View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. 496 assembly...
  2. Anybody building a 420?
  3. Too much lift? Rocker arm ratio?
  4. New G-Force 5 speed shipped today!!
  5. Edlebrock RPM intake on a stock 69 350/300hp engine
  6. Vortec intake & thermostat bypass?
  7. Ordered all my Solid Roller parts :D
  8. 1967 SBC 327 mate to a 1989 T5 Tranny ?
  9. Mike Thermos (founder of NOS) is back in the nitrous game, opened new shop
  10. Recieved my new oil pan !!!
  11. Initial Timing Help (Repost from C3 forum)
  12. value of motor? '70 LS-7 /downsides of BB swap
  13. Help, Head gasket problem.
  14. Exhaust Sucking
  15. from TPI to a carb on an 85, my experience
  16. 100,000 mile parts?
  17. Determining the redline
  18. Tach-drive Help........
  19. 580" BBC cam recommendations?
  20. Alright guys I am breaking down, backhalfing the car
  21. Ring Gap for Speedpro Plasma Moly rings
  22. head opinion needed
  23. Hamburger oilpans ?
  24. Rev Kit - Yea or Na
  25. 2004 6 speed c5 coupe, head and cam swap, whos got the best for my car??
  26. Horizontal vs Vertical Roller Locking Bar
  27. Cam Help/Advice
  28. Possible LS6 BB Build-up
  29. Question about Dampners
  30. Solid Roller
  31. To port, or not to port... that is the question
  32. flat roller tip
  33. Desicions made, update on the new motor
  34. centerforce kissup??
  35. Pontiac 400
  36. LT1 timing chain choices
  37. Has anyone used ARP Permalock rocker nuts?
  38. Dragracing IRS
  39. Gearing question
  40. Possible to buy only a rev limiter for my HEI?
  41. Optimum Quench? Help, ordering gaskets...
  42. How much difference can a couple of jet sizes make?
  43. injector size ?
  44. Piston Choices?
  45. Electronic Fuel Injection
  46. Small block Aluminum heads & Street Blower
  47. 383 head choice question
  48. Turbo Dyno Video
  49. Meziere for L98
  50. Anyone running a SCAT 9000 crank,whats the max rpm?
  51. big block build-up
  52. Roller cam in an older block.......worth it or not?
  53. Brodix vs AFR
  54. Check out the flow #'s from my friends Stage 5 Hemi heads
  55. Any clean and reliable ways of implementing a dry sump on a street car?
  56. Stock spring pressures for 86E (Iron Heads)?
  57. oil pump primer tool
  58. Casadium (sp?) coated roller lifters NO bearings!!
  59. heat barrier coating & friction reducer coatings...
  60. my friend has a stout 383 and is looking for cam suggestions ???
  61. Anyone need a valve spring tool?
  62. New wideband sensor setup
  63. Differances in oil pans between gen 4 and gen 6 motors
  64. Comp Cams.....
  65. Converting Holley 4175 to manual choke
  66. C4's & dry-sump questions...
  67. Well I didn't make the Pump Gas Drags.....:-(
  68. Engine Experts - Help Needed Please
  69. Gen 6 CNC Bowtie block, opinions ?
  70. Wideband questions on Dyno
  71. What do you think of "Noisy" gear drives?
  72. BBC 2.25" headers for C3?
  73. BBC vs forced induction GenII...
  74. 4.375 stroke in a 9.8 deck ?
