View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22
  1. Re: Can someone with Software check my HP
  2. air pressure on valves to change springs-How?
  3. Unhappy with dyno
  4. Which head for 406ci, AFR 210 or Dart 220?
  5. BB SB What's the Difference?
  6. What's my compression
  7. Changing jets question?
  8. Q-Jet & 4160 carb height
  9. Freakin' Monster
  10. LS1 in C4?
  11. Any one ever hang an intercooler on a supercharged C4???
  12. Exhaust manifolds 2" vs 2 1/2" outlet.
  13. 7730 ECM
  14. Need help finding a neutraly balanced flywheel
  15. Timing Fast Burns
  16. Clutch slippage
  17. Oh ya! got a dana 44 today for FREE
  18. What do I have?
  19. Bill Mitchell?
  20. SBC bolt torque numbers
  21. calling all mcleod street twin clutch owners
  22. 1.46 valve springs fm tfs 23 heads
  23. For a few bucks modify stock C5 thermostat to be adjustable
  24. WorldCastings crate engines...anyone ever use one?
  25. CarbedC4 -- Give me some airflow numbers and a little more...
  26. Hey - turbo guys...
  27. who is running Nitrous and which setups are you using ?
  28. "Build" me a bulletproof L98...
  29. What is the perfect AF-1=?SB
  30. Alright,how do you guys run low 11's on motor? I make 500+ horsepower and should run 10's! tips?
  31. What cam in 383/TPI?
  32. MPH in the 1/8mi.
  33. LT1/4 Engine Hoist Lift Plate?
  34. Attn: Super Ram owners
  35. MSD Digital 6 compatible with Petronix?
  36. SBC in a Fiesta/Festiva/Small car, feasible?
  37. How Well Will These Heads Flow?
  38. Re: Accel DFI question
  39. ((Happy Veterans Day)) Any Veterans that owner Vettes out there??
  40. Rocket Block questions...
  41. casting numbers
  42. Sparkle in oil - Engine Builders HELP
  43. Engine paints?
  44. runs crappy after 3K
  45. Direct port nitrous for 87 tpi manifold info needed
  46. went from 160 to 180 lost oil Psi
  47. Here's your chance to own a set of Arao 32 valve cylinder heads at a discount!
  48. Reher-Morrison Engine Assembly Books
  49. Gen VI block to 540ci?
  50. anybody used....
  51. Venolia pistons
  52. I may change my shifter, but has anyone.....
  53. smallblock 400 questions.
  54. Looks like I have to run a new wire from ignition to the coil..{Not enuf Volts)
  55. how much up and down #s do I get in compression ratio
  56. ordered my th350 and 4200 converter today. Anything special for the swap from 700r4?
  57. big block engine...
  58. ATI Procharger Carbed version questions
  59. Smoking Engine Question
  60. Re: Who makes a double roller for Late model roller cams
  61. Who makes turn-key 400+ ci small blocks
  62. Ramport intake
  63. Hey CarbedC4, can you fit a blower under this hood?
  64. Dragboy?
  65. Getting ready to run again...
  66. Re: Hydra Rev kits(question)
  67. Vortec and a carb?
  68. Chassis Dyno results: Comments?
  69. Clutch noise???
  70. New idea for CarbedC4
  71. Live internet chat this Weds on AFR tuning
  72. Trap door (6) road Race oil pan
  73. Fuel System check valve??? C-4
  74. How much stoke in an L98 block???
  75. performance clutch
  76. WHAT ARE SYMPTOMS OF A BAD COIL?? OR POINTS
  77. My cars problem continues....the update!
  78. Dynomax headers
  79. You'd heard about it, now SEE IT....
  80. Does anyone make shorty (header plugs) for aluminum heads?
  81. Help with Horsepower Plan!
  82. To fill or not to fill???!!!
  83. Will this fit???? T-56 question..
  84. Aftermarket drive shaft 3.5 inch diameter
  85. Eagle Connecting Rods
  86. Which flywheel to use to retro fit an '89 350 into a '70 Vette??
  87. Re: Oil Pan question
  88. All GM gears the same?
  89. Carb Flow Rate Question?
  90. Carb build up...should I?
  91. Valve Springs Too Light?
  92. New to domestic engines...
  93. 4 Valve Heads!
