View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21
  1. Midrange Horsepower Increase. Lingenfelter Vs AFR LT4 heads.
  2. Deciding between LS1 and RamJet 502....
  3. I'M new here, and need this question answered. ITS SO ANNOYING!
  4. How to find specs on a camshaft?
  5. Marshall Engines
  6. Got my Twin Turbo stuff today.. trial fitting!
  7. Check out this twin turbo Superram motor - cool.
  8. What would be the best gear for a street/highway combo??
  9. Open Diff to Posi for my 1960 what other Chevy units will swap out?
  10. Intake manifold w/ Demon 750.
  11. Static v. Running Compression
  12. supercharger installion complete now ?
  13. 74 Semi-Pro Tourer
  14. "The Dude's Results ? "
  15. Re: Solid roller valve train ?
  16. Re: How much compression can you go with a S/Charger?
  17. Question about 400 sbc
  18. Serious upgrade for my '71
  19. Can somebody rec. a nitrous kit for my '85 Corvette?
  20. Series 21 Locked & Loaded!
  21. A killer supercharger motor on CamaroZ28.com being built...
  22. cylinder heads HELP!
  23. DFI owners help! Computer crashed lost my program!!!
  24. Bore/Stroke of an Impala 409?
  25. Engine Builder????
  26. Firing Order??? 255 slant 6
  27. Nitrous Basics
  28. [update] 492 heads
  29. Dart block recommendations???
  30. Lets talk blower...
  31. Canfeild heads/ Please look over this flow sheet and tell me what carb/cam to run with it.
  32. 400 ci with a TPI???
  33. Mowtown II or Dart Block?
  34. Exhaust manifolds for a 383 winter makeover
  35. 9" of vacuum???
  36. Custom Fuel Injection Systems
  37. Rear End shops in Maryland/VA/DC area
  38. What size primaries (exhaust) ?
  39. Sprotsman II heads
  40. Nos and TURBO??
  41. Looking for a performance graph of a stock L72
  42. vaccum and forced induction
  43. 700 kickdown!
  44. Small Block Stroker Advice Needed
  45. AVBlend
  46. Drive Shaft Loop
  47. 28" ET Street vs 26" ET Drag ...
  48. Need a 28" drag slick on a 16" rim.
  49. It's done, my Vette's gone.
  50. Bill Mitchell Hardcore Engines???
  51. Big block engines
  52. Looking for a 427/454 or BB crate
  53. 350 4 bolt block?
  54. Does this horsepower sound right??
  55. New Tom's 30 spline posi & side yokes
  56. MMMM pretty rods....
  57. Need advice on engine mods
  58. TH-2004R vs TH-700R4
  59. Auto tranny shields ?
  60. With $2k Suggestions 91 L98 that includes switching to carb. Looking for most hp. Non emmision
  61. Q's about Conn. Rods,Performance reason/gains?
  62. Got my 400 today!!
  63. Lingenfelter twin turbo, LS1427 S-15 4x4 truck - March CHP
  64. Changing from 4spd to auto ?
  65. Like a kid in a candy store....which block??
  66. smallblock heads and pressed in studs
  67. In the 50s and 60s what kind of trap speed were these guys getting in the 1/4?
  68. Moon Weber intake for BBC
  69. Cam Question?
  70. SRP piston cc's .. ??
  71. Re:**Opinions wanted about Canfield heads.
  72. Heads for a 350.
  73. L88 air cleaner drop dimension?
  74. Looking to improve midrange power by 50/60 rwhp
  75. Full roller / roller tip rockers vs stock
  76. Early Camaro 1 and 7/8 headers Hooker Super Comps in C4 Corvette.
  77. JE listings?? Mock buildup #2...
  78. DZ 302 engine
  79. Talked to AFR about their new BBC heads today.
  80. Whats the biggest shot of nitrous a car can handle?
  81. Supercharges & belt life?
  82. How to build power?
  83. Which 400?
  84. Fuel system questions
  85. will a edelbrock air gap intake & carb fit in a c-4???
