View Full Version : Engine Mods
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. Help me build an engine combo
  2. Z Z 502 Oil Pan
  3. cams, cams, cams
  4. Here's what I'm doing...
  5. ECS, again
  6. ****************cosmichrome************* **
  7. 4 pipes all the way back
  8. 540 build, what HP do you think this combo will make
  9. ZZ4 push rods
  10. McJack's Rams Horns?
  11. dart big m block oil pressure
  12. Newbie Needs advice...
  13. Not running smoothly after short restart.
  14. heads/cam question
  15. Will my Oxygen sensor get screwed up with this setup?
  16. GM balanced engine Part II
  17. Results of GM ZZ4 balancing
  18. Is your new block really clean?
  19. Anybody built a C5R 427 with C5R heads?
  20. Tune Port Mod
  21. "How it's Made" filming our engines (Lycoming)
  22. So u wanna guess?
  23. ZZ4 questions
  24. check it out
  25. Hood Clearance Issue
  26. performance and porting BBC heads 702's
  27. cat back system
  28. Dyno numbers on 370ci LT4 w/AFR heads
  29. LT1/4 timing chain slack
  30. tri-power on a zz4?
  31. Take a quick tour of AFR w/ me
  32. Heddman Hedders
  33. Lt1
  34. Cold air intakes, which is best?
  35. Best source for gasket paper?
  36. 430 cu in LS1 at idle
  37. Flywheel for LS2
  38. LS-2 Flywheel Question....
  39. Engine Grounding???
  40. Barry Grant Problems....
  41. Cam install - Does intake need to come off?
  42. Big Block Valvetrain Experts -Step inside...
  43. 406 SBC cam selection & DCR discussion
  44. piston deck height
  45. jojustice C-4
  46. LS7 crank "knifing"
  47. Opinions on clutch kit brands needed
  48. After market heads and Rochester F.I.
  49. ADVANCED DYNO Proudly Announces Facility Expansion! GIANT Thanks To Our Loyal Clients
  50. anyone with zz4 experience
  51. 454 block usability
  52. Hot 350
  53. engine dress up
  54. LS race engine bearing clearance suggestions
  55. NGK Iridium Spark Plugs
  56. Whos Running the Best tranny cooler on the market for my SC Charged vette,
  57. LS-2 Direct port question....
  58. 'Sealing' my polished aluminum manifold
  59. 427 tall deck strikes back!
  60. Chuck CoW - TUNING in TAMPA, FLORIDA @ REV-XTREME
  61. New AFR Eliminator cylinder heads....
  62. 750 Holley bleeds off fuel pressure through vent?
  63. 383, 434 questions
  64. FS: 18* head/414" SB
  65. best overall MODs for a 350 CFI injected C4
  66. Fixing strange oil leak
  67. 1 quart baffeled catch cans, $49.95!!
  68. 440 with 76cc head what compression ratio?
  69. carb jetting
  70. 12 HP gain from springs?
  71. Question about heads?
  72. AFR 205 heads
  73. Help - Too much fuel pressure!
  74. Engine build advice
  75. Valve to piston clearance
  76. 427/435 L89 mods?
  77. Rear end noise .... arghhh
  78. 11.3:1 CR on pump gas?
  79. cryo treatment
  80. patriot-performance anybody know anything about these heads?
  81. Building engine that won't be started for 2 months.
  82. How Much can I Gain w/Headers?
  83. Lsx
  84. Engine combo
  85. I want to build a 9.5:1 355 TBI roller motor for my 95 SUBURBAN
  86. Which heads?
  87. Which stroker rod length?
  88. Measuring Bore Clearance
  89. Help me choose between bottom end or top
  90. Header ?
  91. Carb Guru's,I have an IFR question.
  92. Question about storing a slightly used LS-2 motor...
  93. Pushrod length measuring
  94. Coolant Pressure Modeling
  95. More HP out of my headers !!!!
  96. Aluminum Rectangle Heads vs Cast Oval
  97. What's the story on these rev kits?
  98. Bigger cam?
  99. Carburating a 383 L-98 Engine....
  100. Need advice/info in pursuit of 500rwhp LS1 build
  101. Pushrod length problem
  102. GMPP NA Manifold question....
  103. LS2+QL rockers ++??????
  104. ZZ - 4 Negetives ??
  105. ZZ-4 and Short Water Pump ??
  106. Possible to use an early crank in a late block?
  107. 778 HP Dyno Tuned Fresh 548 $8500
  108. cam for a Vortech blown LT1
  109. 427 Small Block coming together, pics
  110. Cam change
  111. Vote on what to have on the valve corvers of WarHawk Twin Turbo
  112. Cam selection... I need help
  113. what does a .005" do?
  114. Timing Chain Thrust bearing thickness?
  115. zz383 mechanical fuel pump
  116. Help me choose the engine, input needed!
  117. Is it possible to convert to annular discharge boosters?
  118. Finally got my new custom made carb for my new engine
  119. 402 block with ls5 heads
  120. Who makes the best block?
  121. Stud girdles
  122. L-36 hop up
  123. FS: 383 HP 602 HP 532 Torque LS-1 long block
  124. can you Id this cam
  125. dividing my holley 4bbl into 2-2bbls
  126. 383 LS2 thread ?
