View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Econo Big Block Question
  2. 496 vs. 427
  3. domb question about taps
  4. screens in the lifter valley
  5. Drove the 496 with TKO 500 today...
  6. Titanium Valves TiB MMC
  7. Polishing connecting rods?
  8. Help! Does position matter on externally balanced flexplate?
  9. Internal friction... Gear drive VS Chain timing?
  10. 400 build-up help me pick a cam and intake
  11. Cleaning oil passages?
  12. Any prep work needed for pistons?
  13. crankshaft main clearances question
  14. Whats involved in balancing an engine?
  15. Bolts/Nuts/Studs: 6 point OR 12?
  16. Manifold dilema
  17. 2 stupid questions
  18. L98 2Bolt-4Bolt 500HP?
  19. Review of my 4.00 Scat crank
  20. Installing a recirc line from carb.
  21. Adding a Supercharger
  22. pro topline heads
  23. Will this motor make 1000 hp?
  24. Recommendation on a cam change
  25. transmission torque cnverter question
  26. 383 balanced w/ weighted flex plate and neutral balance damper???
  27. 8-71 Supercharged Ford 460?
  28. 355 Horsepower Guess?
  29. Starting over --- Help with direction!!!
  30. Changing crank & rod bearings in the car.
  31. Engine Problems, Please Help!!!!!
  32. Green stuff (Gorilla Snot) on heads
  33. 383& Hyperthuetic Pistons
  34. Valve Train Adjustment process...
  35. 434 or 454 SBC?
  36. Anyone using a CompCam XE284
  37. Late intake valve closing vs compression trade-off
  38. B & M shift kit
  39. Rev kits?
  40. CC'ing Heads?
  41. Total Seal ring problem
  42. Help: lube in wtr jacket, ARP teflon thread sealer failed
  43. is ethanol blend gas ok?
  44. Opinions on this combo plan
  45. 377 Tunnel Ram inital dyno numbers...
  46. A Go on Lars Tuning 4 Beer OC, CA Tour in Jan.
  47. Anyone running Lightweight Billet Al Flywheels?
  48. cranks, cranks, and more cranks....
  49. down nozzle heads for alcohol
  50. Anybody know if a Holley Stealthram will support 600hp
  51. Engine break-in and seating the rings...
  52. Fuel Pump Question
  53. deck height
  54. No Spark energy through the distributor cap/rotor???
  55. New Bests- 10.04 and a 139.96 mph!
  56. Looking for Help! - 540 street BB
  57. Removing valve retainers from installed heads...
  58. questions about cranks
  59. Broken crankshaft... Non corvette..57 Chevy
  60. Block prep
  61. LS1 intake on L98
  62. 496 runs for first time...
  63. Vortec heads? What came equipped with them?
  64. Port matching? Intake manifold selection?
  65. Path of Oil in the SBC
  66. Cam and valve stem tip pitting (long)
  67. Converting RW torque to gross engine torque
  68. Engine Rebuild Rip Off
  69. Break-in with Comp 284XE-BBC:results
  70. Just got word...I'm on the cover of CORVETTE ENTHUSIAST!!
  71. Solid roller adjustment
  72. Help! Cherry Red Headers at 2000rpm
  73. Lobe Seperation Angle
  74. relbuiding a 396
  75. SuperRam porting
  76. 400sbc w/ Moroso 7qt pan -- thick or thin pan gasket???
  77. ~Update~ 406 that drank oil
  78. Main Cap Question
  79. installed (spark) plug depth - effect on combustion?
  80. For sale:406" SB
  81. Avoiding hotspots
  82. Bowtie race block bore diameter questions
  83. Your estimate on gains
  84. Let's Bring Lars Tuning 4 Beer Tour to Orange Co. CA
  85. A/F ratios and EGTs
  86. L84 cam into L76 motor ?
  87. Oil cooler
  88. WTH?!?! Flat Solid valve lash settings last about 5 mins.
  89. Square vs. oval heads
  90. 4” crank in stock 350 block??
  91. BB radiator choice
  92. hydraulic roller to solid roller?
  93. Opinions On My Motor Build-Up
  94. solid roller question
  95. q
  96. NOS 077 Aluminum head what are they worth ?
  97. Hi Po EFI pros please step inside....
  98. Need help finding block spec
  99. Crate Motor Questions
  100. Cranking compression..Pros/Cons
  101. 327 Overbore
  102. MoTeC Engine Management Systems at a discount price.
  103. Fuel Injectors
  104. Stoker Question
  105. Why dont Comp and Crane break in the cams for us?
  106. Holley Carb Connections?
  107. O/T: where should i go to become a 4.3L expert?
  108. MSD tach drive dist?
  109. Looking for LT1 info
  110. Need Cam advise- stroker motor
  111. maddest street SBC to fit this?
  112. Big632 Would you mind posting some pics of your car again
  113. Corvette weekend Texas style
  114. Shorter rod on turbo engines?
  115. Convert a 23* intake on to a 18* head?
  116. Which Clevite77 rod bearings?
  117. Is this crank new?
  118. Nostalgia
  119. ZZ4 cam
  120. my first engine actually started...
