- Pro Star Performance engines
- Keep that Modded engine in your C5 Vette running cooler!
- Ported Intake Manifolds and Throttle Bodies in stock!
- Ported FAST 102's from Peak Speed Shop!
- Porting?: How much power am I leaving on the table?
- 2001 LS6 diff\\LS!
- dgreeing a cam (SBC)
- 427 sbc
- Small vs Big Block?
- G Force Chip
- restricted circle track motor
- we now carry HALLTECH
- LS3 Suspension Upgrade
- Question about Manley pistons.
- Exhaust "Snort"
- 383 Stroker - busted exhaust valve spring
- •► ► MERRY CHRISTMAS & HAPPY HOLIDAYS from CHUCK CoW & CORVETTES of WESTCHESTER ◄ ◄•
- Question pertaining to early 70s LT1 motor
- Factory LS6 cam vs......
- My 62 needs help
- You wont want to miss this special off season holiday price on a Cool Product!
- Vette Valve Covers
- Custom LS engine maker?
- ★★★★ ► CHUCK CoW's HOLIDAY AutoCal TUNING SAVES YOU CASH!!! ◄ ★★★★
- Legality of superchargers?
- 62 fi
- Rebuild
- 10% Off Stainless Works Holiday Sale
- Can You Make This Bracket?
- ARAO Engineering from Chatsworth CA., good or bad ?
- FS: hydraulic cam for SB Chevy
- Lingenfelter Performance Black Friday Specials 2011 (live!)
- Bill Mitchell mountain motors
- L82
- Fuel Injected Big Block
- Change rings on one cylinder with motor in car?
- Spark Plugs
- Ignition Wire Help - 2010 C6 GS
- New LS3 in to a C2
- Searching for information on Dog Box Transmissions
- New supporting vendor!!
- spending lots of $$$ on mods that will never be used
- 427 w/ O RINGED DECK
- Want a Free Tick Performance Shirt? Guess the RWHP of our latest ProCharger Install!
- 502 Build
- manual
- ZZ4 Oil fill location??
- Shafiroff Engine more Compression ???
- Took Motor to the Machine Shop today...
- do you know a way to limit a car to 75 or 80 mph?
- Electronic FI in a 1965
- Dyno testing machined stock heads versus Dart Iron Eagles
- Ballpark cost to prep small block for ~550hp (& SF Bay shop rec))
- Chevy's Small Block to Hit the 100 Million Mark!
- •► ► CoW BOOSTER - THE MOST AMAZING C6 PRODUCT EVER OFFERED - GUARANTEED! ◄ ◄•
- 496 vortecpro
- Prodigy customs
- sbc 4.125 stroke with small journal 5.85 ??
- MSD distributor
- Piston Ring Fit Question
- Cylinder Head Help
- Nitrous for Dummies
- Would this work????????????
- Anybody have a MP90 or 112 on a 350??
- LSX and powerglide ?
- The Vette Doctors presents their Fathers Day Supercharger special of $5,595!!!!!!!
- Trade NC Mountain land for....
- Anyone in Fresno know Hedges Speed Shop?
- Cam specs - what should I expect
- 1976 engine help needed
- 502 Help - Water in Oil Filter
- Custom Wide Band Street tune - Give us a call!
- engine/tranny choice for 72??
- Shift Light in a C-1?
- Swap pistons/rings from bottom?
- Need a single wire temp sensor for LS1
- BB oil pan question
- Finished LT5 install in 99 FRC
- SUPER HUGE garage sale cleanout- tons of GOOD stuff- OEM and RACE
- Tune + Honker CAI + 160 stat
- Wanting to install cam in a ZZ4
- Engine final assembly, roller rocker issue.
- service ASR
- Coolant bypass on Ramjet 350
- BB intake gaskets
- 63' 327 Advice Needed. Compression~ Cam~ PCV~
- 04 Vette all stock, Looking for Stroker
- New head/cam/efi combo 383. Hp/Tq?
- Keeping it original
- Build a Chevy 383 engine for racing?
- IMPORTANT LS Gerotor Oil Pump Data
- Carb question
- •► ► CHUCK CoW TUNING @ VARARAM in TEXAS - MARCH 24-27 - SIGN UP NOW !!! ◄ ◄•
- engine pull soon.. (2 questions)
- Programming question
- Rearend Gear ratio change
- building stock bottom end??????
- Shops in NC
- Should i polish the beams and peen my LT1 powder metal rods?
- 406 Question?
- Need help to choose what is the best LS power plant to fit the need
- CTS-V LS2 Alternator Relocation
- •► ► EDELBROCK E-FORCE SPECIAL - ORDER TODAY! - EDELBROCK prices GO UP @ 4PM◄◄•
- 383 stroker rod lenght, which is the best???
- Has anyone used Flowmaster HP-2 mufflers?
- Classic Chevrolet & Bumberas Performance Nascar Racing Team
- need valve covers i can mod for AFR227 - C4
- Installing a L98 engine in a 1975 C3
- Old school mickey thompson headers
- Any KInsler/Hilborn/Inglese EFI experiences ?
- Richmond 5spd trans swap
- compression test results?
- 5.3L 706 heads on a LS1 make 11:1 compression?
- How much can you mill 1999 ls1 heads?
- Best set up for LS3
- different heads on my L-48
- •► ► CHUCK CoW's HOLIDAY AutoCal TUNING SAVES YOU CASH!!! ◄ ◄•
- Idler Arm Remove
- Super Ram dimensions/blueprint
- NCM LT4 engine pics help pls...
