View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22
  1. Hate leaks... Is it possible to use 1piece rear main seal crank in older block???
  2. Any Chassis Dyno Operators out there? Statistics...
  3. Which BB flywheel should I get?
  4. Merlin777 – A Sneak Preview
  5. fuel pressure help
  6. Blower motor
  7. bcwaller, please expose your camshaft
  8. Need your ignition opinions.
  9. SBC cooling system mods.. recommendations
  10. Aftermarket MAFs...Worth Power Increase?
  11. Re: Cooling Fans, anyone know of an upgrade for a C4?
  12. Dyno'd my 383, Need opinions/Help with the Tune.
  13. Best HP estimate?
  14. How many miles on your REBUILT motor.
  15. Off topic, but you guys know this stuff! Help me out with my driver please
  16. Drove a '72 Panterra the other day...another love hate car.
  17. Mcloed Street Twin got vibration(95Vetteski) any thought?
  18. Any suggestions ? or thoughts
  19. Need some opinions on cam selection
  20. Flywheel needed to balance?
  21. Question on LT1 balancing & symptoms
  22. Valve Stem Seals on BB
  23. twin TURBO crate engines now available!
  24. Pushrod Alignment Concerns
  25. Jegs CNC ported heads?
  26. TBI Intake on a '69 350
  27. Eletric VS mech fuelpump..
  28. porting/gasket matching my super ram. what did you do in this area?
  29. Indirect Vette motor question
  30. Best place to buy an LT-1 bare block?
  31. solid roller
  32. 383 vs 396
  33. Link to engine block casting #s?
  34. 400 sbc....what do i need
  35. which guages are the best??
  36. my distributor does not go all the way in....HELP!!!!!!!!!!!!!!!!!
  37. Question about solid rollers
  38. ? about Intake Runner Sizing
  39. Changing to 1.6 roller rockers,Clearance problems???
  40. Here's somthing for the curios
  41. (Non Engine Queston) 87 Corvette manster Cylinder Question.
  42. Machine shop called today.
  43. cam specs confusion
  44. How do you like this car? Not a Corvette!!
  45. Other than keeping an eye on lash do solid rollers wear out faster than hydraulic rollers.
  46. Turn key engines
  47. Can spark plug gap change hp?
  48. Seeking reference material for first upgrade
  49. Not engine mod but rear gear question.
  50. Dyno Results - Twin Turbo SBC 427
  51. going from flat tappet cam to hydraulic roller
  52. What do I have???? SBC parts
  53. How Good Are The AFR 195s?????
  54. Crazy MAP readings...HELP!!
  55. Pistons: Compression ratio differences.
  56. are 305 rods and 350 rods the same?
  57. TB butterfly sticking
  58. I installed Lars' HEI recurve kit this weekend...
  59. LS6 Big Block Questions...
  60. (L31)Vortec Block
  61. Bill Mitchell Short-blocks?
  62. Deltagate 2 wastegates???
  63. Blocking the Oil Filter Relief Valve on a LT1/LT4?
  64. Twin Turbo SBC 427 Dyno Session Results
  65. GA tunner needed
  66. More advanced initial timing if using Lower CR Pistons ??
  67. 2 major mistakes tody on the hotcam install
  68. 383 build up....
  69. Looking for Corvette Show Vendors in GA.
  70. Airbox for Blackwing
  71. LT4 Head Gasket Thickness?
  72. Replace CAM and Still be NCCC Group II?
  73. C4 Headers for Dart Pro's ???
  74. [WTB-OT] KB231 piston, any builders have a 'spare'?
  75. found a late model block, good deal?
  76. Altitude and ignition advance question.
  77. TRW Piston Website?
  78. New dyno numbers with nitrous.
  79. Where to get header tubing?
  80. What about these cam specs....
  81. Any real life street experiences with aluminium flywheel???
  82. Anybody have their own flowbench??
  83. How much parasitic loss from flywheel to rear wheels?
  84. CNC Cylinder Heads-Any Experience-Specifically LT4?
  85. [Cam Experts] What do ya think of this grind?...