  75. How much torque can a helicoil/weight take?
  76. Question on oil cooler pressure drop
  77. Exhaust Soundclips!
  78. OIL AND ANTIFREEZE...help
  79. My buddies 540 Chevelle featured in this Months Car Craft
  80. Questions on using a Gen VI 454 with a carburetor
  81. Carb Question
  82. Oil Dye?? Hazards?
  83. High-compression motors and stock starters...
  84. Twin Turbo Headers for you Muscle
  85. My friends TT SBC Camaro
  86. sbc main bearing question
  87. Ford Type "F" Trans Fluid?
  88. Ordered some heads today, a few qustions
  89. 305 Carburetors
  90. Good Lord!
  91. Shorty spark plugs for aluminum heads...
  92. Pro Topline heads and heavy nitrous, any problems ?
  93. Balancing question
  94. 63 327 250hp to 350hp swap
  95. Brrrmm... Brrrmm... Started the 406 yesterday
  96. torque specs on c5 00 corvette
  97. LT1 combustion chamber ?
  98. VE of a typical pushrod V8 engine
  99. stock late L98 piston weight
  100. LT1/Mini Ram INtake + 406, which heads should I use?
  101. Well, I'm going to try..."Hot Rod Pump Gas Drags"!
  102. mcleod street twin throw out bearing?????
  103. 383 from Vortec 5.7L, need help selecting parts
  104. 400 small block??
  105. Headers
  106. How do they do this?
  107. Anyone Try the LM1 Wideband Setup?
  108. Anyone running the Lunati Ls stroker kit? I'm worried that a 1.060 c/h is too short for reliability
  109. Carb question
  110. bronze valve guides...cross post from C4 Tech
  111. New 3 valve heads!
  112. Carbon Stuck Rings?
  113. brodix track 1 cnc ported
  114. Stock Head Info?
  115. Tall deck in a C-3, problems ?
  116. Speed-o-motive.
  117. C5 cam/lifter/rod???
  118. AFR 190 flow bench test results.
  119. LT4 Oil Control Problem - Total Seal Rings
  120. finally got the engine together!!!!!
  121. What size throttle-body for 427 SBC???
  122. Desktop Dyno & Super Ram info
  123. 383 pistons and rods for sale in C4 parts forum
  124. does a GM lightweight flywheel have chamfered holes or will I need to machine it?
  125. L-82 versus L-48 intake?
  126. Camshaft Timing - Advance/Retard Optimization
  127. Flowed my 210cc Race Ready AFR's today !
  128. Comp cams pro mag 1.6 rockers and 1.55 in springs?????
  129. Crank trigger on street vehicle?
  130. starter question for my 383
  131. Could you dbl check my main bearing clearences?
  132. Engine Analyzer please !?!
  133. What's the best damper?
  134. carb for 67 camaro need help
  135. Cam selection
  136. 808 in. Chevy Hemi
  137. Comp 220E-XR Cam
  138. TPI Question for y'all :)
  139. Interesting dyno sheet from a buddies 528 Wedge
  140. How lean is too lean for reliability in a race engine? Experience please chime in.
  141. ?'s on engine block
  142. Flow numbers AFR195 & Ported L98
  143. General Kinetics contact
  144. my new motor could somebody please offer help on carb/manifolds?
  145. 441 heads, need opinions.
  146. Carb Guys, Have you had this problem? Accelerating?
  147. New Engine Startup...
  148. Noticed SOMETHING ELSE about AFR 180s v 195s
  149. clearance issues revisited (I swear this will be the last time for me.
  150. oil level indicator kit?
  151. Comp cams rollercam..
  152. Head Intake Port Q's...
  153. lifter valley vents
  154. Is the spark management system of an LS1 motor compatible with a mechanical roller cam?
  155. Carb(s) reccomendation for big motor
  156. Rod Bolts
  157. leakdown test..
  158. 350 cam/intake/carb combo
  159. REV Kit Experiences?
  160. Question about Lobe Center Angle
  161. Just noticed something about AFR 180s vs 195s
  162. SBC manifold cooling lines?
  163. Comp Pro Magnum Rockers ?
  164. How can I get my 355 to scream up to 7000+rpm?
  165. Need help building a motor
  166. ? Max Overbore and Stroke for L98 ?
  167. need your opinion on my d.c.r.
