View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22
  1. 2 piece timing cover?
  2. Finally..a Corvette the dyno's above 300rwhp!!
  3. need some help. oil is coming out the top of my dipstick!
  4. Who is familiar with Clievite 77 H-Series bearings?
  5. Damaged sleeve in a 427C5R block. Any suggestions what to do?
  6. [Paging]: Monty, need some input.
  7. mod car insurance?
  8. 4* cam advance... to do or not to do..
  9. nitrided 1182 350 crank
  10. Drove my Corvette for the 1st time in a year today...not as fast as it should be.
  11. cc306 cam in a 396
  12. Tire smoker, or Dud?
  13. Reading header glow for tuning
  14. 305 head update: good news and bad news
  15. What are Splayed main caps
  16. A little string music please, then I need some suggestions (LONG POST)
  17. Should I o-ring????
  18. F/S: Ultralight Crower 3.50 stroke crank and 6" titanium rods
  19. Nitrous on 10.5?
  20. Can Someone PLEEZ Run These Heads.......
  21. Quick cubic inch question.
  22. [Help]: 4-bolt 350 main cap torque specs?
  23. TB/intake recommendations for supercharged 383?
  24. ok...so im considering raising the cam...
  25. Can a LQ9 6.0 liter ironblock be safely bored to .060 naturaly aspirated application.
  26. Need clearances and advice on first engine build.
  27. e-bay??
  28. Radiator Hose or hard Radiator Pipe?
  29. cryptonite crank? what is it?
  30. Holley Commander 950?
  31. Bulletproof Rear (pics)
  32. anyone put flowmasters on a mid year?
  33. ZZ4 Motor mounts??
  34. My +.030" over-bored block is actually more like 4.035"
  35. lean engine problem
  36. Modifying Intake for Port Injection
  37. Sportman II's vs. AFR 190cc
  38. Rebuilding engine, what should I get done ?
  39. Yet again...another what cam? and other stuff...
  40. Which long tube headers to get ?
  41. Best place to buy a complete 383 kit?
  42. Help! Valve Stem Lock stuck
  43. 11:12 at 122 mph with a superram and mas air
  44. Good engine parts seriously cheap on eBay! Why?
  45. Can you Rate these heads
  46. Electric choke for Quadrajet?
  47. Bad Ash Motor pics
  48. Serpentine belt question ofr C3
  49. ported vac switch bypass on intake manifold
  50. Picking a Distributor and Carburetor
  51. A newbie from Russia needs your help (~600HP needed)...
  52. 8-stack EFI (gulp)
  53. Looking for a good 350 ->383 build up.
  54. Single Turbo for the LS1 Camaro
  55. How choked will I be with bigger CI?
  56. What do you think about these heads for my 85?
  57. Dyno question if anyone knows
  58. my 383 smokes a little when i hammer it
  59. 1st gen engine: spring lock valve seals or not? to splash sheild or not to splash sheild?
  60. L98 Water/Cooling system question
  61. Ok engine gurus: I need some advice. (sorry, long)
  62. Engine casting number
  63. NEW DYNO NUMBERS
  64. against all your previous advise, i'm doing it. i'm putting 305 heads on....
  65. Scat 9000 Crankshafts.
  66. 6.00" rod, what to do to maintain current camshaft?
  67. Why is my buddies 540 eating lifters and breaking valve springs
  68. Disappointing test results from C5 tuner cars...
  69. I need some names of comapnies that build engines.
  70. HELP secondaries aren't opening on edelbrock performer...
  71. Stick with the LT1 or something else??
  72. ZZ4 Complete Crate Engine Base Price?
  73. Vortec with Z06 valve spring
  74. vortec heads???
  75. Info Needed on '96-98 GM 350ci engines.
  76. Seal for oil dip stick tube
  77. Piston/wrist pin slightly binding. Is this OK?
  78. PCV Question. (fast response please :)
  79. intake runner volume size
  80. is there [i] really [/i] a difference in hydraulic lifters?