  86. quasi-stupid question about valve train height
  87. Crate engine internal parts?
  88. Anti-seeze on Aluminum AN fittings?
  89. Head question.
  90. 500 HP LT1, stay n/a or supercharge?
  91. Cylinder Pressure for a Street Engine
  92. What is the difference between a original Torker and TM-1 Intake??
  93. For anyone with a Richmond 6 speed, you might want to check out my post in the c3 section
  94. Drove a friends 1075 (rwhp) Camaro today
  95. Help...Centerbolt valvecovers to fit BIG roller rockers
  96. Can some one w/ desktop dyno help me
  97. What's a ZZ4 look like?
  98. Has anybody every?
  99. Lou G. is leaving the Trans Am series
  100. I Quart or oil every 500 miles, excessive?
  101. How far can you go with a stock 427!!!
  102. TPI/EFI on a ZZ4?
  103. For Sale : BB Speed Pro Pistons with GM rods - exc. cond
  104. Anti-seize on head bolts?
  105. Update on Heads Milled / Compression Question:
  106. Are all valve springs created equal ?
  107. Bunch of 383 questions... strenghts, air flow, etc.
  108. Ultimate Dana 60 IRS, Maybe I can't break it!
  109. building a 377 stroker, need connectnig rod info!
  110. Supercharging a SR problem
  111. 383 kits; best quality?
  112. grinding on heads/block for increased oil drain back
  113. Rear End Questions?
  114. More Help needed
  115. Nitrous on my carbed '81 questions
  116. 383 crankshaft description, your opinions wanted
  117. The new motor is awsome
  118. Help CAN"T GET IT TO RUN!@)($()@#
  119. GM Bowtie Aluminum or Iron Bowtie block?
  120. Best forged crank for a SC?
  121. Just curious about x-pipes and HP
  122. Best Aluminum heads without raised ports
  123. Twisted Wedge vs. Sportsman II
  124. Are Edelbrock Performer RPM heads suitable for a 383?
  125. Cam install question
  126. Supercharged 350 HP questions
  127. How to get more power?
  128. Bowtie Heads vs Vortec
  129. Words to live by...for choosing a cam.
  130. Top end rebuild
  131. manifold gasket with supercharger
  132. suggestions for project engine
  133. Tech Tip--FWIW
  134. LT1/4 Block Source?
  135. Drove my TT Vett on the highway today.
  136. A little more progress - I should be dyno testing the TT SBC 427 next weekend
  137. Big Cube Small Blocks, how much of....
  138. Help, the 427 from hell!
  139. Sportsman 2's
  140. Anybody know anything about moroso distributors?
  141. Need info on "370" heads
  142. Fired up my 383 and have a few concerns
  143. Idle speed problems / Vaccum routing question on big solid lifter motor
  144. Breaking in used hyd. flat tappet cam
  145. Block decking ?
  146. Safe sustained RPM for stock ls6 pistons and rods & bottom
  147. Misc. Motor Questions
  148. Alum 350
  149. LT1 or large journal 3/8" bolt RODS?????
  150. Being raped by an exhaust shop
  151. Piece-by-piece hobby build of a 350 SB...
  152. anyone need an LS6 motor, found one on Ebay!!!!
  153. Dual K&N vs. Blackwing
  154. holley expert please
  155. Richmond 6 speed
  156. Q-Jet Rods/Jets. What size are you using?
  157. 305 heads on 350? kind of long, but i need your help.
  158. Anyone need an engine block?
  159. Check out this new fuel injection controller...
  160. Will you sell me your used Vaccuum Pump please ??!
  161. Two quick q's: Mini-starter and March serp setup
  162. *** Here's my dyno sheets, what do you think? ***
  163. C4 fuel line question?
  164. Anyone reliably getting 7000RPM out of a Hyd Roller?
  165. good article on carb tuning
  166. Reciprocating Weight
  167. Torq Thrust II's with a twist?
  168. Cooling problems on pretty hairy small block
  169. MiniRam help needed!
  170. batch fire to sequential fuel injection
  171. LT1 and LT4 cam specs?
  172. carb c4
  173. Second Newbie question
  174. Probably the ultimate intellectual newbie question (long)
  175. Where to find 400 SBC?
  176. rod question
  177. i finally have my 383 stroker up & running!!!