  94. Turbocharger?
  95. Started Ford 9" Solid Axle 4-link project and TH350 from 700R4. easy!
  96. Spark plug cross reference
  97. Oil Temp Gauge Woes
  98. Why upgrade a Strim Vortech to a Ttrim??
  99. Hello?
  100. I HAVE A PROBLEM NEED INFO
  101. Evan waterless coolant
  102. Could I get a Dyno?
  103. Hey Monty>>>
  104. redvetrcr- another dry sump question
  105. Will a big block fit?
  106. Want to change the 350 in my '73 to a 454
  107. Well that's one reason to run an intercooler.
  108. Tall, affordable SB centerbolt valve covers?
  109. Re-Torque the head gaskets question?
  110. Back from the track.
  111. tfs twisted wedge probs with install
  112. lingenfelter or mallett?????
  113. Timing chain question???
  114. Need Help/Advice - Video - LT1, Muffler Elims, 100 Shop, Bad Dyno Run, Is the clutch slipping?
  115. Torx bolts on fuel rail, egr pipe and intake runners - Thanks
  116. Went to the track last night...
  117. horsepower/torque breaking C4 aluminum halfshafts.....
  118. Carb on my 74 350 is getting very hot!!
  119. shorten throw on T-10
  120. Replacing 85 digital dash with autometer white faced gauges. Pics inside
  121. Any Roots blowers that can fit under a cowl hood and make as much power as nitrous??
  122. Carbed C-4
  123. 454 t-stat housing/heater hose/intake question
  124. Vette has big loss of power, cutting out/missing at high rpm and shooting flames out tailpipes!
  125. HELP!!!!!!!
  126. Modifing heads
  127. Decoding Engine Block #'s
  128. Are these headers big enough 1 7/8 Hooker Super Comp, HP Estimations?
  129. Degreeing a cam on install?
  130. I replaced the fuel pump and fuel lines..Still getting a stumble
  131. Dry Sump oil system
  132. Need For Speed
  133. 6 point or 12 point, what is better to use in engine assembly?
  134. Which head gasket to use?
  135. Best Aftermarket Ignition System for a C4??
  136. Say you just bought a 91. What would be the first things you would do?
  137. Correct injector size????
  138. Installing a Line Lock. Hard?
  139. What are some quick mods I can do to my 91's motor?
  140. WTF am I missing here?
  141. Changing From A 350 To A 454 :)
  142. My engine builder wants me to down compression to 9.5 whats up???
  143. Broken crank plus I was lied to. Need your help with new buildup...
  144. Hows this cam
  145. Whats the biggest cam to use and still pass AZ smog?
  146. Whatta Deal!!!!!
  147. New Best E.T. 11.46@123.15
  148. Re: Lingenfelter's solid roller
  149. are these h.p. numbers realistic?
  150. Can suspension crossbrace running above rack/pinion be cut out ????
  151. converted from hydralic to roller cam, distributor will not go all the way in, stick up 1/4" inch?
  152. A/C removal
  153. Building a Monsta 383 Need advice for Optimal cam
  154. Does retarding a CAM from straight up to 2 deg retarded work for 200hp shot nitrous motor?
  155. Surprise... 615.7 RWHP breaks parts!!!
  156. Where o' where can I find this piston?
  157. OK, I have an Intake manifold problem. any help out there?
  158. 3 wire & 4 wire o2 sensor ?