  81. 400 block question
  82. McLeod has changed the Street Twin somewhat
  83. Anyone know anything about Kinsler intakes?
  84. MSD Knock Sensor - Any experience?
  85. need a late model roller small block
  86. Anyone have the Dart website address?
  87. 383 Break In Procedures.
  88. Spun a bearing, need an engine, help!
  89. How much HP/RPM is this bottom end good for?
  90. Seperating rods to install on crankshaft
  91. Oil pan selection
  92. FYI - Some misc Chevy head info i found today: Part #'s & desctription etc
  93. New Mellings oil pump---no need to weld pickup??
  94. Looking for a Blanchard Grinder
  95. Almost new, SpeedDemon 850 Carb (mech secs, dp., annulars) for sale.
  96. Radiator choices
  97. Does anyone have info on the destroked LS1 302?
  98. who is putting there car on the dyno at carlisle
  99. Rebuild options???
  100. Differences between '91 Z28 and '91 Vette bottom end?
  101. Callies Dragon Slayer crankshaft?
  102. are 3973487 heads worth rebuilding or porting ?
  103. Alu flywheel,Harmonic balancer..
  104. Carburetor choice -- 502/502
  105. A couple of old tech dyno pulls
  106. [vid] 735 rwhp
  107. With all of the cam questions, I have a few too..
  108. A/F ratio readings
  109. Air compressor accessories...
  110. Vibration
  111. Where Can I Get Custom Headers in So Cal?
  112. Camshaft Gurus: Need your opinion!
  113. Nitrous bootle problems - safety blow off cap
  114. Anyone know how to pull the front pump out of a automatic transmission (4L80E)?
  115. How can I identify if my DART IRON EAGLE heads have 64cc or 72cc chamber?
  116. Fuel Injector Size
  117. Your thoughts on a 383...
  118. Went for a little test drive last night
  119. How bad are 882's?? Performance and condition questions.
  120. Nitro w/ stock motor - injectors?
  121. an annoying little discovery I found with Turbonetics Boost controllers
  122. need serious help to cool down 383 vette...please lend me your advice
  123. Aluminum Flywheel for street application?
  124. DFI system choices...
  125. 6.25" vs. 8". harmonic balancer. reasons, opinions, preferences
  126. All you guys with solid-roller cams, or anybody that thinks I am crazy
  127. A/F guys in here please
  128. which turbo
  129. Carburator newb questions
  130. *** Manual C3ers with Lakewood HD Clutch fork, HELP!!! ***
  131. GM to introduce the new 572ci, 720HP crate engine on August 17th!
  132. Electric fuel pump
  133. Aeromotive fuel pumps
  134. How much compression ?
  135. EFI sources
  136. Best Aftermarket Carb Builders
  137. best place to buy heads
  138. patching headers
  139. For all of you that helped me with my engine combo!
  140. Mucie ID help,please..
  141. Largest stroke in production 400 sb?
  142. Monty it is Monday.
  143. Weight Reduction
  144. Tell mea bout SB-2
  145. Need Help?
  146. ZZ3 SETUP
  147. Dana 44 questions
  148. Twin Turbo LT1 on a "budget"?
  149. please help my 81 stingray
  150. I hate fuel pressure regulators/gauges....still having problems...now to high
  151. Why Not O2 Instead of N2O?
  152. Difference in CFM ratings - Throttle Body vs Carburetors
  153. Pro Action Big Block heads..
  154. Shave 2 sec off your ET.
  155. turbo problem
  156. Jet selection for a 750 double pumber with mech sec.
  157. I think some of you may find this interesting, L98 Build up's & Results.
  158. cam selection: hydraulic vs. solid
  159. LS6 Heads/Cam on a LS1?
  160. MD-250 Chassis Dynamometer
  161. 882 heads...Are they worth cleanin up?
