View Full Version : Engine Mods
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. 1971 zz4 install
  2. Keith Black Hypereutectic Pistons
  3. BBC TPI Style Throttle Body Advice Needed
  4. cylinder damage
  5. Elderbrock Heads
  6. Spark plugs in Sportsman heads?
  7. Edelbrock Performers vs. 462's
  8. 406ci small block, 546 HP dyno
  9. Pick-up depth, what to y'all like?
  10. Moly/Graphite Coated Clevite77 Mains
  11. Engine Masters BBC
  12. Kerbeck - Performance Modifications Offered?
  13. LS2 experts PLEASE chime in....
  14. Forged crankshaft advice.
  15. '88 and newer Corvette starter or GMPP hi-torque starter?
  16. 400CI Crank, balance weight amount?
  17. The 632 is in
  18. Stock 400SB Bottom End: Is It Junk?
  19. mods for 86 vette
  20. Engine Cradle
  21. Corsa
  22. Engine Tech Discussion at Hooters Last Night
  23. 5.7 VRS 6.0 Piston Rods
  24. Dyno Simulators: can this software evaluate plenum and runner volume changes?
  25. Headers 1 5/8 vs 1 3/4 tubes
  26. 3731548 Block
  27. ?Someone be willing to Put this in their Sim Dyno for me?
  28. Any induction experts here?
  29. 350 Combustion Chamber Question
  30. Will a Ram Jet 350 Cam work w/ a 600 holley
  31. 580" BBC head recommendations
  32. Looking for advice on 327 Buildup
  33. Opinions on a good Hi-perf muffler?
  34. Canton RR oil pan question
  35. 400/327=350?
  36. Pulsator Questions
  37. Vin and code stamp help
  38. Engine Code Help
  39. Tempered aluminum?
  40. BBC project... 427 or???
  41. Ceramic coated headers curing
  42. Main girdle, do I need one?
  43. BBC Gen IV Oil Pan
  44. 400ci engine vs.8000rpm
  45. Dynosim Advanced
  46. Intake / Head / Cam swap
  47. What Cam,,, Hot Cam , 264 HR or 270 HR, ZZ4
  48. 427=427 ?
  49. LTX block cola crank what and where can I get crank seal adapter?
  50. Spiral Piston Locks - What's the trick?
  51. Exhaust manifold gaskets? do you need them?
  52. New Engine Project - TT LS 427 or TT SBC 427
  53. Safe quench limits, opinions?
  54. Frebie heads. Worth it?
  55. Steel Balancer vs Aluminum Balancer.
  56. 4"+ SBC stroker question
  57. New Nitrous Vendor!!!!!!!!!!!!!!!!!
  58. L98 and short 327 stroke crank
  59. Engine Covers for LS1's with magnacharger
  60. Recommendations or availabilty of programming software for MEFI?
  61. LS-1 piston side-play question???
  62. EFI retrofit wiring question
  63. Max oil temp
  64. Gear drive experts please look at this
  65. "Pep" for my C2
  66. Need a source for a Pilot Bearing extension
  67. Clevite "H" Brgs vs. Rod Side Clearances
  68. NA LS-1 engine build questions???
  69. Indexing bellhousings-How to?
  70. How much will a 2 bolt handle
  71. 400 sb starter
  72. Why not 1.65:1 or 1.7:1 rockers on early sbc
  73. Crane 1.8 Gold Race Rockers vs. Valvespring Selection
  74. Serious Stroker SB's, Step Inside
  75. New LS7's just in, have a look!
  76. Tuning a modified Big Block 427
  77. oil pump drive system question..