  121. CC'd my ported Edelbrock ovals today, interesting results
  122. Which Heads???
  123. Head Replacement
  124. anyone else using a 6TN with 6 pin connector
  125. Gear drives-I have a few questions
  126. TPI Distributor Question
  127. Stupid question: What happens with a big cam but low compression mismatch?
  128. dumb ignition question
  129. Brodix M2 T1 215 or 227 heads
  130. 32 valve LS1/6?????????
  131. The best nitrous system for a 71 vette?
  132. Oval Port/rectanguler Port Heads
  133. Oil pump bushing question
  134. Edelbrock Performer RPM cam kit?
  135. Solid lifter valve lash adjustment procedure
  136. Trouble with Fluidamper installation...
  137. What cam to use
  138. Violent Engine Vibration Above 3500 rpm, HELP!
  139. 434 from a dart little m?
  140. Piston Dish CC?
  141. most economical Blown Big Block
  142. Second compression ring gap
  143. Building a 406 have some ?'s
  144. under drive pulleys
  145. 67 548" chassis dyno results
  146. Where to find 5/8" "tri y" headers for l98.
  147. Consequences of running a big head?
  148. Can an LM1 take a mini blower and not grenade?
  149. non corvette question
  150. newbie question
  151. Hitman Plus Nitrous installed
  152. Used 4 stage peterson drysump kit for SBC.
  153. WorldProducts CNC 400/400 block. 1000.00
  154. Roller cam question: BBC vs. SBC base circle diameter
  155. Poly locks for a BB?
  156. Bench testing engine
  157. Rebuild
  158. breathers
  159. Any problem with doing this???
  160. Anyone know what causes this ?
  161. Wanted - Weiand TeamG 7525 Manifold
  162. Is this cam too big for street?
  163. im new and i need some help
  164. BB aluminum head gasket?
  165. Headers, headers, headers,
  166. Head question..errr..a cylinder head question that is
  167. How do u tight'n guide plates?
  168. question about valve springs
  169. why reverse flow water pumps?
  170. Oil pressure too low?
  171. Will Gen V heads fit a Gen IV block?
  172. 496 shortblock is assembled, cam Overlap question
  173. 406 SB... What Intake?
  174. Possible to change valve steam seals in car?
  175. Dyno Results-327 Hydraulic To Solids
  176. LT1 Harmonic Balancer question!??!
  177. Big Blocks and Balancers-opinions?
  178. Help degreeing cam w/ timing chain
  179. Engine Parts for Sale
  180. 383 crank- SCAT 9000 or Eagle?
  181. Internal Manifold Vaccuum Leak
  182. TPI for '79 383
  183. 64 Spin On Oil Filter Adapter
  184. Let's try again this year...C-1's/C-2's/C-3's at Hallsville TX..Oct 9th!
  185. You must check out Headerdesign.com's web site
  186. Desktop Dyno 2000 Head files
  187. TPI on a 383 street motor. X-post from C3
  188. Wiped Lobes
  189. Highest quality aluminum rods ?
  190. Aluminum head fuel boiling problem
  191. BBC solid lifter cam spec question...
  192. how do you make an engine sound bad?
  193. Anybody tried the new 4 & 7 swap cam from Comp?
  194. Got an attaboy.
  195. help me choose new sbc heads
  196. Distributors
  197. L98-383 Buildup
  198. Can A Super T10 be built stronger
  199. Lars demon tuning tips
  200. 2 bolt block
  201. Extreme Energy Comp cam vs. other Comp versions
  202. Extreme duty timing chain
  203. thoughts on buildup
  204. MSD plug wires and Hookers
  205. Tri-powers
  206. 327 Holley vs Edelbrock
  207. Electric water pumps
  208. Starter noise, carb size...
  209. torque convert. noise's
  210. 461-AFR 195 head swap
  211. porting RPM heads
  212. Top end / Bottom end
  213. valve cover breathers
  214. Distributor end play
  215. siamesed block
  216. 632" motor: First drive & 4-muffler exhaust pics
  217. Finally Coming Together After 6 Years Please Look
  218. How to seal rear freeze plug behind cam
  219. I met 632C2!
  220. MSD Pills-FS/Trade
  221. Dyno 2000 HP #s
  222. HP Predictions for a 79?
  223. MSD and timing
  224. Living With G-Force On The Street
  225. My Internals
  226. Sharioff 406 4.155 Bore Head Gaskets
  227. which tourque specs ?
  228. noisy top end of motor ???
  229. 327 buildup questions?
  230. almost done, pushrod question
  231. Timing gear?
  232. Pics of my fabbed narrowed rear and 3 stage NOS system
  233. DIY leakdown tester
  234. stud girdles ?
  235. Piston choices
  236. Ignition Conversion....Help.
  237. silly big block question
  238. Can I please finish one motor before I move to the next
  239. 4L80E transmission
  240. Holly 650 on a Stock 305(Monte Carlo)
  241. looking for help with this MSD
  242. educate me on rod length please.
  243. whats the truth about carbs
  244. popping noise
  245. question about cams
  246. Edlebrock 600 running rich, I think...
  247. Rod bolt stretch...
  248. 4L80E and Electronic controller
  249. So it begins...my 540
  250. Upgrading power on my '71 BB...
