View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22
  1. Drive Shaft Loop
  2. 28" ET Street vs 26" ET Drag ...
  3. Need a 28" drag slick on a 16" rim.
  4. It's done, my Vette's gone.
  5. Bill Mitchell Hardcore Engines???
  6. Big block engines
  7. Looking for a 427/454 or BB crate
  8. 350 4 bolt block?
  9. Does this horsepower sound right??
  10. New Tom's 30 spline posi & side yokes
  11. MMMM pretty rods....
  12. Need advice on engine mods
  13. TH-2004R vs TH-700R4
  14. Auto tranny shields ?
  15. With $2k Suggestions 91 L98 that includes switching to carb. Looking for most hp. Non emmision
  16. Q's about Conn. Rods,Performance reason/gains?
  17. Got my 400 today!!
  18. Lingenfelter twin turbo, LS1427 S-15 4x4 truck - March CHP
  19. Changing from 4spd to auto ?
  20. Like a kid in a candy store....which block??
  21. smallblock heads and pressed in studs
  22. In the 50s and 60s what kind of trap speed were these guys getting in the 1/4?
  23. Moon Weber intake for BBC
  24. Cam Question?
  25. SRP piston cc's .. ??
  26. Re:**Opinions wanted about Canfield heads.
  27. Heads for a 350.
  28. L88 air cleaner drop dimension?
  29. Looking to improve midrange power by 50/60 rwhp
  30. Full roller / roller tip rockers vs stock
  31. Early Camaro 1 and 7/8 headers Hooker Super Comps in C4 Corvette.
  32. JE listings?? Mock buildup #2...
  33. DZ 302 engine
  34. Talked to AFR about their new BBC heads today.
  35. Whats the biggest shot of nitrous a car can handle?
  36. Supercharges & belt life?
  37. How to build power?
  38. Which 400?
  39. Fuel system questions
  40. will a edelbrock air gap intake & carb fit in a c-4???
  41. How much can I improve the flow of my BBC RPM Air Gap
  42. Sheet metal intake starter kit??
  43. If you have TNN, watch PHR on Sunday Morning, they are covering Mike Moran's 4 turbo car!
  44. Is it necessary to have a 454 balanced with the Harmonic balancer and flywheel attached
  45. Question for Jake -------------------------->>>>>>>>>
  46. Got my 4L80E yesterday - will it fit? Turbo pistons came in too...
  47. At long last, Series 20 locked & loaded!!
  48. Quite upset right now.
  49. Edelbrock RPM Package Running well for me. (Repost from C3 section)
  50. Lou Gigliotti [Trans Am]speaks his mind on racing, car parts and ... GM!
  51. Desktop Dyno Vs. Engine Analyzer
  52. How much time to pull and install a TPI engine?
  53. I hate to beg ten year project almost done, Desk top dyno help please. Critiques?
  54. Finally fired up the Brodix T1 383...
  55. What flywheel for a 400 with a ZF-6???
  56. MOTOWN BLOCK ?
  57. Buy those bulletproof bellhousing. Its worth it.
  58. Engine Rebuild Recomendations Needed!
  59. How much does a 400 block and a new steel crank weigh?
  60. How hard to fit standard headers to raised port heads?
  61. Misc. BBC head questions
  62. I am getting a stall convertor..Anyone recommend one??
  63. Engine ID?
  64. Exhaust gasket recommendation
  65. FS:LT1 HEADS PORTED
  66. flywheel/pressure plate installation
  67. Anyone with a desktop dyno
  68. [L98]: How much lift before piston modification?
  69. ZZ4 Cam In an LT1-Question about cam and Opti-Spark
  70. Time to fire it.
  71. Re: AFR 210's
  72. Casting number on my heads... what can you tell me about them?
  73. What carb intakes will fit on the 87 and up aluminum heads????
  74. [Fuel Rail Fittings AGAIN]: What size IS this thing?
  75. Engine Runs on and spits through front emulsion tube of holley carb
  76. is a rollercam set up better than a a regular cam?