- Piston CC help
- bbc heads for 3969974 piston
- Possible reasons for blowby
- Dart Iron Eagle Small Block Build
- Very rough running/no power, vacuum pump problem?
- Rhs ls aluminum race block - $4200
- Fast precision flow fuel injectors - discounted!!!
- SALE!!!: FAST 102mm Manifold - Free Shipping
- shop to finish a ls1 conversion in a C3
- Stainless Ribbed Radiator Hoses
- Help needed with lower dip stick tube
- Gforce performance chip
- For Sale Sun 450 Diag. Machine
- 214 214 114 lsa 2010 GS w/headers?
- Aviaid 2 stage scavenge pump for sale
- •► ► AUTOCAL E-MAIL TUNE TOOL @ Corvettes of Westchester - ON SALE NOW! ◄ ◄•
- Rebuild Help
- PICS: Heavily Modified LS2’s look to Billet Custom Products.
- lightly build ls7 or supercharged ls376?
- Building an LSX... Need help
- •► ► CHUCK CoW WANTS TO TUNE @ EUREKA SPRINGS CORVETTE SHOW ◄ ◄•
- •► ► EDELBROCK E-FORCE -IN STOCK for immediate install @ Corvettes of Westchester◄ ◄•
- C2 Master Cylinder Clearance Issues W/BBC
- 580 inch engine from MTI Racing, Marietta, GA
- small journal stroker
- Where To Buy??
- Looking for comments or suggestions on this lift?
- cam suggestions - 7 litre LS2
- 1000 hp LSX motor on natural gas?
- 400sbc swap questions
- •► ► EDELBROCK E-FORCE - on display @ CARLISLE ◄ ◄•
- bbc oil pan studs
- •► ► THE OFFICIAL TUNER OF 2010 CORVETTES @ CARLISLE is CORVETTES OF WESTCHESTER ◄ ◄•
- Conversion
- no reluctor hub
- Budget 350 Build? 70 Camaro
- -*-* St Jude Auction #49 PAC Racing HP Ovate Beehive Springs, .650 Lift -*-*-
- decoding front pad
- Reference Books
- copper or MLS head gaskets?
- Need new alternator help.....which one?
- FS:Ultradyne road race camshaft SB 23* (billet roller)
- Bolt pattern?
- building up a '67 327
- zr1 mods
- C6 - Yella Terra Ultra Lite installation
- Need help on New Cam Selection
- Pacaloy valve springs/ Morell Roller Hydraulics
- 180cc or 200cc Dart heads for a 327?
- valve spring 1.55" + on engine spring change tool
- LS3/L99 CNC Cylinder Head Porting Video INSIDE!!
- race engine just wanted to know
- PLEASE SUGGEST CAM OPTIONS!!!! thanks
- LS1 out of chevy truck. Would like 350-400whp
- Engine and tranny question
- 402 advice
- Looking for 1st time- Need engine/tranny combo (wreck pull-out)
- Holley power valve---- yea or nay?
- Quality Motorsports 25% off Labor Special!!!
- Need help finding a retainer
- Mystery Engine Problem....Hoping for help (LONG)
- Broken Valve Springs Mystery
- GM 6.0L 802hp Supercharged (cast iron block)
- FIRST PICS PRC LS-3 Aftermarket Casting Cylinder Heads Sneak Peak INSIDE!!
- New to forum and trying to get some info?
- 350 sbc build
- Temp sensor issue for LS1 transplant
- My heads/Cam... ;)
- Vette motor,12 feet long,Cedar block!
- F/S 6-71 BDS blower
- Super 421 street engine
- Valvetrain with aftermarket heads.
- New Member needs help!!!!
- Transplanting used cam into different block?
- Best choice in gaskets?? rear seal upgrade
- lifters
- hyd roller failure in gm race block
- Rockercover upgrade
- What work CAN'T be done on Jack Stands??
- Any problem using steel shim head gaskets...
- Roller cam and the Thrust washer
- ZZ4 run-on...
- 3/8 fuel line limitations
- Stuck spark plug - non vette
- TSP TX-giant cam in LS2 402 sound clip....
- Casting Number / Engine Size
- ?? & more ?s
- Press Release MTI Racing Machine Shop
- SBC roller cam differences
- Need Help & Advice...I have no clue
- Why to have the valves back cut.
- supercharge vette
- How to Support the Engine?
- please help 83 crossfire and want to go carb
- cam help
- info on cam please
- cam help
- How to surface a flywheel
- How to lighten a stock cast iron Flywheel
- My new 327
- [stock '88 rebuild]need new lifters??
- HELP! What do I check first?
- Valves. How much to spend? What's the difference?
- looking for upgrades for my lt1
- How to install a Heil-Coil
- How to check piston to deck clearance
- How to Balance and hang press fit pistons
- How to CC a Combustion Chamber
- Engine machine work explained
- How to Test Valve springs
- How to check a head for warp
- How to lap a valve
- Why NOT to let your head be Belt Surfaced
- I know nothing about corvettes
- Moroso Oil Pan
- + Attack Blue High Flow O.E Replacement Filter +
- Free Car Manuals to Download Online
- What Clutch to Use
- Replacing Cam on a 502?
- LS2 (799) heads...
- L-88 ???? Help !
- camshaft for a 327 in a C2
- MSD Blaster II Coil with Pertronix Ignitor II?
- Mothballing an engine
- c3 forced induction mod.misc. concerns
- 638 Stroker ?
