View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22
  1. help with throttle cable connection...Where? ..on spread bore holley 650
  2. Toms differential Dana 44 questions, performance questions, gear ratio questions.
  3. ok, could this be my problem?
  4. Keeping it COOL
  5. Understanding timing with DataMaster
  6. Roll Bars?
  7. Should I re-torque my Head Gaskets?
  8. Head Casting # 462624
  9. Degreeing the cam question...
  10. Decoding Engine Block #'s
  11. exhaust systems
  12. Crate Motor - Timing Tab??
  13. Blown 350 vs 454
  14. Aluminum flywheels
  15. 700R4 2-3 shift point too high. How to correct?
  16. Installed Forced Air Induction
  17. Name that problem!
  18. Petition to US Postal Service for 50th Anniversary Corvette Stamp
  19. Cams / Gas consumption "I must be getting OLD"
  20. Anyone using Serpentine Belts from the newer 350's?
  21. new 85 vette dyno #'s with new cam. 693HP and still mild 383 daily driver!
  22. i was suggested to get AFR 195cc heads, possible mistake??
  23. 700R4 Trango Shift Kit Install Qusetion
  24. dana 44 -vs- dana 36
  25. Exhaust question for a '75 Stingray
  26. installing larger valves BBC
  27. Rear Gear Change// Must Change First Gear Shift Point 700R4
  28. 100+ dyno combinations
  29. Vortec 8.1L (496) vs. BBC
  30. 1996 LT1 Rod Length
  31. What does a collapsed lifter sound like? How can I tell?
  32. Cam Blanks...All the same?
  33. Anybody have any advice on porting and polishing tricks on LT-1 heads?
  34. Looking for Info on the LS - 7 Engine.......
  35. 18*degree heads with stock lifters????
  36. Engine Dipstick Install...
  37. Parts Suppliers
  38. Rear differential questions...
  39. ESC No Spark Problems.... HELP PLEASE!!!
  40. ED WRIGHT PROGRAMING
  41. Whoa! Check this auction!
  42. Pics of my blown Felpro 1010 head gasket
  43. 2.5" vs. 3" exhaust
  44. Another "How much compression is too much for pump gas" question
  45. Anyone using billet brackets on their C3?
  46. Big Block Swap
  47. MODS............whats next?? need suggestions
  48. Quest for a 9 sec daily driver, where to have AFR 190 heads ported?
  49. Need help from L-98 engine Guru's
  50. Need measurment, or info on my dist. issue
  51. To anyone who has done ANYTHING to their corvette. HELP CORVETTEFORUM!!!
  52. Carb secondaries, Vac vs. Mech.
  53. Arao 32 valve heads
  54. For your Copy of "In memory of the lifes that were lost Sept 11,2001
  55. TPI Performance 700r4 Tranny
  56. No spark, need help!
  57. 4L80-E Tranny Mods
  58. Trans life: 700R4, 200R4, ???
  59. First time nitrous user
  60. S/R Torquer Heads
  61. Performance Fuel Pump Setup Recommendations Please
  62. Anyone hook up a manual switch to their secondary fan?
  63. Getting High RPM Knock.
  64. Which heads for zz9 cam and 1.6 roller rockers
  65. Input needed on which way to go..
  66. Rectangular Exhaust Tubing
  67. Fuel Pressure Regulator
  68. Who has a 502 C.I. crate motor installed on their Vette?
  69. Demon recall?
  70. Intakes! Edelbrock or Weiand?
  71. BeCool radiator post
  72. WHat is the best clutch to use with an ATI procharger? 1993 LT1 6speed
  73. intake manifold and runner questions
  74. SOS, need torque specs for 95 LT1 head bolts (please advise)
  75. Cam specs for 74219...
  76. Tuning fuel curves with a miniram
  77. Push-rod problems with new TrickFlow heads.
  78. Hows this for engine?
  79. LT4\FIDANZA FLYWHEEL\CENTERFORCE CLUTCH PROBLEMS
  80. Fuel Pressure Check
  81. Victor Reinz 5746 head gasket question
  82. Carb -vs- EFI....pros & cons
  83. Got lots of perf. questions and need good answers before weekend!!!!
  84. Heat coating the Intake
  85. Torque converter
  86. Anybody know of a GOOD distributor COMPLETE for an L98? GM one's are DISCONTIUNED.
  87. 6SSPD - what is your e-mail add?
