View Full Version : Factory Correct Resto
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15
  1. 68 steering wheel colour and appearance
  2. 71 ZR1 pics
  3. Landmark Education
  4. 70 Ignition Shielding
  5. 62 car SN 9943 Would a D172 block be correct
  6. Seat Frames Or Seats
  7. 71 of 1?
  8. White Plastic Restoration
  9. How Were The Bodies Painted on the Assembly Line????
  10. 1991 NCRS Judging Guide
  11. 68 spare key envelope
  12. 70 Headlight Asssembly and Seats
  13. C2 Mechanic near Ventura CA
  14. N.C.R.S. Award's!! Added value?
  15. '61 corvette- cracks in steering wheel
  16. 1991 emissions decal
  17. 63 vette
  18. Label Identification
  19. Wheel Decode
  20. is a 67 steering wheel = as a 68 ?
  21. Platinum Television Group
  22. 70 Seat Hardware finishes
  23. Rag Joint Restoration
  24. Tell me about these tranny numbers (4 speed)
  25. Bezels on 63 Gauge Cluster
  26. 1969 Fiber optics help
  27. 1970 rearend code
  28. Build Sheet for a 1969 BB
  29. Do all '63 to '67 Coupes have the same windshield molding?
  30. Pics of stock 69BB firewall?
  31. Congrats to Viet630 on Top Flight!
  32. Water Pump
  33. How big of a deduct?
  34. 70 PW Breaker Hardware
  35. '69 seats question
  36. '68 427 fan clutch
  37. 68 A.I.R diverter valve assembly value?
  38. 63 Radio?
  39. 1970 door panels
  40. 62 Vette valve covers
  41. [PA] Anybody Going To The Run For The Ribbons In Jenkintown?
  42. Restoration / clean-up solvents
  43. Tripower carb nuts
  44. 1961 body off restoration
  45. Need help to identify 65-66 seats
  46. FS: Older 'NCRS Driveline' issues
  47. 68 Idle solenoid Bracket
  48. 60 Vette Vin Tag.
  49. NCRS/Bloomington Gold
  50. Numbers Matching Expert Needed Pics
  51. 68 engine block cast date ?
  52. Correct tranny ?
  53. '69 dash gauge lights
  54. Chrome Plating
  55. correct finish on L98 valve covers (and 92 LT1's) - ???
  56. correct sun visor for 1970?
  57. which one piece alternator fan/pulley correct for 65
  58. Originality: To be, or not to be!
  59. [Late C3s] Did C3s Ever Get A Service Parts Identification Label?
  60. C3 Right Side Mirror
  61. Alternator fan/pulley finish
  62. 60 vette front end
  63. Correct resto for 67 AC system. Can R-12 still be found for correct freon fill?
  64. Side mirror movement
  65. which of the 2 alternators date wise is best for mine, pirkles has them
  66. ? on # on heads
  67. 69 Horn Relay
  68. [Old Cars] Pictures From The Labor Day Ludwig's Corner Show
  69. #'s Matching Experts - Here's one for you.
  70. Who's Going To The New England Regionals?
  71. Professional Museum Build Sheet Conservator.
  72. Recovering Sunvisors on a 1996- Who?
  73. Choke setting....
  74. pics of differential what gear ratio do I have?
  75. engine ready for paint, couple questions
  76. Chrome middle vents bezel
  77. Marina, Lemans or Mulsanne Blue 0n a 1969
  78. few questions on this radio I bought (pics)
  79. finally got a radio for my 68 at carisle, question though
  80. master cylinder ? before I go buy one at carisle
  81. 70 Vert. Hardware Questions
  82. Mirror glass removal question
  83. vacuum lines
  84. door sill plates....
  85. I know someone has to sell flash chrome igintion shielding
  86. Perfect Body Wanted
  87. Wiper Override switch hardware
  88. paragon has flash chrome valve covers & air lids,do they have flash igition shielding
  89. Restore aluminum valve covers
  90. I think its a 60 vet?
  91. Chevrolet Documentation Campaign
  92. [Memories?] Did Anyone In FCR Attend The 1988 NCRS National?
  93. Question for 96 CE experts
  94. Used Part Vendors?
  95. Wrong paint? Need answers!
  96. muncie prefix
  97. Sidebar On The Corvette Generations
  98. Long term maintenance question
  99. should a original 68 Master cylinder have made in usa on it?
  100. when did the 68's receive the 2nd style valve covers?
  101. Engine Compartment Decals
  102. Finishing a 365hp- Need Valve Spring Advice
  103. Looking for NCRS or ? to check out a car in Alberta,Canada
  104. 66 transmission in a 65. How does this affect value or desirability?
  105. 68 Exhaust Help
  106. Any C4 restoration projects? (LOL)
  107. think I found a correct alternator need to make sure the date will work etc... please
  108. Correct Spark Plug Wires for a 64?
  109. Under Car Mirrors
  110. 1970 LT Convertible Value
  111. tach/speedo color
  112. 1962 Steering Wheel Restoration
  113. Help ID NOS TI Distributor & Amplifier
  114. 69 L-89 heads 842/074?
  115. CE replacement engines
  116. is this TI?
  117. how does say a 4M** datd alternator say a Dec. build, M would be a 13th month
  118. john z need your help
  119. Black 69 corvettes
  120. Fasteners
  121. Are these correct
  122. '71 LS-5 fan
  123. does paragon sell a flash chrome ignition shield?
  124. Fiber tape on headlight vacuum lines
  125. 1968 Tail light housing question.
