View Full Version : Engine Mods
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21
  1. Dyno Sheet: 995.4 rwhp & 920.4 rwtq on my DynoJet
  2. #/hr of rochester injector #17090304
  3. is this possible?
  4. Fired her up,... then hit it...Bad Cappy....Bad Cappy
  5. Looking for opinions on half shaft replacement
  6. First Nitrous runs - 936.8rwhp and 931.8rwtq!!!
  7. How to determine cast or forged Crank????
  8. Mark 4 block heads bolts what to seal with ?
  9. [Cam question]
  10. My Intakes on EBAY ....CHEAP
  11. L98....4 or 2 Bolt Mains
  12. Anyone run AFR BBC Heads? Here are my flow numbers for my new AFR 357s
  13. what is the lowest compression a SBC can go with?
  14. Piston Oil Rail Question...
  15. HELP!!!! Comp Cams, Cam degree bushing kit question
  16. Buttoning up the motor, a few questions re: quench and degreeing the cam
  17. New DynoJet Numbers: 709.9rwhp & 626.9rwtq!
  18. Great Service from Engle!!
  19. [Motor question] 420 cubes
  20. Engine Oil Analysis
  21. Burnt vlave on Big Block ???
  22. MSD Digital 7 Programmable Ignition and N2O
  23. Are head land rings used anymore?
  24. What character would this cam give an engine?
  25. Road Race BBC and SBC set up?
  26. Who Has Upgraded Their Fuel Line From 3/8" to 1/2"?
  27. Another 400 Question.
  28. High Octane Fuel and Performance (or lack thereof)
  29. Fuel injected sbc400 combo 500hp+
  30. Who is using copper head gaskets?
  31. HP from fuel pump change..
  32. 406 vs. 355...Which to build?
  33. Q: Where to buy perforated pipe...
  34. TPI setup on a 64 327.. crankcase ventilation problems??
  35. black braided nylon wire loom
  36. 041's VS vortec's
  37. Missing oil passage plug
  38. Anyone got a 10045339 piston?
  39. how to determine push rod length
  40. connecting rods for a 400 ci
  41. Changed my Jets and now it Bogs at Cruise/Off-Idle
  42. Main Bearing Issue
  43. Rebuilding Holley carb - which rebuild kit?
  44. just a thought for a 415 sb...
  45. For sale: 383ci short block
  46. Cam Lobe Separation Spec...HELP!
  47. Distributorless Ignition
  48. Looking for books on oscilliscope patterns
  49. Got the heads back, flow numbers post
  50. Stock sb400 strength
  51. Drag strip and a New Motor, Should I or shouldn't I...???
  52. Nitrous on a 383?
  53. My new S Roller cam!
  54. [Soon, my LPE-383 is coming apart] Details inside
  55. Cam "lope" question?
  56. Regular belt driven or electric fan?
  57. can a pressure plate be resurfaced?
  58. What is the best way to check air/fuel ratio
  59. Thoughts on "Motor Flush" with additive to oil ???
  60. Opinions on Upgrading to Dyno2003?
  61. Nearest Chassis Dyno to Tulsa Oklahoma
  62. Brazing an oil return fitting to pan
  63. SBC dipstick fit
  64. Detonation Blues
  65. Locktite on Aluminum head exhaust studs
  66. SBC Ream Main Adapters???
  67. Need some direction on my LT1
  68. Correct Oil Level- Help!
  69. determining horsepower and torque
  70. Reduce underhood tempearature
  71. cam duration question
  72. .025 ring gap enough for a 200 shot ?
  73. Which rings to use?
  74. Plastigauge...how tight?
  75. Any automatic transmission gurus out there???
  76. Cam Degreeing?
  77. Want 1/2 of a 350?
  78. Oil Pan Windage Tray?
  79. BBC casting 14015445, tall deck?
  80. Valve Overlap Equation
  81. Proform center section?
  82. underhood supercharger?