  88. Now I'm thinking 355ci for the winter.....
  89. Street racing wreck video i took + street race video of my 10 sec C4 vs 9 sec Chevelle
  90. Paging 88 whtie vette...paging 88 white vette
  91. Rev Kit reliablity
  92. Want your opinion on planned mods.
  93. Is anyone else having problems with the FelPro 1010 head gaskets?
  94. Cheap Way to Make TPI flow like a SR or MR?(pic inside)
  95. AFR Hydra Rev Kit: Anyone using it?
  96. ZZ4 Somg Legal
  97. Need some MSD 6T wiring info
  98. Need a good tuner extremely urgent!!
  99. GP on Vigilante torque converters
  100. Carb questions
  101. Pics of the car
  102. 4L80E conversion...87 vette
  103. Anyone use the zinc accel plug wires????
  104. What type of cambutton,thrust parts do i need for a retrofit roller cam conversion??
  105. Valvecover Spacers for AFR Heads?
  106. Hmmmmmm
  107. 6spd
  108. GKULL, was it you discussing a post about CAMS, and why you like LSA's in the114degrees range?
  109. If I cut .025 off the top of my pistons, will they live w/ 8 lbs of Boost?
  110. Engine part brands to stay away from?
  111. Crankshafts?
  112. Large tires w/o flares?
  113. TPI Intakes
  114. Wide band O2 sensor with stock computer?
  115. Cooper head gaskets question.
  116. ENGINE ASSEMBLY + PICS
  117. Electronics Difficulties
  118. Help me choose new heads
  119. attn mini-ram owners
  120. Fuel injector part number question
  121. Help me understand why no expansion chamber on 4-stroke
  122. chewing up dist gears.....
  123. Fuel rail removal problem
  124. Vette pops and misses at any RPM over idle, cant even drive, any ideas?
  125. Custom Pistons for SB2 heads?
  126. Powerloader came this afternoon
  127. Modified Carburetor Flow
  128. Who is running EDELBROCK VICTOR Jr heads, and have you ever had them flowed?
  129. Req Tech info on TRW L2300F forged piston
  130. Let's see if you guys give a ****
  131. adjusting TV cables
  132. Lots of questions about about this engine setup in a '78 C3
  133. Anybody using 1.7 rockers in a SBC (not LS1)
  134. Why is Carb whistling through primary bowls
  135. Does this sound like a restriction ?
  136. 69 427/435 enigine rebuild. any performance enhancement recommendations?
  137. Crane Roller Rockers Hot Deal
  138. Ceramic Coated Pistons?
  139. IAC only goes to a count of 160
  140. Beachbum: How would you get your car into the low 11's????
  141. anyone using Pro Magnum Lifters?
  142. what turbo for a 406?
  143. Why 96mm tbody for 350ci and 144mm carbs for V65ci Honda motorcycle
  144. Cold start injector for alcohol injection??
  145. Supercharger Bypass
  146. General Questions
  147. thermomaster and sensor
  148. Help me understand a couple of things.
  149. What can cause 85 frontend to sit 4 inchs lower than stock for no reason? Its way to low
  150. 6 Speed shark
  151. Comprssion ratio ?
  152. Straight Axle C4 conversion, Cheaper than buying Dana 44????
  153. PaceSetter® Big Bore "Monza" Exhaust System Kit for '84-90
  154. ZZ4, what should I expect?
  155. Spark knock....HELP!!!
  156. My ZZ4 w/ new heads & stuff
  157. cam specs please
  158. ZZ4 / 430 Performance?
  159. ZZ4 heads / exhaust header question.
  160. New Head Questions
  161. 391ci from speed o motive
  162. Alright dumb question. What's the firing order?
  163. Camfusing Question!
  164. SysteMAX II Performance Package by Holley?
  165. Ignition Goodys
  166. 1.6 Roller Rockers
  167. Bright Idea
  168. New crate motor for my 91
  169. putting 406 back in need advice..