  162. I wanna go "Porting"
  163. Just a THANK YOU to the guys on corvetteforum
  164. EFI tuning after stroker
  165. Cam selection help
  166. Finally, I should be able to hit the road this weekend with the 1200hp Twin Turbo SBC 427.
  167. Big Block Heads
  168. Roller Rocker Question
  169. who has good prices on rotating assemblies?
  170. injection stacks????.....??
  171. Mods to OEM hyd. roller lifters for reduced BC cam ?
  172. exhaust noises on deceleration
  173. Tach drive distributor
  174. Yowza! Big Block C4
  175. Looking for Mod input
  176. anybody seen this nitrous nozzle setup for fuel injection
  177. Bad A** Engines
  178. How to drop 2 sec off your 1/4 without spending any $$...
  179. Complete FI engine swap for C3?
  180. Ls6 heads?
  181. Is a HP per cube (at the wheels) the new standard
  182. Pics of my new/rebuilt motor for my GT-1 car
  183. 10-second Blown LT4 F-body
  184. Cam Change? Or would I even notice the difference?
  185. valve stem seals & valve cover gaskets???
  186. Thermal Coatings
  187. anyone heard of darrell young racing transmissions????
  188. Cylinder head question.
  189. Who makes the best solid roller lifters
  190. Slightly OT. Any reason a ZZ4 distributer won't work on a '76 caddy with HEI?
  191. fuel pressure gauge, liquid filled or not??
  192. How much HP can a modified MAF support?
  193. Down to the cam choice!
  194. Titanium Valves, streetable and gains?
  195. dyno experiences...
  196. Why did I loose a little top end power when I retarded the timing 2 degrees
  197. centerforce clutch
  198. What to do with a 283?
  199. Can’t find washer dropped down the Lifter Valley.
  200. Dutweiller Article - Merlin read this
  201. 400 Block advice, what did you do right or wrong?
  202. thoughts about extrude hone
  203. Shattered my Trannie!
  204. K&N Air Filter Causing Low and Locked BLM
  205. Which Tuner?
  206. Reverse dual pattern cam, more power?
  207. Internally / externally balanced assembly
  208. $74.16 for head gaskets
  209. AFR 190cc Heads with Comp Cam XR288????
  210. 4valve heads for Vette
  211. Thoughts for next engine? Forced induction? Hmm....
  212. Question
  213. Harmonic balancer rubbing timing cover
  214. AFR head ????
  215. Detonation ?
  216. Guess my engine compression ratio.
  217. LS-1 Edit Group Purchase
  218. Where's Monty
  219. Planning new engine, some ??s (long)
  220. Anyone want to guess RWHP on this package???
  221. A question about roller rocker ratios, using 1.6's thinking of going to 1.65's or 1.7's
  222. follow up fuel pressure problems....not good
  223. Turbo motors and boost controllers - any experience?
  224. Q jet basics???
  225. DEsktop Dyno port flow data on BB
  226. Cylinderhead flow experts ...your help is needed here !!!!
  227. How much HP will my fogger nozzles cost.
  228. 396 in 84 vette.. will
  229. Transmissions? I may have broke mine :(
  230. Turbo guys? (Monty)
  231. can a SBC make 500 hp?
  232. Anyone try out the NEW Gtech Pro Competition Meter?
  233. installing new cam in old engine
  234. Holley question...Smaller carb or jets???
  235. Took The 'Vette To The Track!
  236. Trying to make my beater more like my 'vette...
  237. Throttle body question.
  238. Where to ask ,Custom made aluminum flywheels?????
  239. Bunch of parts for sale..maybe
  240. what HP gain from upgrading the cam?
  241. Dumb Question, but I gotta ask.... Timing gear and chain.....
  242. Miami area: Where can I get my windshield replaced??
  243. Lingenfelter LS1 (ASA) Race Engine
  244. How much power can a cast crank take?
  245. Why do you think the LPE blower would not fit on an F-Body?
  246. HIT PAY DIRT!
  247. A ? about siamesing L98 base....
  248. What BB con rods to use in 396
  249. supercharged C3
  250. TB coolant bybass? need more HP also
