View Full Version : Engine Mods
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. piston deck height
  2. jojustice C-4
  3. LS7 crank "knifing"
  4. Opinions on clutch kit brands needed
  5. After market heads and Rochester F.I.
  6. ADVANCED DYNO Proudly Announces Facility Expansion! GIANT Thanks To Our Loyal Clients
  7. anyone with zz4 experience
  8. 454 block usability
  9. Hot 350
  10. engine dress up
  11. LS race engine bearing clearance suggestions
  12. NGK Iridium Spark Plugs
  13. Whos Running the Best tranny cooler on the market for my SC Charged vette,
  14. LS-2 Direct port question....
  15. 'Sealing' my polished aluminum manifold
  16. 427 tall deck strikes back!
  17. Chuck CoW - TUNING in TAMPA, FLORIDA @ REV-XTREME
  18. New AFR Eliminator cylinder heads....
  19. 750 Holley bleeds off fuel pressure through vent?
  20. 383, 434 questions
  21. FS: 18* head/414" SB
  22. best overall MODs for a 350 CFI injected C4
  23. Fixing strange oil leak
  24. 1 quart baffeled catch cans, $49.95!!
  25. 440 with 76cc head what compression ratio?
  26. carb jetting
  27. 12 HP gain from springs?
  28. Question about heads?
  29. AFR 205 heads
  30. Help - Too much fuel pressure!
  31. Engine build advice
  32. Valve to piston clearance
  33. 427/435 L89 mods?
  34. Rear end noise .... arghhh
  35. 11.3:1 CR on pump gas?
  36. cryo treatment
  37. patriot-performance anybody know anything about these heads?
  38. Building engine that won't be started for 2 months.
  39. How Much can I Gain w/Headers?
  40. Lsx
  41. Engine combo
  42. I want to build a 9.5:1 355 TBI roller motor for my 95 SUBURBAN
  43. Which heads?
  44. Which stroker rod length?
  45. Measuring Bore Clearance
  46. Help me choose between bottom end or top
  47. Header ?
  48. Carb Guru's,I have an IFR question.
  49. Question about storing a slightly used LS-2 motor...
  50. Pushrod length measuring
  51. Coolant Pressure Modeling
  52. More HP out of my headers !!!!
  53. Aluminum Rectangle Heads vs Cast Oval
  54. What's the story on these rev kits?
  55. Bigger cam?
  56. Carburating a 383 L-98 Engine....
  57. Need advice/info in pursuit of 500rwhp LS1 build
  58. Pushrod length problem
  59. GMPP NA Manifold question....
  60. LS2+QL rockers ++??????
  61. ZZ - 4 Negetives ??
  62. ZZ-4 and Short Water Pump ??
  63. Possible to use an early crank in a late block?
  64. 778 HP Dyno Tuned Fresh 548 $8500
  65. cam for a Vortech blown LT1
  66. 427 Small Block coming together, pics
  67. Cam change
  68. Vote on what to have on the valve corvers of WarHawk Twin Turbo
  69. Cam selection... I need help
  70. what does a .005" do?
  71. Timing Chain Thrust bearing thickness?
  72. zz383 mechanical fuel pump
  73. Help me choose the engine, input needed!
  74. Is it possible to convert to annular discharge boosters?
  75. Finally got my new custom made carb for my new engine
  76. 402 block with ls5 heads
  77. Who makes the best block?
  78. Stud girdles
  79. L-36 hop up
  80. FS: 383 HP 602 HP 532 Torque LS-1 long block
  81. can you Id this cam
  82. dividing my holley 4bbl into 2-2bbls
  83. 383 LS2 thread ?
  84. 350help
  85. zz4 crate motor
  86. Please Help 5.0 Distributor Trouble
  87. ProComp 320cc BBC Aluminum Head
  88. Holley 4160 questions
  89. Small block oil pressure
  90. Interesting Combustion Video
  91. Need to rebuild a 350, tips/tricks/info?
  92. Need more power for a 82
  93. Missing metal
  94. Supercharged LS3 Stroker
  95. when does your carb switch to the booster?
  96. Here's the deal
  97. Rocker Arms
  98. Attention Supercharged & Turbocharged Corvette Owners - Alcohol Injection Systems
  99. Double pumper
  100. dump piston replacement question
  101. 454 BB in C-4?
  102. Anyone with Desktop Dyno willing to plug some numbers?
  103. Manual Valve Body in a 700R
  104. IAC - Idle Air Control & High Initial Idle
  105. IAC - Idle Air Control & High Initial Idle
  106. racing fuel filters
  107. Does anyone know about the for 8.8" rears
  108. Supercharged spark advance question.
  109. Lingenfelter packages
  110. #113 head question
  111. THE OFFICIAL TUNER OF 2007 CORVETTES @ CARLISLE is CORVETTES OF WESTCHESTER
  112. Looking for input for choosing chamber volume or altering piston dome for desired CR
  113. accel wide band question
  114. Mixing/combining engine oil of different weights
  115. stroke the ls2
  116. Fuel injectors. Is one brand better?
  117. Engine Coolant, "shelf life"?
  118. MSD ignition
  119. Mustang motor locked up
  120. Pure White Silicone Hose
  121. Crankshaft grinding??
  122. 540 Cam
  123. Carbed LS2?
  124. Z28 Carb
  125. New Chevrolet R07 NASCAR engine, etc
  126. Going with a bigger cam on my 91'
  127. GM Parts 454HO 425 HP Crate Motor
  128. What are your main bearing clearances?
  129. Changing over Lt1 to carb
  130. Cam selection help
  131. BB Head Volume Unknown
  132. LS-6 w/ Vortech blower streetable?
  133. Best engine mod for my 85
  134. Huge Solid Roller
  135. Am I checking this Lift clearance correctly?
  136. Am I checking this Lift clearance correctly?
  137. Roots blower...Magnacharger/weiand???
  138. 2 questions to engine gurus.
