- PPCLI condolance website
- Help with crayon marks
- K89 Head Bolt Leak HELP PLEASE
- Master Cylinder Date Code
- plating available
- So I was thinking.....
- 1977 Rear Window W/Defogger Where can I find one?
- My high speed Internet connection is on the way!
- Restoration Update
- What's this part??
- Electrically Challenged
- 1978 antenna with CB radio
- Restoration Update (Closing in!)
- '58 Signet Red Paint Code?
- Pick me for a testimonial commercial......POR-15
- PO2 wheel covers
- PC Technical Question....
- paint formula for Milano Maroon??
- Help with 82 Collectors Edition
- Big block engines?
- Help on parts pricing
- Zinc Dichromate Plating
- Just how many?
- Just showin' off here Boss.....just showin' off.
- Bloomington
- This is a test Mac....
- Help with transportation
- sunfire yellow in a spray can
- tempiture sending unit replacement
- 1966 clutch & brake pedal bushing replacement
- U-Joints won't fit halfshaft flange
- How much does it cost to get a car painted?
- A new rule for consideration....
- Front spindle gasket - what does this thing do?
- 1968 427/390hp (L-36) water pump for sale
- Speedometer question
- The countdown is on.......36 hours........35 hours.......34 hours
- OMG.....this is waaaaaaay too much fun
- Garage "Raise The Roof" Project Done !
- '67 Radiator Support Shims
- reproduction window sticker
- C3 window seal replacement
- Where can I find original parts? I really want a radio
- 1967 427 radiator replacement
- Filter, tach
- Hey topless68
- photo point questions
- Flywheel Resurfacing...
- Steering Wheel Installation
- help with suppliers please
- Hello all
- Restoration Update (doors)
- Hey Dudes, greetings from.....
- I got it figured out
- Paging 67Heaven and PT......
- Midyear Jack Resto
- Question - re: battery frame on '66
- 77 L48 valve covers
- Topless was right...way too fast here ;)...but to help things along...
- T-10 I.D. Help Please
- This is crazy!
- Motor almost done, supplemental paint question and pics inside
- You guys are going way too fast for me....
- Birthday Book and Trim Tag
- LoJack anti-theft question...
- A/C Heater Console Light
- Garage Project Update. Framing Done.
- Folding top restoration question????
- Any Idea where to get a horn contact?
- Why would GM still make this part? (not that i am complaining)
- Crank Balancer I.D.
- Primer...
- CZU 454 Engine question
- Who sell parts for 1954 vette?????
- Are Yawl Watching Ashlely Banfield on MSNBC?
- 1972 then, 2002 now....
- What RPM?
- ok guys need help on radio!!
- Garage Project Begins Today
- birthday calculator
- T.I. Restoration
- WWIII
- Cleaning up the M-21 Muncie....
- Need Help With outer bumper extensions for 71
- Check out my cool racing decals!
- I finally have paint!!!
- '66-'67 Headrest Seat Option...
- Need help on emblem placement
- Frederick, Maryland Automotive Flea Market Friday and Saturday
- Starting a class-action lawsuit...
- How can I id my engine?
- Congrats, Chuck Gongloff
- Center grille: 73-74 vs 76-77
- Need help with reverse VIN search!
- Knock Off Hammer Repro vs Original
- Power Brake Booster Check Valve
- and ever more four post lift stuff.......
- Restoration Update (wetsand and buff)
- Starting The 4 Post Lift Project
- Conversation with my '67's original owner....
- Midyear hood hinges---Black or zink
- Windshield frame alignment
- Need Help With Water Pump Pulley ID
- 67 Owners
- RED LINE TIRE QUESTION....
- Tack-welded nuts for rear sway bar mount
- Can I use 69-72 door weather strips on a 68 roadster ?
- I can't understand why they keep sending me this junkmail...
- At the risk of making one of our guys blush.....
- Favor from Patrick Tighe
- OK...follow-up to Patrick's bad joke of the day...here's a real coon-butt joke....
- LS1 wiring diagram
- Friday Joke...
- Restoration Website Established
- OUR CORVETTE HERITAGE #31: What is unique about your Corvette's era?
- Close the Door!
- Doesn't it make you wanna pull off that tarp?
- Cast Blast v. Eastwood's Detail Gray.....
- Do your homework gentlemen!!!!!
- Is it or is it not an "early car"
- soft top experts
- Sand Blasting
- Had to share this with you guys...
- First day of Spring my butt....
- Calling Chuck Gongloff
- 1968 BB A.I.R. SYSTEM FOR SALE
- Virus email
- spring tags for 1974
- 1964 Roadtser
- 1969 Master Cylinder
- Told my friend that an answer was just Factory Correct Resto away...