  78. Can u index plugs with a NPT die?
  79. New Engine Now Hear Click Click (Valvetrain noise) VIDEO !!!
  80. Anyone use the new Bowtie Performance Vortec heads
  81. Exhaust Note and Cam Duration
  82. Anyone able to use Crane Kool Nuts?
  83. Replacing bearings in high mile 350?
  84. Ring gaps
  85. DIY Spark Plug Modification
  86. Remote oil filter
  87. Good engine shop in boston area?
  88. 383 Help
  89. pushrod question
  90. Rwhp / Rwtq
  91. DYNO Black Smoke out exhaust when let off gas after WOT
  92. Camshaft lobe overlap ??
  93. Engine ID help
  94. Pilot bearing, bronze or roller?
  95. Chemical crack checking vs. magnaflux
  96. Crankcase vent a PCV setup.
  97. Solid Lifter Valve Adjustment Method
  98. Valve Lash Adjustment on BB Aluminum Heads on Iron Block
  99. Sizing head gaskets
  100. Holley 4150 adjustment ?'s.
  101. 6"Rod with 383 Q
  102. Long, (Anyone ever use uncoated headers in a C4?? What problems occured??)
  103. Morel lifters in a Lunati box?
  104. Zero Lash solid roller?
  105. cancelled
  106. So how do you get a flat torque curve?
  107. No Oil to the Rockers
  108. Mighty Demon Carb anyone using?
  109. Broken Piston-Recommendation?
  110. Air flow question
  111. Standard Base Circle for SBC?
  112. DANGER: MINI-RAM II users!!!
  113. Please explain differences of LS1 motors in C5s and Camaros.
  114. block ID
  115. Evacuating blowby via the breather holes, to the Collectors
  116. How Can You ID a BBC Tall Deck Intake From A Standard Deck?
  117. What are your opinions on this combo? (SBC)
  118. Oil filter thoughts on new rebuilt engine.
  119. Best technique for solid roller lash adj?
  120. Cam opinion
  121. Dynatech Header Blowout Sale
  122. Attention C6-c5 Owners
  123. Measuring bore question
  124. Ethanol Conversions?
  125. Port Volume vs Port Area, I'm Confused!
  126. Strange problem with cylinder heads...ideas?
  127. Gen V heads on Dart or Merlin block
  128. Screw In Block Temp Gauge?
  129. spiral locks
  130. Meth injection questions, 90 Z
  131. Oil Priming .... ?
  132. Oil Cooler Location
  133. Swapping L98 for LT1.
  134. Anyone ever install a dry-sump in a C4?
  135. No lockup on 700R4?
  136. Questions concerning motor swap.
  137. hardcore ? about pistons
  138. Will a 10:1 CR 350 run ok on a lower octane?
  139. Chevy TBI Injection Question: Unplug Sensors, no change?
  140. Air fuel ratio
  141. Find a DYNO
  142. Do carb spacers really work?
  143. Barry Grant 6 Shooter
  144. Need advise on reading my sparkplugs.
  145. Flow Bench Availability?
  146. Anyone drill holes in their own valve covers?
  147. big block in 90 chevy
  148. Oil control problem
  149. Electric Cooling Fan Question: Mount TO radiator or leave a gap?
  150. Aluminum heads
  151. Anyone out there purchased a ZZ383?
  152. Anyone in Aerospace or Racing in SoCal? Oil Cooler help needed.
  153. Need a Chevy Engine Eletric Cooling Fan Sender...
  154. 396 engine...chime in please!!!
  155. What you don't want to see on you motor.... :(
  156. Valve Geometry Questions
  157. Plugging the Filter Bypass ; any resulting problems ???
  158. Oil Pressure
  159. 406 running hot
  160. Jet Technologies Superchargers
  161. help 383 problem
  162. 632 hardcore questions
  163. Torker II or Air-Gap Intake?
  164. BB Edelbrock Heads/ Manifold
  165. Hydraulic vs Mechanical Roller
  166. Biggest LT1 / 1 piece oilseal engine ? 427 ?
  167. 406 Experts enter in! (89 A4)
  168. A 540 Saga Part 2
  169. Poll: anyone using CC Magnum rocker self-locking nuts?
  170. A 540 Saga Part 1
  171. Injector Cleaner on New Motor?
  172. Torque to turn engine???
  173. Is it just me or.........
  174. 427 block sources?
  175. Spend time @ high rpm's? Check your pullies!!
  176. Photos of my Whipple SC installation
  177. Piston sideways????.. hope the world is not ending
  178. In case you missed these engine videos
  179. How does this WhippleCharged setup sound...
  180. Hyper of forged pistions
  181. Looking for a good machine shop in chicago area
  182. 415 SBC stroker questions for ya!
  183. !HELP! cracked block
  184. No A/C more HP ???
  185. DOHC Chevy crate motor ?
  186. 400 engine... score!
  187. Anyone running an electric Holley fuel pump?
  188. why do carbs make more power than EFI?
  189. CA. 400 block source?
  190. Original Chevy LT-1 cam specs, what are they?
  191. Head gasket recommendations?
  192. What size oil lines to cooler?
  193. Dynamic Compression ratio q's???
  194. Coil wire length
  195. Harmonic Balancer question...simple
  196. Tranny cooler?
  197. hard anodizing pistons
  198. Get more performance from the same HP
  199. Fuel Pump & Oil pressure
  200. Need input about these cam spec's
  201. GM's 383 stroker rods
  202. What throttle cable bracket you running?
  203. Post Your Dyno Numbers With A XE274
  204. Anybody know what a 502 crank weighs?
  205. E/I Ratio Questions
  206. will a 3.875 stroke fit?
  207. beehive springs
  208. Cam Advice please step in....
  209. Engine Missing
  210. How to measure lobe/vlv lift with vlv train installed in car and hyd liftrs adjusted?
  211. help! rings rusted to cylinder
  212. What are the holes in the block for ?
  213. Solid roller/ valve lash question....
  214. These Brodix Heads any good?
  215. Not exactly an A-B-A test of a flat tappet vs a solid roller..but still interesting..
  216. Header question?
  217. Going to build a little different combo, anyone done this?
  218. WTB-LT1/4 bare block
  219. rant pissed off at SCAT
  220. 358 motor kit F/S
  221. modded 350cid ready to roll- what lifespan can I expect?
  222. How much gain going from Shorties/2¼" to LT's/2½"
  223. Why torque drops at higher RPM ?
  224. Help Identifying Big Block
  225. Carb vs FI dyno numbers
  226. Questions about a 383
  227. Engineer's nightmare? Or masterpiece?
  228. alum.block, what were they in?
  229. Picking the correct rockers arms
  230. How to contact Nick Williams?
  231. Marine big block?
  232. ram jet 350 ???
  233. 391 Sbc
  234. WARNING vettepartsonline WARNING
  235. All the parts are finally here, opinions please...
  236. 1.5 to 1.6 Duration Change
  237. What do you guys think about Gm's new...
  238. 383 build finally finishing...comments?
  239. to damn pretty not to post them
  240. Big Chevy Closing the plugs need help
  241. Flame throwing carburetor!!!
  242. My LS1 Valve spring testing results....
  243. A bit of education, please.
  244. Bore size Oil pressure?
  245. ignition computors boxes.
  246. Headers versus Ram Horns
  247. open headers good bad?
  248. Valve Seals on a Drag race engine
  249. Off Idle bog down on hard acceleration
  250. Pushrod lenght........Can this be right?