  168. The HOT ROD Pump-Gas Drags
  169. JMI Crankshafts
  170. engine build up need sugestions
  171. 427 BB Build Up, Looking for advice
  172. IWON!! "Fastest Street Vette in TX"!
  173. good performance reads....
  174. 383 build up
  175. Help with 900XP Dominator on 427 ci Small Block
  176. GM Generation 4 Small Blocks
  177. Anyone try an Equus digital timing-light with tach.
  178. Building an LT1, suggestions?
  179. 632 pics: 1052.2 hp / 851.7 tq !! But all is not well....
  180. Please recommend a thin head gasket for a 406
  181. Torrington Bearing timing sets
  182. 400 small block 153 tooth flywheel
  183. Small heads on 427sb
  184. Felpro HS7733PT2 Head Gasket thickness anyone?
  185. Quick question: How common for a flat-tappet to drop a lobe???
  186. HotRod: Guide to turbochargers
  187. Dominator with no Vacuum Ports????
  188. 100 rwhp Increase with 4 mods(Less than 2K) NO NOS
  189. Need help identifying this carb....
  190. Comp cam XR288HR,,,,, 236/242
  191. Canfield BBC heads.
  192. Starters on 400 blocks
  193. ZZ4 Cam Specs - P/N: 10185071
  194. Jegs aluminum heads---what heads are they?
  195. Any company sell ported/upgraded Vortecs?
  196. Any other good heads out there that are not AFR?
  197. bearing polishing?? do or don't
  198. anyone using a hilborn fuel inj. system for a sb
  199. Discount rotating parts ?
  200. DD2000 Cam - Feasible?
  201. Powdercoated paint question
  202. MAJOR SPRAYS VETTE DOCTORS C5 9.39@148 Video !!!
  203. Head porting (non corvette) questions
  204. Any Carb experts here ?
  205. Recieved my AFR's today !!!
  206. looking for a burnout video that was posted not too long ago... please help me out here
  207. Need fuel line help--AN and braided hose
  208. Cam/piston ????
  209. Name this exhaust header
  210. Help!!! Will 2.08 valves be too much for my 383
  211. O/T Torque Wrench Recommendation?
  212. Hi Per. Passenger Mark 4 ok for 1000 hp ?
  213. Destrokin 327 to 350.
  214. REV Website?
  215. Fastest Street Vette in TX is on again! We need some "Real Vette's" to attend!
  216. Blown 509 Merlin street car
  217. ENGINE BUILDUP: CRATE LS6 or pre 86 SB foundation
  218. Finally! Started but headers glow red!
  219. Head gaskets
  220. Cross drilled crank ok for 7000 rpms + ?
  221. Talking clutch fork angle blues (Mcleod Street Twin)
  222. 632 Big Chief headers - finally...
  223. Single pattern cam for EFI
  224. GM847 Camshaft?
  225. Help engine gurus!!!!!!!
  226. engine configurations
  227. What is a street/ strip engine ?
  228. Decision made on new combo, opinions / critics ?
  229. WHAT FUEL INJECTION SYSTEM?
  230. HELP needed for my Mighty Demon 750.
  231. Fastest Street Vette Race is postponed due to weather!
  232. 1967 coupe w/548" engine update
  233. Help with 93 LT1 Timing set
  234. lS1 engine in '57
  235. What is the best Corvette engine besides the l88 and l89 in reliability and performance?
  236. Image of 407!
  237. header coatings question
  238. Few questions about AFR heads
  239. Tunnel ram, 660 center squirters hard to tune ?
  240. Help me with a new motor combo
  241. so...what are Dart Olds heads
  242. Anyone Hear of a Romac Damper??????
  243. Eagle SIR I beam rods
  244. Is the block on an '84?
  245. Double hump head performance vs Dart Pro I
  246. We need some old Vette's to run at the Fastest Street Vette in Tx" race on Nov 15th!
  247. Which Harmonic Balancer?
  248. Finally got *A* track time!
  249. Heads Flowrate vs performance.
  250. 6-71 blower ?