  86. How much can I improve the flow of my BBC RPM Air Gap
  87. Sheet metal intake starter kit??
  88. If you have TNN, watch PHR on Sunday Morning, they are covering Mike Moran's 4 turbo car!
  89. Is it necessary to have a 454 balanced with the Harmonic balancer and flywheel attached
  90. Question for Jake -------------------------->>>>>>>>>
  91. Got my 4L80E yesterday - will it fit? Turbo pistons came in too...
  92. At long last, Series 20 locked & loaded!!
  93. Quite upset right now.
  94. Edelbrock RPM Package Running well for me. (Repost from C3 section)
  95. Lou Gigliotti [Trans Am]speaks his mind on racing, car parts and ... GM!
  96. Desktop Dyno Vs. Engine Analyzer
  97. How much time to pull and install a TPI engine?
  98. I hate to beg ten year project almost done, Desk top dyno help please. Critiques?
  99. Finally fired up the Brodix T1 383...
  100. What flywheel for a 400 with a ZF-6???
  101. MOTOWN BLOCK ?
  102. Buy those bulletproof bellhousing. Its worth it.
  103. Engine Rebuild Recomendations Needed!
  104. How much does a 400 block and a new steel crank weigh?
  105. How hard to fit standard headers to raised port heads?
  106. Misc. BBC head questions
  107. I am getting a stall convertor..Anyone recommend one??
  108. Engine ID?
  109. Exhaust gasket recommendation
  110. FS:LT1 HEADS PORTED
  111. flywheel/pressure plate installation
  112. Anyone with a desktop dyno
  113. [L98]: How much lift before piston modification?
  114. ZZ4 Cam In an LT1-Question about cam and Opti-Spark
  115. Time to fire it.
  116. Re: AFR 210's
  117. Casting number on my heads... what can you tell me about them?
  118. What carb intakes will fit on the 87 and up aluminum heads????
  119. [Fuel Rail Fittings AGAIN]: What size IS this thing?
  120. Engine Runs on and spits through front emulsion tube of holley carb
  121. is a rollercam set up better than a a regular cam?
  122. Block Cleaning Question
  123. What can a Speed Pro b-to-b do that the Holley can't?
  124. GM HD timing chain set
  125. Valve Cover DImensions
  126. valve cover 5/8" breather hose
  127. Jaguar XJS with 350
  128. Re:Question about quench area
  129. slim line valve seals
  130. L98 bottom end
  131. Doing a engine swap.
  132. Different headers needed or not
  133. How 'bout a "Super Sucker"?
  134. what is the cam limitof myL98?
  135. Looking for more RWHP from N/A 350 LT1
  136. My wife didn't want me to drink all the wine on Christmas eve.
  137. Santa delivered my roll cage this afternoon!
  138. Hot Rockers
  139. Re: Question about cam install
  140. Happy Holidays!
  141. 406 SBC cracked block repairs
  142. What goop for stainless steel header bolts into aluminum heads?
  143. Header or Peanut spark plugs ?
  144. Re: MSD part# for our distirbutor
  145. Re: AFR build quality is disapointing
  146. Oil blowby problem on built Poncho motor
  147. drive shaft vibration with my new 700r4
  148. Edelbrock NOS manifold!
  149. Does anybody have a picture of the SpeedPro CCom dashboard?
  150. Ls1tech.com:
  151. Hays Lightwieght Flywheel
  152. speed-o-motive
  153. Which Plug for Supercharged LT-1?
  154. updated my Webpage
  155. Power question- need your help
  156. Callaway Headers/ CARB certification
  157. program computer
  158. Machine Shops in the Houston Area?
  159. 6in rod 350
  160. piston interchange
  161. Holley 950 ECM looking better than the Accel 6 ECM
  162. Lt1/Lt4 igniton and MSD
  163. Need some ideas from Carbed L98 owners.
  164. CNC Ported L98 heads cost more than CNC Ported LS1 heads...holy cow!!!!!!!!!!!!!!!!!!!!!
  165. Lightweight Rods?
  166. Engine Break-In ?
  167. Accel DFI ProRam or Holley Commander 950?
  168. Questions for Monty and others with aftermarket Fuel Injection
  169. Anyone install a Ramjet 350 in their C3?
  170. New Holley TB with Nitrous Passages
  171. getting LT-1 heads tomorrow.....Anyone run them??
