View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22
  1. Spend $$$ on Stroke 350 to 383 or P&P D-port heads
  2. What is a rat motor anyway?
  3. Will this work?
  4. Cam Shaft opinion>>
  5. 383 OWNERS , cast or steel who has what?
  6. L98 Guys take a look at this!
  7. need 4" stroke one piece seal crank
  8. 383 people !
  9. exhaust fumes in a garage
  10. "spread exhaust port" heads for pre 92
  11. DFI Gen VII is going in!
  12. What kind of potential do Dart II (Sportsman II) heads have? and other questions...
  13. Pilot Bushing / Bearing R & R - "Trick"
  14. LT1 vs LS1, Turbo Application....
  15. Has anyone had trouble starting the car after cam mod
  16. any advice for what i should build my LT4 into??
  17. "Hardcore" bottom end package from summit....
  18. Piddle-valve vs. Edge-orifice Lifters
  19. Iron Vs. Aluminum heads
  20. 838.1hp on racing gas, 834.2 on pump gas - new numbers!
  21. Piston side wall clearance???
  22. kinda O/T: aligning a scattershield for 1st gen SBC?
  23. Opinions on 4L60E rebuild kits...
  24. Need more HP in my 2003 ZO6
  25. Dish volume of goodwrench piston #12361371??
  26. DE-stroking question
  27. single plane of dual plane
  28. Are BB & SBC lifters the same?
  29. ZF6 scattershield???
  30. any L98s using TPIS cold air inducion?
  31. Big block transmission questions/driveline
  32. Engine Analyzer Pro
  33. LT1 performance cylinder heads
  34. Opinions please
  35. X-Pipes
  36. 6.125" Con Rod in 400sbc ?
  37. What do all the numbers mean?
  38. Balancer broke on 383, what to do ?
  39. Good Price?
  40. Need help with a cam and a carb.
  41. gains from head porting
  42. OIL/Cooling system flush?
  43. stock zz4 rod bolts or arp rod blots
  44. LT-4 heads flow well enough for s/c
  45. expected numbers on my rebuilt 350
  46. influence of grooving on main bearing performance
  47. Custom F/I manifold help???
  48. would like your opinions on a distributor
  49. How to tell if aftermarket RR are self aligning?
  50. Help with blower for my 383
  51. May be a dumb question.
  52. Building a BB replacement motor, any flaws in my formula?
  53. Well I dumped my HOlley 750 DP for this...
  54. DESKTOP 2000 QUESTION
  55. Identifying TPIS cam....Help
  56. ?Downloads of Cam & Head dyno files?
  57. Identifying Dart heads..help me
  58. Dart Pro 1's still for sale!!!!!!! Save $$$$$
  59. Can a 383 be bored?
  60. 421 sbc DD2000 Comments welcomed !
  61. what can i do with my cam???
  62. Removed Dart Iron Eagle Heads
  63. LT4 Head Gasket Specifications?
  64. Composite distributor gear
  65. I wonder if 2600hp is enough???
  66. When are oil restrictors needed?
  67. Block tanking...
  68. Good deal?
  69. External dimensions of big block engine?
  70. winter project- Bolt on power
  71. Best flow from D-ports
  72. Filter and filter bypass revisited
  73. Roller VS. Standard. What kind of changes came out of it?
  74. Emissions Vettes, with pre emissions intake/carb, etc.
  75. Valves still ticking a little........what to do?
  76. Compression Test Values - SBC
  77. Poppin' Fresh Pistons!
  78. StainlessWorks 2" BB C2-3 headers?
  79. 406 Forged Rotating Assy For Sale SAVE SAVE!!!!!
  80. Roller lifters.
  81. Anyone use a pyrometer?
  82. Thoughts on-Internal vs externally balanced 383 crank!!
  83. Big Block Rod / Stroke Ratios...
  84. Need DD2000 bench tested...
  85. ?Can DD2000 be shared?
