transmission Code Help
- GM part numbers?
- GM Part numbers
- Seasons Greetings To FCR!
- 69 Emissions label 435hp car
- 71 hood underside color?
- Correct fuses
- C3 EggCrate Grill and vent Resto - Who/Where/How?
- Vin and code stamp help
- Engine Code Help
- first post! questions about under the hood paints like block paint etc.
- What is the exact cylinder bore and/or exact displacement of Gen I SBCs?
- any one ever heard of a 69 Tank Sticker being sealed under plastic from factory?
- Need '68 Coupe parts
- 67-69 Tri-Power rebuild info needed
- General Resto: Reproduction VIN plates?
- Gel Coat - What is it?
- 70 Door Label
- Casting letters on Original KO Wheel Spinners?
- the vin # and my trans match and I see p8r25 but I don't see the AB or C suffix?
- Found correct carb for my 68, but need help to see if date codes match up please!
- Door panels that "fit like rubber boots on a chicken".....
- should i rechrome my valve covers or buy new ones from paragon?
- Need some parts? Check THIS out!
- paint or powder coating frame??
- anyone here ever ship a complete body?
- looking for clean 69-72 frame assembly !!
- 56-67 valve covers
- 327/350 crank
- Does Anyone Have Picture Of A Holley?
- New Interior Advice - Which Vendor
- Restoring license plates - best way?
- C3 Rally wheel center derby cap
- Bolts
- Help! 1970 Power Steering Question
- Goodyear Eagle GT 255/60/15
- Correct color red for 55 Hub Caps
- What Paint to Use?
- F/S USA - 1 Lisence Plate
- '68 Hardtop Question
- Good Chrome Shop?
- Anybody Coming To The Run For The Ribbons?
- 70-72 Front Grill Paint Formula
- Amateur Smog resto pics
- Smog system re-install question
- Radio Instruction Booklet
- A few pictures from the Queen City NCRS Regional
- 73 wiper compartment refirbishment
- Smog pump fan
- C3 Wiper Transmission Mount
- ready to paint the heads, advice on correct paint etc
- is there a way to tell if my convertible top is original? i think is but not sure
- Need some advice from those who ahve been there
- Do you have Justin's e-mail
- "Corvettes [were crap] before the C5?!?!?
- Real Cadmium Plating!
- i need head specs for a 68 l36 had a valve job done and he didn't stick to specs
- 1967 seat belt question - JOHNZ ?
- engine suffix code label/ headlights
- Need help with codes
- Carb numbers advice?
- Pictures From Saturday At Carlisle
- Identify engine block by cast number,year,or CID..
- Chevy engine code locations
- Side Exhaust Rocker Moulding Detailing
- AM/FM radio
- How do I store my original wheels and tires?
- Queen City Chapter (Cincinnati) regional meet
- Master Cylinder Casting Numbers
- Starter #'s
- JohnZ, take a look at this picture please I could use your help!
- bought a sand blaster etc. got ready to media blast the intake..then was told not to?
- 71 s/b sensors
- Does anyone know where I can buy some very thin light oak leather for my C5?
- Any ZL-1 experts?
- Correct "clocking" of alternator
- park city ncrs
- Part 3942775 ?
- NCRS judging 90 and 91 now
- Real silly judging question
- ok guys where is the best place to buy correct bolts for the engine? head bolts etc..
- bolt kit for body on 62 needed
- Do I have your engine? Do you have mine?
- 70-72 Air Vent placement
- 1990-1991 Judging
- 454 14015445
- 1978 L48 Engine Color
- 1970 Bracket Colors
- '64 4sp Shifter Issue - Requesting Opinions
- 70 Wiper bay sealer and finishes
- 69 AIM help needed
- First Year For a 15 x 8 wheel
- What is the Correct Distributor Cap for a 62 Dual Point
- Black PF 35 Oil Filters
- air cleaner element
- 1972 intake set up
- '63-'67 Alternator Fan Date Codes
- any experts on the Woodward cruise out there please
- Frame Stamping
- Carb Date
- 1965 New Leather Seat Covers Question
- need advice on shop manuals and restoration books, ready to pull the engine on the 6
- 1975 Control Arm Shaft finish?
- what are the benefits of doing a factory correct resto?
- Color of 69 rocker panels
- Some Pictures From The May 22nd Atlantic City Show
- Pics of mint 89 wheels?