  172. timing chain set question ?
  173. AFR heads and valve springs
  174. What is my original L-36 with tranny worth to sell
  175. Need opinions on which package to purchase
  176. Rotating assembly balancing
  177. L88 Power Valves?
  178. May be selling my car check it out under C3 for sale....
  179. zz4 shortblock w/ AFR 190 heads...
  180. 85 computer switch to an 89
  181. I know who Santa Clause really is...and he drives a big brown truck!
  182. Where are the cubes?
  183. Pushrods
  184. Good book to learn about EFI?
  185. [Super Charging]: Carroll Stage-3 Info?
  186. Scat- spend cash or trash?
  187. LT1 Heads/LT1 rebuild
  188. 407 small block out of a 350 block?
  189. Guys.. I need some Advice on what to do with this offer... Thanks!
  190. 347 questions
  191. Monty: '70 Z28 TwinTurbo...
  192. High torque manual trans -- Which clutch?
  193. New 383 : Should I get a Scatter shield Bell housing??
  194. IS A ZZ-4 THE BEST BANG FOR MY BUCK?
  195. Anyone running a Procharger supercharger with a carb?
  196. All you 350 to 383er's
  197. WTB:AFR 227
  198. New Combo being Finalized
  199. This is getting ridiculous
  200. Update on 5 point seats & 8 point roll cage
  201. Which 18* heads will work with the MiniRam & SuperRam?
  202. New exhaust valves
  203. Merlin II vs. Dart Big 'M' block
  204. taken for a ride by tfs what a bunch of jokes
  205. Northstar xv12
  206. marine heads?
  207. Stud Girdle for LT1
  208. Thoughts On Engine Combination...
  209. Holley original jet specs.
  210. I've decided on engine combination...
  211. Need Advice On Solid Roller Cam Selection
  212. Well i did more reading on this iron vs. aluminum business.....
  213. Torque specs for Brodix heads
  214. Need some help with rebuild parts!! PLEASE! :)
  215. TITANIUM PUSHRODS?? to make hyd.roller rev!!
  216. Turning over after ignition is "OFF"
  217. Sanderson Exhaust Manifolds(pic's)
  218. What do you think of this zz4?? 506HP!!
  219. Check out my AVATAR
  220. Need help where did I go wrong mustang kicking me
  221. 3,5" Aluminium tubing and bends.Where????
  222. What is safe redline for this engine?
  223. help me with my compression!
  224. POWERade Becomes New Title Sponsor Of NHRA
  225. How can you tell if its a 400 block?
  226. 1 5/8 or 1 3/4?
  227. ZL1 short block/crate motor?
  228. Smog pump to Vacuum pump conversion???
  229. AFR 227 Compiton ported race heads
  230. LS6 Engine Plan / Schematic ?
  231. Hitting the track tomorrow and need some quick help!
  232. Race 15" wheels on a C4???
  233. 383 stroker question for Texans (and everyone else)
  234. Road Demon
  235. Drivability of XE274 Comp Cam
  236. What would you do?
  237. Detroit Area Dyno Day
  238. Sources for 327 mods?
  239. Can i get an opinon?
  240. How to adjust carb for very rich condition?
  241. What are AFR 190's limits?
  242. Engine-from Scratch Options....
  243. Beach Bum & other drag racers
  244. Rad Rods by Troy
  245. EGR HEAT TUBE
  246. 406 buildup
  247. Need some pointers
  248. what heads will work with the super ram?
  249. AFR 190s good for a 327????
  250. RWHP from ET calculator?