  86. Anyone going to the PRI show?
  87. Cam selection !
  88. L98 Rebuild ?
  89. Edelbrock RPM Heads on a 427sb
  90. How much power does the L-88 funtional hood add
  91. What do you guys think of this engine build?
  92. What additional machine work is required for a 383 Stroker?
  93. Hardblok Block Filler ....
  94. Mileage
  95. TPI Vortech crate engine
  96. increasing rpm limit
  97. John Meany and Troy Trepanier team up again...1370hp Twin Turbo SBC (pump gas)
  98. Holley 4160 idle problem
  99. Hand porting LT4 heads...Need Help
  100. Automatic vs stick?
  101. What size heads should I use? Intake port / roller rocker question.
  102. Merlin heads on C2 BB? (or C3).... what exhaust system??
  103. OT (sorta) Corvette Central Discount?
  104. can AFR 190's be hogged out to 210/220's?
  105. Should I Drive it
  106. Holley DP / Proform leaking problems
  107. Anybody know of a good machine shop in DFW
  108. Fired up my new 408 sbc!!
  109. 84 starter problems
  110. my car pulls at idle
  111. Roller cam Q..
  112. "Corvette" head vs. "Fast Burn" Heads???
  113. I have Performer RPM set-up ( have questions )
  114. Where to find a bare block?
  115. ZL-1 is back! if you have the cash
  116. Valve Train Knock in Solid Lifter 350. Any ideas?
  117. Engine Builders - Micro Polishing?
  118. MSD & Pro Billet In! Why's it Smoking?
  119. Sent in LT1 heads for P/P job.
  120. Comercial Engine (Performance) Packages ????
  121. Vortec or sportsman II
  122. bushed lifter bores???
  123. any carbed 383's running nos?
  124. Any good So. Cal. shops for refreshing a 383 L-98 engine?
  125. ***HELP!*** Can't get engine pre-oiled...
  126. Anybody Recognize this VIN off of LT1 (GEN II) Block?
  127. The total package?
  128. Getting 400sbc, got a few questions...
  129. 32V Heads
  130. Hydraulic vs. Roller Cam
  131. Stock L98 Windage tray. Is it needed?
  132. Question about sleeved engine.
  133. Is it not OK to remove/disable the PCV hose? (Or, Strange smoke from breather!)
  134. Can a 302 pump out 400+ HP?
  135. Looking for 500 rwhp, head porting question.
  136. Great deal on an LT1 to LT4 conversion kit
  137. 383 Pistons
  138. 400 SBC
  139. Any of you guys ever built a 406 to use in a SUV for TOWING, and leisure usage?
  140. Engine trouble with my driver... please help!
  141. what kind of work gloves are you guys using?
  142. 6L Cast Truck Block Specs - Anyone know where I can find?
  143. Plug Wires and ignition efficiency - Marketing or Engineering?
  144. Scoggin-Dickey's price jacking for vortec heads.
  145. What changes could I do to a ZZ502 Crate Motor for more power?
  146. Help - MSD6A on C3
  147. Reassembled Engine - Problems Getting it to Start Up
  148. 355 cam for 10.5
  149. If you have a relocated oil filter, please have a look
  150. LT-1 cam question.
  151. Heads and cam upgrade for a thumper-street 502
  152. Any 377's out there?
  153. Which heads? 74cc or 68cc AFR190's
  154. Cam Suggestions
  155. it begins...scored a block
  156. Spark plug help!
  157. IMPORTANT engine virbrations????
  158. L-98 Distributor Swap
  159. can a vac. secondary work with high power
  160. Max overbore for SB 400?
  161. Retrofit roller lifters - Long lead time?
  162. FYI - GM Performance Parts Sale
  163. Aluminum head shortage ??
  164. what makes a stroker?>
  165. What Blower for my SB 383?
  166. (cross post) "dyno day" questions inside...
  167. Most power from $5000?
  168. Octane question?
  169. Approximate costs to bore block for 383 stroker?
  170. who will have the first vette above 400rwhp on my dyno?
  171. Member of Thirdgen.org dies in high-speed car crash
  172. Convertin to EFI, how many fuel lines do you need?
  173. roller rocker question?????