  83. HELP! Are these forged pistons?
  84. The antisapation is mounting new stuff is arriving
  85. stock gear in 1/4 mile
  86. "Asphault Crayons" - SBC 427 TT driving impressions
  87. Dynamic Compression Ratio Post ???
  88. Had my valve springs cryo'd anyone else done this ?
  89. Head Flow
  90. Help,,plug wire boot melts with afr's and tpis long tubes
  91. "My" 200-4R trans selection process (link to C-2)
  92. Turned BBC cranks, teach me. :)
  93. Brodix BD2000 Heads
  94. Washington Racer
  95. I knew I should have just trusted my self when comming comming to a machine shop!
  96. No More Super Rams?
  97. water pump and pulleys
  98. Cylinder wall distortion... bolts vs. studs question.
  99. HIGH RPM lower half
  100. Help with nitrous system
  101. I wanna get blown
  102. Anone heard of external balance on the crank rear and internal balance up front?
  103. 327 still possible today?
  104. Picked up a small block 3.175 stroke crank the other day.
  105. How accurate are stock tachometers?
  106. dana 44 ???
  107. Harmonic balancer and a few other ?'s
  108. Fuel line size
  109. Without nipicking, how much HP can a BBC 2-bolt take?
  110. AC Delco Oil Filters, PF25, PF35, PF454, PF1218S
  111. Installing an Edlebrock pro flo EFI (3550) on my 502 in my 68 roadster
  112. Where to find info on 427 SBC??
  113. roller rockers
  114. L-98 Cylinder Head Conversion - Which Gasket ?
  115. If running Alcohol, how much compression is needed?
  116. Air Flow 101
  117. Supercharger-Blower-Turbo: what are the differences?
  118. [Help]: BBC 427 Truck block, decking to fit BBC car intakes?
  119. I Just Purchased A New Cam!
  120. How much HP gain from LT-1 to "Hot LT-4 conversion" ?
  121. Breathers o.k. for consistent street use? Or stick with PCV???
  122. anyone using the valve covers in my sig? I just ordered a set from JEGS.
  123. Whats The Best For More HP
  124. 1962 TPI installation
  125. Holley HP series 1000 CFM for my motor
  126. 1980 C3 Engine
  127. Intake Options
  128. top end oil control: configuration + problem = solution?
  129. some info on turbocharging a carb?
  130. Torker II vs. Weiand 7546
  131. Desktop Dyno numbers, look correct?
  132. Throttle "Z" linkage ?
  133. Got the cam, need desktop Dyno one more time, for my 406
  134. Feedback on TCI or B&M Torque Converters
  135. The REAL Merlin!
  136. Engine Knock - Too Lean or Too Much Timing?
  137. Anyone know anything about SBC Dart Pro 1 Aluminum 215CC Heads ?
  138. GM 2500 stall converter impressions
  139. MINIRAM with 406 motor, need a cam
  140. Head questions...
  141. CLUTCH HELP!!!!
  142. Desktop Dyno for 406, please?
  143. What's the difference: Stud girdle, rev kit, rocker shaft system.
  144. Valvetrain problems...Comp Cams XE268
  145. Great Deal!! $49 stainless steel 2.5" mufflers at Summit!!
  146. automatic transmission problems lt1-4l60e
  147. need help on a decision.. (heads)
  148. LT1 Twin Turbo Options?
  149. Aluminum fuel line ?
  150. Aluminum vs Iron Blocks for tiwn turbo?
  151. Porting/Polishing question......
  152. Hmmmm...What Does This Mean?
  153. Urgent question!!! Autocrossing tomorrow morning, car didn't want to start....help please!!
  154. What does this Flywheel fit?
  155. Fuel pump is too loud!!
  156. What brand of valves in Edelbrock BB heads?
  157. ATTENTION: ALL C5 OWNERS!!!!!!!!!!!!!!!!!!
  158. Fuel lines, pump in C4, size, capacity, pump capacity
  159. New engine Build-Up
  160. colortune
  161. Which intake, carb and heads for 1979 L82?
  162. Anyone increased the CFM capacity of an '63-'65 FI UNIT?
  163. ROund exhaust pipes vs. square pipes??
  164. how much oil stuck to sbc rotating assembley?