  126. How do I tell If this is a real '66 396/425hp
  127. emission decal
  128. which air cleaner cover/lid is the right one off paragon for my 68?
  129. 56-57 engine codes
  130. 1969 LT-1 Corvette?
  131. A Gathering Of Old Corvettes Pictures
  132. 71 Rally Wheels
  133. [C4] Targa Top Repair Vendors?
  134. How did GM balance 69 rotors?
  135. Gas Tank Document Resto
  136. Bloomington Gold
  137. About to buy valve covers for my 68 some expert advice needed
  138. Top notch painter in Eastern PA?
  139. Need some help with the 1970 Registry Please
  140. decode an alt.
  141. "Aged restoration documents"
  142. 70 Wire Harness and Battery Cables
  143. Fuel pump Rebuild
  144. 71 Coupe Show or NCRS...Value
  145. AC fuel pump 40310?
  146. 71 454 starter...what is the correct casting number on the starter?
  147. 1958 Corvette Interior Color
  148. 60 kick panel paint question
  149. 79 under body resto help
  150. 1971 454 BB Rochester - Dual or Single Air Snorkel?
  151. Romeo Engineering
  152. 79 Spare Tire Carrier Resto
  153. Interior restoration supplies
  154. Right Hand Windshield washer brass tube.
  155. Seat cover installation
  156. Can any one id these genuine GM numbers?
  157. bright dip anodizing
  158. frame stencil paint & shim markings
  159. 1969 Interior restoration
  160. Tires for a 78
  161. Need supplier of complete Tilt / Tele column for 1971 Saddle
  162. Whats the difference between Truck heads and Vette Heads
  163. AUBURN (IN) NCRS Regional May 17th
  164. Whats the trick?
  165. Corvette jack expert needed
  166. 1972 Protect-O-Plate
  167. BF Goodrich Redline Radials
  168. 68 7" inch wheel judging question
  169. partial VIN numbers
  170. Front clip suggestions needed
  171. Question on '72 LS5
  172. 79 rocker covers-chrome or painted?
  173. Feedback on Ron's Corvette's, Fitchburg, MA
  174. Where did you lose points?
  175. Will vinyl dye cover discoloration?
  176. 70 Hood Hinges and Support
  177. 1973 Paint Code Production Numbers----WHERE Can I Find Them????
  178. Datawiz Quiz tonight around 9:00 PM EST
  179. Were 69 convertibles available with hard top only? No soft top?
  180. VIN tag replacement . . .?
  181. Chrome plating
  182. Dealer tags
  183. ok who sells an exact master cylinder cap for a 68??
  184. carb date question
  185. Half shafts
  186. body line question...
  187. NOS 65 front springs value
  188. clutch cross shaft identification help
  189. How to paint tail light louver's??
  190. Restoring a 67-68 steering wheel?
  191. WTF Ebay item?
  192. replacing my fuel pump, ncrs guys which way should I go...
  193. got engine paint finally at that stage of my restore, tips anyone?
  194. RFI Shielding
  195. Late 69 coupe paint questions
  196. suggestion on what i should use to paint these please
  197. WTK: 69 BB Distributor color
  198. Question on grilles behind rear window
  199. Vac Hoses
  200. Identify 1969 seat belt codes
  201. Matching numbers?
  202. 1967 SB inspection labels pictures
  203. Body Off Help
  204. TFP - typical factory production
  205. 66 427/390 PCV hose brackets painted?
  206. Date code on Q-Jet
  207. when exactly was my '72 built?
  208. missing build sheet..how to document #s
  209. Paint Colors - NCRS?
  210. Cadmium Plating - NCRS ?
  211. Silk Screen
  212. Rally wheel color question
  213. NCRS, Jeff Cook, and free speech
  214. 1972 Rear compartment rivets & hinges.
  215. is there anything more I can do to my exhaust manifolds? not please, pics inside
  216. A-Arm shaft finish
  217. date codes, rally wheel? 69 to 79
  218. Need part # for 1969 quarter trim panels
  219. Newbie here needing help!
  220. john z your prob. the man to ask on this one
  221. Paint Help
  222. Exact difference between 65 & 66 BB Hood?
  223. Correct radiator support paint.
  224. eastwood's chassis black?
  225. Stripping - Chemical / DA / Walnuts
  226. [Weird Question] Conversion From Gross To Net BHP
  227. Best Black Paint for C2 Dash
  228. Does Anybody Know How Many Cars Were Flight Judged At The Florida Regional?
  229. john deere blitz black?
  230. Distributor rebuild service?
  231. need help what date codes should i get?
  232. Need Help Restoring Engine Compartment of a 1974 Corvette...........
  233. Recommendation for tri-power setups
  234. Ignition coil 270 B-R
  235. 57 F.I. Distributor Parts
  236. Which chassis paint is NCRS correct for 68?
  237. I'm buying heads for a 435hp can use some help?
  238. I 12 7 block for C 05 Vette ?
  239. What kind of Tranny is this?
  240. Bumpers of choice for NCRS Cars
  241. ok so tell me what do guys going for ncrs status use on their exhaust manifolds
  242. Glue Type for Wiper Cavity to Firewall.
  243. Correct Paint for 69 Wiper Cavity
  244. Anyone in Virginia - ACT NOW
  245. 71 t-top trim help
  246. How to Id distributor
  247. 70 Vacuum Tank
  248. date in mirror glass what do they mean
  249. Black flex (preheater) hose
  250. '67 Black Plastic Seat Back Covers