  174. Crane gold roller rocker failure
  175. At how many miles is it ok to switch to synthetic?!
  176. Platinum Spark Plugs.....
  177. my eyes are burning!!
  178. Removing LS1 heads in a C5
  179. Big Block Build Suggestions
  180. ? I need T'Stat Housing (fixed) that points toward Right ?
  181. L98 build up, need some advice
  182. Need Help With Distributor
  183. Anybody running the AFR big block heads yet?
  184. Main Crankshaft Bearing clearances, Aluminum Corvette Engines?
  185. Mashine shop prices
  186. LPE 219 cam specs please?
  187. L-98 engine block ?
  188. What Heads/Cam for a 396 LT4 STROKER???
  189. new member, got a question about possible rebuild/ crate motor
  190. msd window sw. anyone have it converted to 5 volt sq. wave for 01 vette
  191. Aluminum Block, Aluminum Heads, Copper Head Gaskets O Ring or not? both sides? Opinions welcome!
  192. OT: Windows XP Professional for $39.95
  193. Help.... welding my broken Header ??
  194. Blowproof bellhousing or kevlar blanket?
  195. Need Cam Suggestion
  196. New "Base" Engine (for No Flight)
  197. How much could this block take?
  198. ZZ4 which starter?
  199. Anyone know anything about THIS engine?
  200. MSD6AL with Spitting Flame option
  201. Who's had engine problems with a big HP 2-bolt?
  202. options for a L98 replacement
  203. Using a special cam instead of octane booster
  204. What size jets are you using in your Holley's
  205. Motown 436sbc and 4L80E trans conversion complete (long)
  206. best place to buy a rebuilt L98
  207. 2 bolt or 4 ?
  208. How much HP can a C5 6 speed trans handle?
  209. How to balance the connecting Rods?
  210. Water Temps 200 Oil Temps 250?????
  211. WHERE TO BUY FUEL RAIL MATERIAL
  212. L-88 Aluminum Heads - Stripped Header Bolt
  213. How does a Big Block fit in a C-4?
  214. E. Choke stuck on Holley (Pict included to enhance your forum pleasure)
  215. block question. part #?
  216. Tall deck block, what needs to be done to the head/intake top make it work?
  217. Intake/Water Pump Pipe Plugs????
  218. Stroker displacement- which to choose!!
  219. 383 stroker kit, what parts should be forged, is it necessary to have all forged?
  220. perfect item on ebay for your garage
  221. To vacume or not to vacume (engine that is)
  222. Engine Paint
  223. Which is better to use with Vortec heads?
  224. Which engine to build ??
  225. ?FastBurn Heads w/ Dished Pistons?
  226. building the ultimate 327??
  227. do you like rubber or teflon valve seals?
  228. Torque converter selection (again)
  229. Need heads done - a few Q's
  230. Edelbrock BBC RPM Cam: Idle?
  231. Any Electronic Engineers here? Need a circuit to monitor electric water pump.
  232. Found a Merlin and a Mowtown block at a swap meet today
  233. Baffled oil pans
  234. which is better for drag racing? 350 or 383
  235. 80mm throttle body or not?
  236. 383 using a 4.00 bore block
  237. 4 motor heads rpm limits
  238. Carb Help - High Idle
  239. Noisey - "Woody" sounding valvetrain. NEED ADVICE QUICKLY... Please
  240. Will these cylinder heads do well in performance applications?
  241. Balancer/FLuidamper Questions(cross-link post)
  242. Cranking pressures and rocker ratios
  243. What’s your take on 3 tube V8 headers? (Looking more for facts than opinions)
  244. crank storage
  245. ZZ9 cam and TFS wedgeheads on a stock shortblock- any word
  246. Any verdict on AFR Hydra-Rev kit?
  247. Does anyone have the phone number for Cam Motion?
  248. Tweakin' and Detailin'...
  249. 400 vs. 350 LT4: Pros and Cons
  250. 2 piece timing cover?