- Corvette penlight
- spare for a 73
- Rear end blue prints wanted.
- '72 Front stablizer bar color-Gray or Black?
- CORRECT carb for my 73
- trim rings with 2 valve stem holes
- I need 64 convertible birdcage parts
- C4 intake parts: do stock parts changes affect NCRS judging?
- Who sells repro rear bumpers for 1960 vette
- Best Carpeting? Al Knock or ACC?
- 87 valve stem caps metal or plastic?
- Correct 1981 Oil filter and battery?
- help with carb identification
- WTB: Battery caps for a 73 L-82
- 87 upper interior door trim question
- Whats the Location of rear letters
- Overspray on intake ...69 big block
- Anybody Doing The Atlantic City Show On May 22nd?
- 1996 Coupe Weatherstrips
- 69 Rallye Wheel Trim Rings
- point me in the best direction for NOS or VERY original reproduction valve covers
- 1969 Door glass sticker
- Bright red and torch red
- some 67 BB parts for sale
- Any sites to "share" VIN/ engine info?
- Touch up paint
- 1970 GM Door Label
- Can anyone help ID these part numbers?
- Z51
- 1969 car jack
- Ralley wheel paint?
- 1973 BB engine re-stamped?
- Paint selection ??????????????
- a.i.r. tube I.D. ?
- Prototype Corvette?!?!
- need some help with some engine numbers
- 1976 Original Spare, never used - $ value?
- 65-66 Black Seat Belt Buckles
- time for paint
- 75 350 water pump question
- Harmonic Balancer Rebuilding/Replacement Suggetion
- spare tire cover
- Tri power lid, correct or incorrect?
- Baton Rouge Area Paint Shop question
- PS and A/C brackets
- 327 Air Cleaner Base Differences - '67 vs '68?
- A.I.R. smog tube question
- 71 Altenator codes
- Need VIN lookup site-1969 Corvette Stingray
- Trim and Molding book ??
- correct wheels on a 71
- 69 L88 heads what are they worth??
- NCRS fit up standands - Interiors
- 69 bb or sb car need help
- 63-67 Power Windows Operation
- Help! Can a NCRS person check a trim code?
- [C4] Gatorbacks, Part II
- 70 Brake Booster Finish and Misc Finish
- Trying to identify decal on valve cover!
- stripping techniques for a 68?
- Found RPO Listings Website
- 70 protecto-plate
- 1969 Corvette seat belt buckles: chrome vs plastic ?
- Question for NCRS people.....
- help on wood steering wheel and knock off rims
- Seat Foam Question???
- how to lower rear 63-67 vette
- What do I have?
- Rear bumper bolts
- 69 427-400 camshaft
- 69 3x2 Carb question
- 427 Engine weight HELP!!!
- 327 intake manifold question
- Larry's BBQ
- rivet setting tools
- Passenger side mirror
- Spark Plugs
- Indianapolis paint shop question
- Protect-O-Plate Question
- top repair ?
- NCRS Orlando
- A.I.R system for 1966
- Air pump blocked off - what will happen?
- Relative Corvette Pricing Over The Years...
- 1970 fender emblems
- C3 convertible decklid - underside finish
- F-41 shock absorber date
- Pics of midyear coupe 2-color interiors
- C-3 "Stingray" emblem differences?
- Bloomington "Survivor" questions
- engine identification help
- sealed beam headlights
- 72 Stock Rear Spring
- Midyear sidepipe question?
- C2 paint sequence question
- Question about VetteHound
- 67 Hood? Repo vs Original/NOS
- 1970 Questions
- Question about 75 floor
- 69 Emission decal
- Do '54 wheels need nubs for wheel covers?
- Steering Column Finish
- midyear overspray removal
- Interior rear view mirror '67
- 73 Big Block Water Pump Pulley ? Please
- C4 Light Bulb Socket Grease
- 1967 front license plate bracket - survivor car
- NCRS C3 Interior Judge????
- NCRS Question
- Paragon part numbers
- What are casting numbers for '66 327/350HP exhaust manifolds
- Head-on collision - not for the faint of heart
- '67 427/400 items - how can you tell if original...
- C-4 Turbine wheel variances.
- GF-432 fuel filter ... interesting
- Texas Regional
- Looking for a posse!
- Exhaust Manifold Clean Up
- Casting date readout ?
- engine decoding , pls. Urgent.
- engine decoding, pls.