  165. Turbo guys - Heat managment products
  166. AN & PS Fittings
  167. Anybody running Schubeck radius lifters / know anything about them?
  168. I need advice on head choice for ROAD RACING SOLID ROLLER SBC 396 engine
  169. TILTON FLYWHEEL/CLUTCH QUESTIONS
  170. sweet EFI 383 buildup
  171. AFR water ports
  172. New Corvette fan - Daddy's little girl!
  173. Need advice on torque converter selection - I'm completely in the dark on this
  174. LPE 700 h.p. twin turbo Caddy Escalade EXT....
  175. cam changing made easier
  176. Gen 7 DFI & Wide Band
  177. Holly Double Pumper Throttle Shaft Leakage
  178. Help, oil clearance question.
  179. Header #2 done
  180. Aftermarket Power Steering Pump+pulley
  181. engine history question?
  182. Tremec TR3550 swap - am I buggered?
  183. Anyone know the chamber size in stock 81 cylinder head?
  184. Do I need Splayed Main Caps?
  185. Know any street cars that have made 1000 or more REAR WHEEL horsepower?
  186. Header Fabrication
  187. Give me your .02$
  188. LS1 style heads for Old motor?
  189. Why is there no power valve on the secondary side of my carb ?
  190. Finally...Over 700 rwhp! (Naturally Aspirated)
  191. Dream engine for a C3?
  192. CC'ing Combustion Chambers?
  193. Dart Pro 1 heads, and head porting question
  194. Bob Rieger sold the TT 57 Chevy....
  195. BB Stroker and rod sizes
  196. Intake Gasket Slipped - How Much Is Too Much?
  197. Picture of my bad sollid roller!
  198. help need flow numbers please
  199. 160degree thermostat question
  200. GROUP BUY DFI GEN 7 who would be intrested?
  201. Which head gasket use to increase compression slightly in 81?
  202. Comp Cams High Energy 268 - comments please
  203. F.A.S.T vs. DFI GEN 7
  204. Slipped Balancer - Normal?
  205. New cam is on the way!
  206. Which booster to use in my carb
  207. Re: Help me choose a cam
  208. Carb gurus... a little advice pleeese.
  209. Holley Adjust-a-Jet kits, do they work??
  210. SR intake, Porting or Extrude hone?
  211. Lost some small carb parts- where can I get replacements?
  212. Cam break-in question...
  213. House of Speed
  214. Erratic high rpm ignition timing
  215. 89-90 runners ?
  216. Re-ringing my motor
  217. Dyno Run #2
  218. My new intake !!!
  219. Crate engine for an '81
  220. Anyone know of a killer 406 build-up?
  221. Compression Ratio estimate help
  222. 383 pistons
  223. GRUMPYVETTE Custom Holley Stealth Plenum Photos from C-4 Tech section
  224. What dynamic compression ratio do you run?
  225. AFR hydra rev kit?
  226. Is this normal? (Pushrods/Guideplates/Rockers)
  227. turbos: mount em high, or mount em low??
  228. F1 style paddle shifter
  229. Comp Cams 350/350
  230. Distributor Vacuum Advance Motor
  231. What is Accel DFI?
  232. Engine theory: Why multiple valves?
  233. GM 3800 V6 mods?
  234. Roller Rockers FS...
  235. 406 EFI, AFR 195's or 210's?
  236. New Dyno - 951 hp!
  237. Help me make a financial decision, AFR 195's or porting current set...
  238. Does DD2000 calculate VE correctly...
  239. Are the bolt holes for the tranny on a scattershield equal distance apart
  240. Ever hear of a chevy "monster motor"?
  241. MOTOWN 220 Heads
  242. THROTTLE BODY BOLT SIZE
  243. Best Prices on Stroker Rotating Assemblies
  244. Custom plenum pics for Holley Stealth
  245. update stock c5 (2:73 rear end) to Z06 (3:42 rear end)
  246. BB cam install help
  247. 535ci shortblock special !!!
  248. Accel DFI ECU Costs?
  249. Anybody familar with Speed-O-Motive Engines & Quality of Work
  250. Bought my last blower from ATI