  127. 350help
  128. zz4 crate motor
  129. Please Help 5.0 Distributor Trouble
  130. ProComp 320cc BBC Aluminum Head
  131. Holley 4160 questions
  132. Small block oil pressure
  133. Interesting Combustion Video
  134. Need to rebuild a 350, tips/tricks/info?
  135. Need more power for a 82
  136. Missing metal
  137. Supercharged LS3 Stroker
  138. when does your carb switch to the booster?
  139. Here's the deal
  140. Rocker Arms
  141. Attention Supercharged & Turbocharged Corvette Owners - Alcohol Injection Systems
  142. Double pumper
  143. dump piston replacement question
  144. 454 BB in C-4?
  145. Anyone with Desktop Dyno willing to plug some numbers?
  146. Manual Valve Body in a 700R
  147. IAC - Idle Air Control & High Initial Idle
  148. IAC - Idle Air Control & High Initial Idle
  149. racing fuel filters
  150. Does anyone know about the for 8.8" rears
  151. Supercharged spark advance question.
  152. Lingenfelter packages
  153. #113 head question
  154. THE OFFICIAL TUNER OF 2007 CORVETTES @ CARLISLE is CORVETTES OF WESTCHESTER
  155. Looking for input for choosing chamber volume or altering piston dome for desired CR
  156. accel wide band question
  157. Mixing/combining engine oil of different weights
  158. stroke the ls2
  159. Fuel injectors. Is one brand better?
  160. Engine Coolant, "shelf life"?
  161. MSD ignition
  162. Mustang motor locked up
  163. Pure White Silicone Hose
  164. Crankshaft grinding??
  165. 540 Cam
  166. Carbed LS2?
  167. Z28 Carb
  168. New Chevrolet R07 NASCAR engine, etc
  169. Going with a bigger cam on my 91'
  170. GM Parts 454HO 425 HP Crate Motor
  171. What are your main bearing clearances?
  172. Changing over Lt1 to carb
  173. Cam selection help
  174. BB Head Volume Unknown
  175. LS-6 w/ Vortech blower streetable?
  176. Best engine mod for my 85
  177. Huge Solid Roller
  178. Am I checking this Lift clearance correctly?
  179. Am I checking this Lift clearance correctly?
  180. Roots blower...Magnacharger/weiand???
  181. 2 questions to engine gurus.
  182. 427 small block?
  183. is bigger better
  184. Off set rocker arms
  185. Intake port question on vortec 906 heads
  186. 4-valve Gen I SBC heads & Weber EFI
  187. should a 383 "shake" or feel off balance at high RPMS in an idle rev?
  188. machine shop costs
  189. Rear main Seal ID ?
  190. Need burnout power
  191. off corvette topic : transmission
  192. LS2 6.0 Liter Question
  193. LS2 6.0 Liter Question
  194. LS2 6.0 Liter Question
  195. Small Block Head Comparison
  196. How does a distributor work?
  197. EnglandGreen Signature Camshafts, now on sale
  198. How much Bob Weights do you have?
  199. 383 Rod Bolt Clearance
  200. Most reliable electric fuel pump? C2 FI
  201. How much oil pressure is too much?
  202. Billy Boat Headers
  203. got afr 195 eliminators help finish the build
  204. 427 L71 & L88 cam events
  205. Ouch!!!
  206. Copper Head Gaskets
  207. Mileage motor... carb questions.
  208. Tap size needed for 90 Vette - Help
  209. Help Needed to Relocate Evap Purge Valve
  210. Anyone heard of a 4340 Flywheel?
  211. Engine "pucks"???
  212. 97 Bonneville SSEi Engine rebuilt problem.
  213. New engine question.
  214. NOS on a C6.
  215. Mod guys, what can I expect?
  216. 2001 SBC Vortec Block
  217. 406, 350 mains or 400 mains?
  218. Generation 1 SBC Timing Chain Cover
  219. Angle milling the cylinderhead
  220. What Big Block Manifolds will clear the stock BB hood???
  221. Corvette heads question in general
  222. Numbers on top of pistons?
  223. possible procharger sale
  224. opinions on engine needed
  225. 406 cam upgrade ?
  226. OEM Powdered Metal Rods - Different Grades?
  227. KwikLift for sale, CHEAP !
  228. ditch cut in exhaust valve
  229. Uh-oh, how bad would this be?!
  230. A6 tranny....
  231. What if I need 2 temp sensors??
  232. Piston ring interchangabliity and questions
  233. c6 question
  234. SAE J604D cam spec????
  235. Injector Question LS7 Intake on C5R heads w/ LS1 wiring.
  236. What RWHP Should I Now Expect
  237. Extra Space
  238. Porting for larger Cross Section
  239. *** ECS Paxton Supercharger - $7695 installed and tuned *** (Florida and SouthEast)
  240. WTK:Holley Rebushing
  241. Finally
  242. GM LSX Tall deck block
  243. Can you identify the manufacturer of this head stud?
  244. Tri Power Manifold Performance Potential
  245. Pre-detonation thought experiment, combustion experts chime in.
  246. Aluminum machinists, please stand up.
  247. 21st Century MC
  248. L92 Block
  249. How to wire new HEI distributor
  250. Considering upgrading my zz4's heads and cam