  77. Block Cleaning Question
  78. What can a Speed Pro b-to-b do that the Holley can't?
  79. GM HD timing chain set
  80. Valve Cover DImensions
  81. valve cover 5/8" breather hose
  82. Jaguar XJS with 350
  83. Re:Question about quench area
  84. slim line valve seals
  85. L98 bottom end
  86. Doing a engine swap.
  87. Different headers needed or not
  88. How 'bout a "Super Sucker"?
  89. what is the cam limitof myL98?
  90. Looking for more RWHP from N/A 350 LT1
  91. My wife didn't want me to drink all the wine on Christmas eve.
  92. Santa delivered my roll cage this afternoon!
  93. Hot Rockers
  94. Re: Question about cam install
  95. Happy Holidays!
  96. 406 SBC cracked block repairs
  97. What goop for stainless steel header bolts into aluminum heads?
  98. Header or Peanut spark plugs ?
  99. Re: MSD part# for our distirbutor
  100. Re: AFR build quality is disapointing
  101. Oil blowby problem on built Poncho motor
  102. drive shaft vibration with my new 700r4
  103. Edelbrock NOS manifold!
  104. Does anybody have a picture of the SpeedPro CCom dashboard?
  105. Ls1tech.com:
  106. Hays Lightwieght Flywheel
  107. speed-o-motive
  108. Which Plug for Supercharged LT-1?
  109. updated my Webpage
  110. Power question- need your help
  111. Callaway Headers/ CARB certification
  112. program computer
  113. Machine Shops in the Houston Area?
  114. 6in rod 350
  115. piston interchange
  116. Holley 950 ECM looking better than the Accel 6 ECM
  117. Lt1/Lt4 igniton and MSD
  118. Need some ideas from Carbed L98 owners.
  119. CNC Ported L98 heads cost more than CNC Ported LS1 heads...holy cow!!!!!!!!!!!!!!!!!!!!!
  120. Lightweight Rods?
  121. Engine Break-In ?
  122. Accel DFI ProRam or Holley Commander 950?
  123. Questions for Monty and others with aftermarket Fuel Injection
  124. Anyone install a Ramjet 350 in their C3?
  125. New Holley TB with Nitrous Passages
  126. getting LT-1 heads tomorrow.....Anyone run them??
  127. timing chain set question ?
  128. AFR heads and valve springs
  129. What is my original L-36 with tranny worth to sell
  130. Need opinions on which package to purchase
  131. Rotating assembly balancing
  132. L88 Power Valves?
  133. May be selling my car check it out under C3 for sale....
  134. zz4 shortblock w/ AFR 190 heads...
  135. 85 computer switch to an 89
  136. I know who Santa Clause really is...and he drives a big brown truck!
  137. Where are the cubes?
  138. Pushrods
  139. Good book to learn about EFI?
  140. [Super Charging]: Carroll Stage-3 Info?
  141. Scat- spend cash or trash?
  142. LT1 Heads/LT1 rebuild
  143. 407 small block out of a 350 block?
  144. Guys.. I need some Advice on what to do with this offer... Thanks!
  145. 347 questions
  146. Monty: '70 Z28 TwinTurbo...
  147. High torque manual trans -- Which clutch?
  148. New 383 : Should I get a Scatter shield Bell housing??
  149. IS A ZZ-4 THE BEST BANG FOR MY BUCK?
  150. Anyone running a Procharger supercharger with a carb?
  151. All you 350 to 383er's
  152. WTB:AFR 227
  153. New Combo being Finalized
  154. This is getting ridiculous
  155. Update on 5 point seats & 8 point roll cage
  156. Which 18* heads will work with the MiniRam & SuperRam?
  157. New exhaust valves
  158. Merlin II vs. Dart Big 'M' block
  159. taken for a ride by tfs what a bunch of jokes
  160. Northstar xv12
  161. marine heads?