  139. 427 small block?
  140. is bigger better
  141. Off set rocker arms
  142. Intake port question on vortec 906 heads
  143. 4-valve Gen I SBC heads & Weber EFI
  144. should a 383 "shake" or feel off balance at high RPMS in an idle rev?
  145. machine shop costs
  146. Rear main Seal ID ?
  147. Need burnout power
  148. off corvette topic : transmission
  149. LS2 6.0 Liter Question
  150. LS2 6.0 Liter Question
  151. LS2 6.0 Liter Question
  152. Small Block Head Comparison
  153. How does a distributor work?
  154. EnglandGreen Signature Camshafts, now on sale
  155. How much Bob Weights do you have?
  156. 383 Rod Bolt Clearance
  157. Most reliable electric fuel pump? C2 FI
  158. How much oil pressure is too much?
  159. Billy Boat Headers
  160. got afr 195 eliminators help finish the build
  161. 427 L71 & L88 cam events
  162. Ouch!!!
  163. Copper Head Gaskets
  164. Mileage motor... carb questions.
  165. Tap size needed for 90 Vette - Help
  166. Help Needed to Relocate Evap Purge Valve
  167. Anyone heard of a 4340 Flywheel?
  168. Engine "pucks"???
  169. 97 Bonneville SSEi Engine rebuilt problem.
  170. New engine question.
  171. NOS on a C6.
  172. Mod guys, what can I expect?
  173. 2001 SBC Vortec Block
  174. 406, 350 mains or 400 mains?
  175. Generation 1 SBC Timing Chain Cover
  176. Angle milling the cylinderhead
  177. What Big Block Manifolds will clear the stock BB hood???
  178. Corvette heads question in general
  179. Numbers on top of pistons?
  180. possible procharger sale
  181. opinions on engine needed
  182. 406 cam upgrade ?
  183. OEM Powdered Metal Rods - Different Grades?
  184. KwikLift for sale, CHEAP !
  185. ditch cut in exhaust valve
  186. Uh-oh, how bad would this be?!
  187. A6 tranny....
  188. What if I need 2 temp sensors??
  189. Piston ring interchangabliity and questions
  190. c6 question
  191. SAE J604D cam spec????
  192. Injector Question LS7 Intake on C5R heads w/ LS1 wiring.
  193. What RWHP Should I Now Expect
  194. Extra Space
  195. Porting for larger Cross Section
  196. *** ECS Paxton Supercharger - $7695 installed and tuned *** (Florida and SouthEast)
  197. WTK:Holley Rebushing
  198. Finally
  199. GM LSX Tall deck block
  200. Can you identify the manufacturer of this head stud?
  201. Tri Power Manifold Performance Potential
  202. Pre-detonation thought experiment, combustion experts chime in.
  203. Aluminum machinists, please stand up.
  204. 21st Century MC
  205. L92 Block
  206. How to wire new HEI distributor
  207. Considering upgrading my zz4's heads and cam
  208. Need reputable machine shop in north Atlanta area.
  209. BB Cams FS
  210. Flywheel recommendations, any better than 3991406?
  211. Cam recommendations 540 Build 1966 Coupe
  212. Piston Question dished vs Valve Notches
  213. Cam and Head Package info
  214. Spark plug hole stripped out. What to do?
  215. Damper questions, SFI approved?
  216. Opinions needed on new build please..(L98/TPI)
  217. 1.25" SBC max valve lift possible?
  218. GMPP 2007 catalog, twice as big as 2006.
  219. Why is my C5 engine cutting off
  220. Best head
  221. 4/7 Cam...Advantages...Disadvantages
  222. Vortec Heads Question: 906 casting or not???
  223. 377 stroker question
  224. Eagle "383" Rotating Assembly Question.
  225. Diesel Power For Corvette?
  226. Solid roller lifters failing in Street motors - mystery solved! CAUTION - VERY LONG
  227. how do you ship a lower end ?
  228. Painting Engine Fuel rail covers
  229. Opinions Needed
  230. #8 (3/8" ID) lines big enough for lines to engine oil cooler?
  231. Welders/plenum
  232. How Close Does the O2 Sensor Really Need to Be?
  233. Lightweight and ultra light Crankshafts
  234. 427 switching closed cc to Open Pitfalls?
  235. Solid roller Question
  236. Gen-I rods in a Gen-III?
  237. Harmonic balancer size for 327
  238. sbc dart iron block vs. worked 400
  239. Compression ratio question
  240. Afr 195 Vs Gm Fast Burn Heads
  241. New pistons, balancing question
  242. 3.875" Stroke/Rod Length questions
  243. Explain stages please.
  244. price on a 400 block?
  245. Supercharger geeks, help with cam selection
  246. Felpro Head Gaskets, I'm Confused
  247. Is Gasoline octane rating altitude adjusted?
  248. When To Discard Tpi?
  249. Anyone Interested in a Blower Motor
  250. Max Rod length for 3.625 stroke?