  170. Just ordered Vigilante 3600 Converter, Did I make the right choice??
  171. Thanks beach bum
  172. What are the BPUs of a L98?
  173. Building a motor for NO2
  174. Paging Beach Bum
  175. Street racing video: 10 sec C4 vette vs 11.20 C5 Vette (i smoked him
  176. Other cams
  177. Why the blocked rear ports on TPI intake manifold gaskets?
  178. Lars' HEI curve kit
  179. Edelbrock rpm heads. Enough flow for a 406?
  180. Congrats to Forum member ODW !!!!
  181. Miniram vs Victor Jr (style) intake systems; which flows more (HP+++) ??
  182. Inexpensive maf replacement with better flow?????????
  183. Artificial Aspiration on a C5
  184. Hedman Headers w/ Trick Flow heads. Need header gasket recommendation.
  185. C1 Side Motor Mounts
  186. One Piece Rear Seal Block Question????
  187. Will C5 Seats bolt into a C4 corvette?
  188. C5 Intake question
  189. a little oil in the radiator???
  190. 700R4 - Governor Question
  191. Fuel injection FUEL PUMP question
  192. Fast Burn Heads
  193. Wacky Tachy
  194. Will AFR 190 Street Heads stock springs be fine with .570/.592 valve lift?
  195. Knock Detector
  196. Got any aluminum blocks?
  197. Best cyl.heads for L98?
  198. Progress on my car...
  199. Anybody lookin for a REALLY big block!!!!!!?????
  200. Good Tuner in Raleigh Area
  201. does anyone.......
  202. Compression Ratio Primer
  203. which sensor is this?
  204. how much better do you think i would do if i put my team G intake on?
  205. How to adjust CompCams magnum rockers??
  206. vortec heads and other questions for you opinions
  207. I love the sound of a blower
  208. Long wheel studs for slicks, what do i need to do it??
  209. aNYONE PUT HEADERS ON AN 80?
  210. Electromotive EFI should I change
  211. More power valve changes....soooo much more power
  212. Check this out
  213. Got NOS?? inquiring advice....
  214. not an Edelbrock
  215. Other Mods to go with Engine Mods?
  216. Oil inside Miniram intake???
  217. HELP..oil leak..cannot locate
  218. DFI
  219. highest compression that can be run/aluminum heads.
  220. Super Ram problems Need Help PLEASE
  221. DFI Help
  222. Which spark plugs should I get???
  223. Building my motor....
  224. A/C gurus... Need A/C Parts Source
  225. Is there a top-notch tuner in the Dallas/Carrollton area?
  226. Better ET at track: Yank 9" Thruster Pro 4000 vs Vigilante 3600 9" converters?? need opinions
  227. Heading to the chassis dyno in the morning in New Jersey...
  228. Can some give me a quick 101 on cam lift & duration???
  229. Anyone have Hedman headers on a C4? Clearance problems...
  230. Air/Fuel Meter
  231. F/S 4 oem wheels and tires
  232. too much fuel?
  233. So many cams...
  234. Need help with Accel DFI
  235. Name all possible needed specialty tools....
  236. where's number 1????!!!
  237. 400 block
  238. Mods to make Mini Ram Bolt-on
  239. LT4 PLUG WIRES?
  240. Paging zwede
  241. How's She Doing Monty?
  242. How do you do it?
  243. Who thinks I can get it done?
  244. 32 vlave big block head???
  245. Beru Plugs
  246. Motown 427 and efi for c4!
  247. New Best!! My 383 - 85 Vette went 10.91 @ 129 whoohoo
  248. Monty -- side pipe options
  249. 540 Chassis Dyno results.....
  250. I Guess It's Heated 02 Sensor Time