  162. Stud Girdle for LT1
  163. Thoughts On Engine Combination...
  164. Holley original jet specs.
  165. I've decided on engine combination...
  166. Need Advice On Solid Roller Cam Selection
  167. Well i did more reading on this iron vs. aluminum business.....
  168. Torque specs for Brodix heads
  169. Need some help with rebuild parts!! PLEASE! :)
  170. TITANIUM PUSHRODS?? to make hyd.roller rev!!
  171. Turning over after ignition is "OFF"
  172. Sanderson Exhaust Manifolds(pic's)
  173. What do you think of this zz4?? 506HP!!
  174. Check out my AVATAR
  175. Need help where did I go wrong mustang kicking me
  176. 3,5" Aluminium tubing and bends.Where????
  177. What is safe redline for this engine?
  178. help me with my compression!
  179. POWERade Becomes New Title Sponsor Of NHRA
  180. How can you tell if its a 400 block?
  181. 1 5/8 or 1 3/4?
  182. ZL1 short block/crate motor?
  183. Smog pump to Vacuum pump conversion???
  184. AFR 227 Compiton ported race heads
  185. LS6 Engine Plan / Schematic ?
  186. Hitting the track tomorrow and need some quick help!
  187. Race 15" wheels on a C4???
  188. 383 stroker question for Texans (and everyone else)
  189. Road Demon
  190. Drivability of XE274 Comp Cam
  191. What would you do?
  192. Detroit Area Dyno Day
  193. Sources for 327 mods?
  194. Can i get an opinon?
  195. How to adjust carb for very rich condition?
  196. What are AFR 190's limits?
  197. Engine-from Scratch Options....
  198. Beach Bum & other drag racers
  199. Rad Rods by Troy
  200. EGR HEAT TUBE
  201. 406 buildup
  202. Need some pointers
  203. what heads will work with the super ram?
  204. AFR 190s good for a 327????
  205. RWHP from ET calculator?
  206. Twin Turbo project - task one completed
  207. Porting Intake Manifold or buy new?
  208. Which intake for a SB 69 383?
  209. Mods to 1979 - L48
  210. belts and pulley problem???
  211. 5.3 engine problems
  212. 5 Point Seats.
  213. Aluminum rods???
  214. Machine work for 383.
  215. VALVE SPRING QUESTION
  216. What's the difference between the Camaro 5.7 TPI and the Corvette 5.7 TPI?
  217. the Ultimate 4L80-E Automatic ???
  218. To block or not to block?
  219. what should it cost...
  220. 1980 L48 performance questions
  221. CAN ANYONE HELP IDENTIFY THESE HIGH PERFORMANCE PIECES?
  222. Increasing compression, need new heads?
  223. Winter's here, next mod underway - turbo's baby!
  224. Time for a 406, what to do?
  225. SDPC tpi and fastburn heads??
  226. restricted engine builder
  227. \\Happy Thanksgiving to all, Did you drive your Vette today? or the other Car//
  228. Headers?
  229. Monty, Jake.... others. fuel injectors ?
  230. Anyone ever heard of Budd Performance? Can't find them.
  231. Installed my MSD Digital 6+
  232. hey, anybody know (ALDL)...
  233. its ALIVE!!!!
  234. Roller rockers..
  235. Does anyone have any experience with the Accel Pro Ram?
  236. Holley 4150-4160 whats the difference?
  237. Mini-Starter wiring in 67 Vet
  238. Update on smoking engine
  239. 12.18@116.88 Street Tires
  240. New best time
  241. MAF to Stock Air Bridge Coupler for C5
  242. BIG TIRES + stock clutch = blue smoke!!
  243. Does ANYONE make a scatter shield for 6sp C4's???
  244. Before & After 3" exhaust test.
  245. Parts needed for a 600+hp supercharged 355 small block
  246. Re: Whats a good cam for 500HP+
  247. Who's using AFR 210cc heads?
  248. Stock "Camel Hump" flow?
  249. So long Art Carr trans
  250. Mea Culpa...