  159. Whats Necessary For Bigger Valves?
  160. Marine Spark Plugs
  161. 69 302 Heads
  162. New Chassis Dyno#'s- 615.7 RWHP!!!
  163. Help, how do i change my front spring on my 85??
  164. Pics - My C4 on draglites and 12.50" slicks and skinnies
  165. Vetrcr87
  166. TEMPORARY fix for leaking seals?
  167. TPIS Long TubeRunners VS Mini-Ram - need assistance
  168. Need help selecting heads
  169. I put an inch and half spacer btw my carb and intake...Will this add Power
  170. Just lucky? Cam hits #6 rod only.
  171. Anyone use a Haltech ECM?
  172. Carburetor question - rich idle.
  173. Side exhaust, loss of HP???
  174. Stronger C4 halfshafts????
  175. Casting Numbers Question
  176. Series 19 Locked & Loaded!
  177. Chandler Arizona Rt. 66 show -- Corvette Forum get together ? (Hooters!)
  178. What does TTT mean???
  179. Who has 383 times/dynos???? I need to know...
  180. Cast VS.Forged Crank
  181. Horn Relay on a 90?
  182. Anyone find an affordable low temp fan switch?
  183. No Exhaust manifold gastet?
  184. Any Hypertech savy here?
  185. C4 - Anyone modified engine harness?
  186. cost to balance & blueprint
  187. If you bore the cylinders 1 over...
  188. Need help choosing valve springs...
  189. Measuring Pistons for stoke & rod length???
  190. Solid advice needed for mods this weekend..new gears,cam change, carb convert
  191. Can anyone help me with DFI tuning?
  192. Which block for a BIG big block? Merlin, Dart, Bowtie?
  193. LT4 Rev Limiter
  194. First post new guy!!!...need some help though, crank is walking!
  195. Transmission problem--Please help
  196. 454 ?s
  197. Why not 150 octane Alcohol???
  198. Help with Paxton Supercharger
  199. Bang for buck?? porting my AFR 190's or selling and switching to AFR 210's??
  200. What is blue printing?
  201. Need help, switching to carb from TPI, what will control shift rpms and redline?
  202. What do you think of putting a Import engine into a Vette?
  203. Octaine/Timing/Boost/Power??????????
  204. hey bowtye8! wanna trade draglites for prostars?
  205. Re:How fast have you gone with a MAF motor?
  206. Re: Lookin for a 350/4bolt for a winter Project
  207. Yup...I found my really, really stupid mistake...
  208. L98 head gskets for sale (link)
  209. LPE 58mm Throttle body for sale (link)
  210. Moving Engine Bores, Partial Block Fill
  211. Where can I get Performance Parts in Calgary & Edmonton?
  212. Switching Heads Dart Iron Eagles for AFR's?
  213. What do you think would help my 1/4 times the most?
  214. 383 went to the track today
  215. Fuel Supply Question
  216. Is your Vette running a fever?
  217. 383 Question
  218. Need help TPI to carb conversion misc parts
  219. The possible return of Merlin
  220. polished intakes?
  221. Does anyone make a tranny brake for 700r4??????
  222. Spark Plugs for S/R Torquer Heads
  223. 1993 LT1 what will my compression be if I mill my heads .030" ??
  224. Bench Racing on a budget.
  225. Advantages/Drawbacks to a Powerglide???
  226. Need changing my weak head Springs...
  227. Anyone had experience with this engine builder?
  228. How long will it take?
  229. Smog engines of the late 70's How do you get more power and keep it legal?
  230. Are these stock BBC heads good?
  231. How much stroke will a GM block take?
  232. 454/425: What's next?
  233. Northstar XV12
  234. EFI to Carb Conversion specifics (help!)
  235. Transgo kit for 4L60E 2K vette
  236. Rachet shifter in a C4
  237. Jacobs Ignition Systems
  238. Looking for an intake recommendation
  239. stand alone o2 sensor?
  240. Dana 44 posi going out ??
  241. LT1 and 350 Turbo
  242. 18 degree heads in c4?
  243. Heads for Chevy 400
  244. electric fuel pump question
  245. LT1 stuff on L98s - might be possible
  246. Undercutting the intake at carb mount-Why?
  247. AFR 190's or CNC heads for LT1? questions?
  248. Has anyone put a L-88 in a C-4?? I would like to know
  249. Help! My new dilemma... Fuelie to carb conversion?
  250. Just Completed Trans Go Shift Kit Install 700R4- One Problem