- Our 69 Made The Cover Of Tom Falconer's New Book
- Lacquer vs. Base coat clear coat
- Can somebody help this guy out with Master Cylinder Rebuild info?
- Yet another reason to dislike the 'Frenchies' up North.......
- Resto guys - Painted and non-painted parts
- 63 FI ???
- So this is what they really think!
- Hey Mac
- Seat attachment
- New '67 Sermersheim's Front End Pictures...
- Restoration Update (Body back on!)
- Dueling Vettes?
- 1973 pics needed
- Alternator #s
- In the garage again.....
- Finally have a rolling chassis...
- Okay you guys.....keep my seat warm while I'm gone....
- Not a day goes by that I don't...
- 60 powerglide wire clip
- Installing the heater box on firewall pics...
- Thinking about a lift for your garage?
- I'm glad I gave this up...
- Vapor Canister Hose Routing 71 350
- Sir Chuckalotte
- The '67 front end is coming Monday...
- The UPS Man cometh...
- 68 L88 T/I distributor with Brown cap an tach. drive. #1111295
- Congrats, 67Heaven
- tie rod configuration question
- followup to 4-post lift questions - pics of install
- They're here!!! The Kustom Headers have landed!!! Pics inside
- Postman brought it today.....
- New convertible top
- 1990 tach problem
- Never thought I'd live long enough.....
- sidepipe cover resto info (3x2-427 and others)
- Trim Shop Recommendation
- Bob Barker gets an eyefull....
- 68 engine/tach question
- Restoration Update (new pics)
- NCRS C2 Technical Judging School Sunday March 16 - Maryland
- 69 Early Late build ????
- Interior Vendor's new website.....
- Check out this Redneck Pacifier.....
- 10.4" clutch on a 14" flywheel???
- Tractor Trailer freight delivery for Corvette part....
- Well, I Reckon I'll Be Lookin For...
- The Texas Trooper.....Mac, you're gonna like this.
- Rear Suspension Questions
- "The Restoration Blues"...
- Seat Feet Color?
- Midyear windshield bonding strip installation pic..
- 67Heaven, they're onto us!
- CD Burner Question......
- Replace tie rod sleeves or not?
- Preventing Rearend Noise
- Question re: steering relay rod for '68.....
- Check out what I got in the mail today....
- Oh no! Not a hockey joke!!
- Congrats Juliet!
- Correct Oil Fill Cap?
- Hey Ronnie, what's the deal on the '62 parts...
- Has anyone ever used Eastwood's........
- Carter AFB ???
- A/C Compressor Label
- Why are rear bumper mounts (C2) not symmetric?
- buying another vette, need help restoring it...
- 1978 L82----4 bolt???2 bolt???
- lost correct engine
- Do I have 1967 Distributor?
- Confusion on part numbers
- Dam Canadian Geese.....
- headlight washer valve?
- Quadrajet Overhaul
- 58 Reveal moulding??
- GM NOS 1967 Corvette Hood Surround
- Some guys have it all.
- Seat belt restoration
- Spot painting the frame. Can I??? How???
- This part is going to be tough to restore....
- Need photos for correct plug wire routing for 1990 L98. Help?
- The FBI stopped by this morning....
- Steering Box and Coupler installation pic...
- The final answer is......
- Idler Arms and Vacuum T's
- Hey Ron, and Jerry
- Missed Opportunities 101.....
- Birdcage notches on original Midyear sidepipe cars....
- Tach problems continued
- Check out this thread on GM Restoration Parts - interesting....but you knew that!
- Hey topless 68
- Who's got the link to the NCRS Birthday calculator?
- 78 Pace Car Leaf Spring Question
- '66 427 400 to 390 transition
- During this brief intermission, let me show you...
- 1969 driveshaft
- Restoration Update (body pics)
- Power window and Intermittent tach question????
- New Spark Plug Wires
- Front Suspension Rebuild Is Finished....Pic
- And the Gold Medal for Men's Hockey goes to...
- Hey Ron!
- My Rag Joint is ragged...
- Corvette Internet Radio Show
- test
- Need Engine Installation Advice...
- drive train question
- Intake Manifold/Cylinder Head Paint From 63-64 NCRS Manual
- Pin striping, how do you get that stuff off????
- Update on my 65 resto
- 58 door post question?????
- Tough decision on factory headers and side exhaust (67HEAVEN you'll like this one)
- Anyone know what this stuff is?
- Rear End questions.....[HELP]
- '66 Factory Picture of engine drop...
- Getting the Interior Vinyl to Match
- Maryland Home Spring Compressor Installation Pics...