  178. GM 482 flow numbers?
  179. Heads milled and compression question..... Fel Pro stuff too
  180. Fel-Pro 1094 head gasket - is sealant required?
  181. Setting Valve lash
  182. Where can I get a Lincoln jack in Southern California?!
  183. predator carburetor
  184. HELP! my vette (1980) just shuts off while driving :(
  185. Lost my favorite sites!
  186. Which vacuum connections require a check-valve?
  187. Why does an L98 Throttle Body have a vacuum connection?
  188. Pre-oil direction
  189. How long did it take your engine builder to port your heads & build your engine?
  190. What is the least amount of manifold vaccuum , a brake booster will operat on??
  191. Valve spring requirements
  192. 400 small block
  193. Which bearings to get ? : Clevite 77 or Federal Mogul
  194. ! piston on a compression test shows 30 psi!
  195. The poor thing, if it only knew what was in store for it...
  196. Three foot flame from the top of the carb! Should I worry?
  197. Porting a miniram
  198. Just been told that '86 exhaust manifolds would be better on my 72 sb stroker????
  199. Vacuum hookups for 6-71 blower applications.
  200. What cam to use?
  201. Leak down?
  202. Finally made a head purchase!
  203. Oiling problem...
  204. Cam basics 101
  205. Shopping for a new crank.
  206. How do late C3 and newer modified engine owners handle inspection?
  207. Does anyone make an ELECTRIC vaccuum pump ???
  208. what do I need for Nitrous while motor is out?
  209. [Help] Too much rod movement bow to stern, bearing wear
  210. Should I take off Cat or put on Hi Po Mufflers on 1st???
  211. OH MY GOD...I'M SPEECHLESS....WHAT THA....
  212. scattershield/driveshaft safety loop for 6 speed
  213. Need cam help!!!!
  214. C3 with a stock 87' vette engne. More power, please!
  215. CAR WONT MOVE IN ANY GEAR? TORQUE CONVERTER?? HELP?
  216. Ultima component car
  217. i want my 84 to go !!!
  218. Need ideas for TB on project w/ fellow forum member
  219. Computer Aided Header Design
  220. High idle problem with a new Holley Street Avenger - HELP!
  221. [Noise]: Lets play the game of....
  222. DD2000 predictions...
  223. Head flow numbers...what would this get me?
  224. WANTED : FORD 460 Big Block "385" Family
  225. Heads, I'm in a pinch
  226. c3 bad vibrationsss , no i am not talking about the beach boy
  227. Need (C4) LT1 header suggestions
  228. 1050 HP on Pump gas....
  229. Engine rebuild ?
  230. Oil pressure problem after rebuild on '71 454
  231. We ordered my turbo cam today, it's bigger than I woulda' thought.
  232. Octane Question
  233. What is the difference between internally & externally balanced engines?
  234. Anyone ever break a camshaft?
  235. Question about AFR Heads
  236. Dynojet vs. Mustang?
  237. LPE 427 TT vs F/A-18 Hornet on Motortrend TV - SpeedVision
  238. Gains on porting heads
  239. If it's metal, polish it?
  240. CorvetteRadios.Com, Just wanted to say "Happy Mother's Day" to all Corvette owner
  241. Anyone here seen AFR competition ported heads? I have my AFR 190 apart Q's /w in
  242. chevy rods?
  243. How to replace seat cushions in a '70-'82?
  244. How to identify a Bowtie block?
  245. Petronix "Flame Thrower"
  246. Solution for totalperformance !!!!!!! :):)
  247. Head Gasket Recomendation
  248. The LS-1 Lives!
  249. Anyone got any tips/hints for polishing stainless steel?
  250. Now I have seen it all part II
